查看: 1008|回复: 111
[Pads_VX.2x] 紫光展锐UMS9621(UMS9230)10层5G 手机主板PCB原理图 展锐T606 T616参考设计资料
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2024-8-9 08:25:56 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NamePart TypePCB DecalValue
    ANT0800CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    ANT0801CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    ANT0802CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    ANT0803CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    ANT0804CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    ANT0805CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    ANT5201CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    ANT5202CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    D4100DIODE-SCHOTTKY-WSB5543W-2/TRSOD_FL_2412_H07040V/1A
    D5200SENSOR-LIGHT+PROX-LTR-578ALS-034WASENSOR_LITEON_LTR-578ALS-034WA
    D5201SENSOR_ACCEL+GYRO_LSM6DSMLGA_14_P050_300X250_H086_LSM6DSM
    D5202SENSOR-MAG-AK09918CBGA_4_P040_076X076_H058_AK09918C
    D6100TVS_PESDU4571D3SOD_2513_H110_N4.5V/530pF
    D6300DIODE-LED-LTST-C19HE1WT-HDIODE-LED-LTST-C19HE1WT-H
    FB4100BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mA
    FB4106BEAD-1K-OHM-100MHZ-300MA-0402SL04021000ohm@100MHz
    FB4111BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mA
    FB6600RES-0-0402SR04020
    FB6601RES-0-0402SR04020
    FB7200RES-0-0402SR04020
    FB7201RES-0-0402SR04020(NF)
    FD6201FID-C100-M200-K200FID_C100_M200_K200(NF)
    FD6202FID-C100-M200-K200FID_C100_M200_K200(NF)
    FD6203FID-C100-M200-K200FID_C100_M200_K200(NF)
    FD6204FID-C100-M200-K200FID_C100_M200_K200(NF)
    J0700CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
    J0701CON_RF_MM5829-2700RJ4CON_RF_MM5829-2700
    J0702CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
    J0703CON_RF_MM5829-2700RJ4CON_RF_MM5829-2700
    J0800CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
    J0801CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
    J4102CON-BTB-F-WP27D-S038VA3_CWCON_BTB_F_WP27D-S038VA3_CWCW
    J5100CON-BTB-F-WP27D-S030VA3_CWCON_BTB_F_WP27D-S030VA3_CWCW
    J5101CON-BTB-F-WP27D-S030VA3_CWCON_BTB_F_WP27D-S030VA3_CWCW
    J5102CON-BTB-F-WP27D-S030VA3_CWCON_BTB_F_WP27D-S030VA3_CWCW
    J5103CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
    J5104CON-BTB-F-WP27D-S030VA3_CWCON_BTB_F_WP27D-S030VA3_CWCW
    J5105CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
    J5106CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
    J5200CON-BTB-F-WP27D-S010VA3_CWCON_BTB_F_WP27D-S010VA3_CWCW
    J6100CON-BTB-F-WP10-S004VA10_UBCON_BTB_F_WP10-S004VA10_UBUB
    J6101CON-BTB-F-WP10-S004VA10_UBCON_BTB_F_WP10-S004VA10_UBUB
    J6200CON_BTB_F_AXF5D6012_UBCON_BTB_F_AXF5D6012_UBUB
    J6201CON_BTB_F_AXT340224_UBCON_BTB_F_AXT340224_UBUB
    J6202CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6203CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6204CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6205CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6206CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6207CON_SPRING_ECT_818003481CON_SPRING_ECT_818003481
    J6208CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6209SHIELD_SHUNKAI_SK-UMS9230-1SHIELD_SHUNKAI_SK-UMS9230-1TOP RF TR
    J6210CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6211CON_SPRING_ECT_818003481CON_SPRING_ECT_818003481
    J6212CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6213CON_BTB_F_AXT340224_UBCON_BTB_F_AXT340224_UBUB
    J6214SHIELD_SHUNKAI_SK-UMS9230-2SHIELD_SHUNKAI_SK-UMS9230-2TOP BB
    J6215CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6216SHIELD_SHUNKAI_SK-UMS9230-3SHIELD_SHUNKAI_SK-UMS9230-3BOT RF PA
    J6217CON-SPRING-TP-180-001CON_SPRING_TP-180-001
    J6218CON-SPRING-TP-180-001CON_SPRING_TP-180-001
    J6219SHIELD_SHUNKAI_SK-UMS9230-4SHIELD_SHUNKAI_SK-UMS9230-4BOT NFC
    J6220CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6221CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6222CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6223CON_SPRING_ECT_818003481CON_SPRING_ECT_818003481
    J6224CON-SPRING-TP-180-001CON_SPRING_TP-180-001
    J6225CON_SPRING_ECT_818010682CON_SPRING_ECT_818010682
    J6226CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6227SHIELD_SHUNKAI_SK-UMS9230-5SHIELD_SHUNKAI_SK-UMS9230-5BOT DC/DC
    J6228CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6229SHIELD_SHUNKAI_SK-UMS9230-6SHIELD_SHUNKAI_SK-UMS9230-6BOT Charger
    J6230CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6231SHIELD_SHUNKAI_SK-UMS9230-7SHIELD_SHUNKAI_SK-UMS9230-7BOT TCXO
    J6232CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6233SHIELD_SHUNKAI_SK-UMS9230-8SHIELD_SHUNKAI_SK-UMS9230-8BOT WCN
    J6262CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6264CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6265CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6266CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6267CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6269CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6270CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6271CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6272CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6274CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6275CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6276CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6277CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6278CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6279CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6282CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6283CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6284CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6288CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6290CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6291CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
    J6300CON_BTB_F_AXG106144_CCWCON_BTB_F_AXG106144_CCWCCW
    J6301CON-SPRING-TP-180-001CON_SPRING_TP-180-001
    J6302CON-SPRING-TP-180-001CON_SPRING_TP-180-001
    J6600PAD_2_P220_R120X160PAD_2_P220_R120X160
    J7200CON_RF_MM5829-2700RJ4CON_RF_MM5829-2700
    J7201CON_RF_MM5829-2700RJ4CON_RF_MM5829-2700
    J7202CON-SPRING-TP-180-001CON_SPRING_TP-180-001
    J7203CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
    J7204CON-SPRING-TP-180-001CON_SPRING_TP-180-001
    J7208CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    J7209CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    J7211CON-SPRING-CM1406-180CON-SPRING-CM1406-180
    J7600CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
    J7601CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
    L0200IND-CER-100NH-5%-0201-SDCL0603Q-02B01SL0201100nH
    L0300IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
    L0301IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
    L0302IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
    L0303IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
    L0304IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
    L0305IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
    L0306IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
    L0307IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
    L0308IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
    L0309IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
    L0310IND_POW_0.47UH_20%_WPN201610UIND_POW_WPN201610U0.47uH(Verifying)(NF)
    L0600IND-NF-0201IND-NF-0201NF
    L0601IND-CER-7.5NH-5%-0201-SDCL0603Q-02B01SL02017.5nH
    L0602IND-NF-0201IND-NF-0201NF
    L0603IND-CER-10NH-5%-0201-SDCL0603Q-02B01SL020110nH
    L0604IND-NF-0201IND-NF-0201NF
    L0605CAP-1PF-0.1-50V-0201-GRM0335C-A01SC02011pF/50V(NF)
    L0606CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
    L0607IND-NF-0201IND-NF-0201NF
    L0608IND-NF-0201IND-NF-0201NF
    L0609IND-NF-0201IND-NF-0201NF
    L0610IND-NF-0201IND-NF-0201NF
    L0611CAP-3.9PF-0201SC02013.9pF
    L0612IND-NF-0201IND-NF-0201NF
    L0613IND-NF-0201IND-NF-0201NF
    L0614IND-CER-10NH-5%-0201-SDCL0603Q-02B01SL020110nH(NF)
    L0615IND-NF-0201IND-NF-0201NF
    L0616IND-CER-8.2NH-5%-0201-SDCL0603Q-02B01SL02018.2nH
    L0617CAP-1.1PF-0.1-50V-0201-GRM0335C-A01SC02011.1pF
    L0618IND-NF-0201IND-NF-0201NF
    L0619IND-NF-0201IND-NF-0201NF
    L0620IND-NF-0201IND-NF-0201NF
    L0621IND-NF-0201IND-NF-0201NF
    L0622IND-NF-0201IND-NF-0201NF
    L0623CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
    L0624IND-NF-0201IND-NF-0201NF
    L0625IND-NF-0201IND-NF-0201NF
    L0626CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V
    L0632IND-CER-1.8NH-0.3-0201-SDCL0603Q-02B01SL02011.8nH
    L0700IND-NF-0201IND-NF-0201NF
    L0701IND-CER-12NH-5%-0201-LQP03TN-02SL020112nH
    L0702IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nH
    L0703IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nH(NF)
    L0704IND-NF-0201IND-NF-0201NF
    L0705IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nH
    L0706IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nH(NF)
    L0707IND-NF-0201IND-NF-0201NF
    L0708IND-CER-2.4NH-0.3-0201-SDCL0603Q-02B01SL02012.4nH
    L0709IND-CER-2.7NH-0.3-0201-SDCL0603Q-02B01SL02012.7nH(NF)
    L0710IND-CER-3.3NH-0.3-0201-SDCL0603Q-02B01SL02013.3nH
    L0711IND-CER-8.2NH-5%-0201-SDCL0603Q-02B01SL02018.2nH
    L0712CAP-1.2PF-0.1-50V-0201-GRM0335C-A01SC02011.2pF/50V
    L0713CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
    L0714IND-CER-22NH-5%-0201-SDCL0603Q-02B01SL020122nH(NF)
    L0715CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
    L0716CAP-NF-0201CAP-NF-0201NF
    L0717CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
    L0718IND-CER-8.2NH-5%-0201-SDCL0603Q-02B01SL02018.2nH
    L0719IND-NF-0201IND-NF-0201NF
    L0720IND-NF-0201IND-NF-0201NF
    L0721IND-NF-0201IND-NF-0201NF
    L0722CAP-2.2PF-0.25-50V-0201-GRM0335C-A01SC02012.2pF/50V
    L0723IND-CER-33NH-5%-0201-SDCL0603Q-02B01SL020133nH
    L0724IND-CER-15NH-5%-0201-LQP03TN-02SL020115nH(NF)
    L0725IND-NF-0201IND-NF-0201NF
    L0726IND-CER-10NH-5%-0201-LQP03TN-02SL020110nH
    L0727IND-CER-18NH-5%-0201-SDCL0603Q-02B01SL020118nH(NF)
    L0728IND-NF-0201IND-NF-0201NF
    L0729IND-NF-0201IND-NF-0201NF
    L0730IND-NF-0201IND-NF-0201NF
    L0731IND-CER-7.5NH-5%-0201-SDCL0603Q-02B01SL02017.5nH
    L0732IND-CER-2.7NH-0.3-0201-SDCL0603Q-02B01SL02012.7nH
    L0733IND-NF-0201IND-NF-0201NF
    L0734IND-CER-2.2NH-0.3-0201-SDCL0603Q-02B01SL02012.2nH
    L0735IND-NF-0201IND-NF-0201NF
    L0736CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V(NF)
    L0737CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V(NF)
    L0738IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL02014.3nH
    L0739CAP-3.9PF-0201SC02013.9pF(NF)
    L0740IND-NF-0201IND-NF-0201NF
    L0741IND-CER-22NH-5%-0201-SDCL0603Q-02B01SL020122nH
    L0742IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
    L0743IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
    L0744IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
    L0745IND-CER-2.4NH-0.3-0201-SDCL0603Q-02B01SL02012.4nH
    L0746IND-CER-18NH-5%-0201-SDCL0603Q-02B01SL020118nH(NF)
    L0747IND-CER-6.2NH-5%-0201-LQP03TN-02SL02016.2nH
    L0748IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
    L0749IND-CER-2.7NH-0.3-0201-SDCL0603Q-02B01SL02012.7nH
    L0750IND-NF-0201IND-NF-0201NF
    L0751IND-NF-0201IND-NF-0201NF
    L0752IND-CER-15NH-5%-0201-SDCL0603Q-02B01SL020115nH
    L0753IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
    L0754IND-CER-9.1NH-5%-0201-SDCL0603Q-02B01SL02019.1nH
    L0756IND-CER-6.2NH-0.3-0201-SDCL0603Q-02B01SL02016.2nH
    L0757IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
    L0760IND-NF-0201IND-NF-0201NF
    L0763IND-CER-9.1NH-5%-0201-SDCL0603Q-02B01SL02019.1nH
    L0764IND-CER-6.2NH-0.3-0201-SDCL0603Q-02B01SL02016.2nH
    L0765IND-NF-0201IND-NF-0201NF
    L0766IND-CER-9.1NH-5%-0201-SDCL0603Q-02B01SL02019.1nH
    L0767IND-CER-15NH-5%-0201-SDCL0603Q-02B01SL020115nH
    L0768IND-CER-1.8NH-0.3-0201-SDCL0603Q-02B01SL02011.8nH
    L0769IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
    L0770IND-NF-0201IND-NF-0201NF
    L0771IND-NF-0201IND-NF-0201NF
    L0772IND-NF-0201IND-NF-0201NF
    L0800IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nH
    L0801IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nH(NF)
    L0802IND-NF-0201IND-NF-0201NF
    L0803IND-CER-15NH-5%-0201-SDCL0603Q-02B01SL020115nH(NF)
    L0804IND-NF-0201IND-NF-0201NF
    L0805IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
    L0806CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V
    L0807CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
    L0809IND-NF-0201IND-NF-0201NF
    L0810CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V(NF)
    L0811CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V
    L0812IND-NF-0201IND-NF-0201NF
    L0813IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
    L0814IND-CER-18NH-5%-0201-SDCL0603Q-02B01SL020118nH
    L0815IND-NF-0201IND-NF-0201NF
    L0816CAP-2.2PF-0.25-50V-0201-GRM0335C-A01SC02012.2pF/50V
    L0817IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL02014.3nH
    L0818IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL02014.3nH
    L0819CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V(NF)
    L0820IND-NF-0201IND-NF-0201NF
    L0821IND-CER-4.7NH-0.3-0201-SDCL0603Q-02B01SL02014.7nH
    L0822CAP-2.7PF-0201SC02012.7pF(NF)
    L0823IND-NF-0201IND-NF-0201NF
    L0824CAP-2.2PF-0.25-50V-0201-GRM0335C-A01SC02012.2pF/50V
    L0825IND-CER-7.5NH-5%-0201-SDCL0603Q-02B01SL02017.5nH
    L0826IND-NF-0201IND-NF-0201NF
    L0827CAP-1.2PF-0.1-50V-0201-GRM0335C-A01SC02011.2pF/50V
    L0828IND-CER-18NH-5%-0201-LQP03TN-02SL020118nH
    L0829IND-CER-12NH-5%-0201-LQP03TN-02SL020112nH
    L0830CAP-2.7PF-0201SC02012.7pF(NF)
    L0831CAP-NF-0201CAP-NF-0201NF
    L0832IND-NF-0201IND-NF-0201NF
    L0833IND-CER-4.7NH-0.3-0201-SDCL0603Q-02B01SL02014.7nH(NF)
    L0834IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
    L0835IND-CER-18NH-5%-0201-SDCL0603Q-02B01SL020118nH
    L0837IND-CER-7.5NH-5%-0201-SDCL0603Q-02B01SL02017.5nH
    L0838IND-NF-0201IND-NF-0201NF
    L0841IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nH(NF)
    L3100IND-POWER-1.0UH-DFE252012F-P2IND_C_2520_H120_DFE2520121.0uH
    L3101IND_WIRE_1.2MH_20%_LQH3NMN-03IND_WIRE_LQH3NMN1.2mH
    L4100IND-POWER-10UH-SWPA3012S100MTIND-POWER-SWPA301210uH
    L4101IND-POWER-4.7UH-WPN2520H-MIND_POWER_WPN2520104.7uH
    L5100IND-POWER-1.0UH-WPN201610H-MIND_POW_WPN201610H1.0uH
    L5200IND-CER-100NH-5%-0201-SDCL0603Q-02B01SL0201100nH
    L6100IND-POWER-1.0UH-DFE252012F-P2IND_C_2520_H120_DFE2520121.0uH
    L6101IND_POW_CER_0.33UH_20%_CIGT252010LM-NIND_POW_CIGT2520100.33uH
    L7200IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL02014.3nH
    L7201IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nH
    L7202IND-CER-1.0NH-0.3-0201-SDCL0603Q-02B01SL02011.0nH
    L7203IND-NF-0201IND-NF-0201NF
    L7204IND-CER-2.0NH-0.2-0201-LQP03TN-02SL02012.0nH
    L7205RES_0_5%_0201_RC-LSR02010
    L7206RES_0_5%_0201_RC-LSR02010
    L7207IND-CER-9.1NH-5%-0201-SDCL0603Q-02B01SL02019.1nH
    L7209IND-CER-27NH-5%-0201-LQP03TN-02SL020127nH
    L7210IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
    L7214RES_0_5%_0201_RC-LSR02010
    L7217RES_0_5%_0201_RC-LSR02010
    L7229IND-CER-3.3NH-0.2-0201-LQP03TN-02SL02013.3nH
    L7600IND-WIRE-160NH-5%-0402-WL1005FS-M01SL0402160nH
    L7601IND-WIRE-160NH-5%-0402-WL1005FS-M01SL0402160nH
    MIC3101MIC_MEMS_BP-SPV0842LR5H-1MIC_MEMS_BP_SPV0842LR5H-1(Verifying)
    MLV3100MLV-AVLC5S02050SMLV0402
    MLV6412MLV-AVLC5S02050SMLV0402(NF)
    REC3100REC_QR090820BL01REC_QR090820BL0130ohm,50mW(NF)
    U0200PMIC_UMP510G_BGA_247_P040BGA_247_P040_770X770_H086_UMP510G
    U0500MEM_EMMC51_EMMC32G-TA29BGA_153_P050_1150X1300_H080_L02732GB,HS400(Verifying)
    U0502MEM_LPDDR4X_MT53E768M32D2NP-046WT-ABGA_200_P080X065_1000X1450_H100_L03024Gb(Verifying)
    U0600RF-TRANSCEIVER-SR3595DBGAS_123_P035_450X450_H085_SR3595D
    U0601RF_PAM_RPM6743-31PQFN_42_P044_680X400_T205X240X2_H090LTE Multi-Band
    U0700RF_SW_RSW9106QFN_14_P040_200X200_T098_H060
    U0701RF-SAW-SAFFB1G90KA0F0AFILTER_5_110X090_H0501900MHz
    U0702RF-SAW-SAFFB2G01AA0F0AFILTER_5_110X090_H0502018MHz
    U0703RF-SAW-SAFFB2G59AA1F0AFILTER_5_110X090_H0502593MHz(Verifying)
    U0704RF-SAW-DUPLEX-SAYEY718MBC0F0AFILTER_8_180X140_H060TxRx:718/773MHz(NF)
    U0705RF-FEM-RTM7916-51PQFN_38_P048_550X530_T390X370_H080
    U0706RF_SAW_SAFRC2G59MC0F0AFILTER_5_140X110_H0602593MHz(Verifying)
    U0707RF-SAW-SAFFB2G35AA0F0ARF-SAW-1.1X0.92350MHz
    U0708RF-SAW-SAFFB2G35MA0F0AFILTER_5_110X090_H0502350MHz(Verifying)
    U0709RF-SAW-DUPLEX-SAYEY2G53BA0F0AFILTER_8_180X140_H060TxRx:2535/2655MHz
    U0710RF_SAW_QUADPLEX_SAHQV1G74BA0H0AFILTER_6_250X200_H070_MURATAB1/B3
    U0711RF-SAW-DUPLEX-SAYEY1G88BA0B0AFILTER_8_180X140_H060TxRx:1880/1960MHz
    U0712RF-SAW-DUPLEX-SAYEY897MBG0F0AFILTER_8_180X140_H060TxRx:897.5/942.5MHz
    U0714RF-SAW-DUPLEX-SAYEY831MBA0B0AFILTER_8_180X140_H060TxRx:831.5/876.5MHz
    U0715RF-SAW-DUPLEX-SAYEY806MBA0F0AFILTER_8_180X140_H060TxRx:847/806MHz
    U0716RF-SW-RDASW293CPSON_6_P040_110X070_H055700-6000MHz(Verifying)
    U0717RF-CPL-CP160825Q0822T/LFCPL_CAF_6_P050_160X080_H070698-2690MHz
    U0718RF-SAW-DUPLEX-SAYEY733MBC0F0AFILTER_8_180X140_H060TxRx:733/788MHz(NF)
    U0719RF-BPF-RFBPF16081G9DS8T60FILTER_4_160X080_H070_WALSIN1805-2025MHz
    U0800RF-SW-RSW5103QFN_12_P050_200X200_T076_H060100-6000MHz
    U0801RF-SAW-SAFFB2G01AA0F0AFILTER_5_110X090_H0502018MHz
    U0802RF-SAW-SAWFD1G84AA0F0ARF-SAW-1.5X1.1-10PIN1842.5/2140MHz
    U0803RF-SAW-SAFFB942MAN0F0ARF-SAW-1.1X0.9942.5MHz
    U0804RF-SAW-SAFFB2G35AA0F0ARF-SAW-1.1X0.92350MHz
    U0805RF-SAW-SAFFB1G90KA0F0AFILTER_5_110X090_H0501900MHz
    U0806RF_SAW_SAFFB2G65AC0F0AFILTER_5_110X090_H0502655MHz(Verifying)
    U0807RF-SAW-SAFFB806MAA0F0AFILTER_5_110X090_H050806MHz
    U0808RF-SAW-SAFFB2G59AA1F0AFILTER_5_110X090_H0502593MHz(Verifying)
    U0810RF-SAW-SAFFB876MAA0F0AFILTER_5_110X090_H050876.5MHz
    U0811RF_SW_RST1245PQFN_10_P040_150X110_H057SP4T
    U0812RF_SW_RSW9108QFN_14_P040_200X200_T098_H0600.7~3.8GHz
    U0817RF-SAW-SAFFB1G96AB0F0ARF-SAW-1.1X0.91960MHz
    U2100BB_UMS9230_BGAS_704_P040_RDBGAS_704_P040_1200X1080_H083_UMS9230
    U2400RF_SW_RST1202QFN_12_P050_200X200_T095_H060
    U2401RF_SW_RST1202QFN_12_P050_200X200_T095_H060
    U3103AUDIO_AMP_UCP1301_BGA_23_P050BGA_23_P050_208X308_H057_UCP1301
    U4100POWER-DC2DC-WD3139F-6/TRSOT_6_P095_280_H090-0.3-40V/1.2A
    U4101POWER_DC2DC_NT50358ABGA_15_P040_136X226_H068_B0264~6V/200mA,-4~-6V/160mA
    U5100SENSOR_TOF_VL53L0CBV0DH/1SENSOR_TOF_VL53L0CBV0DH(Verifying)(NF)
    U5101POWER_LDO_NCP137AFCTADJT2GBGA_6_P040_080X120_H033_B0270.5-3V/700mA(Verifying)
    U5102POWER-LDO-SGM2036-2.8YUDH4G/TRSON_4_P065_100X100_T048_H0602.8V/300mA
    U5103POWER-LDO-SGM2036-2.8YUDH4G/TRSON_4_P065_100X100_T048_H0602.8V/300mA
    U5104POWER_LDO_NCP137AFCTADJT2GBGA_6_P040_080X120_H033_B0270.5-3V/700mA(Verifying)
    U5105SENSOR_XYZ+ALS_TCS34303SENSOR_XYZ_ALS_TCS34303(Verifying)
    U5106POWER-LDO-SGM2036-2.8YUDH4G/TRSON_4_P065_100X100_T048_H0602.8V/300mA
    U5107POWER-DC2DC-OCP8137WPADBGA_12_P040_128X166_H063_B0256V/2A
    U5108POWER-LDO-SGM2036-2.8YUDH4G/TRSON_4_P065_100X100_T048_H0602.8V/300mA
    U5200SENSOR_PROX_SX9338IULTRTSON_10_P040_210X180_H060_L022X075Capative,For SAR
    U6100POWER_CHARGER_BQ25890RTWTQFN_24_P050_400X400_T270_H080_RTWFast Charger,5A,OTG2.4A
    U6101POWER_LOADSW_NCP3902FCCTBGBGA_20_P040_226X166_H060_B0273A/5A(Verifying)
    U6105POWER_CHARGER_BQ25910YFFTBGA_36_P040_244X241_H063_L023Fast Charger,Switch Mode,6A
    U6400SKT-SIM-NANO-TF-ST19S020VCASKT_SIM_NANO_TF_ST19S020VCA
    U7201RF-SAW-TRIPLEX-TPX205950MT-7104A2TPX_CAF_8_P065_200X125_H100_L1.5G/2.4G/5G(Verifying)
    U7202RF-SAW-SAFFB1G56KB0F0AFILTER_5_110X090_H0501561.1/1575.42/1602MHz
    U7203RF_LNA_RDALN1609PSON_6_P040_110X090_H050_RDAGPS/GNSS
    U7204RF-SAW-SAFEA2G45MC0F0AFILTER_5_135X105_H0502441MHz
    U7205WCN_UMW2631_BGAS_117_P035BGAS_117_P035_450X420_H100_UMW2631
    U7208RF_FEM_KCT8553CQFN_16_P040_230X230_T140_H060_KCT5G WLAN,5.15~5.85GHz(Verifying)
    U7600NFC_S3NSN4VXBGA_57_P035_234X402_H059_L020
    X0200XTAL-CRYSTAL-32.768K-Q-SC32S0322070AAAFXTAL_CC_320X150_H08532.768KHz(NF)
    X7200XTAL-TCXO-26MHZ-1XXB26000MABOSC_CC_250X200_H090_KDS26MHz(NF)
    X7600XTAL-CRYSTAL-27M-E1AB27.1200F10E11XTAL_CC_200X160_H050_L085X07527.12MHz(NF)
    Y0200XTAL-CRY+THM-26M-OZ26000012XTAL_CC_250X200_H10026MHz/9pF
    重要提示:PCB作品文件展下载说明
    17万
    管理员
     楼主| 发表于 2024-8-9 08:28:13 | 显示全部楼层
    PCB 原理图一起打包。回复可见下载
    游客,如果您要查看本帖隐藏内容请回复
    前天 08:48
  • 签到天数: 121 天
    发表于 2024-8-9 08:43:14 | 显示全部楼层
    感谢老吴分享。10层还可以,看样子应该是官方的demo板
    5 天前
  • 签到天数: 179 天
    发表于 2024-8-9 09:09:08 | 显示全部楼层
    昨天 18:16
  • 签到天数: 99 天
    发表于 2024-8-9 09:34:38 | 显示全部楼层
    8 小时前
  • 签到天数: 178 天
    发表于 2024-8-9 10:41:22 | 显示全部楼层
    发表于 2024-8-9 10:53:09 | 显示全部楼层
    3 天前
  • 签到天数: 104 天
    PADS20200601高级班
    发表于 2024-8-9 11:32:19 | 显示全部楼层
    10 小时前
  • 签到天数: 111 天
    4万
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模最爱沙发社区明星优秀斑竹奖宣传大使奖
    发表于 2024-8-9 13:55:51 | 显示全部楼层
    终身成就奖社区居民忠实会员灌水天才奖新人进步奖幽默大师奖贴图大师奖优秀斑竹奖宣传大使奖金点子奖社区明星
    发表于 2024-8-9 16:08:20 | 显示全部楼层
