查看: 1128|回复: 2
[AD专用库] 255个 AD  带3D封装的封装库共享
终身成就奖社区居民忠实会员宣传大使奖
发表于 2021-7-19 14:04:32 | 显示全部楼层 |阅读模式
3DPCBLib.zip (45.06 MB, 下载次数: 11)
有以下封装。需要的下载
1N4148
1R1C
2*3P
2*35P
2.54mm_terminal
78M05_TO252
0603
0603_NC
0603L
0603P
0805
AD7156
ADJRH
ADXL345Z
AM240*320B
AMS1117_1V8_SOT89
AMS1117_2V5_SOT89
AMS1117_3V3_SOT89
AudioJackPJ30210
BAT54C-T
Batter5AA
BCY-W2
BEEP_27mm
BELL
BLUETOOTH_ANT
BMX2.54x2
BMX2SMD
BMX4SMD
BNX001
BTM400
BTN_DIP
Button-2pinSMD
C160M
C310M
cap0805
CAPF5_10uF
CAPF63_100uF
CD32_4R7
CON15mm
CR_8M_5032_2PIN
CR_49SM_12M
CR_3215_8MHz
CR_3215_25MHz
CR_3215_12228
CR_3215_32768
CR_3225_8MHz
CR_3225_12MHz
CR_3225_25MHz
CRYSTALS_2mm
CS4334_SO8
D2PAK/A
D0603
D0603LED
D02881NP
DB9/M
DC-057
DC10B
DC0044B
DHT11
DIP-8A
DM9161AEP_LQFP48
DS_USB_DIP
DSUB1.385-2H9
ENC28J60SS
ESP-12
FBGA48(9*11)
FTSH-110-01-L-DV
G6KU-2F-Y
GL850G_SSOP28
HDR1x3
HDR1x5
HDR1X5M
HDR2X1
HDR2x4
HDR2x5
HDR2x6
HDR2x9
HDR2x17R
HDR2x27
HDR4x1
HDR8X2
HDR15X2
HDR25X2
HDRS2_2.54
HDRS4_2.54
HDRS5_2.54
HDRS7_2.54
HDRS11_2.54
HFI-6FFER2
HMC5883L
HR91110A
HT1621
HT1621 1
HYG1625
IC149-144-045-B5
IDC14S
IDC20S
IDC34S
IR_VISHAY3
IR908-7C
IRM
IS62WV51216BLL_TSOP44
JOY_MT008-A
JP2_SMD
KEYSmallWuGui
KEYSmallWuGuiSide
KEYTAIWAN663
KEYTAIWAN667
KLD-0202
KS1508
Lag_1.5
LAGVAL
LCD32X2402.8in(95196)
LCD575
LCD12232-GB1
LCDClamp
LCDSEG32X14MM
LCDSEG35X18MM
LCM2.8 MODE
LD3320_QFN48
LED3mm
LED3MMDIP
LI1220_1
LQFP32(STM8S103)
LQFP48(RTL8201CP)
LQFP48(STM8L152C6T6)
LQFP48(VS1003)
M7_DO124AC
M25P32_SOP8W
M29W128GH70N6E_TSSOP56
MARK
MIC0622DIP
MICF6H5
MicroSDCard
MicroUSB
MofeisCHK
MOFEISCLAMP
MofeisSwitch
MouseEncoder5
MouseEncoder7
MouseEncoder11
MouseEncoder11Wheel
NJMicroUSB
nRF24L01
NRF24L01Core
P
P10_LEDSCREEN
PB10
PD3mm90
PH310
PJ325
PJ382B
polyzen
PR
PT908-7C
PTC_0805
PTC_1812
QFN32
RA_YC164
RA_YC164_102
RDA5820
RELAY-DS2Y-DC5V
RES4B
RES0603_0
RES0603_100
RES0603_101
RES0603_102
RES0603_103
RES0603_104
RES0603_105
RES0603_124
RES0603_152
RES0603_202
RES0603_203
RES0603_220
RES0603_221
RES0603_223
RES0603_330
RES0603_335
RES0603_472
RES0603_473
RES0603_6800
RES0805_101
RES0805_205
res2512_1R67
RM021-01A
SAM(C816)
SCSL Logo
SDM8A7878A
SIP2
SIP3
SM8
SO8
SO8_SI4953ADY
SO28
SOD123_1N4148
SOIC8_AT24C08
SOP8_AD623A
SOP8_LN2544
SOP8_M25P32
SOP8_SP3485
SOP8_ST1151A
SOP8_TDA1308T
SOP8_TDA2822
SOP8_TJA1050
SOP14_LM324
SOP14_MCP42010
SOP16_74HC138
SOP16_74HC595
SOP16_CH340G
SOP48
SOT-23_AO3400A
SOT-23_S8050
SOT-23_S8550
SOT-23_TL431
SOT-223
SOT-223_AMS1117_1V8
SOT-223_AMS1117_3V3
SOT-223_AMS1117_5v
SOT-666
SOT23-6_TP4057
SOT89_TP8350
SS34_DO124AC
SS210_DO124AC
SSOP16
SSOP20_74HC245
SSOP20_CH376T
SSOP20_STM8S103F2
ST-225-02
STM32F103C8T6_LQFP48
STM32F103T8U6
STM32F103ZET6_TQFP144
STM32F105R8T6
STM32F407ZET6_TQFP144
TAN-A
TAN-B
TAOBAOCODE
TBGA64(10*13)
TOUCH
TP
TQFP100
TQFP144
TS1112
TSOP54
TSSOP16-CD4052
TSSOP16-ST3232
TSSOP16-TSC2046
TSSOP48_NandFlash
USB-B
USBDIP
USBOTGCon
USBPCB
VB334
VDFPN8(8*6)
XTAL_socket
XTALSMD
  • 签到天数: 103 天
    7万
    发表于 2021-7-20 06:01:16 | 显示全部楼层
    发表于 2022-11-25 08:53:51 | 显示全部楼层
