SR2990-485水分采集板
CommentDescriptionDesignatorFootprintLibRefQuantity3.6VB1BATTERY_B115pC1, C4080521000pC2080510.1uFC308051104C5, C6, C11, C1408054100uF 16VC7CD3.2MM8.2110uC8120611nFC912061220μF 50C12, C13CD-SMD-10X1021nFC18, C19, C20, C21, C22, C25, C27080571uF/400VC23CD2.5MM51100PC2808051YELLOWD1LED(2.54MM)1SS14D2, D5, D6, D8, D11, D121206-D6P00800SBD3, D7, D9ELL473NPND4SOT-231redD10LED(2.54MM)1PTC-30-110F1, F2120621A 短路F312061ICSPJ1SIP5AM1CON24J2, J3SIP24C-5.0-2LAY2J4, J5B32210uHL1L1211A 47uHL2L-12.51SZ05_STDM1SHUNCOM1PowerP1CON2(3.81MM)12N7002Q3, Q4, Q5SOT-23310KR1, R2, R3, R4, R8, R9, R10, R11, R12, R13, R14, R17, R20, R21, R340805151KR5, R22080523kR6, R7080522.7kR1508051100R1608051100KR18, R1908052330 R23080514.7KR2508051510KR27, R2808052110R2908051110KR300805118kR3108051300R3308051PIC16F886U1SO-28-PIC181DS1302U2SO-8/3.91MAX485U3SO-8/3.91LM2575U4TO-263-51lm324U5SOP-141LM385-2.5U6TO-92B124C1024U7SO-8/3.91MIC5233U8SOT-23-5116MHzY1XTAL1132.768KY2327681 CommentDescriptionDesignatorFootprintLibRefQuantity3.6VB1BATTERY_B115pC1, C4080521000pC2080510.1uFC308051104C5, C6, C11, C1408054100uF 16VC7CD3.2MM8.2110uC8120611nFC912061220μF 50C12, C13CD-SMD-10X1021nFC18, C19, C20, C21, C22, C25, C27080571uF/400VC23CD2.5MM51100PC2808051YELLOWD1LED(2.54MM)1SS14D2, D5, D6, D8, D11, D121206-D6P00800SBD3, D7, D9ELL473NPND4SOT-231redD10LED(2.54MM)1PTC-30-110F1, F2120621A 短路F312061ICSPJ1SIP5AM1CON24J2, J3SIP24C-5.0-2LAY2J4, J5B32210uHL1L1211A 47uHL2L-12.51SZ05_STDM1SHUNCOM1PowerP1CON2(3.81MM)12N7002Q3, Q4, Q5SOT-23310KR1, R2, R3, R4, R8, R9, R10, R11, R12, R13, R14, R17, R20, R21, R340805151KR5, R22080523kR6, R7080522.7kR1508051100R1608051100KR18, R1908052330 R23080514.7KR2508051510KR27, R2808052110R2908051110KR300805118kR3108051300R3308051PIC16F886U1SO-28-PIC181DS1302U2SO-8/3.91MAX485U3SO-8/3.91LM2575U4TO-263-51lm324U5SOP-141LM385-2.5U6TO-92B124C1024U7SO-8/3.91MIC5233U8SOT-23-5116MHzY1XTAL1132.768KY2327681 看看怎么样. 回复才能看,看看。 看看了,谢谢
