Acer宏碁一体机电脑主板Q77 B75H2-AS PCB文件共享
实物图
REFDESCOMP_DEVICE_TYPESYM_NAMEBAT1BATTERY_1BATTERY_1CLRSRTCJ2X1J2X1CLR_CMOS1J3X1J3X1CM1CMM21_1CMM21_1CM2CMM21_1CMM21_1CN8SW_4P_1SW_4P_1CODEC1LQFP48LQFP48COM1J5X2_2MM_USB_1394_1J5X2_2MM_USB_1394_1CPU1LGA1155_SKT-Q67H2-AS_1LGA1155_SKT-Q67H2-AS_1CPU_FANWTB_1D25_4PWTB_1D25_4PC_INTRUSIONJ2X1J2X1D2SOD_523SOD_523D3BAT54_132_2BAT54_132_2D4BAT54_132_2BAT54_132_2D5SMA_2SMA_2D6BAT54_132_2BAT54_132_2D71N41481N4148D8SMA_2SMA_2D9BAT54_132_2BAT54_132_2D10BAT54_132_2BAT54_132_2D11BAV99_132_2BAV99_132_2D12BAV99_132_2BAV99_132_2D13BAT54_132_2BAT54_132_2D14FPC_4P10_R_1FPC_4P10_R_1D15BAT54_132_2BAT54_132_2D161N41481N4148DIMM1DDR3_204P_52S-LINKTEK_2DDR3_204P_52S-LINKTEK_2DIMM2DDR3_204P_92S-LINKTEK_1DDR3_204P_92S-LINKTEK_1DISABLE_ME1J3X1J3X1DPCONN_DISPLAYPORTX2_40P-FOXCONNCONN_DISPLAYPORTX2_40P-FOXCONNDVI1DVI_29P_MB_1DVI_29P_MB_1EC1EC5_10_H13MM_1PEC5_10_H13MM_1PEC2EC2_5_H7MMEC2_5_H7MMEC18OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MMEC19EC2D5_6D3_H5MMEC2D5_6D3_H5MMEC20EC2D5_6D3_H5MMEC2D5_6D3_H5MMEC21EC2D5_6D3_H5MMEC2D5_6D3_H5MMEC22EC3D5_8_H11MM_1PEC3D5_8_H11MM_1PEC23EC2D5_6D3_H11MMEC2D5_6D3_H11MMEC24OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MMEC25OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MMER1R0402R0402ER2R0402R0402ER3R0402R0402ER4R0402R0402ER5R0402R0402ER6R0402R0402F1FUSE_SMD_1FUSE_SMD_1F2F1812F1812F_PANELWTB_1D25_4PWTB_1D25_4PF_USB2USB23_13P3R-A-LOTESUSB23_13P3R-A-LOTESF_USB3USB23_13P3R-A-LOTESUSB23_13P3R-A-LOTESGPIO0J2X1J2X1GPIO1J2X1J2X1H1HOLE8_C132D120-276_2HOLE8_C132D120-276_2H2HOLE8_C132D120-315_2HOLE8_C132D120-315_2H3HOLE8_C132D120-276_2HOLE8_C132D120-276_2H4HOLE8_TS423X354BC354D120_3HOLE8_TS423X354BC354D120_3H5HOLE8_TS568X354BC354D120_3HOLE8_TS568X354BC354D120_3H6HOLE8_C172D160-276_4P_1HOLE8_C172D160-276_4P_1H8HOLE8_TS728X354BC354D120_3HOLE8_TS728X354BC354D120_3H9HOLE8_C172D160-276_6P_1HOLE8_C172D160-276_6P_1INT_SPK1J4X2_4PJ4X2_4PIP1J3X2_IP_SIGNAL1346_1J3X2_IP_SIGNAL1346_1J1DC_PWR_JACK_10P-SINGATRONDC_PWR_JACK_10P-SINGATRONJ22X30_XDP_CONN-NMNP2X30_XDP_CONN-NMNPJ32X30_XDP_CONN-NMNP2X30_XDP_CONN-NMNPJMIC1AUDIO_JACK_6P-DIAAUDIO_JACK_6P-DIAJPHONE1AUDIO_JACK_6P-DIAAUDIO_JACK_6P-DIAJS1AUDIO_1AUDIO_1L1FB0805FB0805L2FB0805FB0805L3FB0805FB0805L4FB0805FB0805L6CHOKE_R56M_R60_MR60CHOKE_R56M_R60_MR60L7CHOKE_R56M_R60_MR60CHOKE_R56M_R60_MR60L8CHOKE_R56M_R60_MR60CHOKE_R56M_R60_MR60L9CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2L10CHOKE_NLC252018_SMD_2PCHOKE_NLC252018_SMD_2PL11FB0805FB0805L12FB0805FB0805L13CHOKE_R56M_R60_MR60CHOKE_R56M_R60_MR60L14FB0805FB0805L15CHOKE_4R7_PT2D65MM_SMDCHOKE_4R7_PT2D65MM_SMDL16L0805L0805L17FB0805FB0805L18FB0805FB0805L19FB0805FB0805L20L0805L0805L21L0805L0805L22CHOKE_2R2N_SMD_2PCHOKE_2R2N_SMD_2PL23FB0603FB0603L24CMM21_1CMM21_1L25CMM21_1CMM21_1L26CHOKE_R56M_R60_MR60CHOKE_R56M_R60_MR60L27FB0805FB0805L29FB0805FB0805L30FB0805FB0805LAN1QFN48_PT04-4D4X4D4MM_1QFN48_PT04-4D4X4D4MM_1LAN2FBGA121_BCM5761FBGA121_BCM5761LED1LED_3D6MM_2P-ECELLED_3D6MM_2P-ECELLED2LED_3D6MM_2P-ECELLED_3D6MM_2P-ECELLED3LED_3D6MM_2P-ECELLED_3D6MM_2P-ECELLPT1J13X2_2MM_LPT_1J13X2_2MM_LPT_1ME_TEST1J3X2J3X2OBRSW_4P_1SW_4P_1P1SHORT2-NMNPSHORT2-NMNPP2SHORT2-NMNPSHORT2-NMNPPCH1BGA942_CPTBGA942_CPTQCTL1Q_TDSON8-GDS-4Q_TDSON8-GDS-4QMH1TO252_GDSTO252_GDSR132SHORT2-NMNPSHORT2-NMNPR133SHORT2-NMNPSHORT2-NMNPROM1SOP8_W210_PT50SOP8_W210_PT50ROM2SOP8_W210_PT50SOP8_W210_PT50RT1R0402R0402RT2R0402R0402RT3R0402R0402RT4R0402R0402RT5R0402R0402SATA_HDD1SATA-HDD_22P_SMD-R-ALLTOPSATA-HDD_22P_SMD-R-ALLTOPSATA_ODD1SATA-ODDCONN_13PSATA-ODDCONN_13PSBT1BAT54_132_2BAT54_132_2SBT2BAT54_132_2BAT54_132_2SBT3BAT54_132_2BAT54_132_2SBT4BAT54_132_2BAT54_132_2SBT5BAT54_132_2BAT54_132_2SBT6BAT54_132_2BAT54_132_2SCN1MOLEX_67910-001_MINIPCIE-HALFMOLEX_67910-001_MINIPCIE-HALFSCN2MOLE_SD-48099-6700_MINIPCIE-PADMOLE_SD-48099-6700_MINIPCIE-PADSD1FPC_4P10_R_1FPC_4P10_R_1SD2FPC_4P10_R_1FPC_4P10_R_1SD31N41481N4148SD41N41481N4148SD5FPC_4P10_R_1FPC_4P10_R_1SEC1EC5D6_6D6MM_SMDEC5D6_6D6MM_SMDSEC2EC2D5_6D3_H9MMEC2D5_6D3_H9MMSEC3EC2D5_6D3_H9MMEC2D5_6D3_H9MMSEC4EC3D5_8_H11MM_1PEC3D5_8_H11MM_1PSEC5EC2D5_6D3_H9MMEC2D5_6D3_H9MMSEC6EC5D6_6D6MM_SMDEC5D6_6D6MM_SMDSEC7EC2D5_6D3_H9MMEC2D5_6D3_H9MMSEC8EC2_5_H7MMEC2_5_H7MMSEC9EC2D5_6D3_H11MMEC2D5_6D3_H11MMSEC10EC3D5_8_H9MM_1PEC3D5_8_H9MM_1PSEC11OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MMSEC12OSCON3D5_8_H8MM_1POSCON3D5_8_H8MM_1PSEC13EC2D5_6D3_H11MMEC2D5_6D3_H11MMSEC14OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MMSH1HOLE_TC230BC200D166HOLE_TC230BC200D166SH2HOLE_TC230BC200D166HOLE_TC230BC200D166SH3HOLE_TC256BC60D48HOLE_TC256BC60D48SH4HOLE_TC256BC60D48HOLE_TC256BC60D48SL19CHOKE_4R7M_PT6D7X6D4MMCHOKE_4R7M_PT6D7X6D4MMSL20CHOKE_4R7M_PT6D7X6D4MMCHOKE_4R7M_PT6D7X6D4MMSL21CHOKE_4R7M_PT6D7X6D4MMCHOKE_4R7M_PT6D7X6D4MMSL22CMM21_1CMM21_1SL23CMM21_1CMM21_1SL24CMM21_1CMM21_1SL25CMM21_1CMM21_1SL26FB0805FB0805SP1SHORT2-NMNPSHORT2-NMNPSP2SHORT2-NMNPSHORT2-NMNPSPDIF_OUTJ4X1_SPDIFO_2PJ4X1_SPDIFO_2PSPI_DEBUG1J6X2_PT1D27MM_SMD_2PJ6X2_PT1D27MM_SMD_2PSQ1SOT23_GDS_2SOT23_GDS_2SQ2SOT23_GDS_2SOT23_GDS_2SQ3SOT23_GDS_2SOT23_GDS_2SQ4SOT23_GDS_2SOT23_GDS_2SQ5SOT23_GDS_2SOT23_GDS_2SQ7SOT23_BCE_2SOT23_BCE_2SQ8SOT23_GDS_2SOT23_GDS_2SQ9SOT23_BCE_2SOT23_BCE_2SQ10SC70_6LSC70_6LSQ11SC70_6LSC70_6LSQ12SC70_6LSC70_6LSQ13SOT363_6PSOT363_6PSQCL1Q_TDSON8-GDS-4Q_TDSON8-GDS-4SQCL2Q_TDSON8-GDS-4Q_TDSON8-GDS-4SQCL3Q_TDSON8-GDS-4Q_TDSON8-GDS-4SU1SOT23_6P_2SOT23_6P_2SU2SOT23_6P_2SOT23_6P_2SU3SOT23_6P_2SOT23_6P_2SU4MSOP10_W120_PT05MSOP10_W120_PT05SU5MSOP10_W120_PT05MSOP10_W120_PT05SU6MSOP10_W120_PT05MSOP10_W120_PT05SU7MSOP10_W120_PT05MSOP10_W120_PT05SU8SOP8_W150_PT50SOP8_W150_PT50SU9SOT23_6P_2SOT23_6P_2SU10SOT23_6P_2SOT23_6P_2SU11SOT23_6P_2SOT23_6P_2SU12QFN20_ISL95870B_1QFN20_ISL95870B_1SU13SOP8_W150_PT50SOP8_W150_PT50SU14SOP8_W150_PT50SOP8_W150_PT50SU15SOT23_6P_2SOT23_6P_2SX1ETXTALS-SPADETXTALS-SPADSX2CRYSTAL_2P_PT4D1MM_SMDCRYSTAL_2P_PT4D1MM_SMDSY1CRYSTALCRYSTALSYS_FANWTB_1D25_4PWTB_1D25_4PTCMJ10X2_TPM_4P-ACERJ10X2_TPM_4P-ACERU1SOT23_6P_2SOT23_6P_2U2QFN48_PT05-ASM1442_1QFN48_PT05-ASM1442_1U3SOP8_W150_PT50SOP8_W150_PT50U4SOT23_6P_2SOT23_6P_2U5QFN48_PT04-4D4X4D4MM-ASUS1QFN48_PT04-4D4X4D4MM-ASUS1U6SOT23_6P_2SOT23_6P_2U7PSOP8_W150_PT50_PAD-UP7719B_1PSOP8_W150_PT50_PAD-UP7719B_1U8SHORT2-NMNPSHORT2-NMNPU9SOT23_8P_1SOT23_8P_1U10SOT23_8P_1SOT23_8P_1U11SHORT2-NMNPSHORT2-NMNPU12SHORT2-NMNPSHORT2-NMNPU14SHORT2-NMNPSHORT2-NMNPU15SHORT2-NMNPSHORT2-NMNPU16SHORT2-NMNPSHORT2-NMNPU17SHORT2-NMNPSHORT2-NMNPU18SOP8_W210_PT50SOP8_W210_PT50U19SOP8_W150_PT50-92X110SOP8_W150_PT50-92X110U20SOT223_AOI_3PSOT223_AOI_3PU21SOP8_W150_PT50SOP8_W150_PT50U22DFN10_RT8106A_1DFN10_RT8106A_1U23DFN10_RT8106A_1DFN10_RT8106A_1U24QFN24_UP6181_1QFN24_UP6181_1U25TQFN42_2TQFN42_2U26QFP128QFP128U27SSOP28_W278_H79SSOP28_W278_H79U28TSSOP28_W170_PT065TSSOP28_W170_PT065U29PSOP8_W150_PT50_PAD-UP7719B_1PSOP8_W150_PT50_PAD-UP7719B_1U30SOP8_W150_PT50-104X120SOP8_W150_PT50-104X120U31SOT23_8P_1SOT23_8P_1U32DFN10_NCP1589A_1DFN10_NCP1589A_1U33SOT23_6P_2SOT23_6P_2USBUSBX4_2USBX4_2USB3LAN1RJ45_USB3_32PRJ45_USB3_32PX1CRYSTAL_2P_SMD-HCM49SCRYSTAL_2P_SMD-HCM49S PCB文件来了 allegro16.6格式。
10金币。。
吴老大逆天PCB 膜拜高端作品 吴老大逆天 谢谢楼主分享。
