u-boot fat
/** fat.c
* R/O (V)FAT 12/16/32 filesystem implementation by Marcus Sundberg
* 2002-07-28 - rjones@nexus-tech.net - ported to ppcboot v1.1.6
* 2003-03-10 - kharris@nexus-tech.net - ported to uboot
* See file CREDITS for list of people who contributed to this
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
#include <common.h>
#include <config.h>
#include <fat.h>
#include <asm/byteorder.h>
#include <part.h>
#if defined(CONFIG_CMD_FAT)
* Convert a string to lowercase.
static void
downcase(char *str)
while (*str != '\0') {
TOLOWER(*str);
str++;
staticblock_dev_desc_t *cur_dev = NULL;
static unsigned long part_offset = 0;
static int cur_part = 1;
#define DOS_PART_TBL_OFFSET 0x1be
#define DOS_PART_MAGIC_OFFSET 0x1fe
#define DOS_FS_TYPE_OFFSET 0x36
int disk_read (__u32 startblock, __u32 getsize, __u8 * bufptr)
startblock += part_offset;
if (cur_dev == NULL)
return -1;
if (cur_dev->block_read) {
return cur_dev->block_read (cur_dev->dev
, startblock, getsize, (unsigned long *)bufptr);
return -1;
int
fat_register_device(block_dev_desc_t *dev_desc, int part_no)
unsigned char buffer;
disk_partition_t info;
if (!dev_desc->block_read)
return -1;
cur_dev = dev_desc;
/* check if we have a MBR (on floppies we have only a PBR) */
if (dev_desc->block_read (dev_desc->dev, 0, 1, (ulong *) buffer) != 1) {
printf ("** Can't read from device %d **\n", dev_desc->dev);
return -1;
if (buffer != 0x55 ||
buffer != 0xaa) {
/* no signature found */
return -1;
#if (defined(CONFIG_CMD_IDE) || \
defined(CONFIG_CMD_SCSI) || \
defined(CONFIG_CMD_USB) || \
defined(CONFIG_MMC) || \
defined(CONFIG_SYSTEMACE) )
/* First we assume, there is a MBR */
if (!get_partition_info (dev_desc, part_no, &info)) {
part_offset = info.start;
cur_part = part_no;
} else if (!strncmp((char *)&buffer, "FAT", 3)) {
/* ok, we assume we are on a PBR only */
cur_part = 1;
part_offset = 0;
} else {
printf ("** Partition %d not valid on device %d **\n",
part_no, dev_desc->dev);
return -1;
#else
if (!strncmp((char *)&buffer,"FAT",3)) {
cur_part = 1;
part_offset = 0;
info.start = part_offset;
} else {
/* FIXME we need to determine the start block of the
* partition where the DOS FS resides. This can be done
* by using the get_partition_info routine. For this
* purpose the libpart must be included.
part_offset = 32;
cur_part = 1;
#endif
return 0;
* Get the first occurence of a directory delimiter ('/' or '\') in a string.
* Return index into string if found, -1 otherwise.
static int
dirdelim(char *str)
char *start = str;
if (ISDIRDELIM(*str)) return str - start;
str++;
return -1;
* Match volume_info fs_type strings.
* Return 0 on match, -1 otherwise.
static int
compare_sign(char *str1, char *str2)
char *end = str1+SIGNLEN;
while (str1 != end) {
if (*str1 != *str2) {
return -1;
str1++;
str2++;
return 0;
* Extract zero terminated short name from a directory entry.
static void get_name (dir_entry *dirent, char *s_name)
char *ptr;
memcpy (s_name, dirent->name, 8);
s_name = '\0';
ptr = s_name;
while (*ptr && *ptr != ' ')
ptr++;
if (dirent->ext && dirent->ext != ' ') {
*ptr = '.';
ptr++;
memcpy (ptr, dirent->ext, 3);
ptr = '\0';
ptr++;
*ptr = '\0';
if (*s_name == DELETED_FLAG)
*s_name = '\0';
else if (*s_name == aRING)
*s_name = '?;
downcase (s_name);
* Get the entry at index 'entry' in a FAT (12/16/32) table.
* On failure 0x00 is returned.
static __u32
get_fatent(fsdata *mydata, __u32 entry)
__u32 bufnum;
__u32 offset;
__u32 ret = 0x00;
switch (mydata->fatsize) {
case 32:
bufnum = entry / FAT32BUFSIZE;
offset = entry - bufnum * FAT32BUFSIZE;
break;
case 16:
bufnum = entry / FAT16BUFSIZE;
offset = entry - bufnum * FAT16BUFSIZE;
break;
case 12:
bufnum = entry / FAT12BUFSIZE;
offset = entry - bufnum * FAT12BUFSIZE;
break;
default:
/* Unsupported FAT size */
return ret;
/* Read a new block of FAT entries into the cache. */
if (bufnum != mydata->fatbufnum) {
int getsize = FATBUFSIZE/FS_BLOCK_SIZE;
__u8 *bufptr = mydata->fatbuf;
__u32 fatlength = mydata->fatlength;
__u32 startblock = bufnum * FATBUFBLOCKS;
fatlength *= SECTOR_SIZE; /* We want it in bytes now */
startblock += mydata->fat_sect; /* Offset from start of disk */
if (getsize > fatlength) getsize = fatlength;
if (disk_read(startblock, getsize, bufptr) < 0) {
FAT_DPRINT("Error reading FAT blocks\n");
return ret;
mydata->fatbufnum = bufnum;
/* Get the actual entry from the table */
case 32:
ret = FAT2CPU32(((__u32*)mydata->fatbuf));
break;
case 16:
ret = FAT2CPU16(((__u16*)mydata->fatbuf));
break;
case 12: {
__u32 off16 = (offset*3)/4;
__u16 val1, val2;
switch (offset & 0x3) {
case 0:
ret &= 0xfff;
break;
case 1:
val1 = FAT2CPU16(((__u16*)mydata->fatbuf));
val1 &= 0xf000;
val2 = FAT2CPU16(((__u16*)mydata->fatbuf));
val2 &= 0x00ff;
ret = (val2 << 4) | (val1 >> 12);
break;
case 2:
val1 &= 0xff00;
val2 &= 0x000f;
ret = (val2 << 8) | (val1 >> 8);
break;
case 3:
ret = FAT2CPU16(((__u16*)mydata->fatbuf));;
ret = (ret & 0xfff0) >> 4;
break;
default:
break;
break;
FAT_DPRINT("ret: %d, offset: %d\n", ret, offset);
return ret;
* Read at most 'size' bytes from the specified cluster into 'buffer'.
* Return 0 on success, -1 otherwise.
static int
get_cluster(fsdata *mydata, __u32 clustnum, __u8 *buffer, unsigned long size)
int idx = 0;
__u32 startsect;
if (clustnum > 0) {
startsect = mydata->data_begin + clustnum*mydata->clust_size;
} else {
startsect = mydata->rootdir_sect;
FAT_DPRINT("gc - clustnum: %d, startsect: %d\n", clustnum, startsect);
if (disk_read(startsect, size/FS_BLOCK_SIZE , buffer) < 0) {
FAT_DPRINT("Error reading data\n");
return -1;
if(size % FS_BLOCK_SIZE) {
__u8 tmpbuf;
idx= size/FS_BLOCK_SIZE;
if (disk_read(startsect + idx, 1, tmpbuf) < 0) {
return -1;
buffer += idx*FS_BLOCK_SIZE;
memcpy(buffer, tmpbuf, size % FS_BLOCK_SIZE);
return 0;
return 0;
* Read at most 'maxsize' bytes from the file associated with 'dentptr'
* into 'buffer'.
* Return the number of bytes read or -1 on fatal errors.
static long
get_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer,
unsigned long maxsize)
unsigned long filesize = FAT2CPU32(dentptr->size), gotsize = 0;
unsigned int bytesperclust = mydata->clust_size * SECTOR_SIZE;
__u32 curclust = START(dentptr);
__u32 endclust, newclust;
unsigned long actsize;
FAT_DPRINT("Filesize: %ld bytes\n", filesize);
if (maxsize > 0 && filesize > maxsize) filesize = maxsize;
FAT_DPRINT("Reading: %ld bytes\n", filesize);
actsize=bytesperclust;
endclust=curclust;
do {
/* search for consecutive clusters */
while(actsize < filesize) {
newclust = get_fatent(mydata, endclust);
if((newclust -1)!=endclust)
goto getit;
if (CHECK_CLUST(newclust, mydata->fatsize)) {
FAT_DPRINT("curclust: 0x%x\n", newclust);
FAT_DPRINT("Invalid FAT entry\n");
return gotsize;
endclust=newclust;
actsize+= bytesperclust;
/* actsize >= file size */
actsize -= bytesperclust;
/* get remaining clusters */
if (get_cluster(mydata, curclust, buffer, (int)actsize) != 0) {
FAT_ERROR("Error reading cluster\n");
return -1;
/* get remaining bytes */
gotsize += (int)actsize;
filesize -= actsize;
buffer += actsize;
actsize= filesize;
if (get_cluster(mydata, endclust, buffer, (int)actsize) != 0) {
return -1;
gotsize+=actsize;
return gotsize;
getit:
return -1;
buffer += actsize;
curclust = get_fatent(mydata, endclust);
if (CHECK_CLUST(curclust, mydata->fatsize)) {
FAT_DPRINT("curclust: 0x%x\n", curclust);
FAT_ERROR("Invalid FAT entry\n");
return gotsize;
endclust=curclust;
} while (1);
#ifdef CONFIG_SUPPORT_VFAT
* Extract the file name information from 'slotptr' into 'l_name',
* starting at l_name[*idx].
* Return 1 if terminator (zero byte) is found, 0 otherwise.
static int
slot2str(dir_slot *slotptr, char *l_name, int *idx)
int j;
for (j = 0; j <= 8; j += 2) {
l_name[*idx] = slotptr->name0_4;
if (l_name[*idx] == 0x00) return 1;
(*idx)++;
for (j = 0; j <= 10; j += 2) {
l_name[*idx] = slotptr->name5_10;
(*idx)++;
for (j = 0; j <= 2; j += 2) {
l_name[*idx] = slotptr->name11_12;
(*idx)++;
return 0;
* Extract the full long filename starting at 'retdent' (which is really
* a slot) into 'l_name'. If successful also copy the real directory entry
* into 'retdent'
__u8get_vfatname_block;
static int
get_vfatname(fsdata *mydata, int curclust, __u8 *cluster,
dir_entry *retdent, char *l_name)
dir_entry *realdent;
dir_slot*slotptr = (dir_slot*) retdent;
__u8 *nextclust = cluster + mydata->clust_size * SECTOR_SIZE;
__u8 counter = (slotptr->id & ~LAST_LONG_ENTRY_MASK) & 0xff;
int idx = 0;
while ((__u8*)slotptr < nextclust) {
if (counter == 0) break;
if (((slotptr->id & ~LAST_LONG_ENTRY_MASK) & 0xff) != counter)
return -1;
slotptr++;
counter--;
if ((__u8*)slotptr >= nextclust) {
dir_slot *slotptr2;
slotptr--;
curclust = get_fatent(mydata, curclust);
return -1;
if (get_cluster(mydata, curclust, get_vfatname_block,
mydata->clust_size * SECTOR_SIZE) != 0) {
FAT_DPRINT("Error: reading directory block\n");
return -1;
slotptr2 = (dir_slot*) get_vfatname_block;
while (slotptr2->id > 0x01) {
slotptr2++;
/* Save the real directory entry */
realdent = (dir_entry*)slotptr2 + 1;
while ((__u8*)slotptr2 >= get_vfatname_block) {
slot2str(slotptr2, l_name, &idx);
slotptr2--;
} else {
realdent = (dir_entry*)slotptr;
do {
slotptr--;
if (slot2str(slotptr, l_name, &idx)) break;
} while (!(slotptr->id & LAST_LONG_ENTRY_MASK));
l_name = '\0';
if (*l_name == DELETED_FLAG) *l_name = '\0';
else if (*l_name == aRING) *l_name = '?;
downcase(l_name);
/* Return the real directory entry */
memcpy(retdent, realdent, sizeof(dir_entry));
return 0;
/* Calculate short name checksum */
static __u8
mkcksum(const char *str)
int i;
__u8 ret = 0;
for (i = 0; i < 11; i++) {
ret = (((ret&1)<<7)|((ret&0xfe)>>1)) + str;
return ret;
#endif
* Get the directory entry associated with 'filename' from the directory
* starting at 'startsect'
__u8 get_dentfromdir_block;
static dir_entry *get_dentfromdir (fsdata * mydata, int startsect,
char *filename, dir_entry * retdent,
int dols)
__u16 prevcksum = 0xffff;
__u32 curclust = START (retdent);
int files = 0, dirs = 0;
FAT_DPRINT ("get_dentfromdir: %s\n", filename);
while (1) {
dir_entry *dentptr;
int i;
if (get_cluster (mydata, curclust, get_dentfromdir_block,
FAT_DPRINT ("Error: reading directory block\n");
return NULL;
dentptr = (dir_entry *) get_dentfromdir_block;
for (i = 0; i < DIRENTSPERCLUST; i++) {
char s_name, l_name;
l_name = '\0';
if (dentptr->name == DELETED_FLAG) {
dentptr++;
continue;
if ((dentptr->attr & ATTR_VOLUME)) {
if ((dentptr->attr & ATTR_VFAT) &&
(dentptr->name & LAST_LONG_ENTRY_MASK)) {
prevcksum = ((dir_slot *) dentptr)
->alias_checksum;
get_vfatname (mydata, curclust, get_dentfromdir_block,
dentptr, l_name);
if (dols) {
int isdir = (dentptr->attr & ATTR_DIR);
char dirc;
int doit = 0;
if (isdir) {
dirs++;
dirc = '/';
doit = 1;
} else {
dirc = ' ';
if (l_name != 0) {
files++;
doit = 1;
if (doit) {
if (dirc == ' ') {
printf (" %8ld %s%c\n",
(long) FAT2CPU32 (dentptr->size),
l_name, dirc);
} else {
printf (" %s%c\n", l_name, dirc);
dentptr++;
continue;
FAT_DPRINT ("vfatname: |%s|\n", l_name);
} else
#endif
/* Volume label or VFAT entry */
dentptr++;
continue;
if (dentptr->name == 0) {
if (dols) {
printf ("\n%d file(s), %d dir(s)\n\n", files, dirs);
FAT_DPRINT ("Dentname == NULL - %d\n", i);
return NULL;
if (dols && mkcksum (dentptr->name) == prevcksum) {
dentptr++;
continue;
#endif
get_name (dentptr, s_name);
if (dols) {
char dirc;
int doit = 0;
if (isdir) {
dirs++;
dirc = '/';
doit = 1;
} else {
dirc = ' ';
if (s_name != 0) {
files++;
doit = 1;
if (doit) {
if (dirc == ' ') {
(long) FAT2CPU32 (dentptr->size), s_name,
dirc);
} else {
printf (" %s%c\n", s_name, dirc);
dentptr++;
continue;
if (strcmp (filename, s_name) && strcmp (filename, l_name)) {
FAT_DPRINT ("Mismatch: |%s|%s|\n", s_name, l_name);
dentptr++;
continue;
memcpy (retdent, dentptr, sizeof (dir_entry));
FAT_DPRINT ("DentName: %s", s_name);
FAT_DPRINT (", start: 0x%x", START (dentptr));
FAT_DPRINT (", size:0x%x %s\n",
(dentptr->attr & ATTR_DIR) ? "(DIR)" : "");
return retdent;
curclust = get_fatent (mydata, curclust);
FAT_DPRINT ("curclust: 0x%x\n", curclust);
FAT_ERROR ("Invalid FAT entry\n");
return NULL;
return NULL;
* Read boot sector and volume info from a FAT filesystem
static int
read_bootsectandvi(boot_sector *bs, volume_info *volinfo, int *fatsize)
__u8 block;
volume_info *vistart;
if (disk_read(0, 1, block) < 0) {
FAT_DPRINT("Error: reading block\n");
return -1;
memcpy(bs, block, sizeof(boot_sector));
bs->reserved = FAT2CPU16(bs->reserved);
bs->fat_length = FAT2CPU16(bs->fat_length);
bs->secs_track = FAT2CPU16(bs->secs_track);
bs->heads = FAT2CPU16(bs->heads);
#if 0 /* UNUSED */
bs->hidden = FAT2CPU32(bs->hidden);
#endif
bs->total_sect = FAT2CPU32(bs->total_sect);
/* FAT32 entries */
if (bs->fat_length == 0) {
/* Assume FAT32 */
bs->fat32_length = FAT2CPU32(bs->fat32_length);
bs->flags= FAT2CPU16(bs->flags);
bs->root_cluster = FAT2CPU32(bs->root_cluster);
bs->info_sector= FAT2CPU16(bs->info_sector);
bs->backup_boot= FAT2CPU16(bs->backup_boot);
vistart = (volume_info*) (block + sizeof(boot_sector));
*fatsize = 32;
} else {
vistart = (volume_info*) &(bs->fat32_length);
*fatsize = 0;
memcpy(volinfo, vistart, sizeof(volume_info));
/* Terminate fs_type string. Writing past the end of vistart
is ok - it's just the buffer. */
vistart->fs_type = '\0';
if (*fatsize == 32) {
if (compare_sign(FAT32_SIGN, vistart->fs_type) == 0) {
return 0;
} else {
if (compare_sign(FAT12_SIGN, vistart->fs_type) == 0) {
*fatsize = 12;
return 0;
if (compare_sign(FAT16_SIGN, vistart->fs_type) == 0) {
*fatsize = 16;
return 0;
FAT_DPRINT("Error: broken fs_type sign\n");
return -1;
__u8 do_fat_read_block;/* Block buffer */
long
do_fat_read (const char *filename, void *buffer, unsigned long maxsize,
int dols)
#if CONFIG_NIOS /* NIOS CPU cannot access big automatic arrays */
static
#endif
char fnamecopy;
boot_sector bs;
volume_info volinfo;
fsdata datablock;
fsdata *mydata = &datablock;
dir_entry *dentptr;
char *subname = "";
int rootdir_size, cursect;
int idx, isdir = 0;
long ret = 0;
int firsttime;
if (read_bootsectandvi (&bs, &volinfo, &mydata->fatsize)) {
FAT_DPRINT ("Error: reading boot sector\n");
return -1;
if (mydata->fatsize == 32) {
mydata->fatlength = bs.fat32_length;
} else {
mydata->fatlength = bs.fat_length;
mydata->fat_sect = bs.reserved;
cursect = mydata->rootdir_sect
= mydata->fat_sect + mydata->fatlength * bs.fats;
mydata->clust_size = bs.cluster_size;
rootdir_size = mydata->clust_size;
mydata->data_begin = mydata->rootdir_sect /* + rootdir_size */
- (mydata->clust_size * 2);
} else {
rootdir_size = ((bs.dir_entries * (int) 256 + bs.dir_entries)
* sizeof (dir_entry)) / SECTOR_SIZE;
mydata->data_begin = mydata->rootdir_sect + rootdir_size
mydata->fatbufnum = -1;
FAT_DPRINT ("FAT%d, fatlength: %d\n", mydata->fatsize,
mydata->fatlength);
FAT_DPRINT ("Rootdir begins at sector: %d, offset: %x, size: %d\n"
"Data begins at: %d\n",
mydata->rootdir_sect, mydata->rootdir_sect * SECTOR_SIZE,
rootdir_size, mydata->data_begin);
FAT_DPRINT ("Cluster size: %d\n", mydata->clust_size);
/* "cwd" is always the root... */
while (ISDIRDELIM (*filename))
filename++;
/* Make a copy of the filename and convert it to lowercase */
strcpy (fnamecopy, filename);
downcase (fnamecopy);
if (*fnamecopy == '\0') {
if (!dols)
return -1;
dols = LS_ROOT;
} else if ((idx = dirdelim (fnamecopy)) >= 0) {
isdir = 1;
fnamecopy = '\0';
subname = fnamecopy + idx + 1;
/* Handle multiple delimiters */
while (ISDIRDELIM (*subname))
subname++;
} else if (dols) {
isdir = 1;
while (1) {
int i;
if (disk_read (cursect, mydata->clust_size, do_fat_read_block) < 0) {
FAT_DPRINT ("Error: reading rootdir block\n");
return -1;
dentptr = (dir_entry *) do_fat_read_block;
for (i = 0; i < DIRENTSPERBLOCK; i++) {
l_name = '\0';
prevcksum = ((dir_slot *) dentptr)->alias_checksum;
get_vfatname (mydata, 0, do_fat_read_block, dentptr, l_name);
if (dols == LS_ROOT) {
char dirc;
int doit = 0;
if (isdir) {
dirs++;
dirc = '/';
doit = 1;
} else {
dirc = ' ';
if (l_name != 0) {
files++;
doit = 1;
if (doit) {
if (dirc == ' ') {
l_name, dirc);
} else {
dentptr++;
continue;
FAT_DPRINT ("Rootvfatname: |%s|\n", l_name);
} else
#endif
dentptr++;
continue;
} else if (dentptr->name == 0) {
FAT_DPRINT ("RootDentname == NULL - %d\n", i);
return 0;
return -1;
else if (dols == LS_ROOT
dentptr++;
continue;
#endif
char dirc;
int doit = 0;
if (isdir) {
dirc = '/';
if (s_name != 0) {
dirs++;
doit = 1;
} else {
dirc = ' ';
if (s_name != 0) {
files++;
doit = 1;
if (doit) {
if (dirc == ' ') {
dirc);
} else {
dentptr++;
continue;
if (strcmp (fnamecopy, s_name) && strcmp (fnamecopy, l_name)) {
FAT_DPRINT ("RootMismatch: |%s|%s|\n", s_name, l_name);
dentptr++;
continue;
if (isdir && !(dentptr->attr & ATTR_DIR))
return -1;
FAT_DPRINT ("RootName: %s", s_name);
FAT2CPU32 (dentptr->size), isdir ? "(DIR)" : "");
goto rootdir_done;/* We got a match */
cursect++;
rootdir_done:
firsttime = 1;
while (isdir) {
int startsect = mydata->data_begin
+ START (dentptr) * mydata->clust_size;
dir_entry dent;
char *nextname = NULL;
dent = *dentptr;
dentptr = &dent;
idx = dirdelim (subname);
if (idx >= 0) {
subname = '\0';
nextname = subname + idx + 1;
while (ISDIRDELIM (*nextname))
nextname++;
if (dols && *nextname == '\0')
firsttime = 0;
} else {
if (dols && firsttime) {
firsttime = 0;
} else {
isdir = 0;
if (get_dentfromdir (mydata, startsect, subname, dentptr,
isdir ? 0 : dols) == NULL) {
if (dols && !isdir)
return 0;
return -1;
if (idx >= 0) {
if (!(dentptr->attr & ATTR_DIR))
return -1;
subname = nextname;
ret = get_contents (mydata, dentptr, buffer, maxsize);
FAT_DPRINT ("Size: %d, got: %ld\n", FAT2CPU32 (dentptr->size), ret);
return ret;
int
file_fat_detectfs(void)
boot_sector bs;
intfatsize;
char vol_label;
if(cur_dev==NULL) {
printf("No current device\n");
return 1;
#if defined(CONFIG_CMD_IDE) || \
defined(CONFIG_MMC)
printf("Interface:");
switch(cur_dev->if_type) {
case IF_TYPE_IDE : printf("IDE"); break;
case IF_TYPE_SCSI : printf("SCSI"); break;
case IF_TYPE_ATAPI : printf("ATAPI"); break;
case IF_TYPE_USB : printf("USB"); break;
case IF_TYPE_DOC : printf("DOC"); break;
case IF_TYPE_MMC : printf("MMC"); break;
default :printf("Unknown");
printf("\nDevice %d: ",cur_dev->dev);
dev_print(cur_dev);
#endif
if(read_bootsectandvi(&bs, &volinfo, &fatsize)) {
printf("\nNo valid FAT fs found\n");
return 1;
memcpy (vol_label, volinfo.volume_label, 11);
vol_label = '\0';
volinfo.fs_type='\0';
printf("Partition %d: Filesystem: %s \"%s\"\n"
,cur_part,volinfo.fs_type,vol_label);
return 0;
int
file_fat_ls(const char *dir)
return do_fat_read(dir, NULL, 0, LS_YES);
long
file_fat_read(const char *filename, void *buffer, unsigned long maxsize)
printf("reading %s\n",filename);
return do_fat_read(filename, buffer, maxsize, LS_NO);
#endif 好长啊 什么东东 哦,这样的啊 代码的用途是什么? 学到了,谢谢 感谢分享
