Name | Part Type | PCB Decal | Value |
ANT3601 | ANTENNA_11 | PAD/1P/R1.3 | ANT / 92138100010F |
BEAD5001 | FB_/_BLM15AG121SN1 | BEAD0402 | FB / BLM15AG601SN1 |
BEAD6001 | FB_/_BLM18BD252SN1 | BEAD0603 | FB / BLM18BD102SN1 / 0603 |
BEAD6002 | FB_/_BLM18BD252SN1 | BEAD0603 | FB / BLM18BD102SN1 / 0603 |
BEAD6003 | FB_/_BLM18BD252SN1 | BEAD0603 | FB / BLM18BD102SN1 / 0603 |
BEAD6701 | FB_/_BLM18BD252SN1 | BEAD0603 | FB / BLM18BD102SN1 / 0603 |
BEAD6702 | FB_/_BLM18BD252SN1 | BEAD0603 | FB / BLM18BD102SN1 / 0603 |
CON3301 | CAR_KIT_/_MM8130-2600 | MM8130-2602 | Car_Kit / MM8130-2600 |
CON3401 | CAR_KIT_/_MM8130-2600 | MM8130-2602 | Car_Kit / MM8130-2600 |
CON5001 | TST_PORT_0 | MM8130-2602 | Car_Kit / MM8130-2600 |
CON6304 | CON/SIM/LUS62-90006-0135_4 | SIM-CAF99-06134-0103 | CON/SIM/LUS62-90006-0135 |
CON6306 | CON/SIM/LUS62-90006-0135_3 | QFN8/SMD/P1.27/64K-M2M-MS0 | M2M MS0 SIM |
CON6700 | CON_/_12_/_TA-M017-012-07-811_1 | TF-CAF11-08134-0512DIP | CON / 12 / TA-M017-012-07-811 |
CON6702 | TMP_1 | OK-06F030-04 | OK-06F030-04 |
D2103 | D_/_MMSZ5231BT1G | D_BZX584C5V1_SOD-523 | SIG5V1T1G |
D6701 | DIODE_DIP_SCHOTTKY | RB160M-40 | RB160M-40 |
D6710 | BZX584C5V1 | D_BZX584C5V1_SOD-523 | BZX584C4V3 |
EMI6702 | EMI_/_TCM0806G-350-2P | FILTER/SMD/TCM0806G | EMI / TCM0806G-350-2P |
EMI6703 | EMI_/_TCM0806G-350-2P | FILTER/SMD/TCM0806G | EMI / TCM0806G-350-2P |
EMI6704 | EMI_/_TCM0806G-350-2P | FILTER/SMD/TCM0806G | EMI / TCM0806G-350-2P |
EMI6705 | EMI_/_TCM0806G-350-2P | FILTER/SMD/TCM0806G | EMI / TCM0806G-350-2P |
EMI6706 | EMI_/_TCM0806G-350-2P | FILTER/SMD/TCM0806G | EMI / TCM0806G-350-2P |
F5001 | BL1608-05K2450_0 | FILTER/SMD/LFD211G57ME3 | TRPX / TDK TPX205950MT-7110A1 |
FB6701 | PZ1005U601-R45TF | LB0402 | 600@100MHZ |
FD9101 | TP_R_1MM | FD | TP / 40 / mil |
FD9102 | TP_R_1MM | FD | TP / 40 / mil |
FD9103 | TP_R_1MM | FD | TP / 40 / mil |
FD9104 | TP_R_1MM | FD | TP / 40 / mil |
J101 | CON10X2/SMD/P1.27/2_0.0MM | CON10X2/SMD/P1.27/2.0MM-2 | CON10*2/SMD/P1.27/2.0MM |
J102 | CON10X2/SMD/P1.27/2_0.0MM | CON10X2/SMD/P1.27/2.0MM-2 | CON10*2/SMD/P1.27/2.0MM |
J3603 | RF_CONN_20279C8_0 | ECT818000157 | ECT818000157(NC) |
J3604 | RF_CONN_20279C8_0 | ECT818000157 | ECT818000157(NC) |
J5002 | RF_CONN_20279C8_0 | ECT818000157 | ECT818000157 |
J5003 | RF_CONN_20279C8_0 | ECT818000157 | ECT818000157(NC) |
J6701 | REC22_DUALROW_0 | CON12X2/SMD/P1.27/2.0MM-1 | REC22_DUALROW_01-220012-211S |
J6702 | REC22_DUALROW_0 | CON12X2/SMD/P1.27/2.0MM-1 | REC22_DUALROW_01-220012-211S |
J6703 | B37.12_1.00031 | CON_FPC_AFC30-30FCA-HF | YXT-BB10-24S-02 |
L2001 | L_/_MDMK2020TR68MM_/_SMD2520 | L/IND/SMD/2520 | PL / 0.33 / uH / 2520 |
L2003 | L_/_MDMK2020TR68MM_/_SMD2520 | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 |
L2006 | L_/_MDMK2020T1R0MM_/_SMD2520 | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 |
L2008 | L_/_MDMK2020T1R0MM_/_SMD2520 | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 |
L2009 | L_/_MDMK2020T1R0MM_/_SMD2520 | L/IND/SMD/VLS201610E | PL / 2.2 / uH / 2016 |
L3206 | L_/_3.3_/_NH_/_0201 | L0201 | C / 1.3 / pF / 0201 |
L6701 | INDUCTOR | L_3X3X1.2MM | LQH3NPN220MJ0L(22UH) |
L6707 | B29.01_0.00021 | L0806 | MAKK2016T2R2M |
MIC1 | CAP_ARRAY_0 | CON_WF12502-022000 | CON2PIN |
NTC3201 | NTC_/_NCP15WF104F03RC_/_0402_ | R0201 | NTC / NTCG064EF104F / 0201 |
NTC6001 | NTC_/_NCP15WF104F03RC_/_0402_ | R0201 | NTC / NTCG064EF104F / 0201 |
Q7 | DTC143TM | T_NPN_DTC114TM_SOT-723 | DTC143TM |
Q6701 | P-MOS_CJ3415 | T_MOSFET_P_CJ3415-SOT23 | P-MOS CJ3415(NC) |
Q6702 | DTC143TM | T_NPN_DTC114TM_SOT-723 | DTC143TM |
Q6703 | DTC143TM | T_NPN_DTC114TM_SOT-723 | DTC143TM |
SH1001 | NO_PAD_0402_SMD_1 | NC/MMD/L1/4MIL | SHORT / NC-MMD-L9-4MIL |
SH4101 | R_/_0_/_OHM_/_0402_1 | R0402 | R / 0 / ohm / 0402 |
SH5001 | R_/_SHORT_/_OHM_/_0402 | R0402 | SHORT / 0402 |
SH5002 | R_/_SHORT_/_OHM_/_0402 | R0402 | SHORT / 0402 |
SH9101 | CON10_0 | SHD_MT6735_BB | SC / PTV0703B |
SH9102 | CON10_0 | SHD_MT6735_PMU | SC / PTV0703B |
SH9103 | NO_PAD_0402_SMD_1 | NC/MMD/4MIL | SHORT / NC-MMD-L9-4MIL |
SH9104 | NO_PAD_0402_SMD_1 | NC/MMD/L1/4MIL | SHORT / NC-MMD-L9-4MIL |
U1001 | IC-MT6735-LP3-E1-SBS_MAP0827 | MT6735/VFBGA641/P0.4/B0.25/12.6X12.6 | U / IC-MT6735-LP3-E1-SBS_MAP0827 |
U1003 | RT9284A_0 | LDO_SGM2019-3.3YC5G/TR_SC70-5 | SGM2019-3.3YC5G/TR |
U2001 | IC/MT6328-E1/XXXMM_0 | MT6328/VFBGA206/P0.4/B0.25/6.6X6.6 | U / MT6328E1 |
U3101 | 60118A_22 | MT6169/VFBGA175/P0.4/B0.25/6.2X5.4 | U / MT6169 |
U3102 | KT2520F26000DCW28QAK | TCXO/SMD/2.5X2.0/KT2520F | VTCXO / 26 / MHz / KT2520F26000DCW28QAK |
U3203 | PA_/_SKY77590_8 | SKY77643 | SKY77643/HRSMAC001/RF5410 |
U3210 | LF1608-B2R5KCB | BALUN/SMD/HHM22112A2 | LPF / LF1608-B2R5KCB |
U3215 | SAW_3 | FILTER/SMD/885049 | SAW / SAFEA2G35MF0F0A |
U3216 | DEA102700LT-6307_0 | FILTER/SMD/LFB212G49CG7D755 | LPF / LF2012-L1R4NAA / NC |
U3220 | BPF_/_ACPF-7141 | ACPF-7141/SMD | BPF / SAFRG2G62MA0F0A |
U3301 | SAW-DPX-RX-BAL_2 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | DPX / SAYEY1G88BA0B0A |
U3302 | SPDT_/_BGS12SL6_2 | RF1628 | SPDT / RF1628A |
U3305 | SAWFD1G90BH0F0A_0 | SAWFILTER/SMD/SAWFD1G90BH0F0A | DIPX / SAWFD1G90BK0F0A |
U3306 | SAW-DPX-RX-BAL_1 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | DPX / SAYEY1G95HA0F0A |
U3307 | ASM_/_SKY13492_6 | SKY77910 | SKY77916/HRTXAB005/RF5216 |
U3308 | SAW-DPX-RX-BAL_1 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | DPX / SAYEY2G53CA0F0 |
U3309 | SAW-DPX-RX-BAL_2 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | DPX / SAYEY1G74BC0B0A |
U3313 | SAW-DPX-RX-BAL_1 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | DPX / SAYEY836MCA0F0A |
U3317 | BAL_/_TFSZ06051897-3317A1 | BALUN/SMD/TFSZ06051897-3317A1 | BAL / TFSZ06051897-3317A1 |
U3322 | SAW_0 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / B8809 |
U3323 | TDK-BALUN_0 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TDK-TFSZ06052460-3310A2 |
U3401 | SPDT_/_BGS12SL6_2 | RF1628 | SPDT / RF1628A |
U3402 | IC/SP6T/SKY13416_0 | SKY13414 | SP6T / SKY13416 |
U3403 | BAL_/_TFSZ06051897-3317A1 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TDK-TFSZ06052460-3310A2 |
U3404 | SAW_3 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / EPCOS_AG07B |
U3406 | SAW_0 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G84FL0F0A |
U3407 | SAW_0 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G90FB0F0A |
U3408 | SAW_0 | SAWFILTER/SMD/F6QB2G595P2BS | SAW / B9898 |
U3410 | BAL_/_TFSZ06051897-3317A1 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TDK-TFSZ06052460-3310A2 |
U3411 | SAW_0 | SAWFILTER/SMD/F6QB2G595P2BS | SAW / SAFFB2G53AA1F0A |
U3412 | SAW_0 | SAWFILTER/SMD/F6QB2G595P2BS | SAW / SAFFB2G60AA1F0A |
U4102 | LP_DDR2(JEDEC_162B)_0 | FBGA221/P0.5/B0.27/11.5X13/SAMSUNG | U / H9TP32A4GDCCPR-KGMx |
U5001 | MT6611_SMD_WLCSP-61_0 | MT6625/SQFN40/SMD/P0.4/5X5 | U / MT6625L / QFN40 |
U5002 | TCXO_RAKON_SMD_4P_0 | TCXO/SMD/2.5X2.0/IT2205BE | TCXO / 26 / MHz / IT2205AE |
U5003 | SAFEB1G57KA0F00 | SAW/SMD/1.05X1.35 | GNSS SAW / B8313 |
U5004 | NJG1107HB3_0 | TSLP6/SMD/P0.4/BGA725L6/S | U / BGA725L6 |
U5005 | SAFEB1G57KA0F00 | FILTER/SMD/ACPF-7124 | FBAR / ACPF-7124 |
U5006 | EMI_ICVE10184E150R101FR | EMI_ICVE10184E150R101FR | EMI_ICVE10184E150R101FR |
U5007 | EMI_ICVE10184E150R101FR | EMI_ICVE10184E150R101FR | EMI_ICVE10184E150R101FR |
U5008 | ICMEF112P900MFR | COMMON_ICMEF112P900MFR | ICMEF112P900MFR |
U5009 | EMI_ICVE10184E150R101FR | EMI_ICVE10184E150R101FR | EMI_ICVE10184E150R101FR |
U6700 | B33.01.00021 | QFN_BST-BMA222 | MC3433 |
U6701 | SGM2019-3_0.3YC5G/TR | SOT-23-5 | SGM6013-ADJYTN5G/TR |
U6703 | AK09911 | SENSOR_AK09911 | AK09911 |
U6705 | MP1518-TSOT23-6 | SOT23_6 | CP2123ST-A2 |
VR6715 | VR0402 | VR0402 | AVLC18S02015 |
X2001 | CRYSTAL_2 | CRYS/SMD/3.2X1.5/9H032000XX/TXC | X / 32 / KHz / CM7V-T1A |
