查看: 16|回复: 0
[IC] XR875_Datasheet_V0.6_draft_version
    昨天 14:16
    发表于 昨天 14:08 | 显示全部楼层 |阅读模式
    RISC-V+Wi-Fi/BT SoC XR875
    Features
    ·XuanTie 64-bit RISC-V C906 CPU,up to 600MHz
    ·ARM M33 Star MCU,up to 240 MHz
    ·Memories
    -1MB SRAM
    -SIP 4MB PSRAM
    -2048-bitefuse
    ·Image and Graphics
    Supports Graphic 2D accelerator with rotate and mixerSupports RGB output interface,upto 1024x768@60fpsSupports display engine
    ·Video lnput
    -8-bit parallelCSI interface
    -Supports JPEGencoder,1920×1088
    -Supportsboth online and offline mode for JPEG encoder
    ·AnalogAudio Codec
    -1 DAC channel and3 ADC channels
    -SupportsUSB audioplayback
    Up to 105 dBSNR during DAC playback path (signal through DAC and Headphone with A-weighted filter)
    Up to 95dBSNR during ADC record path (signalthrough PGA and ADC with A-weighted filter)
    ·One I2S/TDM/PCM extemal interface (12S0)
    ·Security Engine
    Symmetrical algorithm:AES,DES,3DES
    Hashalgorithm:MD5,SHA1,SHA224,SHA256,SHA384,SHA512,HMACAsymmetricalalgorithm:RSA512/1024/2048bitHardware TRNG
    ·Extemal Peripherals
    -One USB DRD 2.0
    -Up to 3UART controllers(UARTO,UART1,UART2)
    -Up to 2SPI controllers(SPIO,SPI1)
    -Up to 2 TWI controllers(TWIO,TWI1)
    -One CIR RX and one CIR TX
    -Up to 8 PWM channels(PWM[7:0])
    -Up to 8 GPADCinput channels
    -One LEDC used to control the external intelligent control LED lamp
    ·Package
    QFN80 balls,0.35mm ball pitch,8 mm×8mm body
    Copyright ◎2022 Xradio Technology Co.,Ltd.All Rights Reserved.
    TECH
    i
    XR875_Datasheet_V0.6_draft_version.pdf
    4.35 MB, 下载次数: 0, 下载积分: 金币 -1 枚
