神话2013 发表于 2014-10-20 14:25
MTK6582 4G智能手机PCB文件
****************以下信息由管理员 @老吴   整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
NameValuePCB DecalPart TypeB403SZ1005K182TF2P_0402L_1L0402-2PB406SZ1005K182TF2P_0402L_1L0402-2PB407SZ1005K182TF2P_0402L_1L0402-2PB412SZ1005K182TF2P_0402L_1L0402-2PB413SZ1005K182TF2P_0402L_1L0402-2PB530100nHL_0402L0402-2PB700SZ1005K102TF2P_0402L_1L0402-2PBAT_CN1BTY32-3K10000BTY10-3K30000CON_BTY10-3K30000BEAD1NC,HZ1005K182TF,50mAB_0402B_0402BEAD2NC,HZ1005K182TF,50mAB_0402B_0402BEAD402SZ1005G121TF,400mAB_0402B_0402BEAD404SZ1005G121TF,400mAB_0402B_0402C133pF2P_0201C_1C0201-2PC2470nFC_0201C_0201C333pF2P_0201C_1C0201-2PC410uF/06032P_0603C_1C0603-2PC5470nFC_0201C_0201C181uF/0402C_0402C_0402C682.2uF/04022P_0402C_1C0402-2PC104100nFC_0201C_0201C108100nFC_0201C_0201C109100nFC_0201C_0201C110100nFC_0201C_0201C111100nFC_0201C_0201C112100nFC_0201C_0201C113100nFC_0201C_0201C1151uF/0402C_0402C_0402C116100nFC_0201C_0201C117100nFC_0201C_0201C1191uF/0402C_0402C_0402C120100nFC_0201C_0201C122100nFC_0201C_0201C123100nFC_0201C_0201C124100nFC_0201C_0201C125100nFC_0201C_0201C127100nFC_0201C_0201C128100nFC_0201C_0201C12910uF/0603C_0603C_0603C1304.7uF/0402C_0402C_0402C131100nFC_0201C_0201C13210uF/0603C_0603C_0603C13310uF/0603C_0603C_0603C13410uF/0603C_0603C_0603C13510uF/0603C_0603C_0603C1401uF/0402C_0402C_0402C142100nFC_0201C_0201C143100nFC_0201C_0201C144100nFC_0201C_0201C1481uF/0402C_0402C_0402C151100nFC_0201C_0201C1521uF/0402C_0402C_0402C1551uF/0402C_0402C_0402C156100nFC_0201C_0201C157100nFC_0201C_0201C158100nFC_0201C_0201C205100nFC_0201C_0201C206100nFC_0201C_0201C2071uF/0402C_0402C_0402C2131uF/0402C_0402C_0402C224100nFC_0201C_0201C241100nFC_0201C_0201C2421uF/0402C_0402C_0402C243NC,1uF/0402C_0402C_0402C3014.7uF/0402C_0402C_0402C3034.7uF/0402C_0402C_0402C3041uF/0402C_0402C_0402C30610uF/0603C_0603C_0603C3071uF/0402C_0402C_0402C3081uF/0402C_0402C_0402C3094.7uF/0402C_0402C_0402C31110uF/0603C_0603C_0603C3161uF/0402C_0402C_0402C318100nFC_0201C_0201C3190RC_0201C_0201C320100nFC_0201C_0201C321100nFC_0201C_0201C3221uF/0402C_0402C_0402C3334.7uF/0402C_0402C_0402C3362.2uF/0402C_0402C_0402C34122uF/CasePF9220J106MPC0603-2PC3524.7uF/0402C_0402C_0402C3531uF/0402C_0402C_0402C4011uF/0603/25VC_0603C_0603C40310uF/06032P_0603C_1C0603-2PC4041uF/04022P_0402C_1C0402-2PC40533pFC_0201C_0201C40633pFC_0201C_0201C4071uF/04022P_0402C_1C0402-2PC41133pFC_0201C_0201C412100pFC_0201C_0201C41333pFC_0201C_0201C41433pFC_0201C_0201C415100pFC_0201C_0201C41633pFC_0201C_0201C417100nFC_0201C_0201C419100nFC_0201C_0201C431100pFC_0201C_0201C4354.7uF/0402C_0402C_0402C43910uF/06032P_0603C_1C0603-2PC4404.7uF/0402C_0402C_0402C441100nFC_0201C_0201C44333nFC_0402C_0402C44433nFC_0402C_0402C4451uF/0402C_0402C_0402C446100nF2P_0201C_1C0201-2PC447100nF2P_0201C_1C0201-2PC463100nFC_0201C_0201C5221uF/0402C_0402C_0402C523100nFC_0201C_0201C524220nFC_0201C_0201C527100nFC_0201C_0201C528100nFC_0201C_0201C529100nFC_0201C_0201C530100nFC_0201C_0201C531100nFC_0201C_0201C5364.7uF/0402C_0402C_0402C5372.2uF/0402C_0402C_0402C5384.7uF/0402C_0402C_0402C5392.2uF/0402C_0402C_0402C5402.2uF/0402C_0402C_0402C541100nFC_0201C_0201C5422.2uF/0402C_0402C_0402C543100nFC_0201C_0201C601470nFC_0201C_0201C6035.6pFC_0201C_0201C60482pFC_0201C_0201C606100nFC_0201C_0201C61118pFC_0201C_0201C61256pFC_0201C_0201C613NCC_0201C_0201C6152.2nHC_0201C_0201C6161.2nHL_0201C_0201C622470nFC_0201C_0201C623470nFC_0201C_0201C625470nFC_0201C_0201C6261uF/0402C_0402C_0402C634470nFC_0201C_0201C635NCC_0201C_0201C636220pF/50VL_0201C_0201C63833pFC_0201C_0201C6392nHC_0201C_0201C64022uF/CasePF9220J106MPC0603-2PC6419.1nHL_0201L_0201C6426.8pFC_0201C_0201C6436.8pFC_0201C_0201C645NCC_0201C_0201C64822pFC_0201C_0201C64918pFC_0201C_0201C6502.2uF/0402C_0402C_0402C666NCC_0201C_0201C6701.5pFC_0201C_0201C6841.8nHL_0201L_0201C6851.8nHL_0201L_0201C7014.7nFC_0201C_0201C702100pFC_0201C_0201C7040.22uFC_0201C_0201C7054.7uF/0402C_0402C_0402C7081uF/0402C_0402C_0402C709100nFC_0201C_0201C710100pFC_0201C_0201C711100nFC_0201C_0201C7122.2uF/0402C_0402C_0402C713100nFC_0201C_0201C715NCC_0402C_0402C71639nHC_0402C_0402C7170RC_0201C_0201C7181uF/0402C_0402C_0402C72018pFC_0201C_0201C72118pFC_0201C_0201C72339nHC_0402C_0402C724NCC_0402C_0402C72818pFC_0201C_0201C7352.2uF/0402C_0402C_0402C73682pFC_0201C_0201C737100nFC_0201C_0201C74556pFC_0201C_0201C749NCC_0201C_0201C754NCC_0201C_0201C10012.2uF/0402C_0402C_0402C10032.2uF/0402C_0402C_0402C1004100nFC_0201C_0201C10051uF/0402C_0402C_0402C10061uF/0402C_0402C_0402C100810uF/0603C_0603C_0603C10091uF/25V/0805C_0805C_0805C1010100nF2P_0201C_1C0201-2PC1011100nF2P_0201C_1C0201-2PC10121uF/0402C_0402C_0402C10131uF/0402C_0402C_0402C101410nF2P_0201C_1C0201-2PC1015100pF2P_0201C_1C0201-2PC11014.7uF/0402C_0402C_0402C11021uF/0402C_0402C_0402C11031uF/0402C_0402C_0402C11041uF/0402C_0402C_0402C11051uF/0402C_0402C_0402C11061uF/0402C_0402C_0402C1107100nFC_0201C_0201C110810uF/0603C_0603C0603-2PC11091uF/0402C_0402C0402-2PC111010uF/0603C_0603C0603-2PC12011uF/04022P_0402C_1C0402-2PC1202100nFC_0201C_0201CAM_CN1BL125-23RL-TAGFCONNECTOR_25PINCON_CAM_BL125-25RL-TAGFCAM_CN2CON_CAM_21PINCON_CAM_21PINCON_CAM_21PINCON501Y-J3CQ6-BWDAUDIO_JACK_Y-J3CQ6-BWDEARJACK-Y-J3CQ6-BWDCON603NC,RF TEST PADRF-TESTRF-TESTCON701C87P101-00003AHECT818000531RFCABLE_ECT818000531D1ESDU5V0F1,0.5pFTVS_0402TVS_0402D302BZT52C5V1WSDIODE_SMD_SOD323DIODE_ZENER_NEWD1001WSB5503W-2/TRRT_DIODE_WSB5503WRT_DIODE_WSB5503WE601SPR-3041519P23-RY01TP1.4ANTENNA_SPRING_1.0E602SPR-3041519P23-RY01TP1.4ANTENNA_SPRING_1.0E701SPR-3041519P23-RY01TP1.4ANTENNA_SPRING_1.0E702SPR-3041519P23-RY01TP1.4ANTENNA_SPRING_1.0J0007C90P103-00004-HRF_TEST_6P_2.5X2.5ECT818000163J1101Flash FPCS5HD_PWRKEYFPC_PAD_2PINS5HD_PWRKEYFPC_PAD_2PINJ1102Flash FPCS5HD_PWRKEYFPC_PAD_2PINS5HD_PWRKEYFPC_PAD_2PINJ12012.5X0.4X0.8MM_20PINCON_SUBFPC_20PIN_P0.8J1202NC,S220-SIDEFPC_4PIN2.5X0.4X0.8MM_5PINCON_SUBFPC_5PIN_P0.8J1203NC,S220-SIDEFPC_4PIN2.5X0.4X0.8MM_5PINBCON_SUBFPC_5PIN_P0.8L2NCL_0201L_0201L639nHL_0201L_0201L82.2nHL_0201L_0201L3010.68uHIND2520IND2520L3030.68uHIND2520IND2520L60012nHL_0201L_0201L60133nHL_0201L_0201L6114.7nHL_0201L_0201L616NCL_0201L_0201L61833nHL_0201L_0201L61912nHL_0201L_0201L6223nHL_0201L_0201L6236.2nHL_0201L_0201L6257.5nHL_0201L_0201L6266.2nHL_0201L_0201L6332.0nHL_0201L_0201L701SZ1005K102TF2P_0402L_1L0402-2PL70282nH2P_0402L_1L0402-2PL703NC,100nH2P_0402L_1L0402-2PL7047.5nHL_0201L_0201L100110uH,550mA,LQH3NPN100MM0LLQH3NPN2R2NG0L_3_3L1101SZ1005K102TFL_0402L_0402LCM_CN1BF040-I30B-C10-WBF040-I30B-C10-WCON_BF040-I30B-C10-WMARK1MARK POINTMARK_1MMMARKMARK2MARK POINTMARK_1MMMARKMARK3MARK POINTMARK_1MMMARKMARK4MARK POINTMARK_1MMMARKQ401PT236T30E2HSOT23-6L-STT818BSOT23-6L-STT818BQ402CJ3134KSOT-723CJ3134K_SOT-723Q1101NC,2SK3019NTE4153NNTE4153NR11KR_0201R_0201R20R2P_0201R_1R0201-2PR1010R/0402R_0402R_0402R1140R/0402R_0402R_0402R1150R/0402R_0402R_0402R1160R/0402R_0402R_0402R2015.1K,1%R_0201R_0201R2031.5K,1%R_0201R_0201R20616.9K,1% /0402R_0402R_0402R20727K,1% /0402R_0402R_0402R2081KR_0201R_0201R2098.2K,1%R_0201R_0201R2104.7KR_0201R_0201R2118.2K,1%R_0201R_0201R2124.7KR_0201R_0201R2174.7KR_0201R_0201R2184.7KR_0201R_0201R2194.7KR_0201R_0201R2204.7KR_0201R_0201R221NC,0RR_0201R_0201R3161KR_0201R_0201R3330RR_0201R_0201R4013.3KR_0201R_0201R402330KR_0201R_0201R40339KR_0201R_0201R4041.5K,1%R_0201R_0201R4050.2R/0805,1%R_0805R_0805R4060RR_0201R_0201R40727R2P_0201R_1R0201-2PR40827R2P_0201R_1R0201-2PR414100R2P_0201R_1R0201-2PR415100R2P_0201R_1R0201-2PR416470R2P_0201R_1R0201-2PR417470R2P_0201R_1R0201-2PR429470K2P_0201R_1R0201-2PR43047K2P_0201R_1R0201-2PR43110KR_0201R_0201R43210KR_0201R_0201R4381KR_0201R_0201R509240R 1%R_0201R_0201R510240R 1%R_0201R_0201R60151R,1%R_0201R_0201R602NCP15WF104F03RCR_0402R_0402R6041KR_0201R_0201R6051KR_0201R_0201R6060RR_0201R_0201R60710KR_0201R_0201R61224KR_0201R_0201R62851R,1%R_0201R_0201R631NC,51R,1%R_0201R_0201R63251R,1%R_0201R_0201R6331KR_0201R_0201R6340RR_0201R_0201R6361KR_0201R_0201R64027RR_0201R_0201R6422K,1%R_0201R_0201R64327RR_0201R_0201R64436RR_0201R_0201R654NCRES0302RES0302R672NC,51R,1%R_0201R_0201R705NCR_0201R_0201R7080RR_0201R_0201R7100R/0402R_0402R_0402R7200R/0402R_0402R_0402R723NCR_0201R_0201R740NCR_0201R_0201R1001100KR_0201R_0201R10117.5R,1%R_0201R_0201R101410R/0402R_0402R_0402R10154.7KR_0201R_0201R1016100K2P_0201R_1R0201-2PR1017NC,0RR_0201R_0201R1018NC,0RR_0201R_0201R111847KR_0201R0201-2PR111947KR_0201R0201-2PR112091KR_0201R0201-2PR11210.22R/0805,1%R_0805R0805-2PR1122NC,33RR_0402R_0402R12011KR_0201R_0201R12021KR_0201R_0201R12031KR_0201R_0201R12041KR_0201R_0201REC401NC,Receiver PADRECEIVER_1206_NEWRECEIVER_R1206_NEWRF1TP_1.5MMTP_1.2TP_1.2RF2TP_1.5MMTP_2X2.5MMTP_2X2.5MMSIM_CN1CON_SIM_CARD_2.55HSIM_CARD_2.55HCON_SIM_CARD_2.55HTP201TP_1.5MMTP15_1TP_1.5TP202TP_1.5MMTP15_1TP_1.5TP307TP_1.5MMTP15_1TP_1.5TP308TP_1.5MMTP15_1TP_1.5TP401TP_1.5MMTP15_1TP_1.5TP535TP_1.5MMTP15_1TP_1.5TP1001TP_1.5MMTP15_1TP_1.5TP1002TP_1.5MMTP15_1TP_1.5TP1003TP_1.5MMTP15_1TP_1.5TP1004TP_1.5MMTP15_1TP_1.5TP1005TP_1.5MMTP15_1TP_1.5TP1006TP_1.5MMTP15_1TP_1.5TP1201TP_1.5MMTP15_1TP_1.5TP1202TP_1.5MMTP15_1TP_1.5TP1203TP_1.5MMTP15_1TP_1.5TP1204TP_1.5MMTP15_1TP_1.5TP_CN1BL115EH-08RL-TAGFCON_TP_BL115H-08RL-TAGFCON_TP_BL115H-08RL-TAGFU201MT6582-LPDDR2MT6582/VFBGA475/P0.4/B0.25/10.6X11MT6583E1_LPDDR2_107U301MT6323MT6323/VFBGA145/P0.4/B0.25/5.8X5.8MT6323_E1_1U401AW8145CSRCSP9AW8145U501FBGA186/P0.5/B0.27/12X16/SUMSUNG/2-IN-1LP_DDR2(JEDEC_162B)_10U601MT6166MT6166/TMP/SMDMT6166U602SKY77590SKY77590RF_TRX_FEM_SKY77590U604SKY77761-11RPF57701BRPF57701BU605SAYRF1G95HQ0F0ASAW/8P/SMD/D2.0X1.6/SAY/MURATA-NEWSAW-DPX-RX-BAL-NEWU607B39881B8553P810SAW/8P/SMD/D2.0X1.6/SAY/MURATA-NEWSAW-DPX-RX-BAL-NEWU701MT6627NMT6627-NS/MQFN40/SMD/P0.4/5X5MT6627U703SAFEB1G57KE0F00SAW942SAFEB897MAL0F00R14U708SKY77765PA_SKY7776XSKY7776XU1001RT9293BSOT-6R1204N113D-TR-FEU1002BMA250EBMA250EBMA250EU1003BGU7005LNA_0.5S_6P_1.5X1.1GPS_LNA_BGU7005U1004AP3216CAP3216CAP3216CU1005MH-251ESNSOT-553MH251ESNU1101SGM3141B,700mASGM3141BSGM3141BUSB_CN1USB-U06-9B05F250USB_5PIN_OFFSET1.6MMCON-I/O-USB-5PIN-U06-9B05F250VR20NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR21NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR22NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR24NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR25NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR26NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR201PESD5V0S1BLTVS_0402_SC5TVS_0402VR202PESD5V0S1BLTVS_0402_SC5TVS_0402VR401PESD5V0S1BLTVS_0402_SC5TVS_0402VR402PESD5V0S1BLTVS_0402_SC5TVS_0402VR408NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402VR409NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402VR412NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402VR1001PESD5V0S1BLTVS_0402_SC5TVS_0402VR1002PESD5V0S1BLTVS_0402_SC5TVS_0402VR1003PESD5V0S1BLTVS_0402_SC5TVS_0402VR1004PESD5V0S1BLTVS_0402_SC5TVS_0402VR1005PESD5V0S1BLTVS_0402_SC5TVS_0402VR1101DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR1102DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR1103NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR1104NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR1201ESDU5V0F1,0.5PTVS_0402_SC5TVS_0402_SC5VR1202ESDU5V0F1,0.5PTVS_0402_SC5TVS_0402_SC5VR1203NC,DTESDBLC5V0LED02TVS_0402_SC5TVS_0402_SC5VR1204PESD5V0S1BLTVS_0402_SC5TVS_0402VR1205PESD5V0S1BLTVS_0402_SC5TVS_0402VR1206PESD5V0S1BLTVS_0402_SC5TVS_0402X602CX3225SB26000Z0FFFA1NX3225DANX3225DAY701TX0395B,26MHzIT2205AEIT2205AEZ600Balun / RFBLN2012090BM5T25BALUN/10P/SMD/BD2012SAW_1
joyce180250 发表于 2014-10-20 15:04
謝謝分享!
bjfxxc 发表于 2014-10-20 15:20
谢谢楼主,好东西。
may 发表于 2014-10-20 16:53
手机PCB这么大?
yuanfengp 发表于 2014-10-20 16:54
謝謝分享!
flying8138 发表于 2014-10-20 17:13
不错,好资料!
372614983 发表于 2014-10-20 17:15
谢谢好资料
allegro 发表于 2014-10-20 17:24
好厉害的板子
fang111 发表于 2014-10-20 17:31
kingmen 发表于 2014-10-20 18:37
画得真牛B!
页: [1] 2 3 4 5 6
查看完整版本: MTK6582 4G智能手机PCB文件
