【Protel 99 se】一份S3C6410核心板原理图和PCB资料分享
一份S3C6410核心板原理图和PCB资料,文件格式是Protel 99 SE板子主要有以下元器件
NameValueFootprintDescriptionC500.1uF0603CCapacitorC30.1uF0603CCapacitorC40.1uF0603CCapacitorC380.1uF0603CCapacitorC220.1uF0603CCapacitorC520.1uF0603CCapacitorC210.1uF0603CCapacitorC170.1uF0603CCapacitorC820.1uF0603CCapacitorC470.1uF0603CCapacitorC460.1uF0603CCapacitorC60.1uF0603CCapacitorC50.1uF0603CCapacitorC150.1uF0603CCapacitorC10.1uF0603CCapacitorC1070.1uF0603CCapacitorC1000.1uF0603CCapacitorC980.1uF0603CCapacitorC1100.1uF0603CCapacitorC420.1uF0603CCapacitorC390.1uF0603CCapacitorC430.1uF0603CCapacitorC960.1uF0603CCapacitorC950.1uF0603CCapacitorC910.1uF0603CCapacitorC890.1uF0603CCapacitorC970.1uF0603CCapacitorC940.1uF0603CCapacitorC920.1uF0603CCapacitorC880.1uF0603CCapacitorC330.1uF0603CCapacitorC310.1uF0603CCapacitorC290.1uF0603CCapacitorC770.1uF0603CCapacitorC730.1uF0603CCapacitorC350.1uF0603CCapacitorC300.1uF0603CCapacitorC280.1uF0603CCapacitorC260.1uF0603CCapacitorC270.1uF0603CCapacitorC360.1uF0603CCapacitorC320.1uF0603CCapacitorC530.1uF0603cCapacitorC1010.1uF0603cCapacitorC141.8nF0603CCapacitorC5910uF/10V0603CCapacitorC6510uF/10VCASEACapacitorC6010uF/10VCASEACapacitorC5510uF/10VCASEACapacitorC6110uF/10VCASEACapacitorC6310uF/10VCASEACapacitorC6410uF/10VCASEACapacitorC2010uF/10VCASEACapacitorC1810uF/10VCASEACapacitorC6210uF/10VCASEACapacitorC2510uF/10VCASEACapacitorC13710uF/10VCASEACapacitorC13610uF/10VCASEACapacitorC14010uF/10VCASEACapacitorC13310uF/10VCASEACapacitorC5610uF/10VCASEACapacitorC5810uF/10VCASEACapacitorC5710uF/10VCASEACapacitorC2410uF/10VCASEBCapacitorC915pF0603CCapacitorC815pF0603CCapacitorC4522pF0603CCapacitorC4422pF0603CCapacitorC1222pF0603CCapacitorC1322pF0603CCapacitorC1022pF0603CCapacitorC1122pF0603CCapacitorCRY412MX3X5CRYSTALCRY125MX3X5CRYSTALCRY327MX3X5CRYSTALCRY232.768KHzCRYSTAL-3276CRYSTALCRY548MHzX3X5CRYSTALR130R0603RRESR1444.2R 1%0603RRESR151K0603RRESR171K0603RRESR631K0603RRESR621K0603RRESR191M0603RRESR181M0603RRESR576.8K/1%0603RRESR646.24K 1%0603RRESR2310K0603RRESR810K0603RRESR910K0603RRESR1110K0603RRESR1010K0603RRESR1610K0603RRESR1100K0603RRESR112100K0603RRESR113100K0603RRESR7100K0603RRESR5100K0603RRESR6100K0603RRESL9BEAD0603LINDUCTORL6BEAD0603LINDUCTORL8BEAD0603LINDUCTORU30CAT811SOT-143CAT811MARK6CON1TP3ConnectorMARK5CON1TP3ConnectorMARK9CON1TP3ConnectorMARK3CON1TP3ConnectorMARK2CON1TP3ConnectorMARK1CON1TP3ConnectorMARK8CON1TP3ConnectorMARK4CON1TP3ConnectorMARK7CON1TP3ConnectorMARK11CON1TP3ConnectorMARK10CON1TP3ConnectorJ30CON5SMD_5ConnectorJ8CON5SMD_5ConnectorJ11CON5SMD_5ConnectorJ13CON5SMD_5ConnectorJ9CON5SMD_5ConnectorJ3CON5SMD_5ConnectorJ29CON5SMD_5ConnectorJ28CON5SMD_5ConnectorJ18CON5SMD_5ConnectorJ32CON5SMD_5ConnectorJ31CON5SMD_5ConnectorJ23CON5SMD_5ConnectorJ10CON5SMD_5ConnectorJ1CON5SMD_5ConnectorJ7CON5SMD_5ConnectorJ4CON5SMD_5ConnectorJ19CON5SMD_5ConnectorJ6CON5SMD_5ConnectorJ5CON5SMD_5ConnectorJ20CON5SMD_5ConnectorJ16CON5SMD_5ConnectorJ12CON5SMD_5ConnectorJ22CON5SMD_5ConnectorJ15CON5SMD_5ConnectorJ14CON5SMD_5ConnectorJ24CON5SMD_5ConnectorJ25CON5SMD_5ConnectorJ2CON5SMD_5ConnectorJ26CON5SMD_5ConnectorJ17CON5SMD_5ConnectorJ27CON5SMD_5ConnectorJ21CON5SMD_5ConnectorU22DM9000AEPLQFP48以太网IC U3K4X51163PC-LGC3K4X51163PCDDR RAMU2K4X51163PC-LGC3K4X51163PCDDR RAMU10K9F1G08U0A-PCB0/PIB0TSOP48NAND-FLASHD2LED0805LEDLEDD1LED0805LEDLEDR3OPEN0603RRESR49OPEN0603RRESR54OPEN0603RRESR2OPEN0603RRESR55OPEN0603RRESR4OPEN0603RRESR12OPEN0603RRESR48OPEN0603RRESR35OPEN0603RRESR47OPEN0603RRESU5RT9701BSOT23-5LDOU4RT9701BSOT23-5LDOU1S3C6410424-FBGA-13.0X13.0SAMSUNG S3C6400TP2TESTPOINTPADTEST POINTTP1TESTPOINTPADTEST POINTTP3TESTPOINTPADTEST POINT 區路过,,,, 看看,谢谢哦 谢谢 看看,不知道怎样 6410还是有点难画的 0.5的BGA,光出线就得2-3天,BGA
