EVK PCB
射频方面的PCB板****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
NameValuePCB DecalPart TypeB1PWR_JACKPW_JACKPW_CONB2Banana RedCON1CON1B3Banana BlackCON1CON1C10.1uFC0603CAP_NPC20.1uFC0603CAP_NPC322pFC0603CAP_NPC422pFC0603CAP_NPC50.1uFC0603CAP_NPC60.1uFC0603CAP_NPC70.01uFC0603CAP_NPC80.1uFC0603CAP_NPC918pFC0603CAP_NPC1018pFC0603CAP_NPC110.1uFC0603CAP_NPC120.1uFC0603CAP_NPC13470uF/10VCC_D63CC141nFC0603CAP_NPC160.1uFC0603CAP_NPC17470uF/10VCC_D63CC18470uF/10VCC_D63CC191uF805CAP_NPC2047nFC0603CAP_NPC210.1uFC0603CAP_NPC22100uF/35VCC_D63CC230.1uFC0603CAP_NPC242.2uF805CAP_NPC250.1uFC0603CAP_NPC260.1uFC0603CAP_NPC270.1uFC0603CAP_NPC280.1uFC0603CAP_NPC290.1uFC0603CAP_NPC300.1uFC0603CAP_NPC311nFC0603CAP_NPC320.1uFC0603CAP_NPC331nFC0603CAP_NPC340.1uFC0603CAP_NPC351nFC0603CAP_NPC361nFC0603CAP_NPC38100uF/16VCC_D5CC390.1uFC0603CAP_NPC400.1uFC0603CAP_NPC410.1uFC0603CAP_NPC420.1uFC0603CAP_NPC430.1uFC0603CAP_NPC440.1uFC0603CAP_NPC450.1uFC0603CAP_NPC460.1uFC0603CAP_NPC470.1uFC0603CAP_NPC480.1uFC0603CAP_NPC490.1uFC0603CAP_NPC500.1uFC0603CAP_NPC510.1uFC0603CAP_NPC52100uF/25VCC_D5CC53100uF/25VCC_D5CC54100uF/25VCC_D5CC554.7uF805CAP_NPC562.2uF805CAP_NPC57100uF/25VCC_D5CC580.01uFC0603CAP_NPC590.1uFC0603CAP_NPC602.2uF805CAP_NPC610.1uFC0603CAP_NPC620.01uFC0603CAP_NPC632.2uF805CAP_NPC640.01uFC0603CAP_NPC650.01uFC0603CAP_NPC660.1uFC0603CAP_NPC670.1uFC0603CAP_NPC69100uF/16VCC_D5CC700.01uFC0603CAP_NPC710.22uFC0603CAP_NPC730.22uFC0603CAP_NPC740.01uFC0603CAP_NPC750.1uFC0603CAP_NPC762.2uF805CAP_NPC780.1uFC0603CAP_NPC79100uF/16VCC_D5CC800.1uFC0603CAP_NPC811uF805CAP_NPC82100uF/35VCC_D63CC830.1uFC0603CAP_NPC8422nFC0603CAP_NPC852.2uF805CAP_NPC860.1uFC0603CAP_NPC870.01uFC0603CAP_NPC880.22uFC0603CAP_NPC902.2uF805CAP_NPC1250.01uFC0603CAP_NPC1260.01uFC0603CAP_NPC1310.1uFC0603CAP_NPC2060.01uFC0603CAP_NPC20710uF/25V1206CAP_NPC2080.1uFC0603CAP_NPC2093.3nFC0603CAP_NPC21022uF/10V1210CAP_NPC211470uF/10VCC_D63CD2805LEDD3SA9.0ASA8BZX83C16D7805LEDD8B140HWSOD-123DIO-MLL41D9805LEDD11805LEDD12SMDJ20ASMC1ADIO-MLL41D13B140HWSOD-123DIO-MLL41D14805LEDD15B340ASOD-123DIO-MLL41GND1IPC1TESTGND2IPC1POSTGND3IPC1POSTGND4IPC1POSTI2CCON10AIDC10CON10AINPADTESTIPPADTESTJ1Reset_SwitchP4-THRESETJ3DHS_4SW_DILJ8CON32IDC32CON32A_0J20DB25_FEMALEDB25L1N1608ZEP800T15603INDUCTOR1L2N1608ZEP800T15603INDUCTOR1L4N1608ZEP800T15603INDUCTOR1L533uHL_D8INDUCTOR1L7N1608ZEP800T15603INDUCTOR1L9N1608ZEP800T15603INDUCTOR1L12100uHL_D8INDUCTOR1L13N1608ZEP800T15603INDUCTOR1L14N1608ZEP800T15603INDUCTOR1L15N1608ZEP800T15603INDUCTOR1L19N1608ZEP800T15603INDUCTOR1L2010uHPWRINDINDUCTOR1Q3SOT23_R2N7002Q4SOT23_R2N7002QNPADTESTQPPADTESTR14.7K603RES-WR1R2180R603RES-WR1R32.7k603RES-WR1R42.7k603RES-WR1R510K603RES-WR1R60R603RES-WR1R7470R603RES-WR1R80R603RES-WR1R92.7K603RES-WR1R102.7K603RES-WR1R111K603RES-WR1R121K603RES-WR1R1310K603R0603R1430.1K 1%603RES-WR1R1552.3K 1%603RES-WR1R1610K603RES-WR1R1730.1K 1%603RES-WR1R1852.3K 1%603RES-WR1R1910K603RES-WR1R202.2K603RES-WR1R210.1R1206RES-WR1R220.1R1206RES-WR1R2310K/1%603RES-WR1R2444.2K/1%603RES-WR1R25NC1206RES-WR1R260R603RES-WR1R2710K603RES-WR1R285.58K603RES-WR1R2910K603RES-WR1R3010K603RES-WR1R3110K603RES-WR1R320R1206RES-WR1R3310K/NC603RES-WR1R340R603RES-WR1R350.1R1206RES-WR1R360R603RES-WR1R3710K603R0603R3810K/NC603R0603R3910K603R0603R400.1R1206RES-WR1R4133R603RES-WR1R4233R603RES-WR1R4333R603RES-WR1R44100R603R0603R45100K603RES-WR1R4633R603RES-WR1R47100K603RES-WR1R4810K603RES-WR1R49100R603R0603R5030K603RES-WR1R512.4M603RES-WR1R520R603RES-WR1R530R603RES-WR1R611K603RES-WR1R6410K603RES-WR1R6510K603RES-WR1R6610K603RES-WR1R6710K603RES-WR1R6810K603RES-WR1R6910K603RES-WR1R741K603RES-WR1R190300R603RES-WR1R1921.2K603RES-WR1S1SWTICHSWU1LQFP64AVL6211U2TPS73701DCQSOT223-6TPS73701DCQU3SO-8MAX931U4QFN20A8293_QFN20U5TPS73701DCQSOT223-6TPS73701DCQU6TPS73701DCQSOT223-6TPS73701DCQU7TPS73701DCQSOT223-6TPS73701DCQU8BS2S7HZ7306ABS2S7HZ7306AU16MP1482MP1842AS5422U21NS-M16ADS90C031TM1U22NS-M16ADS90C031TM1U23NS-M16ADS90C031TM1V1MOUNT_HOLEHIC-EDDIEMOUNT_HOLEV2MOUNT_HOLEHIC-EDDIEMOUNT_HOLEV5MOUNT_HOLEHIC-EDDIEMOUNT_HOLEV6MOUNT_HOLEHIC-EDDIEMOUNT_HOLEY410MHzCRYSTALXTAL1 这是哪产品的图 谢谢分享 看看 看看 好好地学习。。。
