| Name | Part Type | PCB Decal | Value | | D1 | DIODE_TVS | SMB_DO_214AA | SMBJ6.5A | | F4 | FUSE | R1812 | 0.7A/24V | | J1 | HEADER_10X2 | HEADER_200_2X10 | HEADER 10X2 | | J2 | DSP_JTAG_0 | HDR7X2 | DSP_JTAG | | J3 | HEADER_7X2 | HDR7X2 | HEADER 7X2 | | L1 | IND | RC0603 | BLM18PG121 | | L2 | IND | RC0603 | BLM18PG121 | | L3 | IND | RC0603 | BLM18PG121 | | L4 | INDUCTOR_IRON | LC1254 | 3.6 uH | | L5 | INDUCTOR | XAL7070 | 4.7uH/2.5A | | L6 | IND | R0805 | BLM18PG121 | | L7 | IND | R0805 | BLM18PG121 | | L8 | INDUCTOR | XAL7070 | 4.7uH/2.5A | | L9 | IND | R0805 | BLM18PG121 | | L10 | IND | R0805 | BLM18PG121 | | L11 | IND | R0805 | BLM18PG121 | | L12 | IND | R0805 | BLM18PG121 | | L18 | BEAD__FERRITE | C0805 | 220ohm at 100MHz | | L19 | INDUCTOR | XAL7070 | 4.7uH/2.5A | | L20 | INDUCTOR | XAL7070 | 4.7uH/2.5A | | L21 | INDUCTOR | XAL7070 | 4.7uH/2.5A | | L22 | INDUCTOR | XAL7070 | 4.7uH/2.5A | | T2 | TRANSFORMER_CT_6 | SM-22 | MABAES0060 | | U5 | MAX3221/SO_1 | TSSOP16_170_25 | MAX3221/SO | | U6 | MAX3485 | SOP1_27_8 | MAX485 | | U7 | UN3E5_90LSMD | UN3E5_90LSMD | UN3E5_90LSMD | | U8 | TLV1702 | VSSOP8 | TLV1702DGK | | U9 | MAX3485 | SOP1_27_8 | MAX485 | | U10 | UN3E5_90LSMD | UN3E5_90LSMD | UN3E5_90LSMD | | U12 | ADUM1201 | SOIC8_208_50 | ADuM1201AR | | U14 | IS61LV51216-15TI | IS61LV51216 | IS61LV25616AL | | U17 | CAT1021WI-28 | SOIC8_208_50 | CAT1025-30 | | U18 | LT1762-25_2 | MSOP_8 | LT1762-25 | | U19 | LT6362_0 | LT6362 | LT6362 | | U20 | LT2377_0 | LTC2377IMS-16 | LT2377 | | U21 | DNM01_0 | DNM01 | DNM01 | | U23 | LM3560 | HSSOP14 | LM3150 | | U25 | LT8610_0 | MSOP16 | LT8610 | | U26 | LT8610_0 | MSOP16 | LT8610 | | U27 | TS3808G33DBVR | SOT23_6 | TS3808G33DBVR | | U30 | XB1085P25_0 | TO-252 | XB1085P18 | | U32 | LT1762-25_1 | MSOP_8 | LT1965-3.3 | | U33 | LTC3260EMSE_0 | MSOP17 | LTC3260EMSE | | U35 | XC5VSX95T-1FFG1136C_2 | XC5VSX95T-FF1136 | XC5VSX95T-1FFG1136C_1 | | U36 | XCF128XFT64C_2 | XC_FT64 | XCF128XFT64C | | U39 | AD9245_3 | LFCSP_WQ | AD9245 | | U41 | SN74LVTH16245A_1 | TSSOP48_027 | SN74LVTH16245A_1 | | U42 | SN74LVTH16245A_1 | TSSOP48_027 | SN74LVTH16245A_1 | | U43 | SN74LVTH16245A_1 | TSSOP48_027 | SN74LVTH16245A_1 | | U44 | AD5764_0 | TQFP32 | AD5764 | | U45 | DSP_7 | PQFP176 | DSP_7 | | U46 | EN6360QI_0 | QFN_68PIN | EN6360QI_0 | | U47 | EN5339QI_0 | EN5339QI | EN5339QI_0 | | U48 | AD8830 | QSOP-16 | AD8830 | | U49 | XB1085P25_0 | TO-252 | LT1086-5 | | U50 | LT1175-5_0 | DD_PK | LT1175-5 | | U51 | SI7478 | SO-8DP | SI7580 | | U52 | SI7478 | SO-8DP | SI7478 | | XDA1 | SMA | SMA | SMA-K | | XDA2 | SMA | SMA | SMA-K | | XDA3 | SMA | SMA | SMA-K | | XDA4 | SMA | SMA | SMA-K | | XS1 | SMA | SMA | SMA-K | | XS2 | HEADER_5X2 | HD2X5_2_54 | Y50EX-0810ZK10 | | XS3 | SMA | SMA | SMA-K | | XS4 | HEADER_4 | SIP4_254 | Y50EX-0804ZK10 | | XS5 | HEAD7 | HDR7X1PWR | Y50EX-0807ZK10 | | XS6 | SMA | SMA | SMA-K | | XS7 | J30J-25 | J30J-25TJW-J | J30J-25ZKW-J | | XS8 | J30J-25 | J30J-25TJW-J | J30J-25TJW-J | | XS9 | J30J-9 | J30J-9TJW-J | J30J-9ZKW-J | | XS10 | HEADER_5X2 | HD2X5_2_54 | Y50EX-0810ZK10 | | Y1 | OSCILLATOR | CRYSTAL5032 | 50MHz | | Y2 | OSCILLATOR | CRYSTAL5032 | 50MHz | | Y3 | OSCILLATOR | CRYSTAL5032 | 50MHz |
LIB_DSN.7z
857 KB, 下载次数: 20, 下载积分:金币 -1 枚
