查看: 237|回复: 18
[Allegro17.4以下] RK3368方案锐捷网络RG-SmartRain200V2_PAD_V100 智能云终端电脑PCB
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2024-12-12 11:17:17 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    REFDES
    COMP_DEVICE_TYPE
    COMP_VALUE
    SYM_NAME
    CE6
    CAP  E_CT7343_19_100UF 16V 7343
    100UF  16V 7343 SMD
    CT7343_19
    D1
    BAT54CLT1_SOT_23_BAT54CLT1_V-31
    BAT54CLT1
    SOT_23
    D2
    SOD80_AP_SOD80_1N4148_V-3107000
    1N4148
    SOD80
    D3
    1N4148
    SOD80
    D4
    BAT54CLT1
    SOT_23
    D5
    BAT54CLT1_SOT_23_BAT54CLT1_NC_V
    BAT54CLT1_NC
    SOT_23
    D6
    ESD9B5VL_WBFBP_02C_ESD9B5VL
    ESD9B5VL
    WBFBP_02C
    D7
    ESD9B5VL
    WBFBP_02C
    D8
    ESD9B5VL
    WBFBP_02C
    D12
    SRV05_4TCT_SOT_23_6_SRV05_4TCT_
    SRV05_4TCT
    SOT_23_6
    D13
    SRV05_4TCT
    SOT_23_6
    D14
    DIODE_DO_214AA_N_P3100SB_V-3115
    P3100SB
    DO_214AA_N
    D15
    DIODE_DO_214AC_B340A_V-31030009
    B340A
    DO_214AC
    D16
    ESD9B5VL
    WBFBP_02C
    D17
    ESD9B5VL
    WBFBP_02C
    D18
    ESD9B5VL
    WBFBP_02C
    D19
    ESD9B5VL
    WBFBP_02C
    D20
    ESD9B5VL
    WBFBP_02C
    D27
    ESD9B5VL
    WBFBP_02C
    D28
    ESD9B5VL
    WBFBP_02C
    D29
    ESD9B5VL
    WBFBP_02C
    D38
    DIODE_DO_214AB_SMCJ12A_V-310900
    SMCJ12A
    DO_214AB
    D39
    LED_SMT0603_AP_LED_SMT0603_LS_S
    LS_SP190YG84_5
    LED_SMT0603
    D40
    ESD9B5VL_WBFBP_02C_ESD9B5VL_NC
    ESD9B5VL_NC
    WBFBP_02C
    ED1
    DIODE  BI_DIR TRIG_ESD0402_AZ582
    AZ5825-01F_NC
    ESD0402
    F1
    SMD1812P150TF_FUSE1812_SMD1812P
    SMD1812P150TF_NC
    FUSE1812
    HP_OUT1
    AZALIAJACK_5_AUDIO6_2SJS351_AUD
    AUDIO  JACK GREEN
    AUDIO6_2SJS351
    J1
    DC_POWER_JACK_0_DC_JACK_SMT_DC_
    DC_POWER_JACK
    DC_JACK_SMT
    JP1
    JP_3P_SIP_3P_SIP_3P_V-51130002-
    SIP_3P
    SIP_3P
    JSPK1
    WAFER1X2_CON2_85204_WAFER1X2  1.
    WAFER1X2  1.25MM 85204-02001T
    CON2_85204
    J_CTRL1
    2*12PIN  P=2_1.0 LOCK DIP_HEADER
    2*12PIN  P=2.0 90D LOCK DIP
    HEADER2X12X2MM-H-90
    L1
    L_7M2X6M5X3_AP_L_7M2X6M5X3_1.5U
    1.5uH/9A
    L_7M2X6M5X3
    L2
    WSRPG0503_WSRPG0503_2.2UH/5.8A
    2.2uH/5.8A
    WSRPG0503
    L3
    2.2uH/5.8A
    WSRPG0503
    L4
    2.2uH/5.8A
    WSRPG0503
    L5
    2.2uH/5.8A
    WSRPG0503
    L6
    INDUCTOR_L0603_180R-100M
    180R-100M
    L0603
    L7
    INDUCTOR_L0805_80/1.5A_V-250200
    80/1.5A
    L0805
    L8
    80/1.5A
    L0805
    L9
    180R-100M
    L0603
    L10
    180R-100M
    L0603
    L11
    180R-100M
    L0603
    L12
    INDUCTOR_L0805_100/4A_V-2502000
    100/4A
    L0805
    L13
    80/1.5A
    L0805
    L14
    INDUCTOR_L_0M80X2M50_2.2UH/1A_V
    2.2uH/1A
    L_0M80X2M50
    L15
    100/4A
    L0805
    L16
    180R-100M
    L0603
    L17
    180R-100M
    L0603
    L18
    L_7M2X6M5X3_AP_L_7M2X6M5X3_10UH
    10uH/3A
    L_7M2X6M5X3
    L19
    L0805_L0805_X_L0805;L0805_AP
    X
    L0805
    L20
    10uH/3A
    L_7M2X6M5X3
    L21
    80/1.5A
    L0805
    L22
    80/1.5A
    L0805
    L23
    80/1.5A
    L0805
    L24
    80/1.5A
    L0805
    L25
    80/1.5A
    L0805
    L26
    80/1.5A
    L0805
    L27
    80/1.5A
    L0805
    L28
    80/1.5A
    L0805
    L29
    INDUCTOR_L_0M80X2M50_2.2UH/1.5A
    2.2uH/1.5A_NC
    L_0M80X2M50
    L30
    180R-100M
    L0603
    L31
    L0805_L0805_100/4A_V-25020009-0
    100/4A
    L0805
    L32
    100/4A
    L0805
    L33
    100/4A
    L0805
    L34
    100/4A
    L0805
    MIC_IN1
    AZALIAJACK_5_AUDIO6_2SJS351_A_1
    AUDIO  JACK PINK
    AUDIO6_2SJS351
    MIPI1
    H_7_CON39-0D3-FH35C_FPC  39PIN 0
    FPC  39pin 0.3mm
    CON39-0D3-FH35C
    OSC1
    OSC_CRYSTAL_VMK3_32.768KHZ_V-41
    32.768KHZ
    VMK3
    OSC2
    7M20000025_OSC_SMD3M2X2M5_0M65_
    24MHz
    OSC_SMD3M2X2M5_0M65
    OSC3
    7M20000025_OSC_SMD3M2X2M5_0M6_1
    25.000625MHz
    OSC_SMD3M2X2M5_0M65
    OSC4
    7M20000025_OSC_SMD3M2X2M5_0M6_2
    37.4MHz_NC
    OSC_SMD3M2X2M5_0M65
    OSC5
    24MHz
    OSC_SMD3M2X2M5_0M65
    PWR1
    TS7301VH_1_SW_CMOS_3531B_3531B-
    3531B-050
    SW_CMOS_3531B
    Q1
    APM1105NUC_TRG_1_SOT_23_2N7002_
    2N7002
    SOT_23
    Q2
    APM1105NUC_TRG_1_SOT_23_LP2301L
    LP2301LT1G
    SOT_23
    Q3
    BCE_NPN_SOT_23_MMBT3904LT1G_V-3
    MMBT3904LT1G
    SOT_23
    Q4
    APM1105NUC_TRG_1_SOT_23_LP230_1
    LP2301LT1G_NC
    SOT_23
    Q5
    APM1105NUC_TRG_1_SOT_23_2N700_1
    2N7002_NC
    SOT_23
    Q6
    2N7002
    SOT_23
    Q7
    2N7002
    SOT_23
    Q8
    2N7002
    SOT_23
    Q9
    2N7002
    SOT_23
    Q10
    2N7002_NC
    SOT_23
    Q11
    2N7002
    SOT_23
    Q12
    MMBT3904LT1G
    SOT_23
    Q13
    MMBT3904LT1G
    SOT_23
    Q14
    MMBT3904LT1G
    SOT_23
    Q15
    MMBT3904LT1G
    SOT_23
    Q16
    MMBT3904LT1G
    SOT_23
    Q26
    2N7002
    SOT_23
    Q27
    BCE_NPN_SOT_23_MMBT3904LT1G_NC_
    MMBT3904LT1G_NC
    SOT_23
    RTCBAT1
    CON2_85204
    TPD1
    TPCONN_0_FPC10PIN_UP2D0_A_FPC  1
    FPC  10Pin 0.5MM upper
    FPC10PIN_UP2D0_A
    TP_WX1
    TP_WX1_TP_WX1_TP_WX1
    TP_WX1
    TP_WX1
    U1
    SI4488DY_SOIC_8_AO4423_
    AO4423
    SOIC_8
    U2
    TPS54227_SOP_8_EP2M90X2M00_TPS5
    TPS54527
    SOP_8_EP2M90X2M00
    U3
    APL1117_33_SOT_223_APL1117_33_V
    APL1117_33
    SOT_223
    U4
    PMIC_RK808_QFN68-7X7_RK808-B
    RK808-B
    QFN68-7X7
    U5
    DSP_RK3368_BGA453_19R00X19R00X1
    DSP_RK3368
    BGA453_19R00X19R00X1R40
    U6
    DDR3_16BIT_FBGA_96_1M10_R14_128
    128x16bit
    FBGA_96_1M10_R14
    U7
    128x16bit
    FBGA_96_1M10_R14
    U8
    128x16bit
    FBGA_96_1M10_R14
    U9
    128x16bit
    FBGA_96_1M10_R14
    U10
    TLV70025DDCR_SOT_23_5_N_TLV7001
    TLV70018DDCR
    SOT_23_5_N
    U11
    KLMAG2GEAC_B001_FBGA_153_1M2_R1
    KLMAG2GEAC_B001
    FBGA_153_1M2_R10
    U12
    TPS2042BD_SOIC_8_TPS2052BD_V-32
    TPS2052BD
    SOIC_8
    U13
    USB2514B_AEZ_QFN_36_EP3M85_USB2
    USB2514B_AEZ
    QFN_36_EP3M85
    U14
    RTL8211F_QFN_40_EPAD3M60_RTL821
    RTL8211F-CG
    QFN_40_EPAD3M60
    U15
    H5007_SOP24-40-280X160_TRANSFOR
    TRANSFORMER  1000M SMD24
    SOP24-40-280X160
    U16
    RCLAMP0524P_QFN10_20_40X24_RCLA
    RCLAMP0524PA  QFN10
    QFN10_20_40X24
    U17
    RCLAMP0524PA  QFN10
    QFN10_20_40X24
    U18
    RCLAMP0524PA  QFN10
    QFN10_20_40X24
    U19
    LED  DRIVE-BL_SOT23_6_1M10_MP148
    MP1488/UP6003AMT6
    SOT23_6_1M10
    U20
    74LVC1GU04GW_TSSOP_5_NC//74LVC1
    NC//74LVC1GU04GW
    TSSOP_5
    U21
    MP5610_QFN10-0D4-1D8X1D4X0D6_MP
    MP5610
    U22
    ALC5651_QFN_40_5X5_ALC5651
    ALC5651
    QFN_40_5X5
    U23
    LM4990_MSOP_8_PT5305
    PT5305
    MSOP_8
    U24
    AP6335_QFN_44_AP6335_NC
    AP6335_NC
    QFN_44
    U25
    MAX809SD_SOT_23_NC/MAX809RD
    NC/MAX809RD
    SOT_23
    U26
    RCLAMP0524P_QFN10_20_40X24_RC_1
    RClamp0524PATCT  QFN10
    QFN10_20_40X24
    U27
    QFN10_20_40X24
    U28
    QFN10_20_40X24
    U29
    QFN10_20_40X24
    U30
    SN74CB3Q3384A_TSSOP_24_SN74CB3Q
    SN74CB3Q3384A_NC
    TSSOP_24
    U31
    QFN10_20_40X24
    U32
    QFN10_20_40X24
    USB1
    USB2X1_USB_WLUS225A_USB  SINKING
    USB  SINKING DIP
    USB_WLUS225A
    USB2
    USB  SINKING DIP
    USB_WLUS225A
    USB3
    USB  SINKING DIP
    USB_WLUS225A
    USB4
    USB  SINKING DIP
    USB_WLUS225A
    VOL_DOWN1
    TS7301VH_SW_P2_TS7301_TS7301VH
    TS7301VH
    SW_P2_TS7301
    VOL_UP1
    TS7301VH
    SW_P2_TS7301
    WIFI_ANT1
    CON_IPEX_1_ANT-JACK_3PIN  ANT JA
    3Pin  ANT JACK_NC
    ANT-JACK
    重要提示:PCB作品文件展下载说明
    17万
    管理员
     楼主| 发表于 2024-12-12 11:18:08 | 显示全部楼层
    PCB文件。回复可见下载
    游客,如果您要查看本帖隐藏内容请回复
    发表于 2024-12-12 13:35:31 | 显示全部楼层
    发表于 2024-12-12 13:47:00 | 显示全部楼层
    看看,学习学习,下载一下
    昨天 18:10
  • 签到天数: 121 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2024-12-12 13:47:23 | 显示全部楼层
    昨天 08:02
  • 签到天数: 170 天
    终身成就奖优秀斑竹奖特殊贡献奖
    发表于 2024-12-12 13:52:36 | 显示全部楼层
    发表于 2024-12-12 14:07:43 | 显示全部楼层
  • 签到天数: 28 天
    发表于 2024-12-12 15:12:47 | 显示全部楼层
    昨天 10:29
  • 签到天数: 16 天
    发表于 2024-12-12 16:57:58 | 显示全部楼层
    多谢老吴分享,学习学习
    昨天 11:38
  • 签到天数: 205 天
    发表于 2024-12-12 19:15:34 | 显示全部楼层
