查看: 6810|回复: 187
[Allegro17.4以下] RX580 吃鸡显卡 PCB文件 挂8个GDDR5  RX580P181030HJ
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2022-10-16 12:08:40 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    B35BEAD_SMIND1005_0_5H_120R_505000120RSMIND1005_0_5H
    B200BEAD_RES1608_2012_1_1H_220R_520220RRES1608_2012_1_1H
    B202BEAD_SMIND1005_0_5H_120R_505000120RSMIND1005_0_5H
    BR300RES#3_RES1005_0R_3150000000G0RRES1005
    BR301RES#3_RES1005_0R_3150000000G0RRES1005
    D1LED_DUAL_K3A1_K4A2_LED_LITE-ON_LED_RED/BLUELED_LITE-ON_LTST-C195TBJRKT
    D200SCHOTTKY_DIOSOD_523_BAT54KFILM_BAT54KFILMDIOSOD_523
    D201SCHOTTKY_DIOSOD_523_BAT54KFILM_BAT54KFILMDIOSOD_523
    D222DIODE_SERIES_SOT23_1_15H_BAV99_BAV99SOT23_1_15H
    F1800FUSE_RES3216_1_3H_1.5A_512000311.5ARES3216_1_3H
    F1900FUSE_RES3216_1_3H_1.5A_512000311.5ARES3216_1_3H
    F1901FUSE_RES3216_1_3H_200MA_5120003200mARES3216_1_3H
    HS1HEATSINK_WVIA_HS_7123B00900G_CUCuracao_fansinksHS_7123B00900G
    J200CON04_HD2MM1X4_KEY_HEADER_1X4_SHEADER_1X4_SHROUDEDHD2MM1X4_KEY
    J10016140052600G_CON_MFITJR_7_CON_8PPOWER_HEADERCON_8P_HDER_TH_1_CN3_0-C
    J1700DISPLAY_PORT_CON_DISPLAYPORT_ASDP_W/GASKETCON_DISPLAYPORT_ASTRON_R6890020
    J1800DISPLAY_PORT_CON_DISPLAYPORT_ASDP_W/GASKETCON_DISPLAYPORT_ASTRON_R6890020
    J1900DISPLAY_PORT_CON_DISPLAYPORT_ASDP_W/GASKETCON_DISPLAYPORT_ASTRON_R6890020
    J1950DVI_D_COMPUPACK_CON_COMPUPACK_ADVI-DCON_COMPUPACK_ACNDV210031-001
    J2501HDMI_CON_HDMI_PLASTRON_HM0D-G-RHDMI_W/TABCON_HDMI_PLASTRON_HM0D-G-R0-LF
    L900IND#2_IND_6363_4_5H_SUNT_SNR6042.2uHIND_6363_4_5H_SUNT_SNR6045S
    L1080IND_POL#2_IND_GUORUI_SCD0504T_00.47uHIND_GUORUI_SCD0504T
    L1506L_IND_NONRKO_TH_63_57_I125X125_0.47UHIND_NONRKO_TH_63_57_I125X125
    L1507L_IND_NONRKO_TH_63_64_I125X125_1.0UHIND_NONRKO_TH_63_64_I125X125
    L1880IND_RES1005_100NH_5260101900G100nHRES1005
    L1895IND_POL_IND_COPPER-FP1007R3_0.10.15uHIND_COPPER-FP1007R3
    L1897IND_SMIND_IHLP-2525CZ_3_0H_0.470.47uH_17ASMIND_IHLP-2525CZ_3_0H
    L1898L_IND_NONRKO_TH_63_57_I125X125_0.47UHIND_NONRKO_TH_63_57_I125X125
    L1899L_IND_NONRKO_TH_63_64_I125X125_1.0UHIND_NONRKO_TH_63_64_I125X125
    MB200BEAD_RES1608_2012_1_1H_220R_520220RRES1608_2012_1_1H
    MC141CAP_CAP1608_2012_1_40H_22UF_42122uFCAP1608_2012_1_40H
    MC148CAP_CAP2012_1_53H_VIA_47UF_421247uFCAP2012_1_53H_VIA
    MC151CAP_CAP2012_1_40H_10UF_421C010610uFCAP2012_1_40H
    MC152CAP_CAP2012_1_40H_10UF_421C010610uFCAP2012_1_40H
    MC154CAP_CAP1608_2012_1_53H_10UF_42110uFCAP1608_2012_1_53H
    MC155CAP_CAP1608_2012_1_53H_10UF_42110uFCAP1608_2012_1_53H
    MC209CAP_CAP2012_1_40H_10UF_421C010610uFCAP2012_1_40H
    MJ10016140029901G_CON_MFITJR_5_CON_6PPOWER_HEADERCON_6P_HDER_TH_1_CN3_0-C
    ML900IND_POL_IND_GUORUI_SCD0504T_2.22.2uHIND_GUORUI_SCD0504T
    MPCIE1EDGECON_PCIE_164P_EDGECON_PCI_Ex16PCIeEDGECON_PCI_EXPRESS_16
    MT215MOUNTING_8PINS_MTG3_4_8VIAS_NA_NAMTG3_4_8VIAS
    NS700NET_SHORT_NET_SHORT_NET_SHORT_6NET_SHORTNET_SHORT
    NS900NET_SHORT#1_NET_SHORT_NS_VIA_62NS_VIANET_SHORT
    PC900CAP_CAP1608_1000PF_4250010200G1000pFCAP1608
    PC919CAP_POL_CAPT7343_2_1H_330UF_426330uFCAPT7343_2_1H
    PR714RES#3_RES1005_32.4K_3160324200G32.4KRES1005
    PR900RES#3_RES1608_2.2R_323002R200G2.2RRES1608
    Q7NPN#1_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q14NPN#1_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q15NPN#1_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q100MOS_N#1_SOT23_3PIN_BSH111_20200BSH111SOT23_3PIN
    Q101MOS_N#1_SOT23_3PIN_BSH111_20200BSH111SOT23_3PIN
    Q110MOS_N#1_SOT23_3PIN_BSH111_20200BSH111SOT23_3PIN
    Q203NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q206NPN#3_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q209PNP_SOT23_3PIN_1_1H_MMBT3906_20MMBT3906SOT23_3PIN_1_1H
    Q210NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q215NPN#3_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q216NPN#3_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q250NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q251NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363
    Q252MOS_P#1_SOT23_1_15H_AO3415L_202AO3415LSOT23_1_15H
    Q810MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q811MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q1009NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q1010NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q1013NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q1016NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q1024NPN#2_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q1070MOS_N#1_SOT23_3PIN_1_1H_2N7002_2N7002SOT23_3PIN_1_1H
    Q1077NPN#2_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q1604NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q1700NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363
    Q1701MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q1704MOS_N#1_SOT23_3PIN_2N7002E_20202N7002ESOT23_3PIN
    Q1800NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363
    Q1801MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q1804MOS_N#1_SOT23_3PIN_2N7002E_20202N7002ESOT23_3PIN
    Q1810MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q1820MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q1823NPN#2_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q1900NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363
    Q1901MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q1902MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q1904MOS_N#1_SOT23_3PIN_2N7002E_20202N7002ESOT23_3PIN
    Q1951NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363
    Q1980MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363
    Q2604NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363
    Q2626NPN#2_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PIN
    Q4600MOS_P_SOT23_1_15H_AO3415L_20200AO3415LSOT23_1_15H
    Q4602NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363
    Q4613MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALT
    Q4614MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALT
    Q4615MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALT
    Q4616MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALT
    Q4617MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALT
    RP1RES_NTWK_RESN2012_33R_32700040033RRESN2012
    SK1MECH_SOCKET_6GP_SOC_6090055700GELLESMERE_L4_SLT_SOCKETSOC_6090055700G
    SW1SLIDE_SWITCH_3P_4SH_SW_APEM_MA1SPDTSW_APEM_MA12R
    TC901CAP_CAP1005_BGA_1000PF_417001021000pFCAP1005_BGA
    U4NC7SB3157_SOT_SC70-6_1_1H_NC7SBNC7SB3157SOT_SC70-6_1_1H
    U7U_VREG_3PIN_SOT223_ADV_VR=1.25VADV_VR=1.25VSOT223
    U11SERIAL_FLASH_SO8_1_78H_PM25LV01PM25LV010A-100SCSO8_1_78H
    U22SI51214_DFN40P120X140X80-6N_SI5Si51214-A1EAGMDFN40P120X140X80-6N
    U20074VC1G123_MSOP08_3M0X3M0X1M3_P0SN74LVC1G123DCTMSOP08_3M0X3M0X1M3_P0M65
    U300GS7103_SO8_THERMAL_1_75H_GS7103GS7103-ASO8_THERMAL_1_75H
    U506COMPARATOR#1_SOT95P280X145-5N_AAP331AWGSOT95P280X145-5N
    U507COMPARATOR#1_SOT95P280X145-5N_AAP331AWGSOT95P280X145-5N
    U701APW7165A_PSOP_8_THERMAL_1_75H_AAPW7165APSOP_8_THERMAL_1_75H
    U900GS9238_QFN23_4M0X4M0X0M8_P0M50_GS9238-ATQ-RQFN23_4M0X4M0X0M8_P0M50_GS9238
    U2000170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120
    U2100170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120
    U2200170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120
    U2300170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120
    U2400170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120
    U2500170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120
    U2600170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120
    U2700170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120
    U4003LM96063C_QFN050_10_3X3_LM96063_LM96063QFN050_10_3X3
    U4503SERIAL_FLASH_SO8_1_78H_PM25LD01Pm25LD010C-SCESO8_1_78H
    U4506SMD_SC2422_SO16NCP81022QFN52_6M0X6M0X1M0_P0M40_TH8
    U4507XX08_SOT353_1_1H_NC7SZ08P5X_243NC7SZ08P5XSOT353_1_1H
    U451014521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3
    U451114521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3
    U451214521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3
    U451314521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3
    U451414521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3
    U451514521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3
    U4517ADP3418_0_QFN16-3X3-0R5P_NCP811NCP81162QFN16-3X3-0R5P
    U4518ADP3418_0_QFN16-3X3-0R5P_NCP811NCP81162QFN16-3X3-0R5P
    U4519ADP3418_0_QFN16-3X3-0R5P_NCP811NCP81162QFN16-3X3-0R5P
    U4520APW7165A_PSOP_8_THERMAL_1_75H_AAPW7165APSOP_8_THERMAL_1_75H
    U4522XX08_SOT353_1_1H_NC7SZ08P5X_243NC7SZ08P5XSOT353_1_1H
    Y1CRYSTAL_4P_NC_XTAL_NDK_NX3225DA27.000MHzXTAL_NDK_NX3225DA
    Y5CRYSTAL_4P_NC_XTAL_NDK_NX3225DA27.000MHzXTAL_NDK_NX3225DA
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2022-10-16 12:10:52 | 显示全部楼层
    PCB文件来了。由于涉及到保密问题。有删掉部分内容。文件不完整,仅供学习参考。
    游客,如果您要查看本帖隐藏内容请回复
    发表于 2022-10-16 12:15:59 | 显示全部楼层
    发表于 2022-10-16 15:29:14 | 显示全部楼层
    发表于 2022-10-16 15:39:51 | 显示全部楼层
    头像被屏蔽
    禁止发言
    发表于 2022-10-16 17:12:04 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
  • 签到天数: 9 天
    发表于 2022-10-16 17:43:06 | 显示全部楼层
    昨天 08:18
  • 签到天数: 94 天
    发表于 2022-10-16 17:46:07 | 显示全部楼层
  • 签到天数: 28 天
    PADS20210412初级班
    发表于 2022-10-16 20:42:49 | 显示全部楼层
    难过
    2024-12-23 14:47
    终身成就奖金点子奖
    发表于 2022-10-16 21:52:57 | 显示全部楼层
