ADI518板子
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
本主题需向作者支付 10 枚金币 才能浏览 购买主题
谢谢分享
谢谢分享
谢谢分享
谢谢分享
谢谢楼主分享!
谢谢楼主分享
谢谢分享b
| Name | PCB Decal | Part Type |
| CT1 | CAP002 | CAP_POLARIZED |
| CT2 | CAP002 | CAP_POLARIZED |
| CT3 | D2E | CAP_POLARIZED |
| CT4 | D2E | CAP_POLARIZED |
| CT5 | B | CAP_POLARIZED |
| CT6 | D2E | CAP_POLARIZED |
| D1 | DIO005 | DIO_MA3X717E |
| D2 | SOD-123FL | DIO_SCHOTTKY |
| D3 | SOD-123FL | DIO_SCHOTTKY |
| D4 | SOD-123FL | DIO_SCHOTTKY |
| D5 | SOD-123FL | DIO_SCHOTTKY |
| D7 | SMC | DIO_SCHOTTKY |
| D8 | SMC | DIO_SCHOTTKY |
| D9 | SOD-123FL | DIO_SCHOTTKY |
| D10 | SOD-123FL | DIO_SCHOTTKY |
| D11 | SOD-523 | DIO_ESD |
| D12 | SOD-523 | DIO_ESD |
| D13 | SOD-523 | DIO_ESD |
| D14 | SOT23-3 | DIO_ESD_3 |
| D15 | SOT23-3 | DIO_ESD_3 |
| D16 | DO-214AA | DIO_SCHOTTKY |
| D17 | DO-214AA | DIO_SCHOTTKY |
| D18 | DO-214AA | DIO_SCHOTTKY |
| F1 | FUS004 | FUS_STANDARD |
| J1 | QMS52X2_SMT | CON_NGEI_HS_KIT |
| J2 | CON038 | CON_DB9 |
| J3 | CON045 | CON_POWER_MINI |
| J4 | CON050 | CON_STEREOJACK_DUAL |
| J5 | CON050 | CON_STEREOJACK_DUAL |
| J12 | BATT_COIN16MM | BATTHOLDER |
| J13 | CON051 | CON_SD |
| J14 | CON065 | CON_RJ45_MAG_LEDS |
| J15 | CON036 | CON_MII |
| JP3 | IDC2X1 | CON_JP_2X1 |
| JP14 | IDC2X1 | CON_JP_2X1 |
| JP15 | IDC3X1 | CON_JP_3X1 |
| JP16 | IDC2X1_SMT | CON_JP_2X1 |
| JP17 | IDC2X1 | CON_JP_2X1 |
| JP18 | IDC2X1 | CON_JP_2X1 |
| L1 | IND018 | IND_STANDARD |
| L2 | IND019 | IND_STANDARD |
| L3 | IND013 | IND_STANDARD |
| L6 | IND019 | IND_STANDARD |
| L7 | IND019 | IND_STANDARD |
| L8 | IND024 | IND_COUPLED |
| L9 | IND024 | IND_COUPLED |
| LED1 | LED001 | LED_STANDARD |
| LED2 | LED001 | LED_STANDARD |
| LED3 | LED001 | LED_STANDARD |
| LED9 | LED001 | LED_STANDARD |
| LED13 | LED001 | LED_STANDARD |
| LED14 | LED001 | LED_STANDARD |
| P1 | IDC7X2_SMTA | CON_7X2 |
| P2 | IDC25X2_SMTA | CON_NGEI_LS_KIT |
| P3 | IDC35X2_SMTA | CON_NGEI_PPI_KIT |
| P4 | IDC25X2_SMTA | CON_NGEI_LS_KIT |
| P5 | DMAX_ALT | CON_DMAX |
| P6 | DMAX_ALT | CON_DMAX |
| P7 | DMAX_ALT | CON_DMAX |
| P8 | IDC2X1 | CON_2X1 |
| P9 | IDC2X1 | CON_2X1 |
| P10 | IDC2X1 | CON_2X1 |
| P11 | IDC2X1 | CON_2X1 |
| P12 | IDC12X2 | CON_12X2 |
| P13 | IDC18X2_M_SMT | CON_18X2 |
| RN21 | RNS005 | RNET_4SERIES |
| SJ1 | NONE | MSC_SHORT_JUMPER |
| SJ3 | NONE | MSC_SHORT_JUMPER |
| SJ4 | NONE | MSC_SHORT_JUMPER |
| SJ5 | NONE | MSC_SHORT_JUMPER |
| SJ6 | NONE | MSC_SHORT_JUMPER |
| SJ7 | NONE | MSC_SHORT_JUMPER |
| SJ8 | NONE | MSC_SHORT_JUMPER |
| SJ9 | NONE | MSC_SHORT_JUMPER |
| SW1 | SWT027 | SW_ROTARY_3 |
| SW2 | SWT020 | SW_DIP2 |
| SW3 | SWT018 | SW_DIP4 |
| SW4 | SWT017 | SW_DIP6 |
| SW5 | SWT017 | SW_DIP6 |
| SW10 | SWT018 | SW_DIP4 |
| SW11 | SWT024 | SW_MOM_PB |
| SW12 | SWT024 | SW_MOM_PB |
| SW13 | SWT024 | SW_MOM_PB |
| SW14 | SWT025 | SW_ROTARY_EDGE |
| SW15 | SWT016 | SW_DIP8 |
| SW19 | SWT018 | SW_DIP4 |
| SW20 | SWT016 | SW_DIP8 |
| SW21 | SWT020 | SW_DIP2 |
| SW22 | SWT017 | SW_DIP6 |
| SW23 | SWT017 | SW_DIP6 |
| U1 | ICS009 | ICS_SSM2603 |
| U2 | LFCSP32 | ICS_AD7266 |
| U3 | OSC008 | OSC_CRYSTAL_SMT |
| U5 | TFBGA63_80 | PRG_M29W320DB |
| U6 | SOIC14 | ICS_SN74XXX14 |
| U7 | MSOP10 | ICS_AD5258 |
| U8 | SO-8 | ICS_NDS8434A |
| U9 | SO8W | PRG_M25P80 |
| U10 | SSOP20 | ICS_SN74XXX244 |
| U11 | SOT23-3 | ICS_ADR550 |
| U12 | LQFP176_SOCKET | DSP_ADSPBF518F |
| U13 | SOT23-5 | ICS_SN74XXX1G00_1P8V |
| U14 | TSOP54 | ICS_MT48LC32M16A2 |
| U16 | FBGA169 | ICS_MTFC2GDKDM |
| U19 | OSC003 | OSC_SMT_OE_POWER |
| U20 | OSC003 | OSC_SMT_OE_POWER |
| U21 | SOIC16 | ICS_ADM232AARN |
| U22 | SOIC8 | ICS_ADM708AR |
| U23 | SOT23-5 | ICS_SN74XXX1G08 |
| U24 | SOT23-5 | ICS_SN74XXX1G08 |
| U25 | SOT23-5 | ICS_SN74XXX1G08 |
| U26 | SOT23-5 | ICS_SN74XXX1G08 |
| U29 | MSOP8 | ICS_OPAMP |
| U30 | MSOP8 | ICS_OPAMP |
| U31 | MSOP8 | ICS_OPAMP |
| U32 | MSOP8 | ICS_OPAMP |
| U33 | MSOP8 | ICS_OPAMP |
| U34 | MSOP8 | ICS_OPAMP |
| U35 | LQFP48 | ICS_DP83848 |
| VR1 | SOT23-6 | ICS_ADP1864 |
| VR2 | MSOP8 | ICS_ADP1611 |
| VR3 | TSOT5 | ICS_ADP1710 |
| VR4 | MSOP8 | ICS_ADP1715_FIXED |
| VR5 | MSOP8 | ICS_ADP1715 |
| VR6 | MSOP8 | ICS_ADP1611 |
| W2 | 4A | MSC_COPPER |
| ZH7 | MSC004AA | MSC_MOUNTING_HOLE |
| ZH8 | MSC004AA | MSC_MOUNTING_HOLE |
| ZH10 | MSC004AA | MSC_MOUNTING_HOLE |
| ZH11 | MSC004AA | MSC_MOUNTING_HOLE |
| ZP1 | IDC7X2_SMTA | CON_7X2 |
| ZU1 | TSOC6 | PRG_DA |
| ZW1 | PIPE_3_8 | MSC_GLUE_DAM |
