RK3399 VR & &TABLET 原理图
原理图有以下元件
NamePart TypePCB DecalValueANT6001ANT_1P2GANT_JACKANT_JACKANT6002ANT_1P1GANT2_34R00X5R00X12R20N2430GNDANT6003ANT_1P2GANT_JACKANT_JACKANT6004ANT_1P1GANT2_34R00X5R00X12R20N2430GNDJ4501LCM0200CE1A0_1OV9650FSLOV2659J4601CMK-CB0077-FV1_2OK-22F024-04AXT530124J4602CMK-CB0077-FV1_2OK-22F024-04AXT530124J5001EDP_FLEX_0AJ752-B-S-51eDP_FlexJ5201LCD_DUAL_MIPI-61P_1FH36W-61S-03SHWLCD_DualMIPI-61PJ5301X381DLNO1_0FCON-39P-06X381DLNO1J5302X381DLNO1_0FCON-39P-06X381DLNO1J6101ANT3DSANTRFANT5220J6201ANT3DSANTRFANT5220J7001PHONEJACK_STEREO_SW_2AJ302B-5-SAJ302B-5-SJ7002CON2_0R1206CON2J7003CON2_0R1206CON2J7101CON2_0R1206CON2J7102PHONEJACK_7PPJ5_D3R50_PJ3536PJ-3536J7103CON2_0R1206CON2J7501TOUCH_SCREEN_0FPC12P_05MMTouch_screenJ7601TP-54PD97-L3312AD97-L3312AJ7701TP-54PD97-L3312AD97-L3312AJ7801CLAP070LF02CW_8FPC50PIN_0.MM_DNCON50J8101TFCARD_SOCKETTF9_CKT01_009DTF-CKT01-009DJ8201HDMI_CHDMI-19PF_CHDMI_CJ8501HDMI_CHDMI-19PF_CHDMI_CJ8901USB31_TYPE_CUSB_TYPEC_115H0USB_TYPEC_115H0L2001INDUCTORS_OF_FERRITEIND_8282302.2uHL2201INDUCTORS_OF_FERRITEIND_3030153.3uHL2202INDUCTORS_OF_FERRITEIND_2520120.24uHL2203INDUCTORS_OF_FERRITEIND_3030153.3uHL5001INDUCTORS_OF_FERRITEIND_4040204.7uHL5101INDUCTORS_OF_FERRITE_2IND-4X410uH/1AL5201INDUCTORS_OF_FERRITE_2IND-4X410uH/1AL5301INDUCTOR_1IND-3X34.7uHL5302INDUCTOR_1IND-3X310uHL5303INDUCTOR_1IND-3X34.7uHL5304INDUCTOR_1IND-3X34.7uHL5305INDUCTOR_1IND-3X310uHL5306INDUCTOR_1IND-3X34.7uHL6001INDUCTORS_OF_FERRITEIND_3030124.7uHL6101INDUCTORS_OF_FERRITE_2IND-3X3SWPA3012S4R7MT/1AL6201INDUCTORS_OF_FERRITE_2IND-3X3SWPA3012S4R7MT/1AL8501INDUCTORL0603BLM18PG221SN1L21001INDUCTORS_OF_FERRITE_2IND-5X5PCMB051H-2R2MS/6ALCD5101LD089WU1_1FH26-45S-03SHWLTL089CL02-W02MIC7001MICMIC-4020MICMIC7101MIC_2MIC2_4020MIC-4020Q237MOSFET_NSOT_3232SK3018Q238MOSFET_NSOT_3232SK3018Q5301NPN4SOT238050Q5302FET_P_MOSSOT23WPM2015-3/TRQ5303NPN4SOT238050Q8501NPNSOT_232SC2712Q8502MOSFET_PSOT_23WPM2341-3/TRQ8503NPNSOT_23S8050Q21001NPNSOT_23S8050Q21002MOSFET_PSOT_23WPM2341-3/TRQ23009NPNSOT_23S8050Q23010MOSFET_N_8L1DFN8L_3R00X3R00X0R90_TCSD17551Q3AQ23011MOSFET_N_8L1DFN8L_3R00X3R00X0R90_TCSD17551Q3AQ23012MOSFET_N_8L1DFN8L_3R00X3R00X0R90_TCSD17551Q3AQ23013MOSFET_N_8L1DFN8L_3R00X3R00X0R90_TCSD17551Q3AQ23019MOSFET_NSOT_3232SK3018Q23020MOSFET_NSOT_3232SK3018Q23021MOSFET_NSOT_3232SK3018Q23022MOSFET_P_8L_1HSMT8_3R30X3R30X0R90RQ3E120BNQ23023MOSFET_P_8L_2DFN8L_3R00X3R00X0R90_TCSD25402Q3ASW1501KEY_4PINSW2_TS_041VOL+/RECOVERYSW1502KEY_4PINSW2_TS_041VOL-SW1503KEY_4PINSW2_TS_041HOMESW1504KEY_4PINSW2_TS_041ESCSW1505KEY_4PINSW2_TS_041MENUSW21001KEY_4PINSW2_TS_041RESETSW21002KEY_4PINSW2_TS_041POWERSW23001SW4P_0SW22Reset_KEYSW23002KEY_4PINSW2_TS_041POWERU1000DSP_RK3399BGA828_21R00X21R00X1R61RK3399U2001CHARGER_BQ25700_0QFN32_4R00X4R00X1R00_TBQ25700U2201DCDC_SY8088SOT_23_5SY8088AACU2202DCDC_SY827CSP20_1R96X1R56X0R66SYR837U2203LDO_PT5108SOT_23_5PT5108E23E-30U2204LDO_PT5108SOT_23_5PT5108E23E-15U2205DCDC_SY8088SOT_23_5SY8088AACU2207LDO_PT5108SOT_23_5PT5108E23E-28U2208LDO_PT5108SOT_23_5PT5108E23E-28U3200DDR3_16BITFBGA96_14R00X11R00X1R20H5TC4G63AFRU3201DDR3_16BITFBGA96_14R00X11R00X1R20H5TC4G63AFRU3202DDR3_16BITFBGA96_14R00X11R00X1R20H5TC4G63AFRU3203DDR3_16BITFBGA96_14R00X11R00X1R20H5TC4G63AFRU3600LPDDR3_32BIT_178PFBGA178_13R00X11R50X1R20K4E8E304EE-EGCEU3601LPDDR3_32BIT_178PFBGA178_13R00X11R50X1R20K4E8E304EE-EGCEU4001INAND_EMMC_169BGA169_18R00X14R00X1R20KLM8G1GEAC-B031U5001DCDC_SY7203DFN10_3R00X3R00X0R80_TSY7203DBCU5101LED_DRIVE-BLSOT_23_6MP1488/UP6003AMT6U5201LED_DRIVE-BLSOT_23_6MP1488/UP6003AMT6U5301TPS65632_0WQFN16_3R00X3R00X1R00_TTPS65632U5302TPS65632_0WQFN16_3R00X3R00X1R00_TTPS65632U6001MODULE_AP6354MD44_AP6XXX_13RX15RX1R5AP6354U6101WIFI-AP6XXX_0AP6XXXAP6335/AP6330/XZ3660U6201WIFI-AP6XXX_0AP6XXXAP6212/XZ3538U7001ALC5651_3QFN40_5R00X5R00X1R00ALC5651U7002AMPLIFIER_PT1505MSOP8_3R00X3R00X1R10PT1505EMSHU7003AMPLIFIER_PT1505MSOP8_3R00X3R00X1R10PT1505EMSHU7101CODEC_ES8316QFN32_4R00X4R00X0R90_TES8316U7102AMPLIFIER_PT1505MSOP8_3R00X3R00X1R10PT1505EMSHU7103AMPLIFIER_PT1505MSOP8_3R00X3R00X1R10PT1505EMSHU7601TOUCH_CT363QFN68_8R00X8R00X1R00_TCT363U7701TOUCH_FT5506QFN68_8R00X8R00X0R80_TFT5506U7801TOUCH_GSL3680QFN64_8R00X8R00X0R90_TGSL3680BU8001SENSOR_LIS3DHLGA16_3R00X3R00X1R00LSM303DU8002SENSOR_AK8963CBGA14_1R59X1R59X0R57AK8963CU8003SENSOR_ICM20602LGA16_3R00X3R00X0R80ICM-20602U8004SENSOR_LIS3MDLLGA12_2R00X2R00X1R00LIS3MDLU8005SENSOR_MPU6500QFN24_3R00X3R00X0R90MPU6500U8006SENSOR_LSM330LGA24_3R50X3R00X1R00LSM330TR U8007SENSOR_HALLSOT_23HAL248TWCLU8008BMC156_0LGA12P_22X22BMC156U8009LSM6DS3_2LGA14L_2R5X3LSM6DS3U8010SENSOR_CM3217/18OPLGA6_2R35X1R80X1R00CM32181U8201ESD_TPD4E05U06SON10_2R50X1R00X0R50TPD4E05U06U8202ESD_TPD4E05U06SON10_2R50X1R00X0R50TPD4E05U06U8203ESD_TPD4E05U06SON10_2R50X1R00X0R50TPD4E05U06U8401LDO_PT5108SOT_23_5PT5108E23E-18U8501LM1086_2SOT_23_6NL27WZU04U8502INTERFACE_TC358749VFBGA80_7R00X7R00X1R00TC358748XBGU8503DS8008_1SLP2510P8ESD5304DU8504DS8008_1SLP2510P8ESD5304DU8505DS8008_4SOT25PT5108E23E-12U8506DS8008_4SOT25PT5108E23E-18U8903USB_FUSB302MLP14_2R50X2R50X0R80FUSB302BU8906ESD_ESDA6V8ULSOT_23ESD5302F U21001DCDC_NB679QFN12_2R00X3R00X1R00NB679GDU21002DCDC_NB680QFN12_2R00X3R00X1R00NB680GDU21003PMIC_RK808QFN68_7R00X7R00X0R80_TRK808-DU21004DCDC_SY837CSP20_1R96X1R56X0R66SYR838PKCU21005LDO_TT2102SOT_23_5TT2102U21006LDO_PT5108SOT_23_5PT5108E23E-18U23001DCDC_SY827CSP20_1R96X1R56X0R66SYR837U23002DCDC_SY8088SOT_23_5SY8088AACU23003DCDC_SY837CSP20_1R96X1R56X0R66SYR838PKCU23004DCDC_SY8088SOT_23_5SY8088AACU23005LDO_PT5108SOT_23_5PT5108E23E-18U23006DCDC_SY8088SOT_23_5SY8089AACU23007PMIC_RK818QFN68_7R00X7R00X0R80_TRK818-3U23008LDO_PT5108SOT_23_5PT5108E23E-15U23009LDO_PT5108SOT_23_5PT5108E23E-28U23010LDO_PT5108SOT_23_5PT5108E23E-30U23011LDO_PT5108SOT_23_5PT5108E23E-28U23013LDO_PT5108SOT_23_5PT5108E23E-18U23014LDO_TT2102SOT_23_5TT2102U23033GAUGE_CW2013DFN8_3R00X2R50X0R90CW2013CASDU23034LDO_PT5108SOT_23_5WL2803E12-5/TRU23035ESD_ESDA6V8ULSOT_23ESD5302F U23036SWITCH_SY6280SOT_23_5SY6280AACU23037SWITCH_SY6280SOT_23_5SY6280AACU90004ESD_TPD4E05U06SON10_2R50X1R00X0R50TPD4E05U06U90005ESD_TPD4E05U06SON10_2R50X1R00X0R50TPD4E05U06U90006ESD_TPD4E05U06SON10_2R50X1R00X0R50TPD4E05U06U90007ESD_ESDA6V8ULSOT_23ESD5302F U90008ESD_ESDA6V8ULSOT_23ESD5302F U90009ESD_ESDA6V8ULSOT_23ESD5302F USB8902USB20_TYPE_AUSB20A4_USB_AF_01_001USB-HUB_PORTBAY1101CRYSTAL_4PCRY4_3R20X2R50X0R8024MHzY6001CRYSTAL_4PCRY4_3R20X2R50X0R8037.4MHzY6101CRYSTAL-4_0CRY-D322537.4MHz-20ppmY6201CRYSTAL-4_0CRY-D322526MHz-10ppmY8501CRYSTAL-4_1CRY-D322527MHz-10ppmY21001CRYSTAL_2P_1GCRY2_6R90X1R40X1R3032.768KHzY23001CRYSTAL_2P_1GCRY2_6R90X1R40X1R3032.768KHz
原理图都做的这么靓 哎呦不错哦 介绍的很详细 这资料 逆天 学习一下
