armclub 发表于 2017-5-15 22:01
intel  I5电脑主板 LGA1156  PCB共享
REFDESCOMP_DEVICE_TYPESYM_NAMEBT1BATTERY_PLCLF-202168-001PLC_HOLDERCR1DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR2DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR3DIODE_SOT23LF-BAT54LT1,IC,C834ASOT23ACR4DIODE2A_DUAL_SMLF-BAT54C,DIO,CASOT23ACR5DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR6DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR7DIODE_SOT23LF-BAT54LT1,IC,C834ASOT23ACR8DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR9DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR10DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR11DIODE2C_DUAL_SOT23LF-BAT54A,DIASOT23ACR12DIODE_SOT23LF-BAT54LT1,IC,C834ASOT23ACR13DIODEAC_DUAL_SOT23LF-BAV99,DIOASOT23ACR14DIODEAC_DUAL_SOT23LF-BAV99,DIOASOT23ACR15DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR18DIODE_SOT23LF-BAT54LT1,IC,C834ASOT23ACR19DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR21DIODE2A_DUAL_SMLF-BAT54C,DIO,CASOT23ACR22DIODEAC_DUAL_ARRAY_SM6LF-IP422ASSOP6_67_95MBCR23DIODE2C_DUAL_SOT23LF-BAT54A,DIASOT23ADS1LED_DUAL_A_2C1ASMLF-GREEN/YELLASLEDA1208FDS2LED_SMLF-BLUE,IC,D14725-016SLEDR0603AEU1TTL126_SMTHLF-74LVC126A,IC,C88BQFN14_14_14_5MAEU2TTL07_SMTHLF-74LVC07A,IC,D9045BQFN14_14_14_5MAEU382578DM_QFNLF-IC,E34775-001QFN48_24_4MAEU4ISL6313_SMLF-IC,E16272-001MLFP36_24_5MAEU5SC4215A_SOICLF-IC,D75000-001-GASOI8_15_50IGEU682574L_A_LCCLF-IC,E15359-001QFN64_36_5MCEU7MOSFETN_1D3S_SO5LF-NFET,E40052AMLFP5_25_50IBEU8MOSFETN_1D3S_SO5LF-NFET,E40052AMLFP5_25_50IBEU9ISL6313_SMLF-IC,E16272-001MLFP36_24_5MAEU10TTL4066_SMTH-74LV4066,IC,D9136BQFN14_14_14_5MAEU11MOSFETN_1D3S_SM5LF-NFET,E37077AMLFP5_25_50IDEU12MOSFETN_1D3S_SM5LF-NFET,E37077AMLFP5_25_50IDEU13TTL595_SMTHLF-74LV595A,IC,D889AQFN16_14_16_5MAEU14TTL595_SMTHLF-74LV595A,IC,D889AQFN16_14_16_5MAEU15ISL6333_SMLF-IC,E11967-001MLFP48_28_5MBEU26MOSFETN_1D3S_SM5LF-NFET,E37077AMLFP5_25_50IDEU27TTL165_SMTHLF-74LV165A,IC,D889BQFN16_14_16_5MAEU28TTL14_SMTH-74ALVC14,IC,D90461-BQFN14_14_14_5MAEU29TTL07_SMTHLF-74LVC07A,IC,D9045BQFN14_14_14_5MAEU30EN5336_QFNLF-IC,E19219-001QFN44_40_30_65MAEU31TTL08_SMTHLF-74LVC08A,IC,D9040BQFN14_14_14_5MAEU32MOSFETN_1D3S_SO5LF-NFET,D66291AMLFP5_25_50IBEU33MOSFETN_1D3S_SO5LF-NFET,D79684AMLFP5_25_50IBEU34RT9199_SMLF-IC,D20918-001SOI8_15_50IGF1FUSE_SMLF-IC,C92281-001SFU1206AF2FUSE_SMLF-IC,C92281-001SFU1206AF4FUSE_SMLF-IC,C92281-001SFU1206AF6FUSE_SMLF-IC,C92281-001SFU1206AF7FUSE_SMLF-IC,C92281-001SFU1206AF8FUSE_SMLF-IC,C92281-003SFU1206AF9FUSE_SMLF-IC,C92281-003SFU1206AJ1CONN15_D20913001_THLF-CONN,D20BCONN15_D20913001J2CONN9_A92006001_THLF-CONN,A920ACONN9_A92006001J3CONN22_C73572001_THLF-CONN,C73ACONN22_C73572001J4CONN22_C73572001_THLF-CONN,C73ACONN22_C73572001J5SCONN38_665092002_B_SMTLF-EMPTBSCONN38_665092002AJ6CONN2_A91829004_THLF-CONN,A918ACONN2_A91829004J7CONN2_A91829027_THLF-EMPTY,A91ACONN2_A91829027J8CONN2_A91829027_THLF-CONN,A918ACONN2_A91829027J9CONN3_D42317001_THLF-CONN,D423ACONN3_D42317001J10CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J11CONN2_A91829027_THLF-CONN,A918ACONN2_A91829027J12CONN24K_A91854007_THLF-CONN,A9ACONN24K_A91854007J13CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J14CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J15CONN4_C74770001_THMTLF-CONN,C7ACONN4_C74770001J16CONN2_A91829027_THLF-CONN,A918ACONN2_A91829027J17CONN2_A91829027_THLF-CONN,A918ACONN2_A91829027J18SCONN60_C21100002_SMLF-CONN,C2ASCONN60_C21100002J19CONN2_A91829027_THLF-CONN,A918ACONN2_A91829027J20CONN4_D24487001_THLF-CONN,D244ACONN4_D24487001J21CONN5_702688003_THLF-CONN,7026ACONN5_702688003J22CONN10K_A91985026_THLF-CONN,A9ACONN10K_A91985026J23CONN34K_D16503004_THLF-CONN,D1ACONN34K_D16503004J24CONN4_637743009_TH-CONN,637743ACONN4_637743009J25CONN8_A91854015_THLF-CONN,A918ACONN8_A91854015J26CONN98K_C35285003_THLF-CONN,C3ACONN98K_C35285003J27CONN98K_C35285003_THLF-CONN,C3ACONN98K_C35285003J28CONN98K_C35285003_THLF-CONN,C3ACONN98K_C35285003J29CONN98K_C35285003_THLF-CONN,C3ACONN98K_C35285003J30CONN10K_C91088002_THLF-CONN,C9ACONN10K_C91088002J31CONN164_C35285004_THLF-CONN,C3ACONN164_C35285004J32CONN10K_C91088002_THLF-CONN,C9ACONN10K_C91088002J33CONN4_C74770001_THMTLF-CONN,C7ACONN4_C74770001J34CONN20K_A91836065_THLF-CONN,A9ACONN20K_A91836065J35CONN78_E29408002_THLF-EMPTY,E2ACONN78_E29408002J36SCONN3_700000906_CONNLF-EMPTY,ASCONN3_700000906J37CONN120K_C84362001_TH-CONN,C84ACONN120K_C84362001J38CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J39CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J45CONN240_D92964004_THMTLF-CONN,ACONN240_D92964004J46SCONN2_D40676001_SMLF-EMPTY,D4ASCONN2_D40676001J47CONN6_D19123001_THLF-CONN,D191BCONN6_D19123001J48CONN10K_D88097002_THLF-CONN,D8ACONN10K_D88097002J49LGA1156_SKT_H1_B_LGALF-IC,E519AXBGA1156_3_36IA_H1J50CONN2_MFGJMPR_SMT-EMPTY,NAMFG_MODE_JMPRJ51CONN2_A13494008_THLF-TH,A13494ACONN2_A13494008J52CONN7_C92545003_THLF-CONN,C925BCONN7_C92545003J53CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J54CONN2_C73538002_THLF-CONN,C735ACONN2_C73538002J55CONN7_C92545003_THLF-CONN,C925BCONN7_C92545003J56CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J57CONN2_A91829027_THLF-CONN,A918ACONN2_A91829027J58CONN2_A91829027_THLF-CONN,A918ACONN2_A91829027J59CONN2_A13494008_THLF-TH,A13494ACONN2_A13494008J60CONN7_C92545003_THLF-CONN,C925BCONN7_C92545003J61CONN1_A85589002_THMTLF-EMPTY,AACONN1_A85589002J62CONN4_A80097002_TH-CONN,A80097ACONN4_A80097002J63SCONN60_C21100002_SMLF-CONN,C2ASCONN60_C21100002J64CONN2_C73538002_THLF-CONN,C735ACONN2_C73538002J65CONN3_D24487004_THLF-CONN,D244ACONN3_D24487004J66CONN4_D24487001_THLF-CONN,D244ACONN4_D24487001J67CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J68CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J69CONN24K_C85892002_THLF-CONN,C8ACONN24K_C85892002J70CONN4_C74770001_THMTLF-CONN,C7ACONN4_C74770001J71CONN7_C92545003_THLF-CONN,C925BCONN7_C92545003J72SCONN60_C21100002_SMLF-CONN,C2ASCONN60_C21100002J73SCONN7_C66250002_SMLF-CONN,C66ASCONN7_C66250002J74SCONN7_C66250002_SMLF-CONN,C66ASCONN7_C66250002J75CONN4_C74770001_THMTLF-CONN,C7ACONN4_C74770001J76CONN4_C74770001_THMTLF-CONN,C7ACONN4_C74770001J77CONN100_201794136_THLF-CONN,20ACONN100_201794136J78TP50_LAIPROBE_SMLF-EMPTY,NATP50_LAIPROBEJ79TP50_LAIPROBE_SMLF-EMPTY,NATP50_LAIPROBEJ80CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J81CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J82CONN2_A91829027_THLF-CONN,A918ACONN2_A91829027Q1NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ2NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ3NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ4NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ5NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ6FET_N_SOT23LF-2N7002L,FET,C741ASOT23AQ7NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ8FET_N_DUAL_SMLF-2N7002DW,FET,DASSOP6_53_65MAQ9NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ10NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ11NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ12NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ13NPN_SMLF-MMBT3904,EMPTY,C52245ASOT23AQ14NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ15NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ16NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ17PNP_2C_SMLF-BCP69T1G,IC,C57519ASOT223AQ18PNP_2C_SMLF-BCP69T1G,IC,C57519ASOT223AQ19NPN_DUAL_SSOPLF-MBT3904,EMPTY,ASSOP6_53_65MAQ20NPN_SMLF-MMBT6427LT1,IC,C84122ASOT23AQ21FET_N_DUAL_SMLF-2N7002DW,FET,DASSOP6_53_65MAQ22FET_N_DUAL_SMLF-FDY3000NZ,FET,ASSOP6_48_5MAQ23NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ24NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ25NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ26FET_N_SOT23LF-MGSF1N02LT1,FET,ASOT23AQ27NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ28NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ29NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ30NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ31NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ32NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ33NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ34NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ35NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ36NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ37NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ38PNP_SMLF-MMBT3906,IC,C73455-001SOT23AQ39NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ40NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ41NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ42NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ43NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ44FET_N_DUAL_SMLF-2N7002DW,FET,DASSOP6_53_65MAQ45NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ46FET_N_DUAL_SMLF-2N7002DW,FET,DASSOP6_53_65MAQ47PNP_SMLF-MMBT3906,IC,C73455-001SOT23AQ48PNP_2C_SMLF-BCP69T1G,IC,C57519ASOT223AQ49NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ50NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ52NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ53NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ54NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ55FET_N_SOT23LF-MGSF1N02LT1,FET,ASOT23AQ56NPN_SMLF-MMBT3904,IC,C52245-001SOT23AQ57NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ59NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MAQ60NPN_DUAL_SSOPLF-MBT3904,XSTR,CASSOP6_53_65MARP1RPAK8_4_SMLF-4.7K,5%,1/16W,IC,ASCRA0804ART1THERMISTOR_SMLF-IC,6.8K,C14407ASTR0603AS1SWITCH_D90553001_SMLF-IC,D9055ASSW2RPBS2SWITCH_D90553001_SMLF-IC,D9055ASSW2RPBS3NC7SZ66_SMLF-IC,D37827-001-GNDASOT23_5AS4SWITCH_SMTA62367002_SOICLF-IC,ASSW16RDATP1TP_TP-EMPTY,TP_C22P10C26TP_C22P10C26TP2TP_TP-EMPTY,TP_C20P10TP_C20P10TP3TP_TP-EMPTY,TP_C20P10TP_C20P10U1MIC37252_SSOPLF-IC,C87764-001-ASPAK_5U2SI4511DY_SMLF-IC,D10344-001SOI8_15_50IAU3TTL2G125_SMLF-74HCT2G125DP,IC,ATSSOP8_12_65MAU4IRU3037_SMLF-IC,C73809-001-GNDASOI8_15_50IAU6PILOT_II_BGA-IC,D79935-001BGA484_1_1MAU7ADM561_SSOPLF-IC,D26425-001SSOP28_22_65MAU8K4T51163_BGALF-IC,D71357-001BGA84_3_8MBU9ISL90727_SMLF-IC,E47385-001SSOP6_53_65MAU10TLV431_SMLF-IC,C88283-001SOT23_5AU11TTL1G07_SOTLF-IC,C88419-001-GNASSOP5_53_65MAU12QH25F640_SMLF-IC,D86376-001SOI16_30_50IAU13TTL14_SMLF-74LVC14,IC,C88257-0BSSOP14_18_65MAU14ISL90728_SMLF-IC,E18644-001SSOP6_53_65MAU15AT25320_SOIC-IC,C83136-001-GNDASOI8_15_50IAU16LM358_B_SMLF-IC,D69827-001-GNDASOI8_15_50IAU1774CBT3244_SM-74CBT3244,IC,6668BTSSOP20_18_65MAU1874CBT3244_SM-74CBT3244,IC,6668BTSSOP20_18_65MAU19TPS51100_MSOPLF-IC,D10239-001-AMSOP10_12_50MAU20SC2612_SMLF-IC,C92211-001SOI8_15_50ICU21TTL74_SMLF-74LVC74,IC,D11281-0BSSOP14_18_65MAU22GD75232_SMLF-IC,C85357-001-GNDASSOP20_22_65MAU23TTL125_A_SMLF-74LVC125,IC,C884BSOI14_15_50IBU24STS8DNF3LL_SOICLF-IC,C93362-001SOI8_15_50IAU25AT24C32_SOICLF-EMPTY,C83115-00ASOI8_15_50IAU2689HIO524G2PS_BGALF-IC,E31248-0AFBGA324_1_1MAU27CK505_B_SMTLF-IC,D85246-002SSOP64_24_50MAU28LM358_B_SMLF-IC,C71987-001-GNDASOI8_15_50IAU29AT26DF321_SOIC8LF-EMPTY,D64145ASOI8_20_50IBU30QH25F640_SMLF-IC,D86376-001XSOI16_30_50IAU31LM75_SMLF-IC,D35304-001-GND=GNAMSOP8_12_65MAU32AT26DF321_SOIC8LF-EMPTY,D64145ASOI8_20_50IBU33QH25F640_SMLF-EMPTY,D86376-001SOI16_30_50IAU34IBEXPEAK_EXT_BGAALF-IC,E45187-ABGA951_5_IBX_AU35ADM803_SMLF-IC,D61125-001SOT323AU36AT24C64_SOICLF-IC,C47049-001-GASOI8_15_50IAU37TTL3125_SOICLF-74CBTLV3125,IC,BSSOP14_18_65MAU38IRU3037_SMLF-IC,C73809-001-GNDBSOI8_15_50IAU39PCA9515_A_TSSOPLF-IC,C90166-001TSSOP8_12_65MAU40LM4040_SOTLF-IC,D11613-001SOT23AU41TTL2G14_SMLF-74LVC2G14,IC,D184BSSOP6_67_95MAU4274CBT3244_SM-74CBT3244,IC,6668BTSSOP20_18_65MAU43MIC37252_SSOPLF-IC,C87764-001-ASPAK_5U44TPM_SMLF-EMPTY,D94919-002TSSOP28_18_65MBU45SI4511DY_SMLF-IC,D10344-001SOI8_15_50IAU58FET_N_DUAL_TMP_MLFPLF-BSC072N0AMLFP6_25_50IAXBT1VERT_BATT_3PIN_THLF-3PVERT,C68AVERT_BATT_3PINY1OSC_B_ALLLF-50MHZ,OSC,D34520-0ASOSR1310AY2CRYSTAL_SMLF-14.31818MHZ,IC,A9ASMY4719AY3CRYSTAL_SMLF-25MHZ,IC,A93545-0ASMY4719AY4CRYSTAL_3215LF-32.768KHZ,IC,C1ASMY3215A
xnima_irumei 发表于 2017-5-15 22:42
longxuekai 发表于 2017-5-16 00:07
来看看来了
学海无涯 发表于 2017-5-16 07:14
好啊,电脑板!
单枪舞九州 发表于 2017-5-16 08:33
逆天
chjchjchj816 发表于 2017-5-16 08:38
高手啊,真的是高
vagrant_2k 发表于 2017-5-16 08:42
ilpuyi 发表于 2017-5-16 08:47
好东西啊
james_zhangwk 发表于 2017-5-16 08:48
cdl511 发表于 2017-5-16 08:51
谢谢分享
页: [1] 2 3 4 5 6 7 8
查看完整版本: intel  I5电脑主板 LGA1156  PCB共享
