[PADS9.5以下] Amlogic S912 TVBOX DEMO板PCB文件(AP6356S+RTL8211F-CG)
查看27902 | 回复151 | 2018-5-30 23:57:33 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalValuePart Type
1D1SOT-23BAT54CSOT-23
1D7LED0603GREEN_LEDLED0603
1D8LED0603BLUE_LEDLED0603
1EC1C3216NC/47UF_16VC3216
1EC2C3216NC/100UF_10VC3216
1J1DC-002DC-002DC-002
1J2DC-005NC/DC-005DC-005
1K1K_SMDRESET_KEYK_SMD
1K2K_SMDALE_KEYK_SMD
1Q1SOT-23PMBT3904SOT-23
1Q2SOT-23PMBT3904SOT-23
1Q4SOT-23WPM2015SOT-23
1Q7SOT-23AO3401SOT-23
1Q8SOT-23AO3401SOT-23
1Q9SOT-23PMBT3906SOT-23
1U1MP8756_QFN12MP8756GDMP8756_QFN12
1U2SOT23-6NC/SY8105ADCSOT23-6
1U3SOT23-6SY8120B1ABCSOT23-6
1U4SOT23-6SY8120B1ABCSOT23-6
1U5SOT23-5WL2803E18-5SOT23-5
1U6SOT23-6SY8120B1ABCSOT23-6
1U7SOT23-5WL2803E18-5SOT23-5
1U10SOT23-6SY8120B1ABCSOT23-6
2D2LED-D5MMNC/INFRARED_LEDLED-D5MM
2J1CN-2P50-4PA2501WV-4PCN-2P50-4P
2J2CN-2P00-2X20PA2005WV-N-2X20P_DEBUGCN-2P00-2X20P
2J3DB9DB9/FMDB9
2J4CN-2P00-2X5PA2005WV-N-2X5P_DEBUGCN-2P00-2X5P
2J5CN-2P00-2X20PA2005WV-N-2X20P_DEBUGCN-2P00-2X20P
2J6DIP-2X2P-2MMDIP-2X2P-2MM
2Q1SOT-23PMBT3904SOT-23
2Q2SOT-23NC/PMBT3904SOT-23
2Q3SOT-23PMBT3904SOT-23
2SW1SW-TK-TS-03PVUPDATESW-TK-TS-03PV
2U2SOT-23MAX809RD/RS809RSOT-23
2U3DIP-IRIRM-3638N3DIP-IR
2U4SMD_08_SPKSPK0415HM4H-BSMD_08_SPK
2U5SMD_08_SPKSPK0415HM4H-BSMD_08_SPK
2Y2Y-SMD4P322524MHZ_CL12PF_20PPMY-SMD4P3225
3U1BGA96-0P8MMH5TQ4G63AFR-RDCBGA96-0P8MM
3U2BGA96-0P8MMH5TQ4G63AFR-RDCBGA96-0P8MM
3U3BGA96-0P8MMH5TQ4G63AFR-RDCBGA96-0P8MM
3U4BGA96-0P8MMH5TQ4G63AFR-RDCBGA96-0P8MM
4CON1BTOB30P-MALE-0_8MMBTOB30P-MALE-STRAIGHT_0.8MMBTOB30P-MALE-0_8MM
4U5TSOP-48NC/29F64G08CBACATSOP-48
4U7BGA169-INANDEMMC_FLASHBGA169-INAND
5D1ESD0402AZ5725-01FESD0402
5D2ESD0402AZ5725-01FESD0402
5D3ESD0402AZ5725-01FESD0402
5D4ESD0402AZ5725-01FESD0402
5FB1FB1206100MHZ220OHMFB1206
5FB2FB0603100MHZ220OHMFB0603
5J1RJ45LED-LY-RGRJ45-LED-LYRGRJ45LED-LY-RG
5J2RJ45_TAB-DOWN-8PRJ45_TAB-DOWN-WITH-LEDRJ45_TAB-DOWN-8P
5J3T-24P-PT50MILG11T1001T-24P-PT50MIL
5J4DIP-2X13P-2MMDIP2X13_2MMDIP-2X13P-2MM
5J5CN-2P00-2X5PA2005WV-N-2X5P_DEBUGCN-2P00-2X5P
5L1L06031.5UHL0603
5L2L06031.5UHL0603
5L3L30302.2UH_1AL3030
5Q1SOT-23PMBT3904SOT-23
5T1TS8121CH1601CGTS8121C
5TP5TP3020CLKOUTTP3020
5U1QFN40-PT04-5X5MMRTL8211F-CGQFN40-PT04-5X5MM
5Y1XT-SMD4P322525MHZ_CL12PF_10PPMXT-SMD4P3225
5Y2XT-49SNC/25MHZ_CL12PF_10PPMXT-49S
6CON1USB-MICRO-DIPMICROUSB-MICRO-DIP
6D12ESD0402AZ5325-01FESD0402
6F1FUSE-0805FUSE-500MAFUSE-0805
6F2FUSE-0805FUSE-500MAFUSE-0805
6FB2FB0603100MHZ220OHMFB0603
6FB3FB0603100MHZ220OHMFB0603
6J1TF-CARD-PUSHTFWF1-EBF1-1X0XTF-CARD-PUSH
6J2CON4-USB-AFCON4-USB-AFCON4-USB-AF
6J3CON4-USB-AFCON4-USB-AFCON4-USB-AF
6J65P-2_54CON-5P-2_54MM5P-2_54
6L1ACM2012-2PNCACM2012-2P
6L2ACM2012-2PNCACM2012-2P
6L3COMMON-COIL4PNC/EXD24CD900UCOMMON-COIL4P
6SW1SW-TK-TS-03PVUPDATESW-TK-TS-03PV
6U1SOT23-5SY6280AACSOT23-5
6U4SOP65P780X200-28NGL852G-HHGXXSOP65P780X200-28N
6Y1Y-SMD4P322512MHZ_CL20PF_20PPMY-SMD4P3225
7J1J-MS-156ACA-5036-A3-CC-SJ-MS-156
7J2J-MS-156ACA-5036-A3-CC-SJ-MS-156
7J3J-MS-156ACA-5036-A3-CC-SJ-MS-156
7L2L30304.7UH_1A_DCR80MOHML3030
7Q1SOT-23NC/WPM2015SOT-23
7Q2SOT-23NC/WPM2015SOT-23
7Q3SOT-23PMBT3904SOT-23
7Q4SOT-23PMBT3904SOT-23
7U1AP62X2_13X15AP6356SAP62X2_13X15
7U2WF-UM02BSNC/RTL8188-EUSWF-UM02BS
7Y2Y-SMD4P322537.4MHZ_16PF_10PPMY-SMD4P3225
9D1DFN2510P10EAZ1345-04FDFN2510P10E
9D2DFN2510P10EAZ1345-04FDFN2510P10E
9D3ESD0402AZ5725-01FESD0402
9D4ESD0402AZ5725-01FESD0402
9D5ESD0402AZ5725-01FESD0402
9FB1FB0402100MHZ220OHMFB0402
9FB4FB0402100MHZ220OHMFB0402
9FB5FB0402NC/100MHZ220OHMFB0402
9J1HDMI_AHDMI-DIP-TYPE-A-19PHDMI_A
9L1EMI-TF2010A4XNC/SDCMA21-4-900-M1TEMI-TF2010A4X
9L2EMI-TF2010A4XNC/SDCMA21-4-900-M1TEMI-TF2010A4X
9Q1SOT-23NC/WPM2015SOT-23
9Q2SOT-23WNM2020SOT-23
9Q6SOT-23NC/WNM2016SOT-23
AFB1FB0402100MHZ220OHMFB0402
AJ1AV-HJ-313EHJ-313EAV-HJ-313E
AJ2JGQ-10GQ-10JGQ-10
AJ3DIP-2X10P-2MMDIP2X10_2MMDIP-2X10P-2MM
AR3R040222RR0402
AT1TP30GPIODV_24TP30
AT2TP30GPIODV_24TP30
AU2TSSOP-14-PT065DIO2133CT14TSSOP-14-PT065
U1BGA483_0P65GXM_S912BGA483_0P65
VC1C0402100PFC0402
VC2C040227PF_5%_NPOC0402
VC3C0402100PFC0402
VD1ESD0402AZ5725-01FESD0402
VL1L06031.8UHL0603
重要提示:PCB作品文件展下载说明
老吴 | 2018-5-30 23:59:43 | 显示全部楼层
PCB文件。没原理图。 回复可见下载
游客,如果您要查看本帖隐藏内容请回复
mini | 2018-5-31 00:06:01 | 显示全部楼层
wcjcn | 2018-5-31 00:08:23 | 显示全部楼层
wst2016 | 2018-5-31 06:54:39 | 显示全部楼层
marktsui | 2018-5-31 07:14:23 | 显示全部楼层
13517290216 | 2018-5-31 08:30:52 | 显示全部楼层
真是厉害了,啥时候才能达到这种水平
jopey | 2018-5-31 08:31:43 | 显示全部楼层
ldj186 | 2018-5-31 08:32:07 | 显示全部楼层
我的为什么就不能这么好看
到处走看 | 2018-5-31 08:39:15 | 显示全部楼层
