sisi9000 发表于 2017-1-15 12:28
LC4064V-75TN44I+TM4C1237E6PZ+ISO1176DW+TPS55010RTER+TPS2482PW+LM20242MH/NOPB
简单的4层板子。有需要提取封装的可以下载
板子有以下主要元件。
NamePart TypePCB DecalValueD7DIODE_BI-DIR_TRIG_0DIO_SMCSMCJ15CAD8DIODE_SCHOTTKY_2DIO_SMAB120-13-FD9ZENER_2SMBJ5338B-TP, 5.1VD10DIODE_SCHOTTKY_6DIO-SOD-123FMBR0540-TPD11DIODE_SCHOTTKY_6DIO-SOD-123FMBR0540-TPD12DIODE_SCHOTTKY_6DIO_DFLS1200-7DFLS1200-7D13DIODE_SCHOTTKY_6DIO_DFLS1200-7DFLS1200-7D14DIODE_SCHOTTKY_6DIO_SOD523SDM10U45-7-FD15DIODE_SCHOTTKY_1DIO_SMC_P290_PD110X150_8.13_3.07_1.27_1MBRS4201T3GD16MOVVAR_V20E30PDNPD17SMBJ15CA_0DIO_DO-214AASMBJ45CAD18MMSZ5233BT1_1DIO_SOD-123BZT52C8V2-7D52SMBJ15CA_0DIO_DO-214AASMBJ45CAD57ZENER_1DIO_SOD-123BZT52C2V4-7-F, 2.4VD60DIODE_SCHOTTKY_6DIO_SOD523SDM10U45-7-FD61ZENER_1DIO_SOD-123DNPIC1TPS2482PW20TPS2482PWJ1CON2CN2_MTB_P100_PD80_D1.1_S5.54X6.5_STACKOSTVN02A150J2HEADER_5X2CN10_BS5X2_P100_PD70_D1.0HEADER 5X2J5CON-MINI-USB-ABSMDUSB MINI-AB SMDJ6HEADER_5X2HEADER 5X2J7HEADER_2TE_282825-2RMC2J8HEADER_2TE_282825-2RMC2J18HEADER_2TE_282825-2RMC2J19HEADER_5X2CN10_BS5X2_P100_PD70_D1.0HEADER 5X2J20CON2CN2_MTB_P100_PD80_D1.1_S5.54X6.5_STACKOSTVN02A150L1MMZ1608B102C_1FB0603MMZ1608B102CL2CHOKE_CM14_4FIL_ACM2012ACM2012-900-2P-T002L3CHOKE_CM14_0SMDACM2012-900-2P-T002L4INDUCTORINDC12123.3uHL5INDUCTOR_2IND_SRR7032220uHL6INDUCTORINDC12123.3uHL7INDUCTORINDC12123.3uHL8COMMON_MODE_CHOKE_2IND_52106C52106C, 10mHM1CSD18537NQ5A_0SON_CSD18537NQ5ACSD18537NQ5AM3CSD18537NQ5A_0SON_CSD18501Q5ACSD18501Q5AMH12MH_3.5MMMH3.2_H5_W6_KO8_STARHEADMH 3.2MMSW2B3S-1000_SW_0SW_B3S-1000PB3S-1000 SWT1TRAN_ISDN_0XFMR_760390015760390015, 1:2T2TRAN_ISDN_9XFMR_750313998750342156T3Q4337-BL_3XFMR_RLTI-1046RLTI-1046U1TM4C1237E6PZTM4C1237E6PZU2AT2402_2IC8SOIC_P50X189_PD26X90_6.2_0.51_1.27AT24C02C-SSHM-T SL901U3TPS3897APSON50P100X145X60-6NTPS3897ADRYRU5REF3230SOT23-6REF3230AIDBVTU6ISO3082_DW_3IC16SOW_P50X376_PD22X84_10.65_.51_1.27_5ISO3082DWU7TPS55010_TRANS_4QFN50P300X300X55-17NTPS55010RTERU8LC4032/4064-T44_2LC4064V-75TN44IU9TPD4E1B06DCKR_0SC-70-6TPD4E1B06DCKRU10SDCCCN50_ERM-DV-K_P0.8X5_PD20X70_SAMTECERM8-025-05.0-L-DV-TRU11SDCCCN50_ERM-DV-K_P0.8X5_PD20X70_SAMTECERM8-025-05.0-L-DV-TRU12LM5069_1SOP50P490X110-10NLM5069U13LM5017_0SOIC127P517X168-9LM5017MRU14LM20242_1SOP65P772X110-20LM20242MH/NOPBU15LM5017_0SOIC127P517X168-9LM5017MRY1CRYSTAL_1XTAL_ABM1025MHzY2OSCILLATORCB3LV-3I-25M0000
PCB是PADS9.5原理图是ORCAD16.3
junkyoung 发表于 2026-10-21 07:53
好好地学习。。。
junkyoung 发表于 2026-10-21 07:56
好好地学习。。。
查看完整版本: LC4064V-75TN44I+TM4C1237E6PZ+ISO1176DW+TPS55010RTER+TPS2482PW+LM20242MH/NOPB
