TW8810(TW8811) 液晶电视 PCB+原理图+源码+datasheet共享下载 TW8810B
NamePCB DecalValuePart TypeCN2CON-RCJ-04XRCA JACKRCA_JACK_0CN3CON\MDIN4MINI DIN4SVCON_0CN4CON-RCJ-04XRCA JACKRCA_JACK_0CN5CON-VGA-15PCON-VGA-15PVGA-CON15_1CN6CON-RCJ-04XRCA JACKRCA_JACK_0CN7CON-RCJ-04XRCA JACKRCA_JACK_0CN10CON-DIP-40P-2M-2PPPN202FJFN-RCHEADER20X2_12CN14CON-DIP-40P-2M-2PPPN202FJFN-RCHEADER20X2_12CN15CON-DB9HMDB9 MALECONNECTOR_DB9CN16JACK\PJ-2012V/3ADC_SOCKET_0CN17CON-RCJ-04XRCA JACKRCA_JACK_0CN18CON-SIP-6PHEADER 6HEADER_6D1SOT23BAS70-05BAS70-05D2SOT23BAS70DIODE_0D3SOT23BAS70DIODE_0D8D\SML1206SLED-GLED_0D9D\SML1206SLED-RLED_0D10D\DO-214ABSK33DIODE_SCHOTTKY_0D11D\SML1206SLED-OLED_0D12D\DO-214ABSK33DIODE_SCHOTTKY_0F1L1206FUSE 4AFUSEJ3CON-SIP-2PHEADER 2CON2J4CON-SIP-2PHEADER 2CON2J5CON-SIP-2PHEADER 2CON2J6CON-SIP-5P*HEADER 5CON5J7CON-DIP-4PHEADER 2X2HEADER_2X2J8CON-SIP-2PHEADER 2CON2J9CON-DIP-6PHEADER 3X2HEADER_3X2J11HIF3F-10PA-2.54DSACON10APCON10APJ12CON-SIP-11P*HEADER 11HEADER_11J13CON-SIP-3PIR ReceiverHEADER_3J14CON-SIP-5PHEADER 5HEADER_5J15CON-SIP-12PCON12CON12JP1CON-DIP-40PHEADER 20x2(F)HEADER20X2JP2CON-DIP-30PHEADER 15x2(F)HEADER15X2JP3CON-DIP-30PHEADER 15x2(F)HEADER15X2JP4CON-DIP-40PHEADER 20x2(F)HEADER20X2JP5CON-DIP-30PHEADER 15x2(F)HEADER15X2JP6CON-SIP-2PHEADER 2HEADER_2JP7CON-DIP-10PHEADER 5X2HEADER_5X2JP8CON-DIP-20P*Header10x2HEADER10X2Q3SO8IRF7314MOSFET_P_DUAL_SOQ4SOT232N3904NPNQ5SOT232N3904NPNQ6SOT232N39062N2894_0Q7SOT232N39062N2894_0Q8SOT232N39062N2894_0RP29RN40603RSIP-4 33RSIP-4S1SW\KN11BKN11BSW_PUSHBUTTON_1S2SW\KN11BKN11BSW_PUSHBUTTON_1S3SW\KN11BKN11BSW_PUSHBUTTON_1S4SW\KN11BKN11BSW_PUSHBUTTON_1S5SW\KN11BKN11BSW_PUSHBUTTON_1S6SW\KN11BKN11BSW_PUSHBUTTON_1S7SW\KN11BKN11BSW_PUSHBUTTON_1S8SW\KN11BKN11BSW_PUSHBUTTON_1S9SW\7101MD9AV2BESW SPDTSW_SPDT_0SW1DIP16SW DIP-8SW_DIP-8U1SO8AT24C02AT24C21U2LQFN48TW9910-QFN48TW9910U5PQFP208TW8810TW8810_7U6TSOPII-54PK4S641632DK4S641632D_0U7CQFP100M16C/62P-100P6S-AM16C/62P-100P6S-A_0U8PLCC32-SOCKETAM29F040/LCCAM29F040/LCC_0U9SO16MAX232AMAX232U10SO8AT24C16AT24C02_P_0U11TO-263LM2596S-5.0LM2596U12TO-263LM2596S-3.3LM2596U13TO263-4L7805/TO263LM7805C/TO220_1U14SOT223LT1117CST-3.3LT1117CST-3.3U15SOT223LT1963AEST-1.8LT1117CST-3_1.3U16SOT223LT1963AEST-1.8LT1117CST-3_1.3U17TALN-Z200T-1*TALN-Z200TTALN-Z200TU18SOT223LT1963AEST-1.8LT1117CST-3_1.3Y1XTAL\HC49*27MHzCRYSTALY2XTAL\HC4927MHzCRYSTALY3XTAL\32K*32.768KHzCRYSTALY4XTAL\HC4912MHzCRYSTAL
**** Hidden Message ***** TW8810 ,下载学习一下 液晶电视 PCB,学习学习 老大,好资料 看着都舒服 老大这种板子挺多的啊 液晶,只有PCB吗,没原理图呢
回 yulefangzong 的帖子
yulefangzong:液晶,只有PCB吗,没原理图呢 (2016-06-26 23:15) images/back.gif标题没写。就是没有。
