查看: 769|回复: 2
[通用3D模型] 发一个PADS  AD  ALLEGRO 通用 3D元件封装库
    长期免费代管18-28岁小
    发表于 2021-12-7 09:52:14 | 显示全部楼层 |阅读模式
    3d_lib.rar (24.6 MB, 下载次数: 30)
    有以下3D 元件模型。需要的自己下载。
    1101M2S3ABE2.STEP
    3225-1.STEP
    35ZLH1000MEFC12_5X20.STEP
    3DC15-1000J.STEP
    5MM-LED-RG.STEP
    750313102.STEP
    Audio jack 4.step
    BU2032SM-HD-G(CR2032 Battery Holder).STEP
    C0402-1.STEP
    C0603 (1608)_CH.STEP
    C0805(2012M) Cap.STEP
    C1206 (3216)_EH.STEP
    C1210 (3225)_FJ.STEP
    C1812 (4532)_GC.STEP
    C1825 (4564)_HG.STEP
    C2225 (5664)_KD.STEP
    C3216-18_A_case.STEP
    C3216_1206.STEP
    C3528.STEP
    C6032-28_y.STEP
    C7343-20.STEP
    C7343-31.STEP
    C7343-40.STEP
    C7343-43.STEP
    C7343.STEP
    Cap-EL(10x16-5).STEP
    Cap-EL(10x20-5).STEP
    Cap-EL(10x25-5).STEP
    Cap-EL(10x30-5)T.STEP
    Cap-EL(12_5x20-5)T.STEP
    Cap-EL(12_5x25-5).STEP
    Cap-EL(12_5x25-5)T.STEP
    Cap-EL(13x25-5).STEP
    Cap-EL(16x26-7_5).STEP
    Cap-EL(16x31_5-7_5)T.STEP
    Cap-EL(18x26-7_5)T.STEP
    Cap-EL(18x36-7_5)T.STEP
    Cap-EL(18x40-7_5)T.STEP
    Cap-EL(8x12-3_5)T.STEP
    CAP-EL_K21.STEP
    CAP120X100M.step
    CAPF.STEP
    CAPG.STEP
    CAPML200 (2_5x6_6).STEP
    CDPH4D19FNP-100MC.step
    CDPH4D19FNP-6R8MC.step
    CDRH3D18.STEP
    CDRH4D18.STEP
    cdrh4d18c.STEP
    CR1005-0402.STEP
    CR1608-0603.STEP
    CR2012-0805.STEP
    CR3216-1206.STEP
    D0805.STEP
    DIOD SMD 10BF10.STEP
    DIOD SMD CILINDRIC SMALL.STEP
    DIODE_SOD-923.STEP
    DIP4-7_62-2_54.STEP
    DO-214AA SMB.STEP
    DO-214AB SMC.STEP
    DO-214AC SMA.STEP
    DPAK-1.step
    DPAK-5-1.step
    DPAK_TO-252AA.step
    DT-26-1.STEP
    DT-26.STEP
    E-Switch - TL3330AF130QG (Tact Switch, SMD).step
    EL817-SOP.step
    FILESLIST111.TXT
    FUSER_nanoSMD.STEP
    GREENLED.STEP
    HC-49-1.step
    HC-49.step
    HC-49S.step
    HC-49SM-1.step
    HC-49_LT_THT.step
    HC-49_LT_THT_16MHz.step
    HC49-SMD.STEP
    HC49.step
    HC49U-2.step
    HC49US.STEP
    HC49_cystal.STEP
    HC49_SMD.STEP
    HC49_US-SM.STEP
    Header_Male_2Pin.STEP
    Header_Male_40Pin.STEP
    Header_Male_RA_Low_3Pin.STEP
    Header_Male_RA_Low_40Pin.STEP
    Header_Male_RA_Low_4Pin.STEP
    Header_Male_RA_Low_5Pin.STEP
    Header_Male_RA_Low_6Pin.STEP
    Header_Male_RA_Low_7Pin.STEP
    Header_Male_RA_Low_8Pin.STEP
    Header_Male_RA_Low_9Pin.STEP
    IND_0805.STEP
    KCSA56-104.step
    LED 0805.STEP
    LED 1206 BLUE.STEP
    LED 1206.STEP
    LED DIP 3MM.STEP
    LED SMD0603.STEP
    LED SMD0805.STEP
    LED-0402.STEP
    LED0603(G).STEP
    LED0805(B).STEP
    LED0805(G).STEP
    LED0805(R).STEP
    LED0805(Y).STEP
    LED1206G.STEP
    LED1206R.STEP
    LED1206Y.STEP
    LED_0603_B.STEP
    LED_0603_G.STEP
    LED_0603_R.STEP
    LED_0603_Y.STEP
    LED_SMLK34.step
    melf-2.STEP
    MEM2055-00-190-01-A_revG.STEP
    MiniMelf-2.STEP
    Molex - 15-91-0100 (Pin Header 2_54mm 10 Pin).STEP
    PC817_Gullwing.STEP
    PG-SOT223.STEP
    QFN 24 4x4.step
    QSOP16-1.step
    R1206.step
    REDLED.STEP
    RES0201.STEP
    RES0402-2.STEP
    RES0603-3.STEP
    RES0805-2.STEP
    RES1206-2.STEP
    RESC3216X06N.STEP
    RESISTOR 2512.STEP
    RESISTOR 7_62MM DIP.STEP
    RES_OARS1-R003.STEP
    RS-101(RCA-107).STEP
    SC-88A.step
    SC70-3.step
    SDIP.STEP
    SF56S006V4BR2000.STEP
    SIM5060-6-0-26-01-A.STEP
    SIMID 1210-H.STEP
    SM-Cap_0201 (0603)_AB.STEP
    SMA(T)-21 SMD.STEP
    SMD 8x10.step
    SMT DO3316.STEP
    SOD-323.STEP
    SOD-323F.STEP
    SOD-723.STEP
    SOD-923.STEP
    SOD123.STEP
    SOD523.STEP
    sod80-1.STEP
    SOD80-3.STEP
    SOD80C-1.STEP
    SOIC-14.STEP
    SOIC-16-1.STEP
    SOIC-7.STEP
    SOP-6.step
    SOP50P310X110-8N[VSSOP_DGK_MO-187AA].step
    SOT 143.STEP
    SOT-223-1.STEP
    SOT-223-6.STEP
    SOT-223.STEP
    SOT-23-5.STEP
    SOT-23-5L.step
    sot-23-6-5.STEP
    SOT-23-6.STEP
    SOT-23-8-Thin.step
    SOT-23.STEP
    SOT-323-5L.step
    SOT-343N.step
    SOT-523.step
    sot-553.STEP
    SOT-563.step
    SOT-723.step
    SOT-82.STEP
    SOT-89-5.step
    SOT-89.STEP
    SOT-923f.step
    SOT143-1.STEP
    SOT143_1.STEP
    SOT223-3.STEP
    SOT223-5.STEP
    SOT23 5.STEP
    SOT23-6-1.STEP
    SOT233.STEP
    SOT238.step
    SOT323 (SC70-3)-1.STEP
    SOT343-1.step
    SOT343F.step
    SOT343N.STEP
    SOT353-1-1.step
    SOT353-1.step
    SOT353.step
    SOT50P160X60-5.STEP
    SOT50P160X60-6.STEP
    SOT89-5-1.step
    SOT89-5.step
    SOT89.STEP
    SOT895-A-PKG.STEP
    SRN6045 Series.STEP
    SS22F07G7-G.STEP
    SW3dPS-SOT363.STEP
    switch 6x6x9_5mm.STEP
    TACT SMD 6X6.STEP
    TCLT100-SOP4L.step
    TI_LPG0002A_TO-92_Temp_Sensor.step
    TO-220AB-7 SMD.step
    TO-252-3.step
    TO-252.step
    TO-255AA-1.step
    TO-92-6.step
    TO220AB.STEP
    TO252-2.STEP
    TO252AA.step
    tsot-23-5.STEP
    TSOT-23-6(S6).STEP
    TSOT-23-8-1.STEP
    TSOT-23-8.STEP
    TSOT-23.STEP
    TSOT23-5.STEP
    UFL-R-SMD.STEP
    Varistor_20mm.STEP
    VL-3032 HF5N.STEP
    暑假期间,免费代管18-28岁小孩,限女性。
    发表于 2021-12-7 10:04:57 | 显示全部楼层
    发表于 2024-11-14 11:53:36 | 显示全部楼层
