老吴 发表于 2014-7-1 23:18
MTK八核/64位/2GHz/支持4G网络 联发科MT6752 PCB+原理图,平板电
PCB是PADS9.5格式,原理图ORCAD格式
****************以下信息由管理员 @老吴   整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
ReferencePartpcb footprintANT5001,ANT5002,ANT5003SPR / PVT1024ANT/2P/SMD/PVT1024ANT5101,ANT5102SPR / CSS5304-6213EANT/1P/SMD/CSS5301-6301F/SMK/RANDENBEAD5001FB / BLM15AG601SN1BEAD0402BEAD6001,BEAD6002,FB / BLM18BD252SN1 / 0603BEAD0603BEAD6003,BEAD6004,BEAD6005BEAD6011,BEAD6012FB / BLM18PG221SH1 / 0603BEAD0603CON2101CON / BAT-6PIN / CPL6506-0130ESZBAT/6P/SMD/P1.2/CPL6506-0130ESZ/SMKCON3301,CON3401,CON3700Car_Kit / MM8130-2600MM8130-2602CON3303,CON3402,CON3404CON / 4 / TA-RF02-001-03-811COAXIAL/SMD/TA-RF02-001-03-811CON4001CON / 11 / TA-M015-012-04-811MICROSD/8P/SMD/TA-M015-012-04-811CON5001Car_Kit / MM8430-2610MM8430-2600BCON6001CON / 5 / EJ-36952-10-GPAUDIOJACK/5P/DIP/EJ-36952-10-GPCON6002CON / 16 / 24-5804-016-000-829+CON8X2/SMD/F/P0.4/24-5804-016-000-829CON6101CON / 64 / AXE564124CON32X2/SMD/P0.4/F/AXE564124/WS2307CON6102CON / 34 / 24-5804-034-000-829+CON17X2/SMD/F/P0.4/24-5804-034-000-829CON6201CON / 30 / 24-5804-030-000-829+CAMERA_MODULE/30P/SMD/CM9156-B1300BA-ECON6202CON / 30 / AXT530124CAMERA_MODULE/30P/SMD/Q5V22K-0JGCON6301CON / 6 / FH34SRJ-6S-0.5SHH6/SMD/P0.5/FH34S-06S-0.5SHCON6401CON / 5 / KEIRAKU KIU90511S1RMICROUSB/5P/SMD/P0.65/R/KIU90511S1RCON6501,CON6502CON / 10 / SCGD1B0307SIM/10P/SMD/SCGD1B0307CON6503CON / 10 / AXE510127CON5X2/SMD/P0.4/F/AXE510127CON6601CON / 2 / SM02B-SURS-TFH2/SMD/P0.8/SM02B-SURS-TF/SURCON9001CON / 40 / AXT640124CON20x2/SMD/M/AXT640124/FPC C1101,C1104,C2020,C2022,C / 1 / uF / 0201C0201C2029,C2030,C2031,C2035,C2036,C2041,C2042,C2043,C2044,C2047,C2048,C2050,C2051,C2052,C2053,C2054,C2113,C2114,C2202,C2328,C2329,C3014,C3281,C3283,C4110,C4115,C5001,C5012,C5013,C5015,C5123,C5125,C6011,C6014,C6017,C6022,C6026,C6028,C6101,C6201,C6202,C6205,C6206,C6207,C6210,C6311,C6312,C6401,C6501,C6502,C10010,C10011,C10013,C10015,C10017,C10018,C10019,C10023,C10024,C10025,C10026,C10027,C10031,C10033,C10034,C10035,C10037,C10039,C10050,C10051,C10052,C10053,C10054,C10058,C10059,C10060,C10061,C10062,C10063,C10064,C10078,C10079,C10091,C10093,C10094,C10095,C10100C1105,C2032,C2037,C3002,C / 100 / nF / 0201C0201C3101,C3102,C3103,C3104,C3105,C3106,C3108,C3110,C3112,C3209,C3269,C3274,C3710,C4102,C4105,C4106,C4107,C4108,C4109,C4114,C4116,C5002,C6012,C6302,C6303,C6304,C6305,C6306,C6307,C6308,C6309,C6402,C6403,C6404,C6406,C6407,C6408,C6412,C6413,C6414,C6415,C6503,C9001,C10068,C10069,C10070,C10071,C10072,C10073,C10076,C10077,C10080,C10081,C10082,C10083,C10084,C10085,C10086,C10087,C10088,C10089,C10090,C10092,C10097,C10098,C10099C2007,C2142,C3239,C3709,C / 22 / uF / 0603C0603C10001,C10002,C10006,C10008,C10040,C10041,C10065,C10066C2011,C2012,C2013,C2015,C / 2.2 / uF / 0402C0402C2016,C2017,C2023,C2024,C2025,C2026,C2027,C2038,C2040,C2111,C3111,C4101,C4113,C6102,C6103,C6104,C6203,C6310,C10007,C10016,C10028,C10046,C10047C2018,C2021,C2110,C2112,C / 4.7 / uF / 0402C0402C2311,C2316,C2331,C4001,C4111,C5006,C6204,C10004,C10075,C10096C2033,C2034,C3201,C3203,C / 18 / pF / 0201C0201C3257,C3261,C3270,C3277,C3278,L3301,C3307,C3311,C3313,C3342,C3343,C3355,C3356,C3360,C3408,C3432,C3438,C3439,C3444,C5004C2124,C10036,C10038C / 47 / uF / 0805C0805C2131C / 1 / uF / 0603 / X5R / 35VC0603C2133C / 22 / pF / 0402 / X5R / 35VC0402C2203C / 1 / uF / 0201 / NCC0201C2205,C2207,C2320,C2322,C / 10 / uF / 0603C0603C2324,C4103,C4104,C10003,C10012,C10074C2310C / 1 / uF / 0603 / X5R / 50VC0603C2312C / 1 / uF / 0402C0402C2313,C2314,C2317,C2327C / 10 / uF / 0603 / X5RC0603C2315C / 330 / nF / 0201C0201C2321,C3214,C3217,C3225,C / 33 / pF / 0201C0201C3234,C3309,C3310,C3312,C3318,C3336,C3338,C3340,C3359,C3371,C3406,C3407,C3435,C6007,C6008,C6015,C6016,C6019,C6021,C6023,C6024,C6029,C6030,C6031,C6032,C6033C2330C / 33 / nF / 0201 / X7R / 16VC0201C3003,C3006,L3208,L3210,L / 1.8 / nH / 0201L0201L3211,C3262C3004,C3005,C3008,C3015,C / NCC0201C3204,C3215,C3216,C3222,C3229,C3230,C3236,C3250,C3251,C3255,C3258,C3263,C3264,C3271,C3272,C3273,C3279,C3314,C3320,C3701,C3703,C3707,C3708C3007,C3009,C3010,C3020,L / 3.3 / nH / 0201L0201C3021,L3212,L3303,L3304,L3312,L3336,L3412,L3419C3011,C3012,L3316,L3333,L / 18 / nH / 0201L0201L3362,L3417C3013,C3285,C3286,C3402,C / 12 / pF / 0201C0201C3403,C3404L3013,C3016,C3018,L3338,L / 6.8 / nH / 0201L0201L3407C3022,C3023,C3024,C3025,C / 470 / nF / 0201C0201C3026,C3275C3202,C3208,L3363,L3414C / 1.2 / pF / 0201C0201C3205,C3243,C3244,C3246C / 10 / pF / 0201 / X7RC0201C3206,C3713,C3735C / 39 / pF / 0201C0201C3207,C3700C / 56 / pF / 0201C0201C3210,L3402,L3703,L3704L / 3.9 / nH / 0201L0201C3211,L3430,C3714,C3716C / 1 / pF / 0201C0201C3223C / 0.5 / pF/ 0201C0201C3224,C3249,C3266,C6107C / 1 / nF / 0201C0201C3226,C3419,C3420,C3441,C / 3.3 / pF / 0201C0201C3442C3227L / 2 / nH / 0201L0201C3228,C3254C / 1.0 / pF / 0201C0201C3231,C3242C / 1 / nF / 0201 / X7RC0201C3233,C3241,C3253C / 470 / nF / 0201 / X7RC0201L3207,C3235,L3314,L3415,L / 5.6 / nH / 0201L0201L6401,L6402C3237C / 2.2 / pF / 0201C0201C3238L /9.1 / nH / 0201L0201C3240C / 1.8 / pF / 0201C0201C3245,C3247C / 100 / nF / 0201 / X7RC0201C3248,C3348C / 10 / pF / 0201C0201C3252,C3401,C3405C / 0.5 / pF / 0201C0201C3256,C3303,C3434C / 8.2 / pF / 0201C0201L3002,L3006,L3009,C3259,L / 5.1 / nH / 0201L0201C3265C3260L / 1.7 / nH / 0201L0201C3267,C3268,C3706C / 220 / pF / 0201C0201C3280C / 1 / pF/ 0201C0201C3288L / 3.5 / nH / 0201L0201C3302,C3308,C3413,C3417C / 5 / pF / 0201C0201C3315,C3321,C3341,C3344,C / 2.7 / pF / 0201C0201C3365,C3366C3316,C3322C / 1.6 / pF / 0201C0201C3317L / 0.6 / nH / 0201L0201R3218,C3323,C3325,C3423,C / 2.4 / pF / 0201C0201C3425L3217,C3327,C3335,L3347L / 6.2 / nH / 0201L0201C3330L / 4.3 / nH / 0201C0201C3333L / 12 / nH / 0201C0201C3334,C3354C / 4.7 / pF / 0201C0201C3339L / 1.4 / nH / 0201C0201C3349,C3353C / 1.5 / pF / 0201C0201C3352,C3374L / 1.8 / nH / 0201C0201C3361,L3421L / 4.3 / nH / 0201L0201C3362,C3409,C3411C / 1.1 / pF / 0201C0201C3370,C3372C / 3 / pF / 0201C0201L3309,C3373,C3415,L3705L / 1.5 / nH / 0201L0201C3375L / 1.5 / nH / 0201C0201C3412,C3416C / 5.6 / pF / 0201C0201C3414L / 2.2 / nH / 0201C0201C3418C / 6.8 / pF / 0201C0201C3433L / 1.3 / nH / 0201L0201C3440L / 7.5 / nH / 0201C0201C3702,C3704,C3705,C3711C / 22 / pF / 0201C0201C3712C / 0.6 / pF / 0201C0201C3715L / 39 / nH / 0201C0201L3306,L3307,L3405,C3733L / 47 / nH / 0201L0201C3734L / NCC0201C4112C / 220 / nF / 0201C0201C5003,C5011C / 0402 / NCC0402C5005,C5007,C5014,C6013,C / 100 / pF / 0201C0201C6020,C6025,C6027,C6601C5008,C6106C / 10 / nF / 0201C0201C5009C / 4.7 / nF / 0201C0201C5010,C5108,C5109C / 18 / pF / 0402C0402C5016C / 20 / pF / 0201C0201C5101,C5102,C5106,C5107C / 39 / pF / 0402C0402C5104,C5105C / 4.7 / pF / 0402C0402C5110,C5111,C5112C / 180 / pF / 0402C0402C5114C / NCC0402C5115C / 2.2 / uF / 0402 / X5RC0402C5116,C5121,C6800,C6801C / 1 / uF / 0201 / X5RC0201C5117C / 10 / uF / 0402 / X5RC0402C5119,C5122,C5124,C5126C / 470 / nF / 0402 / X5RC0402C5120C / 100 / nF / 0201 / X5RC0201C6018C / 4.7 / uF / 0402 C0402C6105C / 100 / nF / 0201 C0201D2102D / RB521CS-30DIODE/SMD/CO-LAY/0603/AKD2103D / MMSZ5231BT1GDIODE/SMD/MMSZ5221BD2301D / RB160M-60RB160M-30-EVBD6402D / MM5Z6V2SOD-523F/SMD/MM5Z6V2FD9101,FD9102,FD9103,TP / 40 / milFDFD9104F5001TRPX / TDK TPX205950MT-7110A1FILTER/SMD/LFD211G57ME3GB2001BAT / CPH3225ABAT/2P/SMD/CPH3225ALED2302LED / LUW FQELFLASH_LED/LUW_F8DNL2001,L2002PL / 0.47 / uH / 2016 / NCL/IND/SMD/VLS201610EL2003,L2006,L2007,L2008,PL / 0.47 / uH / 2016L/IND/SMD/VLS201610EL2104L2106PL / 2.2 / uH / 2520L/IND/SMD/2520L2107PL / 2.2 / uH / 2016L/IND/SMD/VLS201610EL2308PL / PIFE32251BL/IND/SMD/DFE252012F/TOKOL3001L / 2.7 / nH / 0201L0201L3003,L3005,L3007,L3010,L / NCL0201L3012,L3201,L3202,L3204,L3205,L3218,L3219,L3302,L3308,L3310,L3313,L3317,L3319,L3321,L3322,L3329,L3339,L3340,L3342,L3344,L3346,L3349,L3350,L3351,L3354,L3355,L3359,L3361,L3401,L3406,L3409,L3411,L3413,L3416,L3420,L3428,L3429,L3431,L3434,L3437L3004,L3418L / 1 / nH / 0201L0201L3008L / 39 / nH / 0201L0201L3011L / 22 / nH / 0201L0201L3206,L3311,L3410L / 3 / nH / 0201L0201L3209C / 12 / pF / 0201L0201L3213C / 8 / pF / 0201L0201L3214,L3216L / 0201 / NCL0201L3215,L3343,L3404,L3702L / 4.7 / nH / 0201L0201L3221L / NC / 0201L0201L3222C / 1.3 / pF / 0201C0201L3223L / 3.4 / nH / 0201L0201L3315L / 2.4 / nH / 0201L0201L3318C / 0.3 / pF / 0201C0201L3328L / 15 / nH / NCL0201L3330,L3403L / 12 / nH / 0201L0201L3332L / 8.2 / nH / 0201L0201L3334L / 7.5 / nH / 0201L0201L3335C / 2.2 / pF / 0201L0201L3337L / 3.6 / nH / 0201L0201L3341C / NCL0201L3360L / 10 / nH / 0201L0201L3364C / 1 / pF / 0201L0201L3432C / 1.8 / pF / 0201L0201L3433L / 16 / nH / 0201L0201L3436R / 0 / ohm / 0201L0201L3700C / 39 / pF / 0201L0201L3701L / 2.2 / nH / 0201L0201L3706L / 4.8 / nH / 0201L0201L3707L / 4.1 / nH / 0201L0201L5002L / 82 / nH / 0402L0402L5003L / 5.6 / nH / 0402L0402L5004L / 0402 / NCL0402L5005,L5006,L5007,L5008L / nH / 0201 / NCL0201L5101,L5102L / MLF1608DR56JL/IND/SMD/0603L6001R / 0 / ohm / 0402L0402L6002L / LQM18NN82NM00BEAD0603MIC6002MIC / SPU0410HR5H-PBFILTER/SMD/SPU0410HR5H-PBNTC6301,NTC6302NTC / NTCG104EF104F / 0402R0402PL2103PL / PMSB25201T-R47MSL/IND/SMD/2520PL2205,PL2208PL / 0.33 / uH / 2520L/IND/SMD/2520PL2303PL / PMSB20161T-4R7MSL/IND/SMD/VLS201610EPL2304PL / 4.7 / uH / 2016L/IND/SMD/VLS201610EPL2305PL / VLS252010HBX-1R0ML/IND/SMD/2520REC6001REC / 2403 260 00031 / NCRECEIVE/SMD/NXPR1021,R5006,R5013,R6508,R / 0 / ohm / 0201 / NCR0201R6510R1024R / 0 / ohm / 0201NC/MMD/L8/4MILR1025,R1037,R2001,R3205,R / 0 / ohm / 0201R0201R3242,R3305,R3700,R3701,R5007,R5014,R6401,R6402,R6404,R6406R1027,R3122,R3224,R5004,R / 0 / ohm / 0402R0402R5009,R5101,R5102,R5103,R5104,R5108,R6012,R6403R1101,R4103,R4104R / 240 / ohm / 0201 / 1%R0201R1103,R1104R / 4.7 / K / 0201 (NC)R0201R1201R / 5.1 / K / 0201 / 1%R0201R1202,R1203,R1204,R1205,R / 4.7 / K / 0201R0201R1208,R1209,R6407,R6408,R6410,R6411R1227R / 1.5 / K / 0201 / 1%R0201R2003R / 200 / K / 0201R0201R2006,R2026,R6010R / 1.5 / K / 0201R0201R2032R / 330 / K / 0402 / 1% R0402R2033R / 39 / K / 0402 / 1% R0402R2103R / 24 / K / 0402 / 1%R0402R2107R / 0.01 / ohm / 1206 / 1%R1206R2124R / 2.2 / K / 0201R0201R2309R / 10 / ohm / 0402R0402R2310R / 63.4 / K / 0402R0402R2321,R2322,R2326R / 10 / K / 0201 / 1%R0201R3003,R3009,R3011,R3201,R / 10 / K / 0201R0201R3704R3101R / 62 / ohm / 0201R0201R3102,R3103R / 105 / ohm / 0201R0201R3105R / 2 / K / 0402 / 1%R0402R3107,R3108,R6009,R6507,R / 1 / K / 0201R0201R6509R3202,R3705R / 24 / K / 0201R0201R3206,R3207R / NCR0201R3214L / 9.1 / nH / 0201R0201R3219,R3221L / 9.1 / nH / 0201L0201R3226C / 3.3 / pF / 0201R0201R3303R / 51 / ohm / 0201R0201R5105R / 7.5 / K / 0402R0402R5116,R5128,R5129R / 10 / K / 0402 / NCR0402R6002R / 470 / K / 0402R0402R6005R / 47 / K / 0402R0402R6006,R6007R / 470/ ohm / 0201R0201R6019R / 2.5 / K / 0201 / NCR0201R6103R / 680 / ohm / 0201R0201R6314,R6315R / 390 / K / 0402 / 1%R0402R6405R / 2.7 / K / 0201R0201R6409R / 665 / K / 0402R0402R6804R / 100 / K / 0402R0402SC9105,SC9107,SC9109,SC / PTV0703BSHIELD_CAN_CLIP/PTV0703BSC9110,SC9113,SC9114,SC9115,SC9116,SC9117,SC9118,SC9119,SC9120,SC9121,SC9123,SC9124,SC9126,SC9127,SC9129,SC9130,SC9131,SC9132,SC9133,SC9134,SC9135,SC9136,SC9137,SC9138,SC9139,SC9140,SC9142,SC9144,SC9145,SC9146,SC9147,SC9150,SC9151,SC9152,SC9153,SC9154,SC9155,SC9156,SC9159,SC9160,SC9161,SC9162,SC9163,SC9164,SC9165,SC9166,SC9167,SC9168,SC9169,SC9170,SC9171,SC9172,SC9173,SC9174,SC9175,SC9176,SC9177,SC9178,SC9179,SC9180,SC9181SC9185SC / PCV1003CABLE_CLIP/3P/SMD/PCV1003SC9187,SC9188,SC9189,SC / PTV3121NSHIELD_CAN_CLIP/3P/SMD/PTV3121NSC9190,SC9191,SC9192,SC9193,SC9194SH1001,SH1002,SH1003,SHORT / NC-MMD-L9-4MILNC/MMD/L8/4MILSH1004,SH1005,SH1006,SH1007,SH1008,SH1009,SH1200,SH1201,SH1202,SH1203,SH5002,SH5102,SH5105,SH5106,SH5107,SH5111,SH5112,SH5113,SH5114,SH5115,SH5116,SH5117,SH6000,SH6200,SH1010RDP1_ASH1011,SH4100R / 0 / ohm / 0603 / NCNC0603SH4000,SH4001,SH4002,SHORT / NC-MMD-L9-4MILNC/MMD/L1/4MILSH5001,SH5008,SH5009,SH5010,SH5011,SH5012,SH5013SH5100,SH5101,SH5103,SHORT / 0402 / NCR0402/WS2458SH5104,SH5108,SH5109,SH5110,SH6500,SH6501SH6003SHORT / 0402 / NCNC/RTP2311,TP5101,TP5102,TP / 30 / milTP/SMD/12MILTP6401U1001U / IC-MT6752-E1-SBSMT6752/VFBGA677/P0.4/B0.25/12.6X12.6U2001U / MT6325-E1 / MT6325/TEMPMT6325/VFBGA244/P0.4/B0.25/7.8X7.4U2102U / TPS61280ACSP16/SMD/P0.4/B0.25/TPS6128X/SU2201U / MT6311MT6311/WLCSP30/P0.4/B0.25/2.655X2.255U2301U / RT4505WLCSP9/SMD/P0.4/B0.25/RT4505U2302U / BQ24261QFN24/SMD/P0.5/BQ24261U2304U / NT50358DSBGA15/SMD/P0.4/B0.25/TPS65132U2305U / TPS61163YFFDSBGA9/SMD/P0.4/B0.25/TPS61163U3001U / MT6165MT6165/VFBGA68/P0.4/B0.25/4.3X4.3U3003SAW / SAWEN881MCY0F00R14SAW/SMD/SAWEN881MCY0F00R14U3004SAW / SAWEN1G84CV0F00SAW/SMD/SAWEN881MCY0F00R14U3005SAW / SAFEA1G81FB0F0ASAWFILTER/SMD/SAFEA1G90MB0F0AU3101U / MT6169MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U3102VTCXO / 26 / MHz / KT2520F26000DCW28QAKTCXO/SMD/2.5X2.0/KT2520FU3202LPF / TFSL06050915-4108B1FILTER/SMD/TFSL06050915-4108B1U3203PA / SKY77621SKY77621U3208PA / SKY77778SKY77778U3210LPF / LF1608-B2R5KCBBALUN/SMD/HHM22112A2U32123P4T / SKY13477WLCSP15/SMD/P0.4/B0.25/SKY13477U3214,U3413FBAR / ACPF-7041ACPF-7041/SMDU3215,U3404SAW / 885049FILTER/SMD/885049U3301DPX / SAYFH1G74CA0B0ASAW/8P/SMD/D2.0X1.6/SAY/MURATAU3302,U3324,U3401DP4T / RF1624TSLP10/SMD/P0.4/BGS22WL10U3303CPL / LDJ18829M24AE003BALUN/SMD/HHM22112A2U3305DIPX / SAWFD1G90BK0F0ASAWFILTER/SMD/SAWFD1G90BH0F0AU3306DPX / SAYRF1G95HN0F0ASAW/8P/SMD/D2.0X1.6/SAY/MURATAU3307SP5T / SKY13415SKY13414U3308DPX / D6HN2G655BN56SAW/8P/SMD/D6HN2G655BN56U3309DPX / D6PE1G960P3BYSAW/8P/SMD/D6PE1G960P3BYU3310ASM / SKY13488SKY13488U3313DPX / SAYFH836MCC0F0ASAW/8P/SMD/D2.0X1.6/SAY/MURATAU3316DIPX / AG90ASAW/8P/SMD/1.8X1.4/AG90AU3317SAW / SAFFB942MFL0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3323,U3329,U3403,U3414BAL / TDK-TFSZ06052460-3310A2BALUN/SMD/TFSZ06052460-3310A2U3328DPX / SAYFH710MCA0F0ASAW/8P/SMD/D2.0X1.6/SAY/MURATAU3402SP10T / SKY13473-569LFSKY13473U3406SAW / SAFFB1G84FL0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3407SAW / SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3408SAW / B9898SAWFILTER/SMD/F6QB2G595P2BSU3410SAW / F6QG2G140P2KASAWFILTER/SMD/F6QB2G595P2BSU3415SAW / F5QG740M0P2KHSAWFILTER/SMD/F5QB2G595P2BSU3700PA / SKY77597 (ES2)SKY77590U3703SAW / SACEA1G90TB0F0ASAWFILTER/SMD/SACEA1G90TB0F0AU4102U / H9TQ17ABJTMCUR-KUM / FBGA221FBGA221/P0.5/B0.27/11.5X13/SAMSUNGU5001U / MT6625L / QFN40MT6625/SQFN40/SMD/P0.4/5X5U5002TCXO / 26 / MHz / IT2205AETCXO/SMD/2.5X2.0/IT2205BEU5003U / EPOCOS_B8313SAW/SMD/1.05X1.35U5004U / BGA725L6TSLP6/SMD/P0.4/BGA725L6/SU5005FBAR / ACPF-7124FILTER/SMD/ACPF-7124U5101U / MT6605E3MT6605/MQFN32/SMD/P0.4/4X4/SU6101U / GT917SQFN68/SMD/P0.4/GT917SU6301U / AK8963CWLCSP14/SMD/P0.4/B0.23/AK8963U6302U / MPU-6515AQFN24/SMD/P0.4/MPU-6515U6303U / BMP180SENSOR/7P/SMD/BMP180-DS000U6401U / Sil 8348TFBGA64/P0.5/B0.27/TDA19989BETU6800U / MT6306 / QFN28AW6314/QFN28/P0.4/4X4X2001X / 32 / KHz / CM7V-T1ACRYS/SMD/3.2X1.5/9H032000XX/TXCX3001X / 26 / MHz / 7M26000028TCXO3225X5101X / 27.12 / MHz / FA-128CRYS/SMD/FA-128
老吴 发表于 2014-7-1 23:25
网上找了一篇这个CPU 介绍的文章
在LTE与64位的布局上,联发科正快速向前推进,产品上市时间一再提前,先是首款八核LTE SOC-MT6595登场,随后在MWC大会上发布旗下首个64位手机解决方案MT6732,今日(25日)联发科再次发布重量级产品,即拥有8核心支持LTE网络的64位处理器-MT6752,进一步扩展自身产品线,迈入高阶市场。
本文来自MTK手机网http://www.mtksj.com
相比MT6732,新发布的MT6752性能等方面更上一层楼,MT6752拥有8个Cortex-A53应用处理器,核心主频达到2GHz,支持64位计算,内建ARM 最新图形处理器MALI-T760,带来更强劲的游戏、多媒体性能。
影音方面,MT6752支持1080P 30fps低功耗影音播放和1080P视频录制, 搭配ClearMotion视频倍频技术和MiraVision技术可获得更佳的多媒体影音体验;可支持1600万像素的摄像头;支持FHD级别屏幕显示。
MT672同样整合了多模多频LTE调制解调器,支持Category 4版本,上下行传输速率达到50M/150Mbit/s,兼容TD-LTE/FDD-LTE主流4G制式,支持DC-HSPA +(42Mbits/s)、TD-SCDMA、EDGE以及GSM / GPRS。 本文来自MTK手机网http://www.mtksj.com
联发科一直坚持多核战略,LTE与64位时代同样如此,同时亲民价格亦是联发科的武器之一,MT6752虽然规格比面向中低端市场的MT6732更高,但是联发科方面仍强调了“高性价比”四个字,估计终端产品仍会有亲民价格。 MT6752还有一个优点是与MT6732针脚完美兼容,产品升级更快捷,据悉MT6752将于第三季度给客户测试,年底之前完成量产。 本文来自MTK手机网http://www.mtksj.com
longxuekai 发表于 2014-7-2 00:10
好强大的,
monamemak 发表于 2014-7-2 00:56
的Cortex-A57的更强。A53,只为产品的低预算。
但它只是我的意见。
kingmen 发表于 2014-7-2 01:59
哇!!!大赞赞赞赞赞赞赞!!!
yfchen1003 发表于 2014-7-2 05:33
老大给力
gongping 发表于 2014-7-2 07:17
非常好,谢谢
liposlt 发表于 2014-7-2 07:50
老大的帖子总是高大上。
dragon716 发表于 2014-7-2 08:03
这才是好东西来的,可以上安卓5.0的系统
xiazai9999 发表于 2014-7-2 08:04
太上档次了
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: MTK八核/64位/2GHz/支持4G网络 联发科MT6752 PCB+原理图,平板电
