gaoxiuzhang 发表于 2014-12-2 20:13
SNOD_车载TFT量产PCB+LOGIC
****************以下信息由管理员 @老吴   整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
NamePCB DecalValuePart TypeC1CAP0603104CAPC2CAP121022u/25VCAPC3CAP0603NCCAPC4CAP0603104CAPC5CAP0603104CAPC6CAP0603104CAPC7CAP0603NCCAPC8CAP0603104CAPC9CAP0603104CAPC10CAP0805105/25VCAPC11CAP0603105CAPC12CAP0603105CAPC13CAP0603104CAPC14CAP0603104CAPC15CAP0603104CAPC16CAP0603104CAPC17CAP0603104CAPC18CAP0603104CAPC19CAP0603104CAPC20CAP0603104CAPC21CAP0603104CAPC22CAP0603104CAPC23CAP0603104CAPC24CAP0603104CAPC25CAP0603104CAPC26CAP0603105CAPC27CAP0603333CAPC28CAP0603104CAPC29CAP0603104CAPC30CAP0805106CAPC33CAP0603NCCAPC34CAP0603NCCAPC35CAP0603105CAPC36CAP0603NCCAPC37CAP0603NCCAPC38CAP0603105CAPC39CAP121010u/6.3VCAPC40CAP12104.7uF/16VCAPC41CAP121022u/25VCAPC43C1206B10u/10VECAPC44C1206B10u/10VECAPC72CAP0603104CAPC73CAP0603104CAPC103CAP0805NCCAPCN-1CON30/0.5CON-30P-0.5CN-2CON30/0.5CON-30P-0.5CN1CON40-0.540P P=0.5mmCON40P_O.5CN2FPC4P-1.04P P=1.0CN4P1.0CN3CON40-0.540P P=0.5mmCON40P_O.5CN4CON1.25_8PLJ1.25_8PCN5CON1.25_3PLJ1.25_3PCN6CON1.25_3PLJ1.25_3PCN7CON1.25_8PLJ1.25_8PCN8CON1.25_4PLJ1.25_4PCN9CON1.25_8PLJ1.25_8PCN11CON1.25_4PLJ1.25_4PCN13CON-60-0.5MM60P P=0.5mmCON60P0.5CN15SM02B(3.5)CCFLPWR_CONCCFL_CONCN16CON1.25_8PLJ1.25_8PD1RES0603ESDESDD2RES0603ESDESDD3RES0603ESDESDD8RES0603ESDESDD9RES0603NCESDD10SOD-1061N5819DIODED11RES0603NCESDD12RES0603ESDESDD13SOD-1061N5819DIODED14SOT-23BAV99BAT54SD15RES0603ESDESDD16SOT-23BAV99BAT54SD17RES0603ESDESDD18RES0603ESDESDD20RES0603ESDESDD22LED-0805LEDLED3D23LED-0805LEDLED3D24LED-0805LEDLED3D25LED-0805LEDLED3D26LED-0805LEDLED3D28LED-0805LEDLED3D29LED-0805LEDLED3D30LED-0805LEDLED3D31LED-0805LEDLED3D32LED-0805LEDLED3EC1ECAP-SMD-5.0100u/6.3VCAPEEC2ECAP-SMD-5.0NCCAPEEC3ECAP-SMD-5.047uF/16VCAPEEC4ECAP-SMD-4.010u/16VCAPEEC5ECAP-SMD-5.047u/6.3VCAPEEC6ECAP-SMD-5.047u/6.3VCAPEEC7ECAP-SMD-4.010u/16VCAPEEC30ECAP-SMD-5.0100u/6.3VCAPEFB1RES0805FB/220RINDFB2RES0805FB/220RINDFB3RES0805FB/220RINDFB10RES0805FB/220RINDJ1HOLE-1JJ2HOLE-1JJ3HOLE-1JJ4HOLE-1JJ5HOLE-1JJ6HOLE-1JJ7HOLE-1JJ8HOLE-1JJ9HOLE-1JJACK1JACKJACK-3PINHEADPHONE--CJL1IND-SMT-CD5422uH/CD54INDL2PL_3D16-C22uH/3D16IND-LL13IND-SMT-CD4310uH/CD43INDMIC1BT-MICMIC-1MINIUSB2MIIUSB-5PINMINIUSB5PINMINIUSB5PINNCSENSORIRM3638REMP1TEST-ATEST-AP2TEST-ATEST-AP3TEST-ATEST-AP4TEST-ATEST-AP5TEST-ATEST-AP6TEST-ATEST-AP7TEST-ATEST-AP8TEST-ATEST-AP9TEST-ATEST-AP10TEST-ATEST-AP11TEST-ATEST-AP12TEST-ATEST-AP13TEST-ATEST-AP14TEST-ATEST-AP15TEST-ATEST-AP16TEST-ATEST-AP17TEST-ATEST-AP18TEST-ATEST-AP19TEST-ATEST-AP20TEST-ATEST-AP21TEST-ATEST-AP22TEST-ATEST-AP23TEST-ATEST-AP24TEST-ATEST-AP25TEST-ATEST-AP26TEST-ATEST-AP27TEST-ATEST-AP28TEST-ATEST-AP29TEST-ATEST-AP30TEST-ATEST-AP31TEST-ATEST-AP32TEST-ATEST-AP33TEST-ATEST-AP34TEST-ATEST-AP35TEST-ATEST-AP36TEST-ATEST-AP37TEST-ATEST-AP38TEST-ATEST-AP39TEST-ATEST-AP40TEST-ATEST-AP41TEST-ATEST-AP42TEST-ATEST-AP43TEST-ATEST-AP44TEST-ATEST-AP45TEST-ATEST-AP46TEST-ATEST-AP47TEST-ATEST-AP48TEST-ATEST-AP49TEST-ATEST-AP50TEST-ATEST-AP51TEST-ATEST-AP52TEST-ATEST-AP53TEST-ATEST-AP54TEST-ATEST-AP55TEST-ATEST-AP56TEST-ATEST-AP57TEST-ATEST-AP58TEST-ATEST-AP59TEST-ATEST-AP60TEST-ATEST-AP61TEST-ATEST-AP62TEST-ATEST-AP63TEST-ATEST-AP64TEST-ATEST-AP65TEST-ATEST-AP66TEST-ATEST-AP67TEST-ATEST-AP68TEST-ATEST-AP69TEST-ATEST-AP70TEST-ATEST-AP71TEST-ATEST-AP72TEST-ATEST-AP73TEST-ATEST-AP74TEST-ATEST-AP75TEST-ATEST-AP76TEST-ATEST-AP77TEST-ATEST-AP78TEST-ATEST-AP79TEST-ATEST-AP80TEST-ATEST-AP81TEST-ATEST-AP82TEST-ATEST-AP83TEST-ATEST-AP84TEST-ATEST-AP85TEST-ATEST-AP86TEST-ATEST-AP87TEST-ATEST-AP88TEST-ATEST-AP89TEST-ATEST-AP90TEST-ATEST-AP91TEST-ATEST-AP92TEST-ATEST-AP93TEST-ATEST-AP94TEST-ATEST-AP97TEST-ATEST-AP100TEST-ATEST-AP101TEST-ATEST-AP102TEST-ATEST-AP103TEST-ATEST-AP104TEST-ATEST-AP105TEST-ATEST-AP108TEST-ATEST-AP109TEST-ATEST-AP110TEST-ATEST-AP111TEST-ATEST-AP112TEST-ATEST-AP113TEST-ATEST-AP114TEST-ATEST-AP115TEST-ATEST-AP116TEST-ATEST-AP117TEST-ATEST-AP118TEST-ATEST-AP119TEST-ATEST-AP120TEST-ATEST-AP121TEST-ATEST-AP122TEST-ATEST-AP123TEST-ATEST-AP124TEST-ATEST-AP126TEST-ATEST-AP127TEST-ATEST-AP128TEST-ATEST-AP129TEST-ATEST-AP130TEST-ATEST-AP131TEST-ATEST-AP132TEST-ATEST-AP133TEST-ATEST-AP135TEST-ATEST-AP136TEST-ATEST-AP137TEST-ATEST-AP138TEST-ATEST-AQ9C945(SOT-23)3904C945R1RES060310KRESR2RES060310KRESR3RES06031KRESR4RES08053RRESR5RES08053RRESR6RES06031KRESR7RES06030RRESR8RES060310KRESR9RES06030RRESR10RES06032K7RESR11RES06030RRESR12RES08050RRESR13RES0603NCRESR14RES06031KRESR15RES08050RRESR16RES08050RRESR17RES06031KRESR18RES06031KRESR19RES06031KRESR20RES06031KRESR21RES06031KRESR22RES06031.8KRESR23RES06031KRESR24RES06031KRESR25RES060368KRESR26RES06031KRESR27RES06031KRESR28RES08050RRESR29R060333RRESR30R060333RRESR31R060333RRESR32R060333RRESR33RES06037.5KRESR36RES06032KRESR37RES060310KRESR38RES060310KRESR39RES060310KRESR40RES06033.9KRESR41RES060324KRESR42RES060347KRESR43RES0603470RRESR44RES060347KRESR45RES0603120RRESR46RES0603130RRESR47RES0603390RRESR48RES0603390RRESR49RES0603150RRESR50RES0603150RRESR51RES060382RRESR52RES060382RRESR53RES0603240RRESR54RES060310KRESR55RES060333RRESR56RES0603100RRESR57RES0603330RRESR58RES0603330RRESR59RES0603130RRESR60RES060310KRESR61RES0603130RRESR62RES060382RRESR63RES0603NCRESR64RES0603240RRESR65RES0603NCRESR66RES0603130RRESR67RES0603130RRESR68RES06035K6RESR69RES06033K3RESR70RES060310KRESR71RES0603NCRESR72RES0603NCRESR73RES060310KRESR76RES060347KRESR77RES060347KRESR78RES060347KRESS2KEY-SMD-6X5BANDKEY-2S3KEY-SMD-6X5OPENKEY-2S4KEY-SMD-6X5-BANDKEY-2S5KEY-SMD-6X5SRC/POWERKEY-2S6KEY-SMD-6X4RESETKEY-2S7KEY-SMD-6X5-MENUKEY-2S8KEY-SMD-6X5GPSKEY-2S9KEY-SMD-6X5DVDKEY-2S10KEY-SMD-6X5-OPENKEY-2S11KEY-SMD-6X5-MUTEKEY-2S12KEY-SMD-6X5MUTEKEY-2S13KEY-SMD-6X5DVDKEY-2S14KEY-SMD-6X5GPSKEY-2S15KEY-SMD-6X5MENUKEY-2SD1SD-AAAAASD(CARD)SD_CARD_AAASD2SD-AAAAASD(CARD)SD_CARD_AAAU6SOT-2231117-3.3V1117U8SOT-23-5-MP1541LP3301MP1541U13SOT23-6LP3302MP3202VR1VOLAENVOL-VOLZD1DIO1206ZD7.5VZ5VZD4DIO1206ZD15VZ5V
为自己带盐 发表于 2014-12-3 08:26
jiangxianjun 发表于 2014-12-3 09:47
你资料真的挺多的!
junkyoung 发表于 2026-7-8 09:20
好好地学习。。。
查看完整版本: SNOD_车载TFT量产PCB+LOGIC
