老吴 发表于 2015-8-1 20:37
MTK全模4G芯片 MT6735 智能手机 PCB文件和原理图整套方案资料
MTK全模4G芯片 MT6735 智能手机 PCB文件和原理图整套方案资料共享
PCB文件 和原理图整套资料共享
回复可见下载
**** Hidden Message *****
****************以下信息由管理员 @老吴   整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name      Part Type      PCB Decal      Value
ANT3601      ANTENNA_11      PAD/1P/1X2.3      92138100010F
ANT5003      ANTENNA_11      ANTPVT1024      SPR / PVT1024
ANT5101      ANTENNA      PAD/1P/R2.2      ANT / N124M1
CON2101      BATCON/4P_3      KBC23S3D4XR/KEIRAKU      KBC13S3A2R
CON3301      MM8130-2600      MM8130-2602         MM8130-2600
CON3601      TP-RF005      TA-RF02-001-03-811      TA-RF02
CON5001      TST_PORT_0      MM8430-2600B         MM8430-2610
CON6001      KJA1339C01R_0      EJ-3699M-GP      EJ-3699M-GP
CON6101      AXE510127      CON5X2/F/AXE510127      CON / AXE510127
CON6102      TMP_0      /24-5804-030-000-829      24-5804
CON6201      CSI-4L/24-5804      SMD/CM9156-B1300BA-E      24-5804
CON6202      30P/Q5V22      SMD/Q5V22K-0JG         AXT530124
CON6301      FH34SRJ-6S-0.5SH      /FH34S-06S-0.5SH      FH34SRJ-6S
CON6401      MINI_10PIN_3      R/KIU90511S1R         KIU90511S1R
CON6501      CON/SIM/SCGD1B0206      SCGD1B0307      SCGD1B0307
CON6601      SM02B-SURS-TF      SM02B-SURS-TF/SUR         SM02B-SURS-TF
CON9001      20X2/AXT640124      CON20X2//AXT640124         AXT640124
D2103      D_/_MMSZ5231BT1G      DIODE/SMD/MMSZ5221B      D / MMSZ5231BT1G
D2301      D_/_RB160M-60__0      RB160M-30-EVB      D / PMEG6010CEH
DIPX3801      FI-212P0829G2-T      FI212P0829G2      FI-212P0829G2-T
DPX3802      SAYFH836MCC0F0A      SAW/8P/SAY/MURATA      SAYFH836MCC0F0A
ESD6006      ES_15PF      ESD/SMD/ESD5311N      ESD / ESD5311NKM
F5001      BL1608-05K2450_0      LFD211G57ME3      TPX205950MT-7110A1
L6002      BEAD      BEAD0603      L / LQW18ANR10G00
LED2302      LED_4      FLASH_LED/LUW_F8DN      LED / LUW F8DN
LPF3801      LPF_/_FI-168L083523-T      FI-168L083523-T      FI-168L083523
PA3901      PA_/_SKY77765      SKY77765      PA / SKY77765
PL2303      INDUCTOR      L/CHOKE/LQH3NP      LQH3NPN220MJ0L
PL2305      MDMK2020T1R0MM_SMD2520      L/IND/SMD/2520      VLS252010HBX-1R0M
PL3901      PL_/_LQM21PNR54MG0      /LQM21PNR54MG0      PL / LQM21PNR54MG0
SPK6001      MIC      /2403-260-00071      DMSP1115KJ-10-F1-G
TP5101      T_POINT_F      TP/SMD/12MIL      TP / 30 / mil
TP5102      T_POINT_F      TP/SMD/12MIL      TP / 30 / mil
U1001      MT6735-MAP0827      MT6735/VFBGA641      MT6735-LP3-MAP0827
U2001      IC/MT6328-E1/XXXMM_0      MT6328/TMP/SMD      U / MT6328E1
U2106      FDG6303_2      SOT-6      STT818B / SOT-6
U2116      MOSFET_N_2      2-1L1B/SSM3K35MFV      Q / SSM3K35MFV
U2301      IC/LED-DRV/LM3642      DSBGA9/LM3642      U / LM3642
U2305      APL5151_6      SON6/TPS61161      U / TPS61161
U2401      XC6227-USP-6C_1      WDFN8/NCP6324         NCP6324CMTAATBG
U3101      60118A_22      MT6169/VFBGA175      U / MT6169
U3102      KT2520F26000DCW28QAK      TCXO/KT2520F      KT2520F26000DCW28QAK
U3203      PA_/_SKY77590_9      SKY77643      SKY77643/RF5410
U3210      LF1608-B2R5KCB      BALUN/HHM22112A2      LF1608-B2R5KCB
U3215      SAW_3      FILTER/SMD/885049      SAFEA2G35MF0F0A
U3216      DEA102700LT-6307_0      LFB212G49CG7D755      LF2012-L1R4NAA
U3224      SAW_3      FILTER/SMD/885049      SAFEA2G60MA0F0A
U3301      SAYFH1G74BA0B0A_0      SAYEY710MBA0F0A      SAYEY1G88BA0B0A
U3302      SPDT_/_BGS12SL6_2      RF1628      SPDT / RF1628A
U3303      SAYFH1G74BA0B0A_0      DUPLEXER      DPX / AJ50A
U3304      SPDT_/_BGS12SL6_2      RF1628      SPDT / RF1628A
U3305      SAWFD1G90BH0F0A_0      SAWFD1G90BH0F0A      SAWFD1G90BK0F0A
U3306      SAW-DPX-RX-BAL_1      SAYEY710MBA0F0A      SAYEY1G95HA0F0A
U3307      ASM_/_SKY13492_7      SKY77910      SKY77916/RF5216
U3308      SAW-DPX-RX-BAL_1      SAYEY710MBA0F0A      SAYEY2G53CA0F0A
U3309      DPX_/_B8627_0      DUPLEXERSAYEY710MBA0      SAYEY1G74BC0B0A
U3314      SAW-DPX-RX-BAL_1      DUPLEXER/SAYEY710      SAYEY897MCA0B0A
U3320      DPDT_/_RF1643A_0      SKY13396      DPDT/SKY13396
U3323      TDK-BALUN_0      TFSZ06052460-3310A2      TFSZ06052460-3310A2
U3324      TFSZ06051897-3317A1      TFSZ06051897-3317A1      TFSZ06051897-3317A1
U3325      TDK-BALUN_0      TFSZ06052460-3310A2      TFSZ06050775-3338A1
U3401      XM0860SH-DL0601_0      SKY13418      SKY13418
U3402      SPDT_/_BGS12SL6_2      RF1628      SPDT / RF1628A
U3404      SPDT_/_BGS12SL6_2      RF1628      SPDT / RF1628A
U3405      SAW_0      SAFFB1G90FB0F0A      SAW / EPCOS_AG07D
U3406      SAW_0_3      SAFFB1G90FB0F0A      SAFFB1G84FL0F0A
U3407      SAW_0_3      SAFFB1G90FB0F0A      SAFFB1G90FB0F0A
U3408      SAW_0_3      F6QB2G595P2BS      SAW / B9898
U3409      TFSZ06051897-3317A1      TFSZ06052460-3310A2      TFSZ06052460-3310A2
U3410      SAW_0      F6QB2G595P2BS      SAW / F6QG2G140P2KA
U3411      SAW_0_2      SAFFB1G90FB0F0A      SAFFB773MAA0F0A
U3412      SAW_0      F5QB2G595P2BS      SAW / F5QG942M5P2KB
U3413      SAW_0_2      SAFFB1G90FB0F0A      SAFFB788MAA0F0A
U3415      TFSZ06051897-3317A1      TFSZ06052460-3310A2      TFSZ06050775-3338A1
U3418      SAW_0_3      F6QB2G595P2BS      SAFFB2G60AA1F0A
U3701      MT6158      MT6158/VFBGA91      MT6158
U3801      ASM_/_CXM3599UR      UQFN20//CXM3599UR      ASM / CXM3599UR
U3901      U_/_LM3242      DSBGA9/LM3242      U / LM3242
U4102      LP_DDR2(JEDEC_162B)_0      FBGA221/SAMSUNG      H9TP32A4GDCCPR-KGMx
U5001      MT6611_SMD_WLCSP-61_0      MT6625/SQFN40      U / MT6625L / QFN40
U5002      TCXO_RAKON_SMD_4P      TCXO/IT2205BE      TCXO/ IT2205AE
U5003      SAFEB1G57KA0F00      SAW/SMD/1.05X1.35      GNSS SAW / B8313
U5004      NJG1107HB3_0      TSLP6/BGA725L6/S      U / BGA725L6
U5005      SAFEB1G57KA0F00      FILTER/ACPF-7124      FBAR / ACPF-7124
U5101      MT3301-140      MT6605/MQFN32      U / MT6605E3
U6301      IC/MANG/AK8963C_0      WLCSP8/AK09911      U / AK09911
U6302      /MPU-6050C_0      QFN16/ITG-1010      U / ITG-1010
U6303      R1172X_0      LGA12/MC3410      U / MC3410
X2001      CRYSTAL_2      9H032000XX/TXC         CM7V-T1A
X3701      7M26000028      TCXO3225      7M26000028
X5101      QUARTZ_IQX0_1      CRYS/SMD/FA-128         FA-128
mcunewman 发表于 2015-8-1 21:09
老大的资料一如既往地给力啊
267101126 发表于 2015-8-1 21:12
lxy200 发表于 2015-8-1 21:12
老吴 发表于 2015-8-1 21:24
回 mcunewman 的帖子
mcunewman:老大的资料一如既往地给力啊 (2015-08-01 21:09)嬀/color]images/back.gif
一如既往的 高大上。
ycy 发表于 2015-8-1 22:19
高级的东西啊~
boarmy 发表于 2015-8-1 23:00
,GOOG
kaisaier 发表于 2015-8-1 23:07
那就回家
hueylee 发表于 2015-8-1 23:18
赞,很新鲜。
chenxhunter 发表于 2015-8-1 23:28
确实好东西~强大
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: MTK全模4G芯片 MT6735 智能手机 PCB文件和原理图整套方案资料
