重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | 1V1 | TP1 | T | TP1 | 3V1 | TP1 | T | TP1 | CN1 | USB_C_UCB0015_000_YP | TYPE_C_12P_12P_8.65 | USB_C_UCB0015_000_YP | CN2 | USB_C_UCB0015_000_YP | USB_C_UCB0015_000_YP | USB_C_UCB0015_000_YP | CN3 | TYPE_C_12P_12P_8.65 | TYPE_C_12P_12P_8.65 | TYPE_C_12P_12P_8.65 | CON1 | TF_10 | TF | TF_10 | CON2 | SD_11 | SD | SD_11 | CON3 | RJ45_JXQCB301188AB1W6DB1075_YP | RJ45_H3.0 | RJ45_JXQCB301188AB1W6DB1075_YP | D1 | STZ5.6N_SOT_23_3 | STZ5.6N_NC | STZ5.6N_SOT_23_3 | D2 | LED-DIP | LED_WHITE | LED-DIP | D3 | LED0603 | LED_LV | LED0603 | D4 | LED0603 | LED_CHENG | LED0603 | D5 | SOD-323 | CDBP0130L-G | SOD-323 | D6 | SOD-323 | 1N4148/SOD123 | SOD-323 | D7 | SOD-323 | 1N4148/SOD123 | SOD-323 | D8 | LED0603 | LED/GRE/0805 | LED0603 | D9 | LED0603 | LED/GRE/0805 | LED0603 | D10 | LED0603 | LED/GRE/0805 | LED0603 | D11 | SOD-323 | SSA33L-E3/61T | SOD-323 | D13 | SOD-323 | DIODE_SCHOTTKY/CRS08 | SOD-323 | FB1 | L0603 | ACMS160808A300_0603 | L0603 | J1 | AUDIO-DB | AUDIO_3.5MM | AUDIO-DB | J2 | USB30-DP-90AA | USB3.0A_2.45 | USB30-DP-90AA | J3 | USB30-DP-90AA | USB3.0A_2.45 | USB30-DP-90AA | J4 | USB30-DP-90AA | USB3.0A_2.45 | USB30-DP-90AA | J5 | USB2.0_620_10227_YP | USBA_2.0 | USB2.0_620_10227_YP | J6 | DP-F20 | DP_TX0 | DP-F20 | J7 | HDMI | HDMI_TX1 | HDMI | L1 | 3015_4X4MM | 2.2UH | 3015_4X4MM | L2 | 3015_4X4MM | 2.2UH | 3015_4X4MM | L3 | SSMD0630 | 4.7UH_NC | SSMD0630 | L4 | 3015_4X4MM | 2.2UH | 3015_4X4MM | L5 | 3015_3X3MM | 2.2UH | 3015_3X3MM | L6 | RES0603 | BLM18AG102SN | RES0603 | L7 | RES0603 | BLM18AG102SN | RES0603 | L8 | RES0603 | BLM18AG102SN | RES0603 | L9 | RES0603 | BLM18AG102SN | RES0603 | L10 | L0603 | BLM18SG700TN1D | L0603 | L11 | L0603 | BLM18AG102SN | L0603 | L12 | L0603 | BLM18SG700TN1D | L0603 | L13 | L0603 | BLM18AG102SN | L0603 | L14 | L0603 | BLM18SG700TN1D | L0603 | L15 | L0603 | BLM18SG700TN1D | L0603 | L16 | L-404012 | 1.2UH | L-404012 | L18 | RES0603 | BLM18AG102SN | RES0603 | L19 | RES0603 | BLM18AG102SN | RES0603 | L20 | JTP0403 | 4.7UH_4.7UH/040_0_7MM | JTP0403 | L21 | L-404012 | 1.6UH/1.8A | L-404012 | Q1 | PPAK-3X3-8 | TDM3307A | PPAK-3X3-8 | Q2 | PPAK-3X3-8 | TDM3307A | PPAK-3X3-8 | Q3 | SOT_23_3 | 2N7002 | SOT_23_3 | Q4 | SOT_23_3 | 2N7002 | SOT_23_3 | Q5 | SOT_23_3 | 2N7002 | SOT_23_3 | Q6 | SOT_23_3 | 2N7002 | SOT_23_3 | Q7 | SOT_23_3 | SMC3401S | SOT_23_3 | Q8 | SOT23-GDS | 2N7002 | SOT23-GDS | Q9 | SOT23-GDS | 2N7002 | SOT23-GDS | Q10 | SOT23-GDS | 2N7002 | SOT23-GDS | RXHPD1 | TP1 | T | TP1 | SW1 | KEY-4.5_2.7 | SWTACT/SMD_NC | KEY-4.5_2.7 | U1 | QFN28-VL170 | QFN28-VL170 | QFN28-VL170 | U2 | SOT23_5 | SY8088 | SOT23_5 | U3 | SOT23_5 | SY8088 | SOT23_5 | U4 | QFN16_5 | SC8721_QFN16_5 | QFN16_5 | U5 | SOT23_5 | SY8088 | SOT23_5 | U6 | VL103R_QFN48_6X6 | VL103R_QFN48 | VL103R_QFN48_6X6 | U7 | SOP_8 | FM25FQ04-SO-T-G/FM | SOP_8 | U8 | GL3224_QFN48 | GL3224_QFN48 | GL3224_QFN48 | U9 | SOP_8 | GD25Q512 | SOP_8 | U10 | QFN32_SSS1530 | SSS1530 | QFN32_SSS1530 | U11 | SOP_8 | 24C0X_X | SOP_8 | U12 | SOT23_5 | 24C0X_X | SOT23_5 | U13 | SSOP_16 | FE8.1 | SSOP_16 | U14 | VL817_QFN76 | VL817_QFN76 | VL817_QFN76 | U15 | VL817_QFN76 | VL817_QFN76 | VL817_QFN76 | U16 | S7001_SOT23-6 | S7001 | S7001_SOT23-6 | U17 | SOP_8 | FM25FQ04-SO-T-G/FM | SOP_8 | U18 | GST5009 | GST5009 | GST5009 | U19 | RTL8153_QFN48 | RTL8153 | RTL8153_QFN48 | U20 | SOP_8 | MX25L1606E | SOP_8 | U21 | 10-DFN | NL/ESD8004 | 10-DFN | U22 | 120_SOCKET_TCBGA_0.65MM | VMM5210_BGA120_0 | 120_SOCKET_TCBGA_0.65MM | U23 | 10-DFN | NL/ESD8004 | 10-DFN | U24 | S7001_SOT23-6 | S7001 | S7001_SOT23-6 | U25 | 10-DFN | NL/ESD8004 | 10-DFN | U26 | 10-DFN | NL/ESD8004 | 10-DFN | U27 | SEMTECH/SC70-6L | NL/RCLAMP0504 | SEMTECH/SC70-6L | U28 | TSSOP_14 | PI3C3125LE/TSSOP14 | TSSOP_14 | U30 | 10-DFN | ECMF04-4HSWM10 | 10-DFN | U31 | 10-DFN | ECMF04-4HSWM10 | 10-DFN | U32 | SEMTECH/SC70-6L | RCLAMP0504 | SEMTECH/SC70-6L | U33 | SOP8 | GD25Q40C | SOP8 | U34 | SOT23_5 | SY8089 | SOT23_5 | U35 | SY8003 | SY8003 | SY8003 | U36 | S7001_SOT23-6 | S7001 | S7001_SOT23-6 | X1 | 3225 | 25MHZ | 3225 | X2 | 3225 | XTAL_25M | 3225 | Y1 | 3225 | 12MHZ | 3225 | Y2 | 3225 | 25MHZ | 3225 | Y3 | 3225 | 25MHZ | 3225 | Y4 | X-3225 | 27MHZ/CTS406 | X-3225 |
重要提示:PCB作品文件展下载说明
