MN101EF51A+TDA7388 +SGM9119 车载主板原理图共享 PADS logic格式
PADS9.5格式的没有PCB文件, 为了避免大家下载到没用的。所以把使用到的元件贴出来。有需要的下载。
NamePart TypePCB DecalValueANT96ANT2ANT-CANTCN1CON4_54P/1.25MMCON4CN2CON4_54P/1.25MMCON4CN3CN50P_HSDCN50PA05TAINNOLUX TFTCON1CON-SMT-60PIN-HANNSTARFPC-60PIN-0.5MMD1DIODEDIODE_DO201AD_7MMIN5401D2TVSSTVS0603ESDD3TVSSTVS0603NCD4DSSD2010SS14D5DIODESD0805IN4148WD6DIODESD0805IN4148WD8DSSD2010SS14D9BAT54CSOT23-BAT54BAT54CD10TVSSTVS06030603ESDA-LPD11TVSSTVS06030603ESDA-LCD12DIODESD0805IN4148WD13TVSSTVS06030603ESDA-LPD15BAT54CSOT23-BAT54BAT54CD16DIODE_DIACESD0603ESDD17DIODE_DIACESD0603ESDD21TVSSTVS06030603ESDA-LCD23TVSSTVS06030603ESDA-LCD24TVSSTVS06030603ESDA-LCD26DIODE_DIACESD0603ESDD27TVSSTVS0603ESDD28DIODE_DIACESD0603ESDD30DIODESD08051N4148D31DIODESD08051N4148F1FUSESF1308500MAF2FUSESF1308500MAF3FUSESF1308500MAF4FUSESF1308200MAFB1INDUCTOR_0_2RES0805600RFB2INDUCTOR_0L0603600RFB3FBL0805SZ2012K421TFFB4FBSLB0805SZ2012K601TFFB5FBL0805FB310FB8FBSLB0805SZ2012K601TFFB11INDUCTOR_0_2RES0805600RFB12INDUCTOR_0L0603600RFB13FBL0805SZ2012K421TFJ1JACK-26PINJACK-26PINAAAJ2DDTAPJ3FM-4750DIP-10PIN-FMTDQ-30FMV-001J5DDTAPJ6CON-4PIN-IPODSIP4-78D74-32DUSB_JK CONJ7DDTAPJ8DDTAPL1FBSL08051.8uHL2INDL-5X510uH/1.6AL3FBSL08051.8uHL4IND_18X25MML-13/2535mH非晶呃流线圈L5INDL-5X510uH/1.6AL6FBSL08051.8uHL7INDUCTOR/CHIPCF2522NCL15CD74IND-SMT-CD7522UHL21INDUCTOR/CHIPIND-SMD-CDH8B28/38/43/58NCL51FBSL08051.8uHQ1NPNSOT239014Q2NPNSOT239014Q3NPNSOT239014Q4PNPSOT238550Q5NPNSOT239014Q6PNPSOT238550Q7PMOSSOT23-MOSDMP3098LQ8NPNSOT898050Q9NPNSOT239014Q10PMOSSOT23-MOSDMP3098LQ11PMOSSOT23-MOSDMP3098LQ12NPNSOT239014Q13NPNSOT239014Q14NPNSOT233904Q15PNPSOT23MMBT3906Q16PNPSOT238550Q17NPNSOT239014Q18NPNSOT239014Q19NPNSOT239014Q20NPNSOT23MMBT3904Q21NPNSOT233904Q23PMOSSOT23-MOSDMP3098LQ24NPNSOT233904Q25PNPSOT238550Q26PNPSOT238550Q27PMOSSOT23-MOSDMP3098LQ28NPNSOT239014SC2SCREW-2.6-3.0MMSCREW-2.6MM-4SC3SCREW-2.6-3.0MMSCREW-2.6MM-4SC4SCREW-2.6-3.0MMSCREW-2.6MM-4TP1TP-2TEST-1.0TP-2TP2TP-2TEST-1.0TP-2TP3MARKMARKMARKTP4MARKMARKMARKTP5MARKMARKMARKTP7TP-2TEST-1.0TP-2TP8TP-2TEST-1.0TP-2TP9TP-2TEST-1.0TP-2TP10TP-2TEST-1.0TP-2TP114MARKMARKMARKT]1JACK60PIN_2.0MMJACK_60PIN_2.0MMU1MN101EF51A_1QFP44-31D5-472MN101EF51AU2RT9164-33CG//AIC1117-33CY_0SOT2231117/3.3VU3MTK_CON126_1.27MMMTK_CON126_1.27MMU4SGM9119SOP8-25D59-197SGM9119U6MP3302SOT23-5MP3302U7MP1541SOT23-5MP1541U878MXXTO-25278M08/NCU11TDA7381_0TDA7386ATDA7388U16HT7133SOT89-1HT7533Z1DZSD0805-15.6VZ2DZSD0805-15.6VZ3DZSD0805-10RZ4DZSD0805-1BZT52C9V1Z5DIODESD0805IN4148WZ6DZSD0805-1BZT52C15VZ7DZSD0805-1BZT52C6V8Z10DZSD0805-13V9ZD4BAV99SOT23-BAV99BAT54SZD5BAV99SOT23-BAV99BAT54S
支持 Thanks for sharing. 看看 :lol谢谢分享 感谢分享:victory:
