查看: 12500|回复: 66
[Pads_VX.2x] TMS320C6657+XC3S200AN 挂三个 MT41J128M16HA DDR PCB文件
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2016-9-24 23:46:11 | 显示全部楼层 |阅读模式
    NamePCB DecalPart Type
    560V2_PWR1HD_4X2P_100_DCONNECTOR_-_4_X_2_HD_4X2P_100_D
    AMC1GF-AMC-B00_GF-AMC-B_0_GF-AMC-B_GF-AMC-B
    CLK2QFN_48P_20_276X276_TP220V25CDCE62005RGZT_0_QFN_48P_20_276X
    COM1MOL22-23-2031CONNECTOR_-_3_X_1_MOL22-23-2031
    COM_SEL1SAMTSM-103-01-S-DV1653_JH3X2V_0_SAMTSM-103-01-S-D
    CT6CT7343CAP_POL_CT7343__100UF
    D1LED_LTST-S270K_RA130_LED_LED-0603_R_0_LED_LTST-S
    D2LED_LTST-S270K_RA130_LED_2P_B_0_LED_LTST-S270K_R
    D3DIODE_2P_158_197X110SCHOTTKY_DIODE_DIODE_2P_158_197
    D4ESD_2P_65_63X31130_ESD_D0603_0_ESD_2P_65_63X31
    D5ESD_2P_65_63X31130_ESD_D0603_0_ESD_2P_65_63X31
    D7DIODE_2P_158_197X110130_SCHOTTKY_SMA-1_0_DIODE_2P_1
    D9SOD-323130_SCHOTTKY_SOD-323_SOD-323_DI
    D10SOD-323130_SCHOTTKY_SOD-323_SOD-323_DI
    D11LED_0603130_LED_LED-0603_G_0_LED_0603_G
    D17LED_LTST-C171LED_LED_LTST-C171__LED
    D18DIO_DO214AA_SMBZENER_DIODE_DIO_DO214AA_SMB__SM
    DC_IN1CON_RAPC712_PWRJACKCONN_JACK_PWR_CON_RAPC712_PWRJA
    DSP1BGA80P_38X38_625_SKT_EINFTMS320C6657_BGA80P_38X38_625_SK
    EEPROM1SOIC_8P_50_193X236AT24C1024_0_SOIC_8P_50_193X236_
    EMU1BB_30X2P_50_770X250_2HOLD1654_BB_30X2P_SOLC-115-02_0_BB_
    ESD1AMC-ESD-B00_AMC-ESD-B_0_AMC-ESD-B_AMC-ES
    F6PTC_RUEF300FUSE_PTC_RUEF300__RUEF300
    F7FUSE_C0603FUSE_FUSE_C0603__F0603E3R00FSTR
    F8FUSE_C0603FUSE_FUSE_C0603__MFU0603FF04000
    F9FUSE_C0603FUSE_FUSE_C0603__F0603E1R00FSTR
    FAN1WHL3V-2M1655_WHL3V-2M_0_WHL3V-2M_IO_NU_
    FM1FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIAL
    FM2FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIAL
    FM3FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIAL
    FM4FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIAL
    FPGA1BGA_256P_39_669X669_H61XC3S200AN-4FTG256C_BGA_256P_39_
    FPGA_D1LED_0603130_LED_2P_B_0_LED_0603_GRN
    FPGA_D2LED_0603130_LED_2P_B_0_LED_0603_GRN
    FPGA_D3LED_0603130_LED_2P_B_0_LED_0603_GRN
    FPGA_D4LED_0603130_LED_2P_B_0_LED_0603_GRN
    H1H35-NPTH00_SCREWHOLE_CIRCLE_NPTH_1_H35-
    H2H35-NPTH00_SCREWHOLE_CIRCLE_NPTH_1_H35-
    H3H35-NPTH00_SCREWHOLE_CIRCLE_NPTH_1_H35-
    H4H35-NPTH00_SCREWHOLE_CIRCLE_NPTH_1_H35-
    H5H27P35-MTH00_H27P35-MTH_0_H27P35-MTH_H27P
    HYPERLINK1IPASSHD_36P_76867-00111654_IPASS_36P_76867-0011_0_IPA
    J4SAMTSW-102-07-S-SCONNECTOR_-_2_X_1_SAMTSW-102-07
    J5SAMTSW-102-07-S-SCONNECTOR_-_2_X_1_SAMTSW-102-07
    L2IND_NR80401211_L_0_IND_NR8040_DISCRETE_22
    L3IND_NRG40261211_CHOKE_0_IND_NRG4026_DISC_1
    L15IND_NRG40261211_CHOKE_0_IND_NRG4026_DISCRE
    L16CHK_ELL-5PRR47N1211_CHOKE_0_CHK_ELL-5PRR47N_DI
    L118IND_NR60281211_CHOKE_0_IND_NR6028_DISCRET
    LAN1RJ45_17P_101112FHBMAM404ZA1652_RJ45_17P_101112FHBMAM_0_RJ
    MMC1QFP_80P_20_551X551MSP430F5435IPN_0_QFP_80P_20_551
    NAND1VFBGA80P_10P5X15_63_EINFNAND512R3A2DZA6E_2_VFBGA80P_10P
    PHY1QFN50P900X900_64_PWP_A_EINF88E1112_QFN50P900X900_64_PWP_A_
    PMBUS1HD_5X1P_100_D1653_JH5X1V_0_HD_5X1P_100_D_IO_
    Q1SOT-23131_N_MOS_SOT-23_1_SOT-23_2N700
    Q2QFN_8P_26_118X118TPS73701DRBT_QFN_8P_26_118X118_
    Q3QFN_8P_26_118X118TPS73701DRBT_QFN_8P_26_118X118_
    Q4QFN_8P_26_118X118TPS73701DRBT_QFN_8P_26_118X118_
    Q5QFN_8P_26_118X118TPS73701DRBT_QFN_8P_26_118X118_
    Q6SOT-23131_N_MOS_SOT-23_1_SOT-23_2N700
    Q13SC-70_5P141_MICROCHIP_MCP9700AT-E-LT_0_
    RST_COLD1SW_EVQ-PF003M160_SW-HDK632_SW_EVQ-PF003M_EVQ
    RST_FULL1SW_EVQ-PF003M160_SW-HDK632_SW_EVQ-PF003M_EVQ
    RST_WARM1SW_EVQ-PF003M160_SW-HDK632_SW_EVQ-PF003M_EVQ
    SBW_MMC1PWR-S4PV1655_PWR-S4PV_0_PWR-S4PV_IO_W_4
    SW3SW_SDA08H0SBDIP_SWITCH_-_8_SW_SDA08H0SB__SD
    SW5SW_SDA08H0SBDIP_SWITCH_-_8_SW_SDA08H0SB__SD
    SW9SW_SDA02H0SB160_SW_4P_ESD102EZ_0_SW_SDA02H0
    SYSPG_D1LED_LTST-C171130_LED_2P_B_0_LED_LTST-C171_YE
    TAP_FPGA1HD_8X1P_100_D1653_JH8X1V_0_HD_8X1P_100_D_IO_
    TEST_PH1HD_40X2P_50_2HOLD_F1653_HD_40X2P_F_L1_0_HD_40X2P_5
    U1SOIC_16P_26_197X252ICS557GI-08LFT_0_SOIC_16P_26_19
    U5BGA_96P_31_524X295_C14MT41J128M16HA-125_BGA_96P_31_52
    U6BGA_96P_31_524X295_C14MT41J128M16HA-125_BGA_96P_31__1
    U9QFP_64P_20_472X472FT2232H_QFP_64P_20_472X472__FT2
    U10SOIC_20P_26_256X252TXS0108EPWR_SOIC_20P_26_256X252
    U11TSSOP65P640_14SN74AHC00PWR_TSSOP65P640_14_SN7
    U12SOIC_8P_50_193X236141_ATMEL_AT93C46DN-SH-T_0_SOIC
    U13SOIC_16P_26_197X252SN74AVC4T245PWR_SOIC_16P_26_197
    U16BGA_96P_31_524X295_C14MT41J128M16HA-125_BGA_96P_31_52
    U19SOIC_16P_26_197X252SN74AVC4T245PWR_SOIC_16P_26_197
    U24SOIC_16P_26_197X252SN74AVC4T245PWR_SOIC_16P_26_197
    U26SOIC_8P_50_193X236141_ATMEL_AT25128B-SSHL-B_SOIC_
    U27QFN10P_20_118X118_TP94X65V5TPS51200DRCT_QFN10P_20_118X118_
    U29SOIC_8P_50_193X236141_TI_TPS54231D_0_SOIC_8P_50_1
    U30QFN_14P_20_138X138_TP79TPS54620RGY_QFN_14P_20_138X138_
    U32QFN_48P_20_276X276_TP202V25UCD9222RGZR_QFN_48P_20_276X276_
    U34QFN_32P_20_236X236_UDC7242141_TI_UCD7242RSJT_0_QFN_32P_20
    U36QFN_14P_20_138X138_TP79TPS54620RGY_QFN_14P_20_138X138_
    U244SOIC_8P_20_79X122PCA9306_SOIC_8P_20_79X122__PCA9
    U245SOIC_8P_20_79X122PCA9306_SOIC_8P_20_79X122__PCA9
    U248SOIC_8P_20_79X122PCA9306_SOIC_8P_20_79X122__PCA9
    U249SOIC_16P_26_197X252MAX3221_SOIC_16P_26_197X252_MAX
    U251SOT-23_5P14S_TI_SN74LVC1G07_SOT-23-5_SOT
    U252SOT-23_5P14S_TI_SN74LVC1G07_SOT-23-5_SOT
    U253SOT-23_5P14S_TI_SN74LVC1G07_SOT-23-5_SOT
    U254SOIC_48P_20_492X319TS3L301_SOIC_48P_20_492X319__TS
    U255SOIC_14P_26_197X252141_TI_SN74ALVC125PWR_0_SOIC_14
    U259SOIC_48P_20_492X319TS3L301_SOIC_48P_20_492X319__TS
    U260SOP127P790_8141_NUMONYX_N25Q128A21BSF40F_SO
    U264TSSOP65P640_8AT24C02A_TSSOP65P640_8_24LC02B-
    U266SC70_5PSN74LVC1G08DCKR_SC70_5P_SN74LVC
    U267SC70_5PSN74LVC1G32DCKR_SC70_5P_SN74LVC
    U268SC70_5PSN74AUC1G32DCKR_SC70_5P_SN74AUC
    U269SC70_5PSN74AUC1G32DCKR_SC70_5P_SN74AUC
    U1131SOT23_6TPS3808G_SOT23_6__TPS3808G18DBV
    USB1MOL54819-0519MINI_USB_CONNECTOR_MOL54819-051
    Y1XTAL_ABS10CRYSTAL-2PIN_XTAL_ABS10__ABS10-
    Y2XTAL_ABM3BCRYSTAL-4_PIN_XTAL_ABM3B__ABM3B
    Y3XTAL_ABM3BCRYSTAL-4_PIN_XTAL_ABM3B__ABM_1
    Y5XTAL_ABM31231_XTAL_2P_0_XTAL_ABM3_7A-25.
    Y7OSC_535_9259_11233_OSC_4P_0_OSC_535_9259_1_AS
    游客,如果您要查看本帖隐藏内容请回复
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2016-9-25 07:35:42 | 显示全部楼层
    昨天 11:01
  • 签到天数: 48 天
    4万
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模最爱沙发社区明星优秀斑竹奖宣传大使奖
    发表于 2016-9-25 08:22:19 | 显示全部楼层
    昨天 09:17
  • 签到天数: 72 天
    1元学习Allegro(230718)
    网络监控器IPCAMERA,视
    终身成就奖社区居民特殊贡献奖
    发表于 2016-9-25 08:23:58 | 显示全部楼层
    发表于 2016-9-25 09:13:52 | 显示全部楼层
    执着
    终身成就奖社区居民优秀斑竹奖
    发表于 2016-9-25 10:57:03 | 显示全部楼层
    1111
    昨天 09:16
  • 签到天数: 38 天
    1元学习Allegro(1期)
    发表于 2016-9-25 18:47:33 | 显示全部楼层
    前天 08:40
  • 签到天数: 70 天
    终身成就奖社区居民忠实会员社区劳模
    发表于 2016-9-25 20:56:27 | 显示全部楼层
    社区居民终身成就奖优秀斑竹奖宣传大使奖社区劳模最爱沙发社区明星灌水天才奖幽默大师奖贴图大师奖新人进步奖忠实会员
    发表于 2016-9-25 21:42:09 | 显示全部楼层
    昨天 17:36
  • 签到天数: 88 天
    社区居民终身成就奖特殊贡献奖
    发表于 2016-9-25 21:59:06 | 显示全部楼层
    VERY GOOD!
    论坛开启做任务可以
    额外奖励金币快速赚
    积分升级了
