[Allegro16.6以下] Loongson 2H(龙芯2H)主板PCB原理图共享(RTL8211E-VB-CG+AU6331)
查看25009 | 回复239 | 2017-8-29 10:14:26 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BAT_CON1CONN BATTERY2-PIN_0_BATC2-20_HHOLDER BATBATC2-20
BIOS1SST25VF016B-50-4C-S2AF_0_DIP8_3SPI SOCKET DIP8_300DIP8_300
BIOS2SPIBIOS_SO8_50_208_MX25L8006EPMX25L8006EPI-12GSO8_50_208
BZ1BUZZER_BZ2-6R5-1212C_5VDCBUZZE5VDC BuzzerBZ2-6R5-1212C
CN1SD/MMC_0_CON1_13_SDCARD SOCKETSD CARD SOCKET 11 pinCON1_13
COM1CONNRJ45-8S-S_0_RJ45-8S-S-JACKAJ-068SH-8-F-R4-B4-N4RJ45-8S-S-JACK
CON2SOCKET_DDR3_SODIMM_VERT_0_DDR3_DDR3_SO-DIMM_SOCKET_1.5VDDR3_204_STD_5D2
CON7CON3_HD_1X3P_100_LF3_DIP1X3-2.5DIP1X3-2.54HD_1X3P_100_LF3
CON8D_SUB_18P_4HOLD_DUAL_COM_D_SUB_D_SUB_18P_4HOLDDUAL_COM
CON11CON5X2_2_EJTAG_2X7_EJTAGEJTAGEJTAG_2X7
CON12BOX_HEAD_2X10P_SUYIN_DIP2X10_2DBOX_HEAD_2X10PDIP2X10_2D54_H
D1BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3
D2DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3
D3BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3
D4DIODE LED_LED0805_LED0805 GREELED 0805 GREENLED0805
D5DIODE LED_LED0805_LED0805 GREELED 0805 GREENLED0805
D6BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3
D7BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3
D8BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3
D9DIODE_SCHOTTKY_2PIN_SOD323_X_RBx_RB751V-40,NCSOD323
D10BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3
D11BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3
D12DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3
D13BAT54S_1_SOT23-3_BAT54SBAT54SSOT23-3
D14BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3
D15BAT54S_1_SOT23-3_BAT54SBAT54SSOT23-3
FB1FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB2MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805
FB3MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805
FB4MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805
FB5MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805
FB6FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB7FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB8FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB9FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB10BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
FB11FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB12BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
FB13BEAD_FB0805_X_FB80@100MHZ 3Ax_FB 80@100MHZ 3AFB0805
FB14FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB15FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB16FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB17BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
FB18FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB19FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB20BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
FB48FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB49FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB50FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB51FB_FB0603_X_(FB)600OHM/100MHZ-1x_(FB)600OHM/100MHz-1.5AFB0603
FB52FERRITEBEAD_2_FB0805_X_FB 80@1x_FB 80@100MHZ 3AFB0805
FB53FERRITEBEAD_2_FB0805_X_FB 80@1x_FB 80@100MHZ 3AFB0805
FB54FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB55FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB56FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB57FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB58FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB59FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB60FB_FB0603_X_(FB)600OHM/100MHZ-1x_(FB)600OHM/100MHz-1.5AFB0603
FB63FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB64FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB65FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB66FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB67FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB68FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB69FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603
FB70BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB71BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB72BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB73BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB74BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB75BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB76BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB77BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB78BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB79BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603
FB80INDUCTOR_H_FB0805_FB80@100MHZFB 80@100MHZ 3AFB0805
FB81FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB86FERRITEBEAD_1_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB87FERRITEBEAD_1_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB88FERRITEBEAD_1_FB0805_FB 80@100FB 80@100MHZ 3AFB0805
FB89MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805
FB90MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805
H1HOLE_1_HOLE138-339-8STAR_HOLEHOLEHOLE138-339-8STAR
H2HOLE_1_HOLE138-339-8STAR_HOLEHOLEHOLE138-339-8STAR
H3HOLE_1_HOLE138-339-8STAR_HOLEHOLEHOLE138-339-8STAR
H4HOLE_1_HOLE138-339-8STAR_HOLEHOLEHOLE138-339-8STAR
ID1MARKOPTICS-1_0_MARKC_MARKMARKMARKC
ID2MARKOPTICS-1_0_MARKC_MARKMARKMARKC
ID3MARKOPTICS-1_0_MARKC_MARKMARKMARKC
ID4MARKOPTICS-1_0_MARKC_MARKMARKMARKC
ID5MARKOPTICS-1_0_MARKC_MARKMARKMARKC
ID6MARKOPTICS-1_0_MARKC_MARKMARKMARKC
J1MINIPCIE_0_MPCI52-F_MINIPCIE 5MINI PCIE 52PINHIGH7.0MMMPCI52-F
JK1CON_AUDIO-PHONO-X2_0_AUDIO_2_STSTACKED_AUDIO_JACKAUDIO_2
JP1HEADER20X2_1_DIP2X20_2D_H_HEADHEADER 20X2DIP2X20_2D_H
L7L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603
L8L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603
L9L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603
L10L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603
L11L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603
LED1LED_0_LED0805_LED0805 GREENLED 0805 GREENLED0805
LED2LED_0_LED0805_LED0805 GREENLED 0805 GREENLED0805
LED3LED_DUAL_BICOLOR_3_LED-4P_21PCT21PCT120TG4-140LED-4P
LED4LED_DUAL_BICOLOR_3_LED-4P_21PCT21PCT120TG4-140LED-4P
LED5LED_LED0805_LED 0805GREENLED 0805 GREENLED0805
MINIPCIE1CONN PCIE MINICARD_0_MPCI52-F_MINI PCIE 52PINHIGH7.0MMMPCI52-F
MINIPCIE2CONN PCIE MINICARD_0_MPCI52-F_MINI PCIE 52PINHIGH7.0MMMPCI52-F
PCIEX1PCIEX16_1_PCIESLOT_164_PCIE164PCIE164PCIESLOT_164
PD1DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3
PD2DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3
PD3DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3
PL1BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL2BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL3BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL4INDUCTOR_IND_MS0603_MS0603-1R0MMS0603-1R0MB/11AIND_MS0603
PL5BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
PL6BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
PL7BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL8BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL9BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL10BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
PL11BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
PL12INDUCTOR_IND_MS0603_MS0603-1R0MMS0603-1R0MB/11AIND_MS0603
PL13BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL14BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL15BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL16BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL17BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805
PL18INDUCTOR_IND_MS0603_MS0603-1R0MMS0603-1R0MB/11AIND_MS0603
PL19BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805
POC1C_C0603_DISCRETE_4700PF/50V4700PF/50VC0603
POC2C_C0603_DISCRETE_4700PF/50V4700PF/50VC0603
POC3C_C0603_DISCRETE_4700PF/50V4700PF/50VC0603
POR1R_R0805_DISCRETE_1,5%1,5%R0805
POR2R_R0805_DISCRETE_1,5%1,5%R0805
POR3R_R0805_DISCRETE_1,5%1,5%R0805
POR4R_R0805_DISCRETE_1,5%1,5%R0805
PQ1NPN_SOT23_SOT23-3_DISCRETE_PMBTPMBT3904SOT23-3
PQ2NPN_SOT23_SOT23-3_DISCRETE_PMBTPMBT3904SOT23-3
PQ3PH8230E_MB_SOT669_DISCRETE_AO_1AON6414ALMB_SOT669
PQ4PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669
PQ5PH8230E_MB_SOT669_DISCRETE_AO_1AON6414ALMB_SOT669
PQ6PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669
PQ7NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
PQ8NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
PQ9PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669
PQ10PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669
PQ11PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669
PQ12NPN_SOT23_SOT23-3_DISCRETE_PMBTPMBT3904SOT23-3
PQ13PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669
PQ14PH8230E_MB_SOT669_DISCRETE_AO_1AON6414ALMB_SOT669
PQ15PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669
PQ16NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
PQ17NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
PU2SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PAD
PU3RT9214A_SOP8-50-150_IC_RT8105GSRT8105GSSOP8-50-150
PU4RT9214A_SOP8-50-150_IC_RT8105GSRT8105GSSOP8-50-150
PU5SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PAD
PU6SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PAD
PU7SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PAD
PU8SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PAD
PU9RT9214A_SOP8-50-150_IC_RT8105GSRT8105GSSOP8-50-150
PWR1CONNDC-JACK_1_CONN_PWR_MSTDC00CONN DC-JACKCONN_PWR_MSTDC00520
PWR_HDD1HDD POWER CONNECTOR1X4_PWC4-204P 5.08mmPWC4-200TM-HDD
Q1N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q2N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q3N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q4N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q5N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q6N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q7N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q8N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q9N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q10N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q11SMD_NDS7002A_SOT23-GDSAP2306GNSOT23-3
Q12SMD_NDS7002A_SOT23-GDSAP2306GNSOT23-3
Q13N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q14MOSFET_P-CH_GENERIC_S08_SOIC_8PME4435SOIC_8P_50_197X236
Q15N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q16N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q17N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q18N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q19NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
Q20N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q21N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q22N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q232020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q24NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
Q25RT9173_8P_SOP8-50-150_RT9173GSRT9173GSSOP8-50-150
Q262020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q27NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
Q282020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q29NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
Q302020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q31NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
Q322020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3
Q33NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
Q34NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3
SATA1CONNSATA_0_SATA7-TF_SATA 1X7SATA 1X7SATA7-TF
SIM_CON19346_0_SIM_6P_100_2HOLD_HAMBURGSIM_SLOTSIM_6P_100_2HOLD_HAMBURG
SP2SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP3SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP4SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP5SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP6SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP7SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP8SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP9SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP10SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP11SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP12SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP13SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP14SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SP15SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PAD
SW1SW4PIN_SW_P2P_RESET_BUTTONRESET_BUTTONSW_P2P
SW2SW4PIN_SW_P2P_RESET_BUTTONRESET_BUTTONSW_P2P
SYS_FANCPU_FAN_1_H1X3_FAN_FAN1X3/WHITEFAN1x3/WhiteH1X3_FAN
U1LOONGSON2H_LS2H_BGA_(S1+S2+S3+Loongson 2HLS2H_BGA
U21GBITNAND_0_TSOP48-750-20_K9F1K9F1G08U0C-PCB0TSOP48-750-20
U3NC7SZ08_SOT23_5_NC7SZ08NC7SZ08SOT23_5
U4NC7SZ08_SOT23_5_NC7SZ08NC7SZ08SOT23_5
U5PWRTPS2052BD_SOP8-50-150_TPS20TPS2052BDSOP8-50-150
U6CM1293A_SOT23-6_(KW)CM1293A-04S(KW)CM1293A-04SOSOT23-6
U7ADM3202_MAX3232/SO_TSSOP16_0D65(IC)SP3232ECYTSSOP16_0D65_4D4
U8PWRTPS2052BD_SOP8-50-150_TPS20TPS2052BDSOP8-50-150
U9CM1293A_SOT23-6_(KW)CM1293A-04S(KW)CM1293A-04SOSOT23-6
U10RTL8211D/E_QFN48_0D4_1G_RTL8211RTL8211E-VB-CGQFN48_0D4_1G
U11RTL8211D/E_QFN48_0D4_1G_RTL8211RTL8211E-VB-CGQFN48_0D4_1G
U12ZT2083_MSOP-10L_X_ZT2083x_ZT2083MSOP-10L
U13RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8E
U14RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8E
U15ALC888S_GR_4_QFP_48P_20_354X354ALC888S_GRQFP_48P_20_354X354_H63
U16LM78_SOP8-50-150_IC_L78L05ACD13L78L05ACD13TRSOP8-50-150
U17RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8E
U18MAX811_SOT143_IMP811TEUS-TIMP811TEUS-TSOT143
U19MAX811_SOT143_IMP811TEUS-TIMP811TEUS-TSOT143
U23TMP_0_QFPS48_0D5_1D6_AU6331AU6331QFPS48_0D5_1D6
U24ADM3202_MAX3232/SO_TSSOP16_0D65(IC)SP3232ECYTSSOP16_0D65_4D4
U25ADM3202_MAX3232/SO_TSSOP16_0D65(IC)SP3232ECYTSSOP16_0D65_4D4
U26D_SUB_VGA_COM_4HOLD_VGA_COM_D_SD_SUB_VGA_COM_4HOLDVGA_COM
U27RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8E
U28RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8E
USB_RJ45_1USB_RJ45_LED_8_USB_RJ45LED_T_USUSB_RJ45_LED_8USB_RJ45LED_T
USB_RJ45_2USB_RJ45_LED_8_USB_RJ45LED_T_USUSB_RJ45_LED_8USB_RJ45LED_T
V1BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3
V2BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3
V3BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3
V4BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3
V5BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3
V6BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3
V7BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3
Y1MX_CRYSTAL_1_XN8038_XNMCHCNDED-XNMCHCNDED-32.768KHzXN8038
Y2CY_CRYSTAL_4_XS4_5032_0D8_XVHEEXVHEECNANF-12.0000XS4_5032_0D8
Y3CY_CRYSTAL_4_XS4_5032_0D8_XVHEEXVHEECNANF-12.0000XS4_5032_0D8
Y4CY_CRYSTAL_4_XS4_5032_0D8_XVH_1XVHEECNANF-25.0000XS4_5032_0D8
Y5CY_CRYSTAL_4_XS4_5032_0D8_XVH_1XVHEECNANF-25.0000XS4_5032_0D8
Y6CY_CRYSTAL_4_XS4_5032_0D8_XVH_1XVHEECNANF-25.0000XS4_5032_0D8
Y7OSC_SMD7050_OCETGIJANF(100MHZ-SOCETGIJANF(100MHz-SMD7050)SMD7050
Y9CY_CRYSTAL_4_XS4_5032_0D8_XVHEEXVHEECNANF-12.0000XS4_5032_0D8
重要提示:PCB作品文件展下载说明
老吴 | 2017-8-29 10:16:10 | 显示全部楼层
PCB文件和原理图 ,回复可见下载。
游客,如果您要查看本帖隐藏内容请回复
miaomiao | 2017-8-29 10:25:59 | 显示全部楼层
xnima_irumei | 2017-8-29 10:35:30 | 显示全部楼层
wenaidao | 2017-8-29 10:40:26 | 显示全部楼层
eshine | 2017-8-29 11:04:04 | 显示全部楼层
eshine | 2017-8-29 11:04:12 | 显示全部楼层
eshine | 2017-8-29 11:04:20 | 显示全部楼层
evs001 | 2017-8-29 11:07:13 | 显示全部楼层
evs001 | 2017-8-29 11:07:43 | 显示全部楼层
老吴所出,必是精品!
