armclub 发表于 2026-8-14 12:34
SemiDrive芯驰E3620 高端车规智控MCU芯片 PCB文件
D201DIODE_TVS_BD_D2-4_57X3_94-H2_44_TPSMB33CATPSMB33CAD2-4_57X3_94-H2_44
D202DIODE_ZENER_SOD128-4_0X2_7-H1_1_PMEG4050ETP-QPMEG4050ETP-QSOD128-4_0X2_7-H1_1
D205DIODE_SOD523_LRB521S-40T1G/NMLRB521S-40T1G/NMSOD523
D301DIODESCHOTTKY_DO-214AC_RBR5L40ADD/NMRBR5L40ADD/NMDO-214AC
D401DIODE_TVS_BIDIR_DFN1006-2_IC_PESD5V0S1BLPESD5V0S1BLDFN1006-2
D403DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D404DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D405DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D901DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D1101DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D1102DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D1201DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D1202ESD_BD_L0402-H0_55_AVRH10C221KT1R5YA8AVRH10C221KT1R5YA8L0402-H0_55
D1203ESD_BD_L0402-H0_55_AVRH10C221KT1R5YA8AVRH10C221KT1R5YA8L0402-H0_55
D1204DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D1301ESD_2-CH_BIDIR_3P_SOT-23-3_PESD2CAN.215PESD2CAN.215SOT-23-3
D1302ESD_2-CH_BIDIR_3P_SOT-23-3_PESD2CAN.215PESD2CAN.215SOT-23-3
D1303DIODE_TVS_BIDIR_PESD1LIN_IC_PESD1LIN,115PESD1LIN,115PESD1LIN
D1304DIODESCHOTTKY_SBR3U30P_SBR3U30P1-7SBR3U30P1-7SBR3U30P
D1305DIODE_TVS_BIDIR_PESD1LIN_IC_PESD1LIN,115PESD1LIN,115PESD1LIN
D1306DIODESCHOTTKY_SBR3U30P_SBR3U30P1-7SBR3U30P1-7SBR3U30P
D1307DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D1308DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D1309DIODE_SOD523_LRB521S-40T1GLRB521S-40T1GSOD523
D1310ESD_2-CH_BIDIR_3P_SOT-23-3_PESD2CANFD24V-TRPESD2CANFD24V-TRSOT-23-3
D1311ESD_2-CH_BIDIR_3P_SOT-23-3_PESD2CANFD24V-TRPESD2CANFD24V-TRSOT-23-3
D1401DIODE_TVS_DIODE_SMD_025X013_MSP5.0A-M3/89AMSP5.0A-M3/89ADIODE_SMD_025X013
E201CAP_+_AEC2-8_5X8_5-H10_5_47UF_50V47uF_50VAEC2-8_5X8_5-H10_5
E202CAP_+_AEC2-8_5X8_5-H10_5_47UF_50V47uF_50VAEC2-8_5X8_5-H10_5
J201DCPOWER JACK_PJ-202B_IO_PJ-002BHPJ-002BHPJ-202B
J202SIP_2_SIP_2_210S-1*2P210S-1*2PSIP_2
J203SIP_2_SIP_2_210S-1*2P210S-1*2PSIP_2
J401JTAG20PIN_1_JTAG20PIN_300S-20P300S-20PJTAG20PIN
J402BUTTON_P4_SW4-6_2X6_2-H5_1_TPF16LS-SC50TPF16LS-SC50SW4-6_2X6_2-H5_1
J403BUTTON_P4_SW4-6_2X6_2-H5_1_TPF16LS-SC50TPF16LS-SC50SW4-6_2X6_2-H5_1
J404BUTTON_P4_SW4-6_2X6_2-H5_1_TPF16LS-SC50TPF16LS-SC50SW4-6_2X6_2-H5_1
J405JTAG20PIN_10_I_JET_MIPI_20P_I-JET_MIPI_20P/NMI-Jet_MIPI_20P/NMI_JET_MIPI_20P
J406BUTTON_P4_SW4-6_2X6_2-H5_1_TPF16LS-SC50TPF16LS-SC50SW4-6_2X6_2-H5_1
J407SIP_2_SIP_2_210S-1*2P210S-1*2PSIP_2
J408SHP-04GT_0_DSIC01LS-P_DSIC01LS-PDSIC01LS-PDSIC01LS-P
J501JTAG20PIN_8_2X10_2_54MM_300S-20P300S-20P2X10_2_54MM
J502JTAG20PIN_8_2X10_2_54MM_300S-20P300S-20P2X10_2_54MM
J503JTAG20PIN_8_2X10_2_54MM_300S-20P300S-20P2X10_2_54MM
J504SIP_2_SIP_2_210S-1*2P210S-1*2PSIP_2
J701JTAG20PIN_3_2X15_2_54MM_300S-30P300S-30P2X15_2_54MM
J702JTAG20PIN_11_2X22_2_54MM_300S-44P300S-44P2X22_2_54MM
J801JTAG20PIN_3_2X15_2_54MM_300S-30P300S-30P2X15_2_54MM
J802JTAG20PIN_3_2X15_2_54MM_300S-30P300S-30P2X15_2_54MM
J901JTAG20PIN_7_2X20_2_54MM_300S-40P300S-40P2X20_2_54MM
J902JTAG20PIN_7_2X20_2_54MM_300S-40P300S-40P2X20_2_54MM
J903JTAG20PIN_7_2X20_2_54MM_300S-40P300S-40P2X20_2_54MM
J1001JTAG20PIN_7_2X7_2_54MM_300S-14P300S-14P2X7_2_54MM
J1101RJ45-HR911130C_2_CON_MISC_016_TH_RA_217X102_ODC_RJ45-HR911130CRJ45-HR911130CCON_MISC_016_TH_RA_217X102_ODC
J1201RJ45-HR911130C_2_CON_MISC_016_TH_RA_217X102_ODC_RJ45-HR911130CRJ45-HR911130CCON_MISC_016_TH_RA_217X102_ODC
J1202CON1X2_CON2-3_81-7_82X7_3-H8_6_WJ124-3.81-02P/NMWJ124-3.81-02P/NMCON2-3_81-7_82X7_3-H8_6
J1203SHP-04GT_0_DSIC01LS-P_DSIC01LS-P/NMDSIC01LS-P/NMDSIC01LS-P
J1204SIP_4_SIP_2_210S-1*2P/NM210S-1*2P/NMSIP_2
J1301CON1X2_CON2-3_81-7_82X7_3-H8_6_WJ124-3.81-02PWJ124-3.81-02PCON2-3_81-7_82X7_3-H8_6
J1302SIP_4_SIP_2_210S-1*2P210S-1*2PSIP_2
J1303SIP_4_SIP_2_210S-1*2P210S-1*2PSIP_2
J1304CON1X2_CON2-3_81-7_82X7_3-H8_6_WJ124-3.81-02PWJ124-3.81-02PCON2-3_81-7_82X7_3-H8_6
J1305JTAG20PIN_2_2X25_2_54MM_300S-50P300S-50P2X25_2_54MM
J1307CON1X2_CON2-3_81-7_82X7_3-H8_6_WJ124-3.81-02PWJ124-3.81-02PCON2-3_81-7_82X7_3-H8_6
J1308SIP_4_SIP_2_210S-1*2P210S-1*2PSIP_2
J1309CON1X2_CON2-3_81-7_82X7_3-H8_6_WJ124-3.81-02PWJ124-3.81-02PCON2-3_81-7_82X7_3-H8_6
J1310SIP_4_SIP_2_210S-1*2P210S-1*2PSIP_2
J1311CON1X2_CON2-3_81-7_82X7_3-H8_6_WJ124-3.81-02PWJ124-3.81-02PCON2-3_81-7_82X7_3-H8_6
J1312SIP_4_SIP_2_210S-1*2P210S-1*2PSIP_2
J1401USB_MICRO_AB_MICROUSBB_ZX62D-B-5PA8ZX62D-B-5PA8MICROUSBB
J1502CONN_AUDIOJACK_4P_CON_AUDJACK_4F_2P8_SM_RA_IO_3.5MMJACK3.5mmJACKCON_AUDJACK_4F_2P8_SM_RA
J1503CONN_AUDIOJACK_4P_CON_AUDJACK_4F_2P8_SM_RA_IO_3.5MMJACK3.5mmJACKCON_AUDJACK_4F_2P8_SM_RA
L201INDUCTOR_P2_L2-10_3X10_3-H6_3_22UH@2.6A22uH@2.6AL2-10_3X10_3-H6_3
L202INDUCTOR_P2_L2-5_5X5_4-H3_0_2.2UH@4.9A2.2uH@4.9AL2-5_5X5_4-H3_0
L203INDUCTOR_P4_0_L4-5_3X5_3-H2_5_DLW5BTH501TQ2DLW5BTH501TQ2L4-5_3X5_3-H2_5
L204INDUCTOR_IND2016_0.47UH/NM0.47uH/NMIND2016
L205INDUCTOR_IND2520_0.47UH0.47uHIND2520
L302INDUCTOR_IND2016_0.47UH/NM0.47uH/NMIND2016
L303INDUCTOR_IND2520_0.47UH0.47uHIND2520
L306INDUCTOR_IND2016_0.47UH/NM0.47uH/NMIND2016
L307INDUCTOR_IND2520_0.47UH0.47uHIND2520
L1101BEAD_0_SMD0603_BLM18KG121TBLM18KG121TSMD0603
L1102INDUCTOR_P2_L0806_2.2UH@1.9A2.2uH@1.9AL0806
L1103BEAD_0_SMD0603_BLM18KG121TBLM18KG121TSMD0603
L1201BEAD_0_SMD0603_BLM18KG121TBLM18KG121TSMD0603
L1202INDUCTOR_P2_L0806_2.2UH@1.9A2.2uH@1.9AL0806
L1203BEAD_0_SMD0603_BLM18KG121TBLM18KG121TSMD0603
L1204INDUCTOR_P4_SMD1210_P4_ACT1210E-131-2P-TL00/NMACT1210E-131-2P-TL00/NMSMD1210_P4
L1205BEAD_0_SMD0603_BLM18KG121TBLM18KG121TSMD0603
L1301INDUCTOR_P4_SMD1210_P4_ACT1210D-510-2P-TL00ACT1210D-510-2P-TL00SMD1210_P4
L1302INDUCTOR_P4_SMD1210_P4_ACT1210D-510-2P-TL00ACT1210D-510-2P-TL00SMD1210_P4
L1303INDUCTOR_P4_SMD1210_P4_ACT1210D-510-2P-TL00ACT1210D-510-2P-TL00SMD1210_P4
L1304INDUCTOR_P4_SMD1210_P4_ACT1210D-510-2P-TL00ACT1210D-510-2P-TL00SMD1210_P4
LB1401BEAD_B0603_2.3A@100MHZ2.3A@100MHzB0603
LB1402BEAD_B0603_2.3A@100MHZ2.3A@100MHzB0603
LED201LED_1_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
LED202LED_1_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
LED203LED_0_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
LED204LED_0_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
LED205LED_1_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
LED206LED_1_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
LED207LED_0_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
LED501LED_0_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
LED901LED_0_SMD-LED-0603_19-217/GHC-YR1S2/3T19-217/GHC-YR1S2/3TSMD-LED-0603
M1401MHOLE_1_HOLE_M3X6_2_M3*5.5*L8+1.5M3*5.5*L8+1.5HOLE_M3X6_2
M1402MHOLE_1_HOLE_M3X6_2_M3*5.5*L8+1.5M3*5.5*L8+1.5HOLE_M3X6_2
M1403MHOLE_1_HOLE_M3X6_2_M3*5.5*L8+1.5M3*5.5*L8+1.5HOLE_M3X6_2
M1404MHOLE_1_HOLE_M3X6_2_M3*5.5*L8+1.5M3*5.5*L8+1.5HOLE_M3X6_2
M1405MHOLE_1_HOLE_M3X6_2_M3*5.5*L8+1.5M3*5.5*L8+1.5HOLE_M3X6_2
M1406MHOLE_1_HOLE_M3X6_2_M3*5.5*L8+1.5M3*5.5*L8+1.5HOLE_M3X6_2
M1407MHOLE_1_HOLE_M3X6_2_M3*5.5*L8+1.5M3*5.5*L8+1.5HOLE_M3X6_2
M1408MHOLE_1_HOLE_M3X6_2_M3*5.5*L8+1.5M3*5.5*L8+1.5HOLE_M3X6_2
M1409MHOLE_HOLE3_2CT5_0_MHOLEMHOLEHOLE3_2CT5_0
Q201MOSET_P_NVTFS512_WDFN8-0_65-3_3X3_3-H0_8MM_DMP4025SFGQ-13DMP4025SFGQ-13WDFN8-0_65-3_3X3_3-H0_8MM
Q202MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q203MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q204SI2305_SI2305_SQ2315ES-T1_GE3SQ2315ES-T1_GE3SI2305
Q205MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q206MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q207SI2305_SI2305_SQ2315ES-T1_GE3SQ2315ES-T1_GE3SI2305
Q208MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q209MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q307SI2305_SI2305_SQ2315ES-T1_GE3SQ2315ES-T1_GE3SI2305
Q308MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q309SI2305_SI2305_SQ2315ES-T1_GE3SQ2315ES-T1_GE3SI2305
Q310MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q311SI2305_SI2305_SQ2315ES-T1_GE3SQ2315ES-T1_GE3SI2305
Q312MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q401MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q402MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q403MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q501MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q601TRANSISTOR_PNP_BEC_SOT95P237X112-3N_MMBT4403LT1GMMBT4403LT1GSOT95P237X112-3N
Q901MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
Q1001MOSFET_N_GSD_LBSS139WT_LBSS139WT1GLBSS139WT1GLBSS139WT
Q1002MOSFET_N_GSD_LBSS139WT_LBSS139WT1GLBSS139WT1GLBSS139WT
Q1003MOSFET_N_GSD_LBSS139WT_LBSS139WT1GLBSS139WT1GLBSS139WT
Q1004MOSFET_N_GSD_LBSS139WT_LBSS139WT1GLBSS139WT1GLBSS139WT
Q1005MOSFET_N_GSD_LBSS139WT_LBSS139WT1GLBSS139WT1GLBSS139WT
Q1006MOSFET_N_GSD_LBSS139WT_LBSS139WT1GLBSS139WT1GLBSS139WT
Q1101MOSFET_N_GSD_LBSS139WT_LBSS139WT1GLBSS139WT1GLBSS139WT
Q1201MOSFET_N_GSD_LBSS139WT_LBSS139WT1GLBSS139WT1GLBSS139WT
Q1307MOSFET_N_GSD_SQ2310ES_SQ2310ES-T1_GE3SQ2310ES-T1_GE3SQ2310ES
SW201BUTTON_P3_SSSS910800_SSSS910800SSSS910800SSSS910800
SW601BUTTON_P3_3_DSW5-2_0-14_5X13_0-H8_5_SSSF114900SSSF114900DSW5-2_0-14_5X13_0-H8_5
U201TPS7A16XX_SOP8-0_65-3_1X3_1P-H1_1_TPS7A1601AQDGNRQ1TPS7A1601AQDGNRQ1SOP8-0_65-3_1X3_1P-H1_1
U202LM636X5-Q1-WSON12_WSON12-0_5-3_1X3_1H-H0_8_LM63625DQDRRRQ1LM63625DQDRRRQ1WSON12-0_5-3_1X3_1H-H0_8
U203TPS62810_TPS62810_TPS6281020QWRWYRQ1TPS6281020QWRWYRQ1TPS62810
U206SBC_MD_6_SBC_MD_BASE_SBC_MD/NMSBC_MD/NMSBC_MD_BASE
U301E3620_E3650_BGA494-0_8-19X19MM_(S1+S2+S3+S4+S5+S6+S7)_E3620E3620BGA494-0_8-19X19MM
U302TPS74501_TPS74501_TPS74501PQWDRVRQ1TPS74501PQWDRVRQ1TPS74501
U303TPS74501_TPS74501_TPS74501PQWDRVRQ1TPS74501PQWDRVRQ1TPS74501
U304TPS62810_TPS62810_TPS6281020QWRWYRQ1TPS6281020QWRWYRQ1TPS62810
U305TPS7A16XX_SOP8-0_65-3_1X3_1P-H1_1_TPS7A1601AQDGNRQ1TPS7A1601AQDGNRQ1SOP8-0_65-3_1X3_1P-H1_1
U306REF3333_SOT_23_3_REF3333AIDBZRREF3333AIDBZRSOT_23_3
U307TPS62810_TPS62810_TPS6281120QWRWYRQ1TPS6281120QWRWYRQ1TPS62810
U308TPS22965TDSGTQ1_0_TPS22965TDSGTQ1_TPS22965QWDSGTQ1TPS22965QWDSGTQ1TPS22965TDSGTQ1
U309TPS22965TDSGTQ1_0_TPS22965TDSGTQ1_TPS22965QWDSGTQ1TPS22965QWDSGTQ1TPS22965TDSGTQ1
U310SN74LVC1G08QDCKRQ1_SC70-5-0_65-2_15X1_4-H1_1_SN74LVC1G08QDCKRQ1SN74LVC1G08QDCKRQ1SC70-5-0_65-2_15X1_4-H1_1
U311SN74LVC1G08QDCKRQ1_SC70-5-0_65-2_15X1_4-H1_1_SN74LVC1G08QDCKRQ1/NMSN74LVC1G08QDCKRQ1/NMSC70-5-0_65-2_15X1_4-H1_1
U801TLV9152-Q1_VSSOP8_TLV9002QDGKRQ1/NMTLV9002QDGKRQ1/NMVSSOP8
U802TLV9152-Q1_VSSOP8_TLV9002QDGKRQ1/NMTLV9002QDGKRQ1/NMVSSOP8
U1001MT35XU_OSPI_24BALL_MT35XU512ABA1G12-0AAT/NMMT35XU512ABA1G12-0AAT/NMOSPI_24BALL
U1003E2PROM_SOIC8_SOIC8-1_27-5_0X4_0-H1_75_GT24C64E-2GLA1-TRGT24C64E-2GLA1-TRSOIC8-1_27-5_0X4_0-H1_75
U1101RTL8211F_QFN40-0_4-5_0X5_0-H0_9MM_RTL8211FI-CG/RTL8211F-CGRTL8211FI-CG/RTL8211F-CGQFN40-0_4-5_0X5_0-H0_9MM
U1201RTL8211F_QFN40-0_4-5_0X5_0-H0_9MM_RTL8211FI-CG/RTL8211F-CGRTL8211FI-CG/RTL8211F-CGQFN40-0_4-5_0X5_0-H0_9MM
U1202DP83TD530-Q1_0_DFN8-0_65-3_1X3_1H2_4X1_6-H1_0_DP83TD530RBRQ1/NMDP83TD530RBRQ1/NMDFN8-0_65-3_1X3_1H2_4X1_6-H1_0
U1203TMUX1574_0_SN3257Q1_DYY_SN3257QDYYRQ1/NMSN3257QDYYRQ1/NMSN3257Q1_DYY
U1301CAN_NO_WAKEUP_PG-DSO-8_TJA1042T/3TJA1042T/3PG-DSO-8
U1302LIN_SOIC8_SOP8-1_27-5_0X4_0-H1_75_TLIN1021ADRQ1TLIN1021ADRQ1SOP8-1_27-5_0X4_0-H1_75
U1303TJA1145T_TJA1145AT_TJA1145AT/FDTJA1145AT/FDTJA1145AT
U1304LIN_SOIC8_SOP8-1_27-5_0X4_0-H1_75_TLIN1021ADRQ1TLIN1021ADRQ1SOP8-1_27-5_0X4_0-H1_75
U1305NT156_HVSON8_TCAN6062VDRBRQ1TCAN6062VDRBRQ1HVSON8
U1306NT156_HVSON8_TCAN6062VDRBRQ1TCAN6062VDRBRQ1HVSON8
U1401FT4232_LQFP64_0_5P_10X10_FT4232HL-REELFT4232HL-ReelLQFP64_0_5P_10X10
U1402TPS74501_TPS74501_TPS74501PQWDRVRQ1TPS74501PQWDRVRQ1TPS74501
U1403TXB0108PWR_1_TXB0108PW_TXS0108EQPWRQ1TXS0108EQPWRQ1TXB0108PW
U1404TXS0104E-Q1_TXS0104EQPWR_TXS0104EQPWRQ1TXS0104EQPWRQ1TXS0104EQPWR
U1501AK4619VN_QFN32-0_5-5_1X5_1-H0_8MM_AK4619VNAK4619VNQFN32-0_5-5_1X5_1-H0_8MM
U1502MIC_DIGITAL_SMD4-SA2718T421-WT01_SA2718T421-WT01SA2718T421-WT01SMD4-SA2718T421-WT01
U1503MIC_DIGITAL_SMD4-SA2718T421-WT01_SA2718T421-WT01SA2718T421-WT01SMD4-SA2718T421-WT01
VR501RES_1_VRES_3266W_Y_3266W-1-104LF3266W-1-104LFVRES_3266W_Y
VR502RES_1_VRES_3266W_Y_3266W-1-104LF3266W-1-104LFVRES_3266W_Y
X401XTAL_24M_XTAL2016_IC_CX2016SA24000D0HSSCCCX2016SA24000D0HSSCCXTAL2016
X40232768_NX3215SA_NX3215SA-32.768KHZ(STD-MUS-2)NX3215SA-32.768KHZ(STD-MUS-2)NX3215SA
X1101XTAL_24M_XTAL2016_IC_25MHZ25MHZXTAL2016
X1201XTAL_24M_XTAL2016_IC_25MHZ25MHZXTAL2016
X1501TXON_SMD3225_4P_TXON-012288-3KLJ400/NMTXON-012288-3KLJ400/NMSMD3225_4P
Y1401CRYSTAL_P4_X4-3_3X2_6-H0_8MM_12MHZ12MHzX4-3_3X2_6-H0_8MM
x198956 发表于 2026-8-14 13:27
11111111111111111111111
shuszhao 发表于 2026-8-14 13:57
有对应电路图吗?
longxuekai 发表于 2026-8-14 15:15
学习一下的
bidinghong 发表于 2026-8-14 15:51
Limx122 发表于 2026-8-14 17:47
学习一下
太菜 发表于 2026-8-14 19:15
学习一下
bidezhi7777 发表于 2026-8-14 20:12
a6682100 发表于 2026-8-14 21:15
1111
junkyoung 发表于 2026-8-15 06:44
好好地学习。。。
页: [1] 2 3
查看完整版本: SemiDrive芯驰E3620 高端车规智控MCU芯片 PCB文件
