重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | D4 | HSOD882 | DZ_L | HSOD882 | D5 | HSOD882 | DZ_L | HSOD882 | D10 | HSOD882 | DZ3 | HSOD882 | D11 | HSOD882 | DZ_L | HSOD882 | D15 | HSOD323A | D_A | HSOD323A | D16 | HSOD882 | DZ_L | HSOD882 | D17 | HSOD882 | DZ3 | HSOD882 | D18 | SD1710A | DZ3 | SD1710A | D19 | SD0805-LED | LED | SD0805-LED | D20 | HSOD882 | DZ3 | HSOD882 | D21 | HSOD882 | DZ3 | HSOD882 | D22 | SD1714D | DZ3 | SD1714D | D23 | SD0805-LED | LED | SD0805-LED | D31 | SD1714A | | SD1714A | D40 | SD0805-LED | | SD0805-LED | D41 | HSOD882 | DZ_L | HSOD882 | D42 | HSOD882 | DZ_L | HSOD882 | J10 | SATA7-M-A | SIP7M2 | SATA7-M-A | J16 | MOLEX_47151 | DB19S4 | MOLEX_47151 | J37 | DIP-4PIN-2.0MM-1 | | DIP-4PIN-2.0MM-1 | J45 | DIP-2PIN-2.0MM | MIC6M1_B | DIP-2PIN-2.0MM | J47 | SMD-6PIN-1.25MM | USB-4S4 | SMD-6PIN-1.25MM | J48 | SMD-8PIN-1.25MM | USB-4S4 | SMD-8PIN-1.25MM | J49 | SMD-4PIN-1.25MM | | SMD-4PIN-1.25MM | J50 | SMD-4PIN-1.25MM | | SMD-4PIN-1.25MM | L1 | SPL0505H | 4.7U | SPL0505H | L2 | SL1008 | 1UH | SL1008 | L3 | SPL0404L | 2.2UH | SPL0404L | L4 | SL2828 | 4.7UH | SL2828 | L9 | HSL1008D | 2.2U | HSL1008D | L10 | HSL1008 | 2.2UH | HSL1008 | M1 | MTH_C40MMD3P2MM | NC | MTH_C6MMD3P2MM | M2 | MTH_C40MMD3P2MM | NC | MTH_C6MMD3P2MM | M3 | MTH_C40MMD3P2MM | NC | MTH_C6MMD3P2MM | M4 | MTH_C40MMD3P2MM | NC | MTH_C6MMD3P2MM | OSC2 | HSX4-0302B | 25MHZ | HSX4-0302B | Q6309 | SOT-23 | | SOT-23 | RN1 | SRN8-0804 | 33 | SRN8-0804 | RN2 | SRN8-0804 | 22 | SRN8-0804 | TS2 | TP24-SMD | NC | TP24-SMD | U2 | SOP8-50-150 | ADM706SAR | SOP8-50-150 | U3 | DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 | U5 | WSON8-MX25L12835ZN | NC | WSON8-MX25L12835ZN | U7 | HSOT-SC70-DCK | SN74LVC1G125Q-Q1 | HSOT-SC70-DCK | U8 | HBGA427-26-2323 | HI3536CV100_SYS | HBGA427-26-2323 | U9 | HSOT-563 | MP1601 | HSOT-563 | U10 | BGA96-32-1609M | MT41J256M16RE-15E-D | BGA96-32-1609M | U11 | SOT23-6B | RT9065 | SOT23-6B | U12 | TSOT23-8 | MP1494 | TSOT23-8 | U15 | TSOT23-8 | MP1494 | TSOT23-8 | U16 | SBAT2-13A | PWR1-2 | SBAT2-13A | U17 | TSOT23-8 | MP2122 | TSOT23-8 | U18 | DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 | U19 | SOT23-6L | AZC199-04S | SOT23-6L | U20 | MLF6-065-0202L | TPS2551DRVR | MLF6-065-0202L | U21 | QFN64-050-0909LH | RTL8211EG_1 | QFN64-050-0909LH | U22 | MLF32-050-0505LE | TLV320AIC31 | MLF32-050-0505LE | U32 | WSON8-MX25L12835ZN | NC | WSON8-MX25L12835ZN | U34 | STFM16-50-285 | | HR681686 | X1 | HSX4-0302B | 24MHZ | HSX4-0302B | X2 | HSX2-0302 | 32.768KHZ | HSX2-0302 |
重要提示:PCB作品文件展下载说明
