bennygd11 发表于 2014-12-14 15:09
6410底板PCB,布局走线整洁。
6410底板PCB,布局走线整洁。
****************以下信息由管理员 @老吴   整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
NameValuePCB DecalPart TypeB110uH1206INDUCTOR_0B210uH1206INDUCTOR_0BAT1BATTERY2BATTERYC11nf0603ACAP_NP_0C21nf0603ACAP_NP_0C315pf(NC)0603ACAP_NP_0C410u3216ACAP-AE4C50.1u0603ACAP1206C610u3216ACAP-AE4C70.1u0603ACAP1206C810u3216ACAP-AE4C90.1u0603ACAP1206C100.1u0603ACAP1206C110.1u0603ACAP1206C1210u3216ACAP-AE4C130.1u0603ACAP1206C140.1u0603ACAP1206C150.1u0603ACAP1206C160.1u0603ACAP_0C170.1u0603ACAP1206C1847u3216ACAP-AE4C1947u3216ACAP-AE4C2022pf0603AC_0C21100u3216ACAP-AE4C2210u3216ACAP-AE4C230.1u0603ACAP1206C240.1u0603ACAP1206C2510u3216ACAP-AE4C260.1u0603ACAP1206C2710u3216ACAP-AE4C280.1u0603ACAP_0C330.1u0603ACAP_NP_0C340.1u0603ACAP1206C351u0603ACAP1206C361u0603ACAP1206C371u0603ACAP1206C391u0603ACAP1206C411u0603ACAP1206C421u0603ACAP1206C4447u3216ACAP-AE4C4647u3216ACAP-AE4C48220pf0603ACAP1206C49220pf0603ACAP1206C5010u3216ACAP-AE4C5110u3216ACAP-AE4C520.1u0603ACAP1206C530.1u0603ACAP1206C540.1u0603ACAP1206C5510uF/16V3216ACAPACITOR_POL_0BC560.1u0603ACAP1206C570.1u0603ACAP1206C580.1u0603ACAP_NP_0C591u0603ACAP1206C600.1u0603ACAP1206C611u0603ACAP1206C620.1u0603ACAP1206C630.1u0603ACAP1206C640.1u0603ACAP1206C651u0603ACAP1206C661u0603ACAP1206C670.1u0603ACAP1206C6810u3216ACAP-AE4C6922pf0603AC_0C70100nf0603AC_0C71100u3216ACAP-AE4C7210u3216ACAP-AE4C730.1u0603ACAP1206C740.1u0603ACAP1206C75100nf0603AC_0C76100nf0603AC_0C7710u3216ACAP-AE4C81100nF0603ACAP_0C830.1u0603ACAP1206C840.1u0603ACAP1206C850.1u0603ACAP1206C86100nF0603ACAP_0C90100nF0603ACAP_0C910.1u0603ACAP1206C920.1u0603ACAP_0C940.1u0603ACAP_0C960.1u0603ACAP1206C970.1u0603ACAP1206C980.1uF0603AC_0C990.1uF0603AC_0C1000.1uF0603AC_0C1010.1uF0603AC_0C1020.1uF0603AC_0C1030.1uF0603AC_0C1040.1uF0603AC_0CN1USB-B2USB2.1CN2MULTI_ICEIDC20SMULTI_ICECN3AD01DZQCN4MULTI_ICEIDC20SMULTI_ICECON1FPC40FPC-40ACON2SD CARD SOCKET (SKT SD/MMC Standard Type)SD-CARDSD_CARD_1D1LED1206NAADIODED2LED1206NCDIODED3LED1206NBDIODEDS1DSAAAADS18B20H1HY01HYJ1CON80A_08_DCONN40X2J2CON80A_08_DCONN40X2J3CON80A_08_DCONN40X2J4CON80A_08_DCONN40X2J5SWITCH_ASIP2.0J6PHONE1MIC_SPEAKERJ7PHONE1MIC_SPEAKERJ8IDC20SCON20J9SIP3SCON3J10RJ-45A12HR911105AJ11JACK-2.5MM_BCN1J12IDC20SCON20J13IDC20SCON20J14PHONE1MIC_SPEAKERJ15ZSBZSBJP1IDC20SCAM_EXTENLED1SMD TYPE (GREEN)LEDXLED_0LED2SMD TYPE (GREEN)LEDXLED_0LED3SMD TYPE (GREEN)LEDXLED_0LED4SMD TYPE (GREEN)LEDXLED_0LED6SMD TYPE (GREEN)LEDXALED_0M1HOLE157-8STARMHOLE_GND3M2HOLE157-8STARMHOLE_GND3M3HOLE157-8STARMHOLE_GND3M4HOLE157-8STARMHOLE_GND3M5HOLE157-8STARMHOLE_GND3M6HOLE157-8STARMHOLE_GND3M7HOLE157-8STARMHOLE_GND3M8HOLE157-8STARMHOLE_GND3M9HOLE157-8STARMHOLE_GND3P1DB9-HFRS232_9Q5SOT23TBC328NPNR12k0603ARES-1/4WR220|?0603ARES-1/4WR3330|?0603ARESISTOR_2R4220603ARESISTOR_2R515K0603ARESISTOR_2R615K0603ARESISTOR_2R715K0603ARESISTOR_2R815K0603ARESISTOR_2R915K0603ARESISTOR_2R1015K0603ARESISTOR_2R1115K0603ARESISTOR_2R1215K0603ARESISTOR_2R1300603ARR140805RESISTOR_2R154.7K0603ARESISTOR_2R1600603ARESISTOR_2R174.7K0603ARESISTOR_2R1810K0603ARESISTOR_2R1910K0603ARESISTOR_2R2010K0603ARESISTOR_2R2115K0603ARESISTOR_2R2210K0603ARESISTOR_2R2310K0603ARESISTOR_2R2410K0603ARESISTOR_2R2522R0603ARESISTOR_2R2622R0603ARESISTOR_2R27100K0603AR_0R280R0603AR_0R2910K0603ARESISTOR_2R3010K0603ARESISTOR_2R3110K0603ARESISTOR_2R3210K0603ARESISTOR_2R3310K0603ARESISTOR_2R3400603ARR3500603ARR364.7K0603ARR374.7K0603ARR384.7K0603ARES-ZR3900603ARR404.7K0603ARES-ZR4115K0603ARESISTOR_2R426.8k1%0603AR_0R4350 1%0603AR_0R4450 1%0603AR_0R4550 1%0603AR_0R4650 1%0603AR_0R474.7K0603AR_0R484.7K0603AR_0R494.7K0603ARESISTOR_2R5010K0603ARESISTOR_2R5110K0603ARESISTOR_2R5215K0603ARESISTOR_2R5315K0603ARESISTOR_2R5510K0603ARESISTOR_2R5710K0603ARESISTOR_2R5810K0603ARESISTOR_2R5910K0603ARESISTOR_2R6000603ARR6110K0603ARR6200603ARR63100K0603ARR64220603ARESISTOR_2R65220603ARESISTOR_2R66220603ARESISTOR_2R6722R0603ARESISTOR_2R6847K0603ARR6947K0603ARR7047K0603ARR7100603ARR7215K0603ARESISTOR_2R73680R0603ARR7410K0603ARESISTOR_2R7510K0603ARESISTOR_2R7610K0603ARESISTOR_2R7710K0603ARESISTOR_2R7810K0603ARESISTOR_2R8010K0603ARESISTOR_2R8210K0603ARESISTOR_2R8300603AR_0R8400603AR_0R8500603AR_0R8615K0603ARESISTOR_2R8722R0603ARESISTOR_2R8822R0603ARESISTOR_2R8915K0603ARESISTOR_2R9022R0603AR_0R9110K0603ARESISTOR_2R9210K0603ARESISTOR_2R9310K0603ARESISTOR_2R9410K0603ARESISTOR_2R9510K0603ARESISTOR_2R9622R0603ARESISTOR_2RA210KR-AR4RP4RS1SW_PUSH2PUSHSW1SW_PUSH2S2SW_PUSH2SW-PB2SW_2S3SW_PUSH2SW-PB2SW_2S4SW_PUSH2SW-PB2SW_2S5SW_PUSH2SW-PB2SW_2S6SW_PUSH2SW-PB2SW_2S7SW_PUSH2SW-PB2SW_2SW2SWITCH8SWITCH8TV1BNCTVBBNC_1U1TO-252LLM1117-CT3.3U2QFN48WM9714LGEFLU3TO-252LLM1117-CT1.8U4BELLBELLU5SO16NBMAX202EU6MTP6NJM2561F1U7DM9000AEDM9000AU8XC6218BXC6219B33AMRU9USB\S56579-0576U10TO-252LLM1117-CT3.3U1124.576MHzOSCLCCY7050X125.0MhzOSC2PR-1CRYSTALA
yfchen1003 发表于 2014-12-14 15:47
谢谢
joyce180250 发表于 2014-12-15 09:40
看看,学习学习
为自己带盐 发表于 2014-12-15 17:10
新复活 发表于 2014-12-16 15:49
好漂亮呵呵呵
jxhuanglj 发表于 2014-12-16 20:13
看看,学习学习
ytian668 发表于 2014-12-17 15:36
看看,
breadrumb 发表于 2014-12-17 16:49
底板PCB
望卿舒眉 发表于 2014-12-18 15:42
看看,学习学习
早日成才 发表于 2014-12-18 17:35
红东西谢谢分享!!!
页: [1] 2 3
查看完整版本: 6410底板PCB,布局走线整洁。
