ES9038Q2M +GD32F105+NC7SZ157+KA7812+FSC-BT1026D做的一个蓝牙音响PCB文件
NamePart TypePCB DecalValue
ANTIPEXIPEXIPEX
C0N1CON10CON10-P2.010PIN_2.0
C0N12ACON10CON_10PIN10PIN_2.54
C0N12BCON10CON_10PIN10PIN_2.54
C01CAP0805C0.1uF 0805
CJ3XRL-MALE-CT3-05MJACK-XLR-CONNECT-90-MALE-CT3-05M
CJ4XRL-MALE-CT3-05MJACK-XLR-CONNECT-90-MALE-CT3-05M
CN1CN20CN20PIN_2x10_2.54
CON1CON2SIP2-7.922PIN_7.92
CON2CON4SIP4-7.924PIN_7.92
CON3CON5SIP5-3.965PIN_3.96
CON4ACON-4CON4-2.54PIN_2.54
CON4BCON-4CON4-2.54PIN_2.54
CON5CON-2CON2-P2.02PIN_2.0
CON6CON-4CON4-P2.04PIN_2.0
CON7CON8CON8-P2.08PIN_2.0
CON7AFPC_30P_1FPC_30PFPC_30P
CON8CON4CON4-2.544PIN_2.54
CON9CON4_3.96/7.92SIP4-7.924PIN_7.92
CON9ACON-3-2.54-2.0CON3-P2.53PIN_2.54
CON9BCON-3-2.54-2.0CON3-P2.53PIN_2.54
CON109-BCON4CON4-2.544PIN_2.54
D1DIODED101N4007
D2DIODED101N4007
D3DIODED101N4007
D4DIODED101N4007
D5DIODED5_4GS1M
D6DIODED10P6KE200A
D7DIODED5_4ES1D
D8DIODED101N5819
D9DIODED5_4B240A
D10IN41481N4148IN4148
D11SS34DO-214AC1N4001
D12SS34DO-214AC1N4001
D13DIODED101N5819
D14IN41481N4148IN4148
D15BRIDGE4DIODE-BRIDGE(8.3_6.3)DF02M
D16IN41481N4148IN4148
D17BRIDGEBR610KBPC610
D19Z1150D5_4SZ1200 1W
D292.5NPTH2.5NPTH
D302.5NPTH2.5NPTH
D312.5NPTH2.5NPTH
D322.5NPTH2.5NPTH
D101BRIDGE4DIODE-BRIDGE(8.3_6.3)DF02M
D102BRIDGE4DIODE-BRIDGE(8.3_6.3)DF02M
DAC_OUTCON-3-2.54-2.0CON3-P2.53PIN_2.54
ED1PESD5V0S1ESDSUPP-0603-WAVEESD5Z5.0
ED2PESD5V0S1ESDSUPP-0603-WAVEESD5Z5.0
ED3PESD5V0S1ESDSUPP-0603-WAVEESD5Z5.0
ED4PESD5V0S1ESDSUPP-0603-WAVEESD5Z5.0
FB1FERRITE0805L103 100MHz
FB2FERRITE0805L103 100MHz
FB3FERRITE0805L103 100MHz
FB4FERRITE0805L103 100MHz
FB5FERRITE0805L103 100MHz
FB6FERRITE0805L103 100MHz
FB7FERRITE0805L103 100MHz
FB8FERRITE0805L103 100MHz
FB101FERRITE0805L103 100MHz
FB201FERRITE0805L103 100MHz
FB203FERRITE0805L103 100MHz
HS1CON1HEATSINK2HEATSINK
HS2CON1HEATSINK2HEATSINK
HS3CON1HEATSINK2HEATSINK
HS4CON1HEATSINK2HEATSINK
HS5CON1HEATSINK2HEATSINK
HS6CON1HEATSINK2HEATSINK
HS7CON1HEATSINK2HEATSINK
INSETSW-PB1SWS-8_6
J2CN4PUSB_SIP_4PIN4PIN_2x2_2.54
J201USB-5USB-B-102USB-B-102
K1RELAY-SPDTRELAY-SPDT3(30_13)G2RL-1-CN 5VDC
L1INDUCTOR_2R310uH
L2CMC1CMC6(22_19-10_13)8.5UH
L3INDUCTOR0805L1000ohm/100MHz 0805
L4INDUCTORSMR63B100uH/1A
L5INDUCTOR0805LNC
L6INDUCTOR0805L10uH 0805
L7INDUCTORSMR63B100uH/1A
L8INDUCTOR0805L10uH 0805
L9INDUCTOR0805L10uH 0805
L10INDUCTOR0805L10uH 0805
L11INDUCTOR0805L1000ohm/100MHz 0805
L12INDUCTOR0805L1000ohm/100MHz 0805
L18INDUCTOR0805L1000ohm/100MHz 0805
L103INDUCTOR12104.7uH
LED-ACON2CON2-2.52PIN_2.54
LED-BCON2CON2-2.5
LED1LEDLED-21LED_YELLOW
LED101LEDLED-21LED_YELLOW
M1MARKMARK
M2MARKMARK
NEXTSW-PB1SWS-8_6
OPT1OPT_OUT_RCA_5PINOPT_OUT_RCA_5PINJST1583
PAUSESW-PB1SWS-8_6
PLAYSW-PB1SWS-8_6
POINTPOINTPOINT
POWER_ONSW-PB1SWS-8_6POWER ON
PRESW-PB1SWS-8_6
Q1NPNSOT23WSS9014
Q2TIP50TO220ABTIP50
Q3NPNSOT23WSS9014
Q4NMOS-2SOT23MOS(123GSD)2N7002
Q6MOSFET_PSOT23MOSG2301
Q7NMOS-2SOT23MOS(123GSD)2N7002
Q9TIP32TO220ABTIP32
Q10NPNSOT23WSS9014
Q11NPNSOT23WSFMMT617
Q102NPNSOT23WSS9014
R01RES2_2R-1W10R
RY1RELAY-10PINRLY-10P-ATQ2-5V
RY2RELAY-10PINRLY-10P-ATQ2-5V
SOURCESW-PB1SWS-8_6
SWSW_DPDTSW-T22205B_115_230
T1TRANS7EI-21_17
T8TRANSFORMER-COAXTRANSFORMER-8P-DIGITAL-TRANS
U1ES9038Q2M_30_PIN_QFNES9038Q2M-1ES9038Q2M
U2TLV70033SOT_5PINTLV7033
U3NC7SZ74K8X8_LEAD_US8NC7SZ74K8X
U4LMV358M-SO8NSO8OPA2134
U5TNY174-180SOP8_7TNY175DG-TL
U6OPTOISO1OPTOISOPC-17K1
U7TL431TO-92_TL431TL431
U8KA7912TO220L7912CV
U9KA7812TO220-VL7812CV
U10VOLTREG_1TO-220HLM317T
U11VOLTREG_1TO-220HLM317T
U12AT24C04SOP-8-SMDAT24C04
U13TLV70033SOT_5PINTLV7033
U14FSC-BT1026DFSC-BT1026D-1FSC-BT1026D
U15NC7SZ157SC70-6NC7SZ157
U16TLV70033SOT_5PINTLV7033
U17IRRIR_1KS1838
U18NC7SZ157SC70-6NC7SZ157
U19NC7SZ157SC70-6NC7SZ157
U20LMV358M-SO8NSO8OPA2134
U21NC7SZ157SC70-6NC7SZ157
U22KA7812TO220-VL7812CV
U23TLV70033SOT_5PINTLV7033
U24CD74HC4094SOP16CD7HC4094
U26NC7SZ157SC70-6NC7SZ157
U29LP2951SOP-8-SMDLP2951
U30NE5534SO8NE5534
U101VOLTREG_1TO-220HLM317T
U102VOLTREG_1TO-220HLM317T
U104COMPONENT_12TO252(DPAK)-1234LD1117DT33DPAK
U106STM32F105LQFP64-10X10GD32F105
U201COMPONENT_12TO252(DPAK)-1234LD1117DT33DPAK
U204ICM74HC04SM1RSO14SO14MC74HC04A
V1V1TUBE-GZC9-A
VOL+SW-PB1SWS-8_6
VOL-SW-PB1SWS-8_6
V_IN_ACON-3-2.54-2.0CON3-P2.53PIN_2.54
V_IN_BCON-3-2.54-2.0CON3-P2.53PIN_2.54
V_OUTCON-3-2.54-2.0CON3-P2.53PIN_2.54
Y1XTXT_5X7100MHZ
Y101CRYSTALXTAL-2P-DIP-116MHz
学习学习 谢谢分享! good good study, day day up 多谢分享
