电子小跑腿 发表于 2016-11-10 22:58
5.1 声道 功放PCB文件共享下载
NamePCB DecalPart TypeC0N1CON4P2.5PIN4PC1203P-250V203P-250VC2203P-250V203P-250VC3102P-250V104PC4102P-250V104PC5102P-250V104PC6102P-250V104PC7203P-250V203P-250VC8203P-250V203P-250VC9CE/R5/25CE10U/80C10CC-L4CC104C11CE/R5/25CE10U/80C12CC-L4CC104C13CM/5T/75CM104C14CC-L4CC104C15CM/5T/75CM104C16CM/5T/75CM104C17CC-L4CC104C18CC-L4CC104C19CC-L4CC104C20CE/R5/25CE10U/80C210603CC100PC220603CC100PC240603CC100PC25CE/R5/25CE10U/80C260603CC100PC27CE/R5/25CE10U/80C33R0603R0603C34R0603R0603C36CE/R5/25CE10U/80C37CE/R5/25CE0.22UC38CE/R5/25CE0.22UC39R0603R0603C40R0603R0603C420603CC100PC440603CC100PC45CM/5T/75CM104C46CM/5T/75CM104C47CE/R5/25CE10U/40C510603CC100PC520603CC100PC530603CC100PC54CE/R5/25CE10U/80C101ECAP5/8CE220U/16VC102ECAP5/8CE220U/16VC103ECAP5/8CE220U/16VC104ECAP5/8CE220U/16VCC1CE/R18CE4700U/35CC2CE/R18CE4700U/35VCC3CE/R18CE4700U/35CON2CON4P2.5PIN4PCON3CON-2.5-180CON-2.5CON5PIN3-H-2MPIN3PCON6CON-2.5-180CON-2.5CON7CON4P2.5PIN4PCON8CON4P2.5PIN4PD15402/15DIO-1N5402/15D25402/15DIO-1N5402/15D35402/15DIO-1N5402/15D45402/15DIO-1N5402/15D55402/15DIO-1N5402/15D65402/15DIO-1N5402/15D75402/15DIO-1N5402/15D85402/15DIO-1N5402/15D10DIO10DIO-1N4001F1FUSE-AFUSE-20F2FUSE-AFUSE-20F3FUSE-AFUSE-20IC17805IC-MC7805IC2TDA7265TDA7265IC13LM117KA7812IC21LM117M7912NC2CON9P2.0FAX-9P2.0NC3J-10MMJ-10MMNC4J-17MMJ-17MMNC5J-10MMJ-10MMNC8J-10MMJ-10MMNC9CON-3.96-180CON-3.96-180NC10PIN3-3.96/HPIN3/3.96NC11J-7.5MMJ-7.5MMNC13J-17MMJ-17MMNC15J-17MMJ-17MMNC16J-17MMJ-17MMNC18J-5MMJ-5MMNC19J-11MMJ-10MMNC21J-13.4MMJ-13.4MMNC22J-8.2MMJ-8.2MMNC23J-7.5MMJ-7.5MMNC24J-5MMJ-5MMNC25J-5MMJ-5MMNC27J-8.2MMJ-8.2MMNC29J-12.5MMJ-12.5MMNC30J-12.5MMJ-12.5MMNC31J-8.2MMJ-8.2MMNC32J-8.2MMJ-8.2MMNC33J-5MMJ-5MMNC35J-5MMJ-5MMQ1TO92C-CNPNQ4TO92C-CNPNQ8TO92C-CNPNR0603R10K0603R10603RR-0603R20603RR-0603R30603RR-0603R40603RR-0603R50603RR-0603R60603RR-0603R70603RR-0603R80603RR-0603R90603RR-0603R100603R10K0603R110603RR-0603R120603R10K0603R13R-L10R10KR14R-L10R10KR15R-L10R10KR16R-L10R10KR17R-L10R10KR20R-L10R10KR210603R10K0603R230603R10K0603R320603R10K0603R330603R10K0603R340603R10K0603R350603R10K0603R360603R10K0603R370603R10K0603R380603R10K0603R390603R10K0603R44R-L10R10KR450603R10K0603R460603R10K0603R470603R10K0603R51R-L13R-L13R550603RR-0603R560603RR-0603R570603RR-0603R580603R10K0603R590603R10K0603R600603R10K0603R61R-0.7MMR-0.7MMR640603R10K0603R650603R10K0603R670603R10K0603R680603R10K0603R690603R10K0603R700603R10K0603R710603R10K0603R720603R10K0603U124C02UTC4558U324C02UTC4558U424C02UTC4558U6TDA7377TDA7377Z1DO35ZPD5.6
laowu1680 发表于 2016-11-11 07:56
cooldog123pp 发表于 2016-11-11 08:59
很好的作品哟~~
asd2919748 发表于 2016-11-12 22:59
静哥哥 发表于 2016-11-15 12:11
可以哦不错
laowu1680 发表于 2016-11-16 08:59
urverycool 发表于 2016-11-16 09:01
yuanfengp 发表于 2016-11-23 09:32
很好的作品哟~~
xinyu1727 发表于 2016-11-27 22:35
7265的???
zhanglous 发表于 2016-11-28 16:50
很多零件啊 DIY不容易
查看完整版本: 5.1 声道 功放PCB文件共享下载
