845E电脑主板PCB+原理图 ALLEGRO格式PCB,PDF原理图
REFDESCOMP_DEVICE_TYPESYM_NAMEAGP1DIP_AGP-SLOT_132PAGPUNIVERSALATXPWR1DIP_ATXPWR_2X2PPOWER_2X2PATXPWR2DIP_ATXPWR_2X10PPOWER-ATXAUDIO_GAME1DIP_CONN_AUDIO-GAMEAUDIO-GAMEBAT1DIP_COIN_BATBATCN2DIP_CONN_USB-RJ45RJ45_USBCN11DIP_CONN_CDIN_1X4-PP25CN1X4-25MMWHCN12DIP_CONN_CDIN_1X4-PP20CN1X4-2MMWHCOM1DIP_CONN_DTYPE-9PDB9MCOM2DIP_CONN_DTYPE-9PDB9MCOM_LPT1DIP_CONN_DTYPE-25PDB25FDD30SMD_DIODE_DO1545-12DO1545-12DDR1DIP_DDR-SLOT-184PDIMM184DDR2DIP_DDR-SLOT-184PDIMM184FAN2DIP_FAN_1X3PFAN_CONNFAN3DIP_FAN_1X3PFAN_CONNFDD1DIP_BOX-HEADER_2X17FDD_CNTR_2X17FS1SMD_POLY-SW_MINI-C110MINI-SMDC110FS2SMD_POLY-SW_MINI-C110MINI-SMDC110FS3SMD_POLY-SW_MINI-C110MINI-SMDC110FS4SMD_POLY-SW_MINI-C110MINI-SMDC110IDE1DIP_BOX-HEADER_2X20_P20NCIDEIDE2DIP_BOX-HEADER_2X20_P20NCIDEJ1DIP_HEADER_1X5PJP5J2DIP_HEADER_1X5PJP5J3DIP_HEADER_2X6PJP6X2J4DIP_CONN-WOL_1X3PWOLJ5DIP_HEADER_2X8PJP8X2VJP1DIP_HEADER_1X3PJP3JP3DIP_HEADER_1X3PJP3JP4HEADER_2X4HEADER_2X4JP6DIP_HEADER_1X3PJP3JP7DIP_HEADER_1X3PJP3JP8DIP_HEADER_1X3PJP3L7DIP_COIL_L165-P89-H140COIL-17MML8SMD_L_0805L0805L9DIP_COIL_L165-P89-H140COIL-17MML10SMD_L_0805L0805L11DIP_COIL_L165-P89-H140COIL-17MML63SMD_L_0805L0805MH1DRILL-150_PAD-300DRILL-150_PAD-300PS2KBMS1DIP_CONN_KB-PS2PS2X2Q7SMD_TO263AB-GDSTO263AB-GDSQ8TO92-RACTO92-RACQ9SMD_SOT23-GDSSOT23-GDSQ11SMD_SOT23-GDSSOT23-GDSQ12SMD_SOT23-BCESOT23-BCEQ13SMD_SOP8SOP8Q14SMD_SOT23-GDSSOT23-GDSQ15SMD_SOT23-BCESOT23-BCEQ16SMD_SOT23-BCESOT23-BCEQ17SOT223-BCESOT223-BCEQ18SMD_SOP8SOP8Q19SMD_SOT23-GDSSOT23-GDSQ21SMD_TO252-GDSTO252-GDSQ24DIP_TO92-123TO92-123Q28SMD_TO252-GDSTO252-GDSQ30SMD_SOT23-BCESOT23-BCEQ31SMD_SOT23-GDSSOT23-GDSQ32SMD_SOT23-BCESOT23-BCEQ34SMD_SOT23-BCESOT23-BCEQ36SMD_SOT23-BCESOT23-BCEQ37SMD_TO252-GDSTO252-GDSQ38SMD_SOT223-123SOT223-123Q39SMD_SOT23-BCESOT23-BCERN129SMD_R-PACK-8P4R8P4RRT1DIP_HEADER_1X2PJP2SCN14SMD_CAP-PACK-8P4C8P4CT1SMD_H1102_SOP16H1102U3SMD_SOP14SOP14U4SMD_SOP16SOP16U5SSOP28SSOP28U6SMD_SOP16SOP16U7SMD_SOP14SOP14U8SMD_TSSOP20TSSOP20U10SMD_SOP8SOP8U11SMD_ZIF478ZIF478U14SMD-SSOP56SMD-SSOP56U15SMD_VT8754_BGA858SMD_VT8754_BGA858U16SMD_SOP8SOP8U17SMD_TQFP48TQFP48U18SMD_SOP8SOP8U19SMD_SSOP48SSOP48U20SMD_VT8235_BGA487SMD_VT8235_BGA487U21SMD_SOP14SOP14U22SMD_TQFP128PQFP128U24SMD_SOP14SOP14U27SMD_PLCC32PLCC32U28SMD_SOP14SOP14U33SMD_SOP8SOP8U36SMD_SOT23-5SOT23-5U37SMD_SOT23-5SOT23-5U38SMD_TSSOP20TSSOP20USB1DIP_HEADER_2X5PJP5X2USB2DIP_HEADER_2X5PJP5X2Y1DIP_XTAL_49USXTAL_49USY2DIP_XTAL_49USXTAL_49USY3DIP_XTAL_49USXTAL_49USY4DIP_XTAL_CYLINDERXTAL_CYLINDER **** Hidden Message ***** 值得一看,学习啦! 下载来研究学习! 都是好东西呀 帅气的板子啊
回 pcb 的帖子
pcb:[内容隐藏] (2012-08-22 17:08) images/back.gif这个号啊 电脑主板,下载下来学习了。
