老吴 发表于 2017-2-13 16:03
AML8726-MX挂4个DDR3 PCB和原理图 GL830+GL852G+WL-212+LAN8720A+CS4354+
板子有以下主要元件。
NamePCB DecalValuePart TypeANT1NT003NT003NT003CN1CN-2.0FH2X20P-902.0FH_2X20PCN-2.0FH2X20P-90CN3CON-20P-2MM2.00mm_2x10P_connectorCON-20P-2MMCN4CON-20P-2MM2.00MM_2X10P_CONNECTORCON-20P-2MMCON1CON6-2.5MM6P2.54MM_PITCH_CONNECTORCON6-2.5MMCON500CON-SATA-7PSATA_7PCON-SATA-7PCON501CON-A3961WV-4PA3961WV-4PCON-A3961WV-4PCON600CON6-2.0NC/VGACON6-2.0D2SOD-123NC/B5819WSOD-123D4SOT-23-2ABAT54CSOT-23-2AD17SOT-23-2ABAT54CSOT-23-2AD500SOT-23-2ABAT54CSOT-23-2AD502SOT-23-2ABAT54CSOT-23-2AEA1TVS-SLP25108PNC/TEPAR08V06B4XTVS-SLP25108PEA2TVS-SLP25108PNC/TEPAR08V06B4XTVS-SLP25108PF401FUSE-0805FUSE_500mAFUSE-0805F403FUSE-0805FUSE_500mAFUSE-0805FB1FE0805100Mhz;100ohm?à25%_3AFE0805GC1DSK_3R30.22F_3.3VDSK_3R3J1DC-005DC-005DC-005J21CON4_2.54P2.0mm_pitch_connectorCON4_2.5J27CON-ZX-HDMI-07AZX-HDMI-07ACON-ZX-HDMI-07AJ301RJ-45BRJ45(81-8P8C-1x1-LED)RJ-45BJ302TS8121CH1601CGTS8121CJ400MINIUSB-5P-DIPMini_usbMINIUSB-5P-DIPJ402USB-A-F-SIDE-DIPUSB-AUSB-A-F-SIDE-DIPJ403USB-A-F-SIDE-DIPUSB-AUSB-A-F-SIDE-DIPJ404CN_6P_USBWDMLK-003ACN_6P_USBWDJ600CQ2-B-3IN1-CARD3IN1CARDCQ2-B-3IN1-CARDJ601AV6-8.4-13PB-HVIDEO_AUDIOAV6-8.4-13PB-HJ700RCA-GQ-09RCA-GQ-09RCA-GQ-09K606TK-TS-03PVOk_tact_switchTK-TS-03PVL1L-SWPA50406R8UH_2AL-SWPA5040L2L-SWPA50406R8UH_2AL-SWPA5040L5L-SWPA50406R8UH_2AL-SWPA5040L9L-SWPA50402R2UH_2AL-SWPA5040L10L-SWPA50402R2UH_2AL-SWPA5040L12L-SWPA50402R2UH_2AL-SWPA5040L404ACM2012-2PACM2012-900-2PACM2012-2PL405ACM2012-2PACM2012-900-2PACM2012-2PL406ACM2012-2PACM2012-900-2PACM2012-2PL613L06031.8uHL0603L2120L-SWPA30153.3uH_1AL-SWPA3015LE1TEF2012A4X101MTTEF2012A4X101MTTEF2012A4X101MTLE2TEF2012A4X101MTTEF2012A4X101MTTEF2012A4X101MTLED2LED_DOUBLE_COLOR20mALED_DOUBLE_COLORLED500LED-D3MMHDD_LEDLED-D3MMQ6SOT-23MSPP2341SOT-23MQ8SOT-23PMBT3904SOT-23Q11SOT-23PMBT3904SOT-23Q500SOT-23MSPP2341SOT-23MQ501SOT-23MNC/SPP2341SOT-23MQ502SOT-23PMBT3904SOT-23Q600SOT-23MSPP2301DSOT-23MQ615SOT-23SPP2301DSOT-23Q616SOT-23SPP2301DSOT-23Q617SOT-23PMBT3904SOT-23RP2120RA0402-4P4x22ohmRA0402-4PRP2121RA0402-4P4x33KRA0402-4PSW1SPTY-DSR01-E1DRS01-E1SPTY-DSR01-E1T300TESTVDDCR_TESTTESTT301TESTGNDTESTT302TESTRBIASTESTTF2TF_3806ThermofinTF_3806TP14TEST???TESTTP15TESTPWD_BTESTTP26TEST_POINT_3020DC_12VTEST_POINT_3020TP27TEST_POINT_3020SATA5VTEST_POINT_3020TP28TEST_POINT_3020SATA_VDDTEST_POINT_3020TP29TEST_POINT_3020SATA_VDD18TEST_POINT_3020TP30TEST_POINT_3020V5VTEST_POINT_3020TP31TEST_POINT_3020DA_5VTEST_POINT_3020TP34TEST_POINT_3020WIFI_VBATTEST_POINT_3020TP35TEST_POINT_3020WIFI_VDDIOTEST_POINT_3020TP36TEST_POINT_3020HUB_VDDTEST_POINT_3020TP37TEST_POINT_3020HUB_AVDDTEST_POINT_3020TP38TEST_POINT_3020VDDQTEST_POINT_3020TP39TEST_POINT_3020DC_12VTEST_POINT_3020TP40TEST_POINT_3020AO_5VTEST_POINT_3020TP41TEST_POINT_3020VDDIO_AOTEST_POINT_3020TP42TEST_POINT_3020VDD_AOTEST_POINT_3020TP43TEST_POINT_3020VDDQTEST_POINT_3020TP44TEST_POINT_3020VCC3.3VTEST_POINT_3020TP45TEST_POINT_3020VCC2.8VTEST_POINT_3020TP46TEST_POINT_3020VCCKTEST_POINT_3020TP47TEST_POINT_3020VCC5VTEST_POINT_3020TP48TEST_POINT_3020AVDD2.5VTEST_POINT_3020TP2120TESTBT_CLKOTESTTP2121TESTRF_CTRL6TESTTP2123TESTRF_CTRL3TESTU1TSOT23-6MP1470TSOT23-6U4TSOT23-6MP1470TSOT23-6U5TSOT23-6MP1470TSOT23-6U6TSOT23-6MP1470TSOT23-6U7SOT-23-5EMP8734-25V05GRRSOT-23-5U10IC-TSOP-II-48P29F32G08CBACAIC-TSOP-II-48PU12IC-TSOP-II-48PNCTSTS45-04GIC-TSOP-II-48PU13IC-SOP8L-209MILMX25L3205DIC-SOP8L-209MILU16SOT-23-5PST20141/AIC6163SOT-23-5U21TSOT23-6MP1470TSOT23-6U22TSOT23-6MP1470TSOT23-6U23SOT-23EMP8733-18VB03GRRSOT-23U37AML8726-MXAML8726-MXAML8726-MXU41BGA78-DDR3GT8UB256M8BN-BGBGA78-DDR3U42BGA78-DDR3GT8UB256M8BN-BGBGA78-DDR3U43BGA78-DDR3GT8UB256M8BN-BGBGA78-DDR3U44BGA78-DDR3GT8UB256M8BN-BGBGA78-DDR3U300IC_QFN24PINLAN8720AIC_QFN24PINU402SSOP28P_GL852GGL852GSSOP28P_GL852GU405SOT-23-5EMP8734-33V05GRRSOT-23-5U501IC-LQFP48GL830IC-LQFP48U701IC_SO14CS4354IC_SO14U800REMOTEIRM_3638NCREMOTEU809SOT-23-5EMP8965-28V05GRRSOT-23-5U827SOT-23MAX809RD/PT7M7809RSOT-23U830SSOP16SGM330ASSOP16U831SC70-6SGM3157SC70-6U2120WL-212WL-212WL-212Y1Y_MC-146/_SJK6K632.768KHZ_12.5PF_10PPMY_MC-146/_SJK6K6Y2322524MHz_20pF3225Y5Y-SJK-322512MHz_20ppmY-SJK-3225Y402Y-SJK-322525MHZ_20PPMY-SJK-3225Y500Y-SJK-322525MHz_20ppmY-SJK-3225Y2120Y-SJK-322526MHz_10ppm_16pFY-SJK-3225
老吴 发表于 2017-2-13 16:05
PCB为PADS9.5格式,原理图是ORCAD格式。
**** Hidden Message *****
bidezhi7777 发表于 2017-2-13 16:43
看看,是不是有早老了!!!
老吴 发表于 2017-2-13 19:01
回 bidezhi7777 的帖子
bidezhi7777:看看,是不是有早老了!!! (2017-02-13 16:43) images/back.gif
恩。有一定时间了。 哎。没办法。很多新资料现在不能发。都要等23年后才敢发上来。
miaomiao 发表于 2017-2-13 19:10
谢谢,也很厉害了
ycy 发表于 2017-2-13 20:11
谢谢分享~
o桃花岛主o 发表于 2017-2-14 00:10
回 老吴 的帖子
老吴:PCB为PADS9.5格式,原理图是ORCAD格式。
[内容隐藏]
 (2017-02-13 16:05) images/back.gif
谢谢楼主分享
o桃花岛主o 发表于 2017-2-14 00:12
回 老吴 的帖子
老吴:恩。有一定时间了。 哎。没办法。很多新资料现在不能发。都要等2  3年后才敢发上来。 (2017-02-13 19:01) images/back.gif
老大,来点新的,挂点rmb的,让大家开开眼啊
老吴 发表于 2017-2-14 00:26
回 o桃花岛主o 的帖子
o桃花岛主o:老大,来点新的,挂点rmb的,让大家开开眼啊 (2017-02-14 00:12) images/back.gif
新的不敢挂啊,马上就有人投诉了。
cdl511 发表于 2017-2-14 08:27
多谢分享 ,认真学习
页: [1] 2 3 4 5 6 7 8 9
查看完整版本: AML8726-MX挂4个DDR3 PCB和原理图 GL830+GL852G+WL-212+LAN8720A+CS4354+
