查看: 617|回复: 4
[Allegro17.4以下] RK_EVB1_RK3576_LP4XD200P132SD6_V12(LPDDR4X) PCB 原理图共享下载
此广告位出租
发表于 2024-7-12 21:18:15 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
PCB 原理图一起打包。回复可见下载
RK_EVB1_RK3576_LP4XD200P132SD6_V12.zip (16.06 MB, 下载次数: 15)
REFDES
COMP_DEVICE_TYPE
COMP_VALUE
SYM_NAME
ANT6400
SMA_1P4G_ANT5_SMA_ST_EM1_SMA-J-P-H-RA-TH1
SMA-J-P-H-RA-TH1
ANT5_SMA_ST_EM1
ANT6401
SMA-J-P-H-RA-TH1
ANT5_SMA_ST_EM1
ANT6402
ANT_1P2G_ANT_JACK_ANT_JACK
ANT_JACK
ANT_JACK
CON4600
61082-08_2_CNN80M_0R80_61082_61082-08
61082-08
CNN80M_0R80_61082
CON4700
61082-08
CNN80M_0R80_61082
CON5000
LCD_HITACHI_TX05D99VM1AAA_2_CNN30_1R00_FP05SL_V_MIPI/LVDS_PANEL_CON0
MIPI/LVDS_Panel_CON0
CNN30_1R00_FP05SL_V
CON6500
61082-061402LF_CNN60M_0R80_61082_61082-061402LF
61082-061402LF
CNN60M_0R80_61082
CON7700
DIGITALAUDIO_HS_MB_30_CNN40_0R80_61082_AUDIO_61082-041402LF_AUDIO
61082-041402LF_Audio
CON9300
CON3_2X3_CNN6M_2R54_H_DIP_CNN6M_2R54_H_DIP
CNN6M_2R54_H_DIP
CNN6M_2R54_H_DIP
CON9301
CON3_2X2_CNN4M_2R54_H_DIP_CNN4M_2R54_H_DIP
CNN4M_2R54_H_DIP
CNN4M_2R54_H_DIP
CON9304
CON4_1X4_CN4M_2R54_V_DIP_CN4M_2R54_V_DIP
CN4M_2R54_V_DIP
CN4M_2R54_V_DIP
CON9600
CON4_1X4_CN4M_2R54_V_DIP_NC/CN4M_2R54_V_DIP
NC/CN4M_2R54_V_DIP
CN4M_2R54_V_DIP
CON9700
POWERMEASUREMENT_CNN60_0R80_B406_POWERMETERAGE
PowerMeterage
CNN60_0R80_B406
CON9900
CON4_0_CN4M_2R54_V_P_DIP_CN4M_2R54_V
CN4M_2R54_V
CN4M_2R54_V_P_DIP
D2000
DIODE_DO_214AB_SS32
SS32
DO_214AB
D2300
DIODE  ZENER2_ESD0603_PSUR1610DNV07
PSUR1610DNV07
ESD0603
D2301
DIODE_SOD_323_B5819WS
B5819WS
SOD_323
D2400
DIODE  DOUBLE_SOT_23_BAT54C
BAT54C
SOT_23
D5600
DIODE_SOD_123_B5819W
B5819W
SOD_123
D5601
B5819WS
SOD_323
D9100
DIODE_SOD_523_RB520S-30
RB520S-30
SOD_523
D9800
RB520S-30
SOD_523
ED2500
DIODE  BI_DIR TRIG_ESD0402_ESD5341N
ESD5341N
ESD0402
ED2501
ESD5341N
ESD0402
ED2502
ESD5341N
ESD0402
ED2503
ESD5341N
ESD0402
ED2504
ESD5341N
ESD0402
ED2505
ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034D
ESD73034D
ED2506
ESD5341N
ESD0402
ED2507
ESD73034D
ED2508
DIODE  BI_DIR TRIG_ESD0402_ESD5311X
ESD5311X
ESD0402
ED2509
ESD5311X
ESD0402
ED2510
ESD5311X
ESD0402
ED2511
ESD5311X
ESD0402
ED2512
ESD5341N
ESD0402
ED2513
ESD5341N
ESD0402
ED2514
ESD56161D24_DFN3_2R00X2R00X0R65_ESD56161D24
ESD56161D24
DFN3_2R00X2R00X0R65
ED4201
DIODE  BI_DIR TRIG_ESD0402_ESD5471X
ESD5471X
ESD0402
ED4202
DIODE  BI_DIR TRIG_ESD0402_NC/ESD5341N
NC/ESD5341N
ESD0402
ED4203
NC/ESD5341N
ESD0402
ED4204
NC/ESD5341N
ESD0402
ED4205
NC/ESD5341N
ESD0402
ED4206
NC/ESD5341N
ESD0402
ED4207
NC/ESD5341N
ESD0402
ED5600
ESD73034D
ED5601
ESD73034D
ED5602
ESD5341N
ESD0402
ED5603
ESD5341N
ESD0402
ED5604
ESD5341N
ESD0402
ED5605
ESD5341N
ESD0402
ED5606
ESD5341N
ESD0402
ED6700
NC/ESD5341N
ESD0402
ED9003
DIODE  BI_DIR TRIG_ESD0402_ESD5451N
ESD5451N
ESD0402
ED9300
PSM712_SOT_23_PSM712
PSM712
SOT_23
ED9302
ESD5451N
ESD0402
ED9303
ESD5451N
ESD0402
ED9600
ESD5471X
ESD0402
ED9601
ESD5341N
ESD0402
ED9602
ESD5341N
ESD0402
ED9800
ESD5341N
ESD0402
ED9801
ESD5341N
ESD0402
ED9802
ESD5451N
ESD0402
ED9803
ESD5451N
ESD0402
F2000
FUSE_F8050_JK-SMD150L
JK-SMD150L
F8050
F9900
FUSE_R1206_JK-NSMD035
JK-nSMD035
R1206
FB7400
BEAD_L0603_120R-100M
120R-100M
L0603
FB7401
120R-100M
L0603
FB7402
120R-100M
L0603
FB7403
120R-100M
L0603
GND9900
GND_GATE_CON2_1X2_5R08_DIP_GND_GATE
GND_GATE
CON2_1X2_5R08_DIP
GND9901
GND_GATE
CON2_1X2_5R08_DIP
GND9902
GND_GATE
CON2_1X2_5R08_DIP
GND9903
GND_GATE
CON2_1X2_5R08_DIP
GND9904
GND_GATE
CON2_1X2_5R08_DIP
H9900
HOLE_HOLE_C3R20_C6R00_HOLE_3R20
HOLE_3R20
HOLE_C3R20_C6R00
IR9100
IRM_3638_IJ3_IRM_3638_IRM_3638
IRM_3638
IJ3_IRM_3638
J2000
DCJACK_3P_DC3_DC_0007_5P_DC-0007-5P
DC-0007-5P
DC3_DC_0007_5P
J2300
JM_0_OPEN_JM
JM
OPEN
J2301
JM_0_OPEN_JM
JM
OPEN
J2302
JM_0_OPEN_JM
JM
OPEN
J2303
JM_0_OPEN_JM
JM
OPEN
J2304
JM_0_OPEN_JM
JM
OPEN
J2305
JM_0_OPEN_JM
JM
OPEN
J2306
JM_0_OPEN_JM
JM
OPEN
J2307
JM_0_OPEN_JM
JM
OPEN
J2400
CON_BATTERY-20MM_BAT_CR1220_CR1220-3V
CR1220-3V
BAT_CR1220
J2500
USB30_TYPE-C  RECEPTACLE_0_TYPEC30_24P_SD-2012670005_USB30_TYPE-C RECEPTACLE
USB30_TYPE-C  Receptacle
J2501
USBA_4_USB30_AF_SMT_THF_USB30_AF_SMT_THF
USB30_AF_SMT_THF
USB30_AF_SMT_THF
J4200
TFCARD_SOCKET_TF9_TFP09-2-12B_TFP09-2-12B
TFP09-2-12B
TF9_TFP09-2-12B
J5600
HDMI_A_HDMIA19_HDMI_01A_HDMI_A
HDMI_A
HDMIA19_HDMI_01A
J6700
HR911130C_RJ45_HR911130C_HR911130C
HR911130C
RJ45_HR911130C
J6800
HR911130C
RJ45_HR911130C
J7000
AUDIO_JACK_PJ8_B2339J_PJ8_B2339J_AUDIO_JACK_PJ8_B2339J
Audio_Jack_PJ8_B2339J
PJ8_B2339J
J7400
AUDIO_SPK_JACK_2P_CN2M_2R00_V_P_DIP_AUDIO_SPK_JACK_2P_V
Audio_SPK_Jack_2P_V
CN2M_2R00_V_P_DIP
J7401
Audio_SPK_Jack_2P_V
CN2M_2R00_V_P_DIP
J9800
USB20_TYPE_C_NEW_TYPEC20_16P_U20401_USB20_TYPE_C_NEW
USB20_TYPE_C_NEW
TYPEC20_16P_U20401
J9801
CN4M_2R54_V_DIP
CN4M_2R54_V_DIP
J9900
RADIATOR_FAN_2_RADIATOR_FAN_65RX65RX13R_RADIATOR_FAN_65X65
Radiator_Fan_65x65
J9901
SOCKET_RK3576_EVB_RK3576_65R0X65R0X54R3_S_RK3576_SOCKET
RK3576_Socket
J9902
RADIATOR_0_RADIATOR_38RX38RX10R_RADIATOR_38X38
Radiator_38x38
L2000
INDUCTORS  OF FERRITE_IND_667028_4.7UH
4.7uH
IND_667028
L2001
INDUCTORS  OF FERRITE_IND_404020_2.2UH
2.2uH
IND_404020
L2300
INDUCTORS  OF FERRITE_IND_201610_0.47UH
0.47uH
IND_201610
L2301
INDUCTORS  OF FERRITE_IND_252012_0.24UH
0.24uH
IND_252012
L2302
0.47uH
IND_201610
L2303
0.24uH
IND_252012
L2304
0.47uH
IND_201610
L2305
0.24uH
IND_252012
L2306
0.47uH
IND_201610
L2307
0.24uH
IND_252012
L2308
0.47uH
IND_201610
L2309
0.47uH
IND_201610
L2400
INDUCTORS  OF FERRITE_IND_252010_1.0UH
1.0uH
IND_252010
L2401
1.0uH
IND_252010
L2500
INDUCTOR  COM_RP2_0405_NC
NC
RP2_0405
L2501
NC
RP2_0405
L4100
1.0uH
IND_252010
L4101
1.0uH
IND_252010
L6400
INDUCTORS  OF FERRITE_IND_303015_2.2UH
2.2uH
IND_303015
L6401
2.2uH
IND_303015
L6700
2.2uH
IND_303015
L6800
2.2uH
IND_303015
L8100
2.2uH
IND_404020
LED9500
LED_LED0603_LED_WHITE
LED_WHITE
LED0603
LED9501
LED_LED0603_LED_YELLOW
LED_YELLOW
LED0603
LED9502
LED_LED0603_LED_GREEN
LED_GREEN
LED0603
LED9800
LED_LED0603_LED_BLUE
LED_BLUE
LED0603
M9900
MARK_MARK_MARK
MARK
MARK
M9901
MARK_MARK_MARK
MARK
MARK
M9902
MARK_MARK_MARK
MARK
MARK
M9903
MARK_MARK_MARK
MARK
MARK
M9904
MARK_MARK_MARK
MARK
MARK
M9905
MARK_MARK_MARK
MARK
MARK
MIC7000
MIC_WMM7037AT6_A_MIC4_2R95X3R76X1R10_MIC_WMM7037AT6
MIC_WMM7037AT6
Q3800
MOSFET  N_SOT_23_WNM2016-3/TR
WNM2016-3/TR
SOT_23
Q3801
MOSFET  N_SOT_323_WNM2021-3/TR
WNM2021-3/TR
SOT_323
Q4100
MOSFET  P_SOT_23_WPM2015-3/TR
WPM2015-3/TR
SOT_23
Q4101
NPN_SOT_23_S8050
S8050
SOT_23
Q5000
MOSFET  P_SOT_23_WPM2341-3/TR
WPM2341-3/TR
SOT_23
Q5001
NPN_SOT_23_S8050
S8050
SOT_23
Q5002
NPN_SOT_23_S8050
S8050
SOT_23
Q5600
MOSFET  N_SOT_323_WNM6002-3/TR
WNM6002-3/TR
SOT_323
Q5601
WNM6002-3/TR
SOT_323
Q5602
WNM6002-3/TR
SOT_323
Q5603
WNM6002-3/TR
SOT_323
Q5604
MOSFET  N_SOT_323_2SK3018
2SK3018
SOT_323
Q5605
2SK3018
SOT_323
Q5606
2SK3018
SOT_323
Q5607
2SK3018
SOT_323
Q5608
2SK3018
SOT_323
Q6400
NPN_SOT_23_S8050
S8050
SOT_23
Q6401
NPN_SOT_23_S8050
S8050
SOT_23
Q7000
WNM2016-3/TR
SOT_23
Q7001
WNM2016-3/TR
SOT_23
Q8000
2SK3018
SOT_323
Q8100
MOSFET  P_SOT_23_WPM3407-3/TR
WPM3407-3/TR
SOT_23
Q8101
NPN_SOT_23_S8050
S8050
SOT_23
Q9500
NPN_SOT_23_S8050
S8050
SOT_23
Q9900
MOSFET  N_SOT_23_WNM3003-3/TR
WNM3003-3/TR
SOT_23
S1700
DIAL_SWITCH_1_SW2_2R88X5R40X2R30_DIAL_SWITCH_1
Dial_Switch_1
SW2_2R88X5R40X2R30
S2000
BR-11C-11P6
KCD1-11-3P-W
SW3_KCD1-11-3P-W
SMTSO4600
SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJ
SMTSO3050CTJ
SMTSO4601
SMTSO3050CTJ
SMTSO4602
SMTSO3050CTJ
SMTSO4603
SMTSO3050CTJ
SMTSO4700
SMTSO3050CTJ
SMTSO4701
SMTSO3050CTJ
SMTSO4702
SMTSO3050CTJ
SMTSO4703
SMTSO3050CTJ
SMTSO6500
SMTSO3050CTJ
SMTSO6501
SMTSO3050CTJ
SMTSO7700
SMTSO3050CTJ
SMTSO7701
SMTSO3050CTJ
SW1800
DIAL_SWITCH_4_SW8_5R68X5R40X2R30_DIAL_SWITCH_4
Dial_Switch_4
SW8_5R68X5R40X2R30
SW1801
Dial_Switch_4
SW8_5R68X5R40X2R30
SW9000
KEY_5PIN_SW5_6R20X6R20X2R50_TS-1125S
TS-1125S
SW5_6R20X6R20X2R50
SW9001
TS-1125S
SW5_6R20X6R20X2R50
SW9002
TS-1125S
SW5_6R20X6R20X2R50
SW9003
TS-1125S
SW5_6R20X6R20X2R50
SW9004
KEY_4PIN_SW4_6R50X7R00X7R10_TS-1138V1
TS-1138V1
SW4_6R50X7R00X7R10
SW9005
TS-1125S
SW5_6R20X6R20X2R50
SW9006
TS-1125S
SW5_6R20X6R20X2R50
U1000
SOC_RK3576_BGA698_16R1X17R2X1R08_RK3576
RK3576
U1300
SWITCH_FSUSB30MUX_MSOP10_3R00X3R00X1R10_FSUSB30MUX
FSUSB30MUX
U1301
FSUSB30MUX
U1302
FSUSB30MUX
U1700
GMA340_QFN18L_2R00X2R80X0R567_T_GMA340
GMA340
U2000
TMI3255S_SOT_23_6_TMI3255S
TMI3255S
SOT_23_6
U2001
TMI3253SH_SOT_23_6_TMI3253SH
TMI3253SH
SOT_23_6
U2300
PMIC_RK806S-5_QFN68_7R00X7R00X0R80_T_RK806S-5
RK806S-5
U2400
DCDC_ETA3409_SOT_23_5_TMI3112H
TMI3112H
SOT_23_5
U2401
TMI3112H
SOT_23_5
U2402
CW3301_LOAD  SWITCH_WLCSP4_0R80X0R80X0R50_CW3301
CW3301
U2403
SWITCH_SY6280_SOT_23_5_SGM2590D
SGM2590D
SOT_23_5
U2404
LDO_PT5108_SOT_23_5_TMI6050-33
TMI6050-33
SOT_23_5
U2405
RTC_HYM8563_TSSOP8_3R10X3R10X1R10_HYM8563TS
HYM8563TS
U2500
USB_FUSB302B_MLP14_2R50X2R50X0R80_HUSB311
HUSB311
U2501
WS3221_CSP6L_1R25X0R77X0R63_WS3221C
WS3221C
U2502
SGM2590D
SOT_23_5
U2503
SGM2590D
SOT_23_5
U3800
LPDDR4_1_BGA200_15R00X10R00X0R90_LPDDR4_200P
LPDDR4_200P
U4000
INAND_EMMC_153_2L_BGA153_13RX11R5X0R9_2L_EMMC_B153_2L
EMMC_B153_2L
U4100
NANDFLASH_UFS_153P_FBGA153_11R5X13R0X1R00_UFS_B153
UFS_B153
U4101
TMI3112H
SOT_23_5
U4102
TMI3112H
SOT_23_5
U4200
SGM2590D
SOT_23_5
U4300
SPI_FLASH_8PIN_T_0_WSON8_8R00X6R00X0R80_T_NC/SPI_NAND_FLASH
NC/SPI_Nand_Flash
U4700
UM3212M8_MSOP8_3R00X3R00X1R10_UM3212M8
UM3212M8
U6400
MODULE_AP627XP_MD55_WIFI_AP6276P_AP6275P
AP6275P
MD55_WIFI_AP6276P
U6700
ETHERNET_RTL8211F_QFN40_5R00X5R00X0R90_T_RTL8211F-CG
RTL8211F-CG
U6800
RTL8211F-CG
U7000
AUDIO_ES8388_QFN28_4R00X4R00X0R90_T_ES8388
ES8388
U7400
AMPLIFIER_TCS7191A_MSOP8_3R10X3R10X1R10_TCS7191A_MH
TCS7191A_MH
U7401
TCS7191A_MH
U7402
AUDIO_ES7202_QFN16_3R00X3R00X0R80_T_ES7202
ES7202
U8000
CG_PI6C557-05B_TSSOP20_6R50X4R40X1R20_NC/RS2CG5705BLE
NC/RS2CG5705BLE
U8001
TMI6050-33
SOT_23_5
U8100
PCIEX4_0_PCIE64_X4_SMT_PCIE-SMT-64PIN
PCIe-SMT-64PIN
PCIE64_X4_SMT
U8101
TMI3253SH
SOT_23_6
U9100
U  / ITG-1010_0_LGA14_3R00X2R50X0R86_ICM-42607-C_U05-ITG-10100-0000
ICM-42607-C
U9300
TJA1051T_0_SOP8_5R00X4R00X1R75_TCAN1044V-Q1
TCAN1044V-Q1
SOP8_5R00X4R00X1R75
U9800
INTERFACE_FT232RL_SSOP28_10R20X5R30X2R00_FT232RL
FT232RL
Y1100
CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHZ
24MHz
CRY4_3R20X2R50X0R80
Y1300
CRYSTAL_4P_CRY4_3R20X2R50X0R80_26MHZ
26MHz
CRY4_3R20X2R50X0R80
Y2400
CRYSTAL_2P_CRY2_3R20X1R50X0R90_32.768KHZ
32.768KHz
CRY2_3R20X1R50X0R90
Y6400
CRYSTAL_4P_CRY4_3R20X2R50X0R80_37.4MHZ
37.4MHz
CRY4_3R20X2R50X0R80
Y6401
CRYSTAL_OSC_CRY4_3R20X2R50X1R20_32.768KHZ
32.768KHz
CRY4_3R20X2R50X1R20
Y6700
CRYSTAL_4P_CRY4_3R20X2R50X0R80_NC/25MHZ
NC/25MHz
CRY4_3R20X2R50X0R80
Y6800
NC/25MHz
CRY4_3R20X2R50X0R80
Y8000
CRYSTAL_4P_CRY4_3R20X2R50X0R80_25MHZ
25MHz
CRY4_3R20X2R50X0R80
重要提示:PCB作品文件展下载说明
    12 小时前
  • 签到天数: 205 天
    发表于 2024-7-14 14:44:42 | 显示全部楼层
    点评
    学习学习  详情 回复 发表于 3 天前
    4 天前
  • 签到天数: 28 天
    Allegro240402初级班
    发表于 2024-12-30 22:58:39 | 显示全部楼层
    3 小时前
  • 签到天数: 13 天
    发表于 3 天前 | 显示全部楼层
    社区居民
    发表于 昨天 13:15 | 显示全部楼层
