ucas123 发表于 2015-11-15 14:22
电力系统电压源元件的建模方法,delphi源码
2-17-00Change Log
          Added Angle to VMag calculation
6-18-00Added ability to do specify impedance in ohms or short circuit current
5-17-01 Moved Spectrum to Base class
2-10-09 Converted to 2-terminal voltage source
interface
USES DSSClass, PCClass,PCElement, ucmatrix, ucomplex, Spectrum;
TYPE
   TVsource = CLASS(TPCClass)
   private
       Procedure VsourceSetBus1(const S:String);
   Protected
       Procedure DefineProperties;
       Function MakeLike(Const OtherSource:STring):Integer;Override;
   public
       constructor Create;
       destructor Destroy; override;
       Function Edit:Integer; override;
       Function Init(Handle:Integer):Integer; override;
       Function NewObject(const ObjName:String):Integer; override;
   End;
   TVsourceObj = class(TPCElement)
   private
      MVAsc3 :Double;
      MVAsc1 :Double;
      Isc3   :Double;
      Isc1   :Double;
      ZSpecType :Integer;
      R1, X1:Double;
      R0, X0:Double;
      X1R1    :Double;
      X0R0    :Double;
      ScanType:Integer;
      Procedure GetVterminalForSource;
      public
      Z   :TCmatrix;// Base Frequency Series Z matrix
      Zinv:TCMatrix;
      VMag:Double;
      kVBase      :Double;
      PerUnit   :Double;
      Angle       :Double;
      SrcFrequency:Double;
      constructor Create(ParClass:TDSSClass; const SourceName:String);
      destructorDestroy; override;
      Procedure RecalcElementData; Override;
      Procedure CalcYPrim; Override;
      FunctionInjCurrents:Integer; Override;
      Procedure GetInjCurrents(Curr:pComplexArray); Override;
      Procedure GetCurrents(Curr: pComplexArray);Override;
      PROCEDURE MakePosSequence;Override;// Make a positive Sequence Model
      PROCEDURE InitPropertyValues(ArrayOffset:Integer); Override;
      Procedure DumpProperties(Var F:TextFile; Complete:Boolean); Override;
      FUNCTIONGetPropertyValue(Index:Integer):String;Override;
   End;
VAR
    ActiveVsourceObj:TVsourceObj;
implementation
USESParserDel, Circuit, DSSClassDefs, DSSGlobals, Utilities, Sysutils, Command;
Const NumPropsThisClass = 18;
constructor TVsource.Create;// Creates superstructure for all Line objects
Begin
   Inherited Create;
   Class_Name   := 'Vsource';
   DSSClassType := SOURCE + NON_PCPD_ELEM;// Don't want this in PC Element List
   ActiveElement := 0;
   DefineProperties;
   CommandList := TCommandList.Create(Slice(PropertyName^, NumProperties));
   CommandList.Abbrev := TRUE;
End;
Destructor TVsource.Destroy;
Begin
    // ElementList andCommandList freed in inherited destroy
    Inherited Destroy;
End;
Procedure TVSource.DefineProperties;
Begin
   Numproperties := NumPropsThisClass;
   CountProperties;   // Get inherited property count
   AllocatePropertyArrays;
   // Define Property names
   PropertyName := 'bus1';
   PropertyName := 'basekv';
   PropertyName := 'pu';
   PropertyName := 'angle';
   PropertyName := 'frequency';
   PropertyName := 'phases';
   PropertyName := 'MVAsc3';
   PropertyName := 'MVAsc1';
   PropertyName := 'x1r1';
   PropertyName := 'x0r0';
   PropertyName := 'Isc3';
   PropertyName := 'Isc1';
   PropertyName := 'R1';
   PropertyName := 'X1';
   PropertyName := 'R0';
   PropertyName := 'X0';
   PropertyName := 'ScanType';
   PropertyName:= 'bus2';
   // define Property help values
   PropertyHelp := 'Name of bus to which the main terminal (1) is connected.'+CRLF+'bus1=busname'+CRLF+'bus1=busname.1.2.3';
   PropertyHelp := 'Base Source kV, usually phase-phase (L-L) unless you are making a positive-sequence model or 1-phase model'+
                        'in which case, it will be phase-neutral (L-N) kV.';
   PropertyHelp := 'Per unit of the base voltage that the source is actually operating at.'+ CRLF +
                        '"pu=1.05"';
   PropertyHelp := 'Phase angle in degrees of first phase: e.g.,Angle=10.3';
   PropertyHelp := 'Source frequency.Defaults to system default base frequency.';
   PropertyHelp := 'Number of phases.Defaults to 3.';
   PropertyHelp := 'MVA Short circuit, 3-phase fault. Default = 2000. ' +
                        'Z1 is determined by squaring the base kv and dividing by this value. '+
                        'For single-phase source, this value is not used.';
   PropertyHelp := 'MVA Short Circuit, 1-phase fault. Default = 2100. ' +
                        'The "single-phase impedance", Zs, is determined by squaring the base kV and dividing by this value. '+
                        'Then Z0 is determined by Z0 = 3Zs - 2Z1.For 1-phase sources, Zs is used directly. ' +
                        'Use X0R0 to define X/R ratio for 1-phase source.';
   PropertyHelp := 'Positive-sequenceX/R ratio. Default = 4.';
   PropertyHelp := 'Zero-sequence X/R ratio.Default = 3.';
   PropertyHelp := 'Alternate method of defining the source impedance. ' + CRLF +
                         '3-phase short circuit current, amps.Default is 10000.';
                         'single-phase short circuit current, amps.Default is 10500.';
                         'Positive-sequence resistance, ohms.Default is 1.65.';
                         'Positive-sequence reactance, ohms.Default is 6.6.';
                         'Zero-sequence resistance, ohms.Default is 1.9.';
                         'Zero-sequence reactance, ohms.Default is 5.7.';
   PropertyHelp := '{pos*| zero | none} Maintain specified sequence for harmonic solution. Default is positive sequence. '+
                         'Otherwise, angle between phases rotates with harmonic.';
   PropertyHelp := 'Name of bus to which 2nd terminal is connected.'+CRLF+'bus2=busname'+CRLF+'bus2=busname.1.2.3' +
                        CRLF + CRLF +
                        'Default is Bus1.0.0.0 (grounded wye connection)';
   ActiveProperty := NumPropsThisClass;
   inherited DefineProperties;// Add defs of inherited properties to bottom of list
   // Override help string
   PropertyHelp := 'Name of harmonic spectrum for this source.Default is "defaultvsource", which is defined when the DSS starts.';
End;
Function TVsource.NewObject(const ObjName:String):Integer;
Begin
    // Make a new voltage source and add it to Vsource class list
    With ActiveCircuit Do
    Begin
      ActiveCktElement := TVsourceObj.Create(Self, ObjName);
      Result := AddObjectToList(ActiveDSSObject);
    End;
End;
procedure TVsource.VsourceSetBus1(const S: String);
Var
   s2:String;
   i, dotpos:Integer;
   // Special handling for Bus 1
   // Set Bus2 = Bus1.0.0.0
BEGIN
   WITH ActiveVSourceObj DO BEGIN
   SetBus(1, S);
   // Default Bus2 to zero node of Bus1. (Grounded-Y connection)
   // Strip node designations from S
   dotpos := Pos('.',S);
   IF dotpos>0 THEN S2 := Copy(S,1,dotpos-1)
               ELSE S2 := Copy(S,1,Length(S));// copy up to Dot
   FOR i := 1 to Fnphases DO S2 := S2 + '.0';   // append series of ".0"'s
   SetBus(2, S2);    // default setting for Bus2
   END;
end;
Function TVsource.Edit:Integer;
VAR
   ParamPointer :Integer;
   ParamName,
   Param      :String;
Begin
// continue parsing with contents of Parser
ActiveVSourceObj            := ElementList.Active;
ActiveCircuit.ActiveCktElement := ActiveVSourceObj;
Result := 0;
WITH ActiveVSourceObj DO Begin
   ParamPointer := 0;
   ParamName := Parser.NextParam;
   Param   := Parser.StrValue;
   WHILE Length(Param) > 0 DO Begin
         IF Length(ParamName) = 0 THEN Inc(ParamPointer)
         ELSE ParamPointer := CommandList.GetCommand(ParamName);
         If (ParamPointer > 0) and (ParamPointer <= NumProperties) Then PropertyValue := Param;
         CASE ParamPointer OF
            0: DoSimpleMsg('Unknown parameter "' + ParamName + '" for Object "VSource.'+Name+'"', 320);
            1: VSourceSetBus1(param);   // special handling of Bus 1
            2: kVBase    := Parser.DblValue; // basekv
            3: PerUnit   := Parser.DblValue; // pu
            4: Angle   := Parser.DblValue; // Ang
            5: SrcFrequency := Parser.DblValue; // freq
            6: Begin
               Nphases   := Parser.Intvalue; // num phases
               NConds    := Fnphases;// Force Reallocation of terminal info
               End;
            7: MVAsc3 := Parser.DblValue; // MVAsc3
            8: MVAsc1 := Parser.DblValue; // MVAsc1
            9: X1R1   := Parser.DblValue; // X1/R1
         10: X0R0   := Parser.DblValue; // X0/R0
         11: Isc3   := Parser.DblValue;
         12: Isc1   := Parser.DblValue;
         13: R1    := Parser.DblValue;
         14: X1    := Parser.DblValue;
         15: R0    := Parser.DblValue;
         16: X0    := Parser.DblValue;
         17:Case Uppercase(Param) of
                  'P': ScanType := 1;
                  'Z': ScanType := 0;
                  'N': ScanType := -1;
                ELSE
                   DoSimpleMsg('Unknown Scan Type for "' + Class_Name +'.'+ Name + '": '+Param, 321);
                END;
         18: SetBus(2, param);
         ELSE
            ClassEdit(ActiveVsourceObj, ParamPointer - NumPropsThisClass)
         End;
         // Set the Z spec type switch depending on which was specified.
             7, 8   :ZSpecType := 1;
             11, 12 :ZSpecType := 2;
             13, 14, 15, 16 : ZSpecType := 3;
         END;
   End;
   RecalcElementData;
   YPrimInvalid := True;
End;
End;
Function TVsource.MakeLike(Const OtherSource:String):Integer;
VAR
   OtherVSource :TVSourceObj;
   i :Integer;
Begin
   Result := 0;
   {See if we can find this line name in the present collection}
   OtherVSource := Find(OtherSource);
   IF OtherVSource<>Nil THEN
   WITH ActiveVsourceObj DO Begin
       IF Fnphases <> OtherVSource.Fnphases THEN Begin
         Nphases := OtherVSource.Fnphases;
         NConds:= Fnphases;// Forces reallocation of terminal stuff
         Yorder := Fnconds * Fnterms;
         IF Z<>nil    THEN Z.Free;
         IF Zinv<>nil THEN Zinv.Free;
         Z    := TCmatrix.CreateMatrix(Fnphases);
         Zinv := TCMatrix.CreateMatrix(Fnphases);
       End;
       Z.CopyFrom(OtherVSource.Z);
       // Zinv.CopyFrom(OtherLine.Zinv);
       VMag      := OtherVsource.Vmag;
       kVBase    := OtherVsource.kVBase;
       PerUnit   := OtherVsource.PerUnit;
       Angle   := OtherVsource.Angle;
       SrcFrequency := OtherVsource.SrcFrequency;
       MVAsc3    := OtherVsource.MVAsc3;
       MVAsc1    := OtherVsource.MVAsc1;
       X1R1      := OtherVsource.X1R1;
       X0R0      := OtherVsource.X0R0;
       ClassMakeLike(OtherVSource);
       For i := 1 to ParentClass.NumProperties Do FPropertyValue := OtherVsource.FPropertyValue;
       Result := 1;
   End
   ELSEDoSimpleMsg('Error in Vsource MakeLike: "' + OtherSource + '" Not Found.', 322);
End;
Function TVsource.Init(Handle:Integer):Integer;
Begin
   DoSimpleMsg('Need to implement TVsource.Init', -1);
   Result := 0;
End;
Constructor TVsourceObj.Create(ParClass:TDSSClass; const SourceName:String);
Begin
   Inherited create(ParClass);
   Name := LowerCase(SourceName);
   DSSObjType := ParClass.DSSClassType; //SOURCE + NON_PCPD_ELEM;// Don't want this in PC Element List
   Nphases:= 3;
   Fnconds:= 3;
   Nterms   := 2;   // Now a 2-terminal device
   Z      := nil;
   Zinv   := nil;
   {Basefrequency := 60.0;} // set in base class
   MVAsc3   := 2000.0;
   MVAsc1   := 2100.0;
   ZSpecType := 1; // default to MVAsc
   R1       := 1.65;
   X1       := 6.6;
   R0       := 1.9;
   X0       := 5.7;
   Isc3   := 10000.0;
   Isc1   := 10540.0;
   kVBase   := 115.0;
   X1R1   := 4.0;
   X0R0   := 3.0;
   PerUnit:= 1.0;
   SrcFrequency := BaseFrequency;
   Angle    := 0.0;
   Scantype := 1;
   Spectrum := 'defaultvsource';
   InitPropertyValues(0);
   Yorder := Fnterms * Fnconds;
   RecalcElementData;
End;
Destructor TVsourceObj.Destroy;
Begin
    Z.Free;
    Zinv.Free;
    Inherited Destroy;
End;
Procedure TVsourceObj.RecalcElementData;
VAR
   Zs,Zm:Complex;
   i,j    :Integer;
   Factor :Double;
   Rs, Xs, Rm, Xm :Double;
Begin
    IF Z    <> nil THEN Z.Free;
    IF Zinv <> nil THEN Zinv.Free;
    // For a Source, nphases = ncond, for now
    If   FNPhases = 1 THEN Factor := 1.0 ELSE Factor := SQRT3;
    Rs := 0.0;
    Rm := 0.0;
    Xs := 0.1;
    Xm := 0.0;
    {Calculate the short circuit impedance and make all other spec types agree}
    CASE ZSpecType OF
      1:Begin// MVAsc
            X1   := Sqr(KvBase) / MVAsc3/Sqrt(1.0 + 1.0/Sqr(X1R1));
            Xs   := Sqr(KvBase) / MVAsc1/Sqrt(1.0 + 1.0/Sqr(X0R0)); // Approx
            R1   := X1 / X1R1;
            Xm   := Xs - X1;
            X0   := (Xs + 2.0 * Xm);
            R0   := X0 / X0R0;
            Isc3 := MVAsc3 * 1000.0 /(SQRT3 * kVBase);
            Isc1 := MVAsc1 * 1000.0 /(Factor * kVBase);
            IF Fnphases = 1 THENRs := Xs / X0R0
                            ELSERs := (2.0 * R1 + R0) / 3.0;
            Rm   := (R0 - R1) / 3.0;
          End;
      2:Begin// Isc
            MVAsc3 := SQRT3 * kVBase * Isc3 / 1000.0;
            MVAsc1 := Factor * kVBase * Isc1 / 1000.0;
            X1   := Sqr(KvBase) / MVAsc3 /Sqrt(1.0 + 1.0/Sqr(X1R1));
            Xs   := Sqr(KvBase) / MVAsc1 /Sqrt(1.0 + 1.0/Sqr(X0R0)); //Approx
            R1   := X1 / X1R1;
            Xm   := Xs - X1;
            R0   := X0 / X0R0;
          End;
      3:Begin// Z1, Z0    Specified
            Isc3 := kVBase *1000.0 / SQRT3 /Cabs(cmplx(R1, X1));
            If Fnphases=1 Then Begin// Force Z0 to be Z1 so Zs is same as Z1
                R0 := R1;
                X0 := X1;
            End;
            Xs := (2.0 * X1 + X0) / 3.0;
            Isc1   := kVBase *1000.0 / Factor /Cabs(cmplx(Rs, Xs));
            Xm   := Xs - X1;
          End;
    End;
    {Update property Value array}
   { Don't change a specified value; only computed ones}
    Zs := cmplx(Rs, Xs);
    Zm := cmplx(Rm, Xm);
    FOR i := 1 to Fnphases DO Begin
       Z.SetElement(i, i, Zs);
       FOR j := 1 to i-1 DO Begin
         Z.SetElemsym(i, j, Zm);
       End;
    End;
   CASE Fnphases OF
   1: Vmag := kVBase * PerUnit * 1000.0;
   ELSE
      Vmag := kVBase * PerUnit * 1000.0 / 2.0 / Sin((180.0/Fnphases)* PI/180.0);
   End;
   SpectrumObj := SpectrumClass.Find(Spectrum);
   IF SpectrumObj=NIL Then Begin
          DoSimpleMsg('Spectrum Object "' + Spectrum + '" for Device Vsource.'+Name+' Not Found.', 324);
   End;
   Reallocmem(InjCurrent, SizeOf(InjCurrent^)*Yorder);
End;
Procedure TVsourceObj.CalcYPrim;
Var
   Value :Complex;
   i, j:Integer;
   FreqMultiplier:Double;
Begin
// Build only YPrim Series
   IF YPrimInvalid THEN Begin
       IF YPrim_Series <> nil Then YPrim_Series.Free;
       YPrim_Series := TcMatrix.CreateMatrix(Yorder);
       IF YPrim <> nil Then YPrim.Free;
       YPrim := TcMatrix.CreateMatrix(Yorder);
   End
   ELSE Begin
          YPrim_Series.Clear;
          YPrim.Clear;
   End;
   FYprimFreq := ActiveCircuit.Solution.Frequency;
   FreqMultiplier := FYprimFreq / BaseFrequency;
   { Put in Series RL Adjusted for frequency }
   For i := 1 to Fnphases Do Begin
         For j := 1 to Fnphases Do Begin
         Value    := Z.GetElement(i, j);
         Value.im := Value.im * FreqMultiplier;{Modify from base freq}
         Zinv.SetElement(i, j, value);
         End;
   End;
   Zinv.Invert;{Invert in place}
   If Zinv.InvertError>0 Then
      Begin       {If error, put in Large series conductance}
      DoErrorMsg('TVsourceObj.CalcYPrim', 'Matrix Inversion Error for Vsource "' + Name + '"',
                   'Invalid impedance specified. Replaced with small resistance.', 325);
      Zinv.Clear;
      For i := 1 to Fnphases Do Zinv.SetElement(i, i, Cmplx(1.0/EPSILON, 0.0));
      End;
   // YPrim_Series.CopyFrom(Zinv);
   For i := 1 to FNPhases do Begin
       For j := 1 to FNPhases do Begin
          Value := Zinv.GetElement(i, j);
          YPrim_series.SetElement(i, j, Value);
          YPrim_series.SetElement(i + FNPhases, j + FNPhases, Value);
          YPrim_series.SetElemsym(i + FNPhases, j, CNegate(Value))
       End;
   End;
   YPrim.CopyFrom(YPrim_Series);
   {Now Account for Open Conductors}
   {For any conductor that is open, zero out row and column}
   Inherited CalcYPrim;
   YPrimInvalid := False;
End;
Procedure TVsourceObj.GetVterminalForSource;
Var
   i   :Integer;
   Vharm :Complex;
   SrcHarmonic :Double;
Begin
TRY
{This formulation will theoretically handle voltage sources of any number of phases assuming they are
   equally displaced in time.}
       CASE Fnphases OF
         1:Vmag := kVBase * PerUnit * 1000.0;
         ELSE
         Vmag := kVBase * PerUnit * 1000.0/2.0/Sin((180.0/Fnphases)*PI/180.0);
       End;
      WITH ActiveCircuit.Solution Do
       IF IsHarmonicModel THEN Begin
            SrcHarmonic :=Frequency/SrcFrequency;
            Vharm := CMulReal(SpectrumObj.GetMult(SrcHarmonic), Vmag);// Base voltage for this harmonic
            RotatePhasorDeg(Vharm, SrcHarmonic, Angle);// Rotate for phase 1 shift
            FOR i := 1 to Fnphases Do Begin
            Vterminal^ :=Vharm;
            VTerminal^ := CZERO;
            If (i < Fnphases) Then Begin
               CASE ScanType of
                  1: RotatePhasorDeg(Vharm, 1.0, -360.0/Fnphases); // maintain pos seq
                  0: ;// Do nothing for Zero Sequence; All the same
                  Else
                     RotatePhasorDeg(Vharm, SrcHarmonic, -360.0/Fnphases); // normal rotation
                  END;
            End;
            End;
       End ELSE Begin
         Ifabs(Frequency - SrcFrequency) > EPSILON2 ThenVmag:=0.0;// Solution Frequency and Source Frequency don't match!
   {NOTE: RE-uses VTerminal space}
            CASE ScanType of
                  0: Vterminal^ :=pdegtocomplex(Vmag, (360.0 + Angle) );   // all the same for zero sequence
               Else
                     Vterminal^ :=pdegtocomplex(Vmag, (360.0 + Angle - (i-1)* 360.0/Fnphases) );
            END;
            VTerminal^ := CZERO;    // See comments in GetInjCurrents
         End;
       End;
EXCEPT
      DoSimpleMsg('Error computing Voltages for Vsource.'+Name+'. Check specification. Aborting.', 326);
      IF In_Redirect Then Redirect_Abort := TRUE;
END;
End;
Function TVsourceObj.InjCurrents:Integer;
Begin
   GetInjCurrents(InjCurrent);
{This is source injection}
   Result := Inherited InjCurrents; // Add into system array
End;
Procedure TVsourceObj.GetCurrents(Curr: pComplexArray);
VAR
   i:Integer;
Begin
TRY
   DO Begin
   //FOR i := 1 TO (Nterms * NConds) DO Vtemp^ := V^];
   // This is safer    12/7/99
       FOR   i := 1 TO Yorder DOVterminal^ := NodeV^];
       YPrim.MVMult(Curr, Vterminal);// Current from Elements in System Y
       GetInjCurrents(ComplexBuffer);// Get present value of inj currents
      // Add Togetherwith yprim currents
       FOR i := 1 TO Yorder DO Curr^ := Csub(Curr^, ComplexBuffer^);
   End;{With}
EXCEPT
    On E: Exception
    Do DoErrorMsg(('GetCurrents for Element: ' + Name + '.'), E.Message,
      'Inadequate storage allotted for circuit element.', 327);
End;
End;
Procedure TVsourceObj.GetInjCurrents(Curr:pComplexArray);
Begin
   { source injection currents given by this formula:
   _   _         _         _
   |Iinj1|         |Vsource|
   |Iinj2|         | 0       |
   _   _         _         _
   GetVterminalForSource;// gets voltage vector above
   ITerminalUpdated := FALSE;
End;
Procedure TVsourceObj.DumpProperties(Var F:TextFile; Complete:Boolean);
VAR
   i,j:Integer;
   c:Complex;
Begin
    Inherited DumpProperties(F,Complete);
    With ParentClass Do
   For i := 1 to NumProperties Do
   Begin
      Writeln(F,'~ ',PropertyName^,'=',PropertyValue);
   End;
    If Complete Then Begin
      Writeln(F);
      Writeln(F,'BaseFrequency=',BaseFrequency:0:1);
      Writeln(F,'VMag=',VMag:0:2);
      Writeln(F,'Z Matrix=');
          FOR j := 1 to i DO Begin
            c := Z.GetElement(i,j);
            Write(F, Format('%.8g +j %.8g ',));
          End;
          Writeln(F);
      End;
    End;
End;
procedure TVsourceObj.InitPropertyValues(ArrayOffset: Integer);
begin
   {PropertyValue Allocated in DSSObject.Create}
   PropertyValue:= GetBus(1);
   PropertyValue:= '115';
   PropertyValue:= '1';
   PropertyValue:= '0';
   PropertyValue:= Format('%d',);
   PropertyValue:= '3';
   PropertyValue:= '2000';
   PropertyValue:= '2100';
   PropertyValue:= '4';
   PropertyValue := '3';
   PropertyValue := '10000';
   PropertyValue := '10500';
   PropertyValue := '1.65';
   PropertyValue := '6.6';
   PropertyValue := '1.9';
   PropertyValue := '5.7';
   PropertyValue := 'Pos';
   PropertyValue:= GetBus(2);
   inheritedInitPropertyValues(NumPropsThisClass);
end;
function TVsourceObj.GetPropertyValue(Index: Integer): String;
begin
      Case Index of
          7 : Result:= Format('%-.5g',);
          8 : Result:= Format('%-.5g',);
          11 : Result := Format('%-.5g',);
          12 : Result := Format('%-.5g',);
          13 : Result := Format('%-.5g',);
          14 : Result := Format('%-.5g',);
          15 : Result := Format('%-.5g',);
          16 : Result := Format('%-.5g',);
      Else
          Result := Inherited GetPropertyValue(Index);
      End;
end;
procedure TVsourceObj.MakePosSequence;
Var
      S:String;
begin
      S :='Phases=1 ';
      S := S + Format('BasekV=%-.5g ', );
      S := S + Format('R1=%-.5g ', );
      S := S + Format('X1=%-.5g ', );
      Parser.CmdString := S;
      Edit;
      inherited;
end;
end.
ahljj 发表于 2015-12-15 09:03
电力系统电压源元件的建模方法
查看完整版本: 电力系统电压源元件的建模方法,delphi源码
