干货。全网首发。
| Name | Value | PCB Decal | Part Type |
| ANT1 | ANT_2P | ANT_2P | |
| ANT2 | ANT_2P | ANT_2P | |
| ANT3 | ANT_2P | ANT_2P | |
| AV1 | ??? | AV4-8.4-10-B | AV4-8.4-10 |
| BT | BTà??à?£?é | CON_BT | BT |
| CON1 | 4PX2.0MM?±2? | CON_4PX2MM_V | CON_4P |
| CON2 | 3PX2.0MM?±2? | CON_3PX2MM_V | CON_3P |
| CON3 | 9PX2.0MM?±2?á??ó×ù | CON_9PX2MM_V | CON_9P |
| CON4 | 40PX0.5MM???óμ?ìù??á??ó×ù | CON_FPC-40P | CON_SMT_40PX0.5MM |
| CON5 | CON_OUT12P_FOR_BAOLAI | CON_OUT_12P | |
| CON8 | NC | CON_5PX2MM_V | CON_5P |
| D1 | 1N4148 | DIODE_1206_A | DIODE |
| D2 | 1N5401 | DIODE_DO201AD_7MM | DIODE |
| D3 | 1N4148 | DIODE_1206_A | DIODE_SMT |
| D4 | 1N4148 | DIODE_1206_A | DIODE |
| D5 | M1 | DIODE_2010_B | DIODE |
| D6 | M1 | DIODE_2010_B | DIODE |
| D7 | 1N4148 | DIODE_1206_A | DIODE |
| D8 | 1N4148 | DIODE_1206_A | DIODE_SMT |
| D9 | 1N4148 | DIODE_1206_A | DIODE_SMT |
| D10 | M1 | DIODE_2010_B | DIODE |
| D11 | 1N4148 | DIODE_1206_A | DIODE |
| D12 | 1N4148 | DIODE_1206_A | DIODE |
| D13 | 1N4148 | DIODE_1206_A | DIODE |
| D14 | 1N4148 | DIODE_1206_A | DIODE |
| D15 | 1N4148 | DIODE_1206_A | DIODE |
| D17 | 1N4148 | DIODE_1206_A | DIODE |
| D18 | BAV99 | SOT23_A | DIODE_3P |
| DZ1 | 9V1 | ZD_1206_A | DIODE_ZEN |
| DZ2 | 6V8 | ZD_1206_A | DIODE_ZEN |
| DZ3 | 5V6 | ZD_1206_A | DIODE_ZEN |
| EC1 | 47UF16V | ECAP_DIP_5MM | ECAP_DIP |
| EC2 | 100UF/16V | ECAP_DIP_6MM | ECAP_DIP |
| EC3 | 100UF16V | ECAP_DIP_6MM | ECAP_DIP |
| EC4 | 100UF16V | ECAP_DIP_6MM | ECAP_DIP |
| EC5 | 100UF16V | ECAP_DIP_6MM | ECAP_DIP |
| EC6 | 47UF/16V | ECAP_DIP_5MM | ECAP_DIP |
| EC7 | 47UF/16V | ECAP_DIP_5MM | ECAP_DIP |
| EC8 | 47UF/16V | ECAP_DIP_5MM | ECAP_DIP |
| EC9 | 47UF/25V | ECAP_DIP_6MM | ECAP_DIP |
| EC10 | 100UF/16V | ECAP_DIP_6MM | ECAP_DIP |
| EC11 | 47UF/16V | ECAP_DIP_5MM | ECAP_DIP |
| EC12 | 47UF/16V | ECAP_DIP_5MM | ECAP_DIP |
| EC13 | 47UF/16V | ECAP_DIP_5MM | ECAP_DIP |
| EC14 | 47UF/16V | ECAP_DIP_5MM | ECAP_DIP |
| EC15 | 3300UF/25V | ECAP_DIP_13MM | ECAP_DIP |
| EC16 | 47UF/25V | ECAP_DIP_6MM | ECAP_DIP |
| EC19 | 100UF/16V | ECAP_DIP_6MM | ECAP_DIP |
| EC23 | 47UF/16V | ECAP_DIP_5MM | ECAP_DIP |
| EC24 | 1000UF/10V | ECAP_DIP_8MM | ECAP_DIP |
| EC25 | 100UF/16V | ECAP_DIP_6MM | ECAP_DIP |
| FUSE1 | 100MA | FUSE_1210 | FUSE-2P |
| FUSE2 | 500MA | FUSE_1210 | FUSE-2P |
| L1 | 270NH | COIL_DIP_10MM | COIL |
| L2 | FB310 | COIL_0805_B | COIL |
| L3 | 10UH | COIL_0805_B | COIL |
| L4 | 47UH | COIL_SMTL8X8A | COIL_SMT |
| L5 | FB | COIL_0805_B | COIL |
| L6 | 100uH/10A | COIL_16X9X5MM | COIL_16X9X5MM |
| L7 | 2.2UH | IND-SMT-CD32 | COIL |
| L8 | FB310 | COIL_0805_B | COIL |
| L9 | 470UH | COIL_1206_B | COIL |
| L10 | FB310 | COIL_0805_B | COIL |
| L11 | FB310 | COIL_0805_B | COIL |
| L12 | 10UH | COIL_0805_B | COIL |
| L13 | 1.5UH | COIL_0603_B | COIL_SMT |
| L14 | 1.5UH | COIL_0603_B | COIL_SMT |
| L15 | FB310 | COIL_0805_B | COIL_SMT |
| L16 | FB310 | COIL_0805_B | COIL_SMT |
| L17 | FB310 | COIL_0805_B | COIL_SMT |
| L23 | 1.8UH | COIL_0603_B | COIL |
| MIC | 2PX2.0?±2? | CON_2PX2MM_V | CON_2P |
| Q1 | 3904 | SOT23_A | NPN |
| Q2 | 3904 | SOT23_A | NPN |
| Q3 | 3904 | SOT23_A | NPN |
| Q4 | 3904 | SOT23_A | NPN |
| Q5 | 3904 | SOT23_A | NPN |
| Q6 | 3906 | SOT23_A | PNP |
| Q7 | 9018H | SOT23_A | NPN |
| Q9 | B772 | SOT89 | PNP |
| Q10 | 8550 | SOT23_A | PNP |
| Q11 | 3904 | SOT23_A | NPN |
| Q12 | 3904 | SOT23_A | NPN |
| Q13 | 3904 | SOT23_A | NPN |
| Q14 | 3904 | SOT23_A | NPN |
| Q15 | D882 | SOT89 | NPN |
| Q16 | 3904 | SOT23_A | NPN |
| Q17 | 3904 | SOT23_A | NPN |
| Q18 | 3906 | SOT23_A | PNP_SMT |
| Q19 | 3904 | SOT23_A | NPN |
| Q32 | 8050 | SOT23_A | NPN |
| Q35 | 3906 | SOT23_A | PNP_SMT |
| Q42 | 3906 | SOT23_A | PNP_SMT |
| U1 | SC51F2832LL | IC_QFP48P_0707_0.5A | IC_SC2832 |
| U2 | TDA7388 | IC_FLEXIWATT25 | IC_TDA7386 |
| U3 | KIA4558 | IC_SOP8P_235_1.27 | IC_KIA4558 |
| U4 | EU3482DIR1 | IC_SOP8P_235_1.27 | EU3484DIR1 |
| U5 | 24C02 | IC_SOP8P_235_1.27 | IC_24C02 |
| U6 | 24C08 | IC_SOP8P_235_1.27 | IC_24C02 |
| U7 | TDA7313D | IC_SOP28P_300_1.27 | IC_TDA7313D |
| U8 | ACP2802 | SOT-23-5 | ACP2802 |
| U9 | M12L2561616A-6T-16X16M | IC_SSOP-54P | IC_SDRAM_1X16X4M |
| U10 | W25Q32V | IC_SOP8P_270_1.27 | IC_W25Q32V |
| U11 | HT7533 | SOT89 | IC_HT75XX-1 |
| U12 | SI4730/SI4731 | IC_SSOP24P | IC_SI4730_1 |
| U13 | BIT1630M | IC_QFP64P_0707_0.4 | BIT1630M |
| U14 | SI4702 | SI4702 | SI4702 |
| U15 | AMS1117-3V3 | SOT223 | IC_1117_X |
| U16 | AMS1117-1V8 | SOT223 | IC_1117_X |
| U17 | F1C100 | IC_LQFP128P_1414_0.4 | IC_F1C100 |
| U18 | AMS1117-3V3 | SOT223 | IC_1117_X |
| U19 | RDA5807-10P | IC_MSOP-10L | IC_RDA5807-10P |
| XT1 | 32.768KHZ | CRY_3X8MM | CRY |
| XT2 | 32.768KHZ | CRY_3X8MMA | CRY |
| XT3 | 24MHZ | CRY_11X4.5MM | CRY |
| XT4 | 32.768KHZ | CRY_3X8MM | CRY |
| XT5 | SCREW-DRILL-1.7MM | SCREW-3MM | |
| Y1 | 24.576MHZ | CRY_11X4.5MM | CRY |
| Z1 | 6V8 | ZD_1206_A | DIODE_ZEN |
| Z3 | 15V | ZD_1206_A | DIODE_ZEN |
都不舍得发的。要积分升级 @老吴
