sii9000 发表于 2017-3-18 00:41
DJX-120W(DJX120)信号机PCB  SCH整套共享下载 AD
驱动检测核心板
CommentPatternQuantityComponents100uF/16V,贴片钽DSO-C2/X3.31C24104,贴片0805R2012-08051210p,贴片0805R2012-0805410uF/16V,贴片钽CC3216-12061C231117,3.3VDSO-G31UPOW1220电池座+电池BAT21BT11K,贴片0805R2012-08052R3, R62.0间距针,2X20MHDR2X152J1, J2330,贴片0805R2012-08052R1, R24.7uF/16V,贴片钽CC3216-12061C17521-1,贴片DIP-41U818M晶振RAD0.21M1Cap2R2012-08051C22CommentRAD0.21M2CTM1050CTM10501U2FM25L256BSO81U3LED,0805SMD _LED1DS1STM32F103ZETQFP1441U1双列2.54座,2X5HDR2X51JP1
液晶显示
100uF/16V,贴片钽DSO-C2/X3.31CU4104,贴片0805R2012-080525105,贴片0805R2012-08051C4610K,6针阻排HDR1X61R3A10K,贴片0805R2012-0805610pF,贴片0805R2012-08052C1, C210uF/16v,贴片钽R2012-08051C501117,3.3V,贴片DSO-G31UPOW1K,贴片0805r2012-0805112.54直插座2X5HDR2X51JP62.54座,弯针2X5HDR2X52P2, P720K,直插蓝色可调电阻VR51RL720pF,贴片0805R2012-08052C3, C4220uF/16V,贴片钽DSO-C2/X3.31CU32k,贴片0805r2012-08051R95.08,接插件CON5.0-81P98MHzrad0.21X19012,贴片SO-G3/X.91Q1A03SIP32BOOT0, BOOT1CommentFLY21COMCommentMHDR1X21X2CommentNSO161U11CommentSMD _LED1DS1CR1220 电池座BAT21BT1CTM1050CTM10501U9FM25L256BSO81UTIS61LV51216TSOP2-544U1, U2, U3, U4K9F1208TSOP481U6SN74HC04D,贴片D0141U10SN74LS138NSO-G161U5STM32F103ZET6TQFP1441U8单列直针1X21HDR1X221JP2
综合控制通信核心控制板
0.1uf贴片0805R2012-08051C20104,贴片0805R2012-080517105,贴片0805R2012-08051C2710K,贴片0805R2012-08051R210p,贴片0805R2012-08054C1, C2, C3, C412K,贴片0805,1%R2012-08051R3118p,贴片0805R2012-08052C32, C331K,贴片0805R2012-08055R1, R4, RM3, RP1, RP21K,贴片0805R2012-08053RL1, RL5, RL61uH直插R2012-08051L32.0间距针,2X20MHDR2X152J1, J22012电池座BAT21BT125M晶振RAD0.21M3300,贴片0805,1%R2012-08051R3232768晶振MHDR1X21M54.7uF/16V,贴片钽CC3216-12061C174.7uF/16V,贴片钽CC3216-12062C21, C2574LS04SO-141D48563TSO81RTC8M晶振RAD-0.21M1CommentRAD0.21M2FM25L256BSO81U3LED,0805SMD _LED1DS1STM32F103ZETQFP1441U1W5100LQFP801U5标准SD卡座SDCARD1CN1双列2.54座,2X5HDR2X51JP1贴片发光二极管,0805SMD _LED3Link, RX, TX
krh 发表于 2017-3-18 00:46
sii9000 发表于 2017-3-18 00:48
PCB文件来了。全部PCB一起打包。
sii9000 发表于 2017-3-18 00:23
DJX120信号机原理图 整套共享下载 AD格式
linyuanfei 发表于 2017-3-18 08:28
多谢,看看
miaomiao 发表于 2017-3-18 08:40
多谢,看看
james_zhangwk 发表于 2017-3-18 08:42
baihushan 发表于 2017-3-18 08:48
设备看着挺高端啊
riverhill 发表于 2017-3-18 08:50
gameboy 发表于 2017-3-18 08:56
厉害了
页: [1] 2 3 4
查看完整版本: DJX-120W(DJX120)信号机PCB  SCH整套共享下载 AD格式
