全网唯一 GM8185 DVR PCB文件和原理图 整套资料共享
挂3个DDR 的板子。NamePart TypePCB DecalValueBT1BATERRY_0RTCBATERRY_0BUZ1126ANS_0BEEP12_75BuzzerD41ZC2800E/SOT_0DO-214ACSR24F1SMD050FUSE_2P_5.1DHR16-500IR1CON3INFRARED_100InfraredJ2CONN_TRBLK_9MTGNP9-350MMH3_5MMJ4CONN_TRBLK_9MTGNP9-350MMH3_5MMJ5CONN_TRBLK_9MTGNP9-350MMH3_5MMJ7CONN_TRBLK_9MTGNP9-350MMH3_5MMJ8CONN_TRBLK_9MTGNP9-350MMH3_5MMJ9CONN_TRBLK_9MTGNP9-350MMH3_5MMJ10CONN_TRBLK_9MTGNP9-350MMH3_5MMJ11CONN_TRBLK_9MTGNP9-350MMH3_5MMJ12CONN_TRBLK_9MTGNP9-350MMH3_5MMJ13CONN_TRBLK_9MTGNP9-350MMH3_5MML1INDUCTORIND-D21-P816uHL2INDUCTORIND-D8-P53uHL3INDUCTORIND-D21-P816uHL4INDUCTORIND-D8-P53uHL5100MHZ@110OHM_5IND0805N22uHL6100MHZ@110OHM_5IND0805N22uHL73.3UH_0.26A_10%_SMD_CM_CC3225IND0805N1.8uHL8INDUCTORINDB780X700N22uH/3AL9INDUCTORINDB780X700N22uH/3AL10INDUCTORINDB780X700N22uH/3ALED1LEDRES0603NGREENLED2LEDRES0603NGREENLED3LEDRES0603NGREENLED4LED_0LEDH254P500MM-TESTGREENLED5LED_0LEDH254P500MM-TESTGREENLED6LED_0LEDH254P500MM-TESTGREENLED7LED_0LEDH254P500MM-TESTGREENLED8LED_0LEDH254P500MM-TESTGREENLED9LED_0LEDH254P500MM-TESTGREENLED10LED_0LEDH254P500MM-TESTGREENLEM1XFRM_LINEAR_0DNM01-SXFRM_LINEARPT1PCB_TRACE_W_8MILSJO_120MILI=3A, W_120milPT2PCB_TRACE_W_8MILSJO_200MILI=5A, W_200milPT3PCB_TRACE_W_8MILSJO_320MILI=8A, W_320milPT4PCB_TRACE_W_8MILSJO_8MILPCB_Trace,W_8milPT5PCB_TRACE_W_8MILSJO_8MILPCB_Trace,W_8milPT6PCB_TRACE_W_8MILSJO_8MILPCB_Trace,W_8milPT7PCB_TRACE_W_8MILSJO_8MILPCB_Trace,W_8milPT8PCB_TRACE_W_8MILSJO_120MILI=3A, W_120milQ1MFE823_1TO-263(DPAK)SUM110P06Q2MFE823_2TO-263(DPAK)SUM110P06Q440237_1_2SOT23-240NT5551Q540237_1_2SOT23-240NT5551Q640237_3TO252-3KTC2020DQ7MFE825_0TO-252FDD10AN06A0Q8MFE825_0TO-252FDD10AN06A0Q9MFE825_0TO-252FDD10AN06A0Q10MFE825_0TO-252FDD10AN06A0Q1140237_0SOT23-240NT5551Q12MFE825_0TO-252FDD10AN06A0Q13MFE825_0TO-252FDD10AN06A0Q142SD601AR_SOT23SOT23-240NMMST3904Q152SD601AR_SOT23SOT23-240NMMST3904Q16MFE823_0SOT23-240NAO3401Q1740237_1SOT23-240NMMST3904Q18MFE823_0SOT23-240NAO3401Q19MFE823_0SOT23-240NAO3401/NCQ2040237_1SOT23-240NMMST3904Q21NPN_BCESOT23-240NMMST3904Q22BC178ASOT23-240NMMST3906Q23NPN_BCESOT23-240NMMST3904Q2440237_0_2SOT23-240NMMST3904Q43AO3415_SOT23_0SOT23-240NAO3415Q44MFE823_0SOT23-240NAO3401Q4540237_1SOT23-240NMMST3904Q46MFE825_0SOT23-240NAO3400Q4740237_1SOT23-240NMMST3904Q4840237_1SOT23-240NMMST3904Q49MFE825_0SOT23-240NAO3400Q5040237_1SOT23-240NMMST3904RV1DIODE_BREAKDOWN_1VAR-D10-P7.510D560SW1SW_PUSHBUTTONKEY2P-3.6X2.6-SMDM_RST/NCSW2SW_TACT-SPST/SMKEY2P-3.6X2.6-SMDM_RST/NCT1H1102_1SOP16-127P953NM3066ANLTP11X1P_MALE_DIP_2.0TP80TP_SMDTP21X1P_MALE_DIP_2.0TP80TP_SMDTP31X1P_MALE_DIP_2.0TP80TP_SMDTP41X1P_MALE_DIP_2.0TP80TP_SMDTP5TESTPOINT_SMDTP80TP_SMDTP6TESTPOINT_SMDTP80TP_SMDTP71X1P_MALE_DIP_2.0TP80TP_SMDTP81X1P_MALE_DIP_2.0TP80TP_SMDTP91X1P_MALE_DIP_2.0TP80TP_SMDU1LM393_3SOP8-127P600NLM2904U2LM393_3SOP8-127P600NLM2904U340237_2SOT23-240NAZ431U4XWM8731EDSR_SSOP28_2TSOP24-65P640NLTC3780U5LM5116SOP-20P-LM5116LM5116U6GM8185_BGA700_V2_9BGA700_100GM8185_BGA700_V2U7G916-120T1UF_SOT25SOT23-5-95P280NG916-120T1UfU8S29GL256P90TFC02_TSOP56_1TSOP56-50P2000NS29GL256P90TFCR2U9S29GL256P90TFC02_TSOP56_1TSOP56-50P2000NS29GL256P90TFCR2U10MAX3490ESOP8-127P600NSP3490ENU11ADM485_0SOP8-127P600NSP3485EEN-LU12K4T1G164QE-HCE7_FBGA84BGA84-80P9X15CK4T1G164QE-HCE7,FBGA84U13K4T1G164QE-HCE7_FBGA84BGA84-80P9X15CK4T1G164QE-HCE7,FBGA84U14G916-120T1UF_SOT25SOT23-5-95P280NG916-120T1UfU15K4T1G164QE-HCE7_FBGA84BGA84-80P9X15CK4T1G164QE-HCE7,FBGA84U16TW2865_3TQFP128-40P1600NTW2865U17XWM8731EDSR_SSOP28_3SOP28-65P780NXWM8731EDSR_SSOP28U18CAT24WC02J_SOP8_2TSOP8-65P490N-TESTADT75U19SII3512_2TQFP128_PSII3512U20LAN8710QFN33-50P500NLAN8710U21FE1_1S_SSOP28SOP28-64P600NFE1_1s_SSOP28U22RT9701CBSOT23-5-95P280NRT9701PBU23ISL1208IB8-TKSOP8-127P600NISL1208U24CAT24WC02J_SOP8SOP8-127P600NAT24C02U25AT89C52_2TQFP44-80P1200NAT89S52U26CON2_3SOP8-127P600NSP813LENU27CAT24WC02J_SOP8SOP8-127P600NAT24C02U28RT9701CBSOT23-5-95P280NRT9701PBU29XC9572XLTQFP64-50P1200NXC9572XVU30CAT24WC02J_SOP8_1SOP8-127P600NAOZ1360AILU31LTV847SO16TCMT4100U32LTV847SO16TCMT4100U33LTV847SO16TCMT4100U34LTV847SO16TCMT4100U35MAX3232CSE_SOP16_0SOP16-65P780NSP3232ENU36PESDXS2UATSOT23-240NPESD24VS2UATU37CM1624SON17-40P135Ncm1624U38PACDN044YSOT5-65P210NPACDN044YU39PACDN044YSOT5-65P210NPACDN044YU40PACDN044YSOT5-65P210NPACDN044YU41PACDN044YSOT5-65P210NPACDN044YU42PACDN044YSOT5-65P210NPACDN044YU43PACDN044YSOT5-65P210NPACDN044YU44TPS54231SOP8-127P600NTPS54331U45EM6323_0SOT23-5-95P280NEM6323LXSP5B-2.9U46EM6323_0SOT23-5-95P280NEM6323LXSP5B-2.9U47TPS54231SOP8-127P600NTPS54331U48TPS54231SOP8-127P600NTPS54331U49PESDXS2UATSOT23-240NPESD24VS2UATX112MHZ_CRY_30PPM_49US_1SMAQ-5032B12MHzX224_1.576MHZ_CRY_30PPM_49USSMAQ-5032B24.576MHzX327MHZ_OSC_30PPM_SMD5X3_0OSCS500X700-4N27MHzX4ZTA_0SMAQ-5032B25MHZX530MHZ_CRY_30PPM_49US_0SMAQ-5032B25MHzX6ZTA_1SMAQ-5032B12MHzX727MHZ_OSC_30PPM_SMD5X3_1OSC-150X700N-TEST32.768KHzX8CRYSTAL_0SMAQ-5032B22.1184ZD1ZC2800E/SOT_1SOD-123N14VZD2ZC2800E/SOT_1SOD-123N14VZD4ZC2800E/SOT_1SOD-123N9.1VZD5ZC2800E/SOT_1SOD-123N13VZD6ZC2800E/SOT_1SOD-123N5.1V 回归初心。继续不断的高大上作品。
PCB文件和原理图,原理图有 ORCAD 和 PADS 两种格式。 ORCAD为原版。
好厉害的板子,谢谢楼主奉献 厉害! 谢谢楼主奉献 顶顶。。。
