| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | ESDA14V2L_SOT23-3_ESDA14V2L | ESDA14V2L | SOT23-3 |
| D2 | ESDA14V2L_SOT23-3_ESDA14V2L | ESDA14V2L | SOT23-3 |
| D3 | RCLAMP3304NTCT_DFN10-050-2R6X2R | RCLAMP3304NTCT | DFN10-050-2R6X2R6 |
| D4 | B3D230L_ARRESTER-7R6X5_B3D230L | B3D230L | ARRESTER-7R6X5 |
| D5 | B3D230L_ARRESTER-7R6X5_B3D230L | B3D230L | ARRESTER-7R6X5 |
| D6 | B3D230L_ARRESTER-7R6X5_B3D230L | B3D230L | ARRESTER-7R6X5 |
| D7 | B3D230L_ARRESTER-7R6X5_B3D230L | B3D230L | ARRESTER-7R6X5 |
| D8 | RCLAMP3304NTCT_DFN10-050-2R6X2R | RCLAMP3304NTCT | DFN10-050-2R6X2R6 |
| D9 | FM4004-T_SMA_FM4004-T | FM4004-T | SMA |
| D10 | FM4004-T_SMA_FM4004-T | FM4004-T | SMA |
| D11 | FM4004-T_SMA_FM4004-T | FM4004-T | SMA |
| D12 | FM4004-T_SMA_FM4004-T | FM4004-T | SMA |
| D13 | SMDJ58A_SMC_SMDJ58A | SMDJ58A | SMC |
| D14 | FM4004-T_SMA_FM4004-T | FM4004-T | SMA |
| D15 | FM4004-T_SMA_FM4004-T | FM4004-T | SMA |
| D16 | FM4004-T_SMA_FM4004-T | FM4004-T | SMA |
| D17 | FM4004-T_SMA_FM4004-T | FM4004-T | SMA |
| D27 | MBRS240LT3G_SMB_MBRS240LT3G | MBRS240LT3G | SMB |
| D28 | BAS21LT1G_SOT23-3_BAS21LT1G | BAS21LT1G | SOT23-3 |
| D29 | MBRS240LT3G_SMB_MBRS240LT3G | MBRS240LT3G | SMB |
| D30 | 1SMA5931BT3G_SMA_1SMA5931BT3G | 1SMA5931BT3G | SMA |
| D31 | BAS21LT1G_SOT23-3_BAS21LT1G | BAS21LT1G | SOT23-3 |
| F1 | FUSE-2A-SF6127_FUSESM2-6R1X2R7_ | FUSE-2A | FUSESM2-6R1X2R7 |
| ID1 | ID_MARK1R0_ID MARK | ID MARK | MARK1R0 |
| ID2 | ID_MARK1R0_ID MARK | ID MARK | MARK1R0 |
| ID3 | ID_MARK1R0_ID MARK | ID MARK | MARK1R0 |
| ID4 | ID_MARK1R0_ID MARK | ID MARK | MARK1R0 |
| ID5 | ID_MARK1R0_ID MARK | ID MARK | MARK1R0 |
| ID6 | ID_MARK1R0_ID MARK | ID MARK | MARK1R0 |
| J1 | SHEAD-14PIN_HDR2X7-2R54-SM-V_SH | SHEAD-14PIN | HDR2X7-2R54-SM-V |
| J2 | RJ45_RJ8-21R85_RJ45 | RJ45 | RJ8-21R85 |
| J4 | RJ45_RJ8-21R85_RJ45 | RJ45 | RJ8-21R85 |
| J5 | P1251_04_B_FPC4-1R25_P1251_04_B | P1251_04_B | FPC4-1R25 |
| J6 | MCX_CON5-6X6-SMA_MCX | MCX | CON5-6X6-SMA |
| J7 | MCX_CON5-6X6-SMA_MCX | MCX | CON5-6X6-SMA |
| J8 | MCX_CON5-6X6-SMA_MCX | MCX | CON5-6X6-SMA |
| J9 | MCX_CON5-6X6-SMA_MCX | MCX | CON5-6X6-SMA |
| L1 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L2 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L3 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L4 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L5 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L6 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L7 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L8 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L9 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L10 | BEAD-0.5A-SL0805_SL0805_0.5A | 0.5A | SL0805 |
| L11 | BEAD-3A-SL1210_SL1210_3A | 3A | SL1210 |
| L12 | INDUCTOR-3.3NH-190MA-SL0402_SL0 | 3.3nH | SL0402 |
| L13 | INDUCTOR-NOLOAD-A-SL0402_SL040 | no load | SL0402 |
| L14 | INDUCTOR-2NH-300MA-SL0402_SL040 | 2nH | SL0402 |
| L15 | INDUCTOR-3.3NH-190MA-SL0402_SL0 | 3.3nH | SL0402 |
| L16 | INDUCTOR-2NH-300MA-SL0402_SL040 | 2nH | SL0402 |
| L20 | INDUCTOR-10NH-250MA-SL0402_SL04 | 10nH | SL0402 |
| L21 | INDUCTOR-4.7NH-160MA-SL0402_SL0 | 4.7nH | SL0402 |
| L22 | INDUCTOR-3.3NH-190MA-SL0402_SL0 | 3.3nH | SL0402 |
| L23 | INDUCTOR-NOLOAD-A-SL0402_SL040 | no load | SL0402 |
| L24 | INDUCTOR-2NH-300MA-SL0402_SL040 | 2nH | SL0402 |
| L25 | INDUCTOR-3.3NH-190MA-SL0402_SL0 | 3.3nH | SL0402 |
| L26 | INDUCTOR-2NH-300MA-SL0402_SL040 | 2nH | SL0402 |
| L30 | INDUCTOR-10NH-250MA-SL0402_SL04 | 10nH | SL0402 |
| L31 | INDUCTOR-4.7NH-160MA-SL0402_SL0 | 4.7nH | SL0402 |
| L32 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L34 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L35 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L36 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L37 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L38 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L40 | INDUCTOR-2NH-300MA-SL0402_SL040 | 2nH | SL0402 |
| L42 | INDUCTOR-2.7NH-220MA-SL0402_SL0 | 2.7nH | SL0402 |
| L43 | INDUCTOR-2NH-300MA-SL0402_SL040 | 2nH | SL0402 |
| L44 | INDUCTOR-8.2NH-SL0402_SL0402_8. | 8.2nH | SL0402 |
| L51 | INDUCTOR-2NH-300MA-SL0402_SL040 | 2nH | SL0402 |
| L54 | INDUCTOR-2.7NH-220MA-SL0402_SL0 | 2.7nH | SL0402 |
| L55 | INDUCTOR-2NH-300MA-SL0402_SL040 | 2nH | SL0402 |
| L56 | INDUCTOR-8.2NH-SL0402_SL0402_8. | 8.2nH | SL0402 |
| L63 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L64 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L65 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L66 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L71 | BEAD-2A-SL0805_SL0805_2A | 2A | SL0805 |
| L72 | LFB2H2G45SG7A158_FILSM4-2R5X2R0 | LFB2H2G45SG7A158 | FILSM4-2R5X2R0 |
| L73 | LFL182G45TCED448_FILSM6-1R6X0R8 | LFL182G45TCED448 | FILSM6-1R6X0R8 |
| L74 | ACPF-7024_ACPF-7024_ACPF-7024 | ACPF-7024 | ACPF-7024 |
| L75 | LFB2H2G45SG7A158_FILSM4-2R5X2R0 | LFB2H2G45SG7A158 | FILSM4-2R5X2R0 |
| L76 | LFL182G45TCED448_FILSM6-1R6X0R8 | LFL182G45TCED448 | FILSM6-1R6X0R8 |
| L77 | LFB2H2G45SG7A158_FILSM4-2R5X2R0 | LFB2H2G45SG7A158 | FILSM4-2R5X2R0 |
| L78 | ACPF-7024_ACPF-7024_ACPF-7024 | ACPF-7024 | ACPF-7024 |
| L79 | LFB2H2G45SG7A158_FILSM4-2R5X2R0 | LFB2H2G45SG7A158 | FILSM4-2R5X2R0 |
| L81 | DEA165850LT-1197B2_FILSM4-1R6X0 | DEA165850LT-1197B2 | FILSM4-1R6X0R8 |
| L82 | DEA205425BT-2028A4_FILSM4-2R0X1 | DEA205425BT-2028A4 | FILSM4-2R0X1R25 |
| L83 | DEA205425BT-2028A4_FILSM4-2R0X1 | DEA205425BT-2028A4 | FILSM4-2R0X1R25 |
| L84 | DEA205425BT-2028A4_FILSM4-2R0X1 | DEA205425BT-2028A4 | FILSM4-2R0X1R25 |
| L85 | DEA165850LT-1197B2_FILSM4-1R6X0 | DEA165850LT-1197B2 | FILSM4-1R6X0R8 |
| L86 | DEA205425BT-2028A4_FILSM4-2R0X1 | DEA205425BT-2028A4 | FILSM4-2R0X1R25 |
| L87 | INDUCTOR-1UH-9A-SPL1209_INDSM2- | 1uH-9A | INDSM2-12R95X9R4 |
| L88 | BEAD-6A-SL1806_SL1806_6A | 6A | SL1806 |
| L90 | INDUCTOR-2.2UH-1.5A-SL1717_INDS | 2.2uH-1.5A | INDSM2-4R2X4R2 |
| L91 | INDUCTOR-2.2UH-1.5A-SL1717_INDS | 2.2uH-1.5A | INDSM2-4R2X4R2 |
| L92 | INDUCTOR-8.2NH-SL0402_SL0402_8. | 8.2nH | SL0402 |
| L93 | INDUCTOR-8.2NH-SL0402_SL0402_8. | 8.2nH | SL0402 |
| L94 | INDUCTOR-1UH-9A-SPL1209_INDSM2- | 1uH-9A | INDSM2-12R95X9R4 |
| L95 | INDUCTOR-NOLOAD-A-SL0402_SL040 | no load | SL0402 |
| L96 | INDUCTOR-1.8NH-280MA-SL0402_SL0 | 1.8nH | SL0402 |
| L97 | INDUCTOR-1.8NH-280MA-SL0402_SL0 | 1.8nH | SL0402 |
| L98 | INDUCTOR-NOLOAD-A-SL0402_SL040 | no load | SL0402 |
| L99 | INDUCTOR-1.8NH-280MA-SL0402_SL0 | 1.8nH | SL0402 |
| L100 | INDUCTOR-1.8NH-280MA-SL0402_SL0 | 1.8nH | SL0402 |
| LED1 | LTST-C190KGKT_LED0603_LTST-C190 | LTST-C190KGKT | LED0603 |
| LED2 | LTST-C190KGKT_LED0603_LTST-C190 | LTST-C190KGKT | LED0603 |
| LED3 | LTST-C190KGKT_LED0603_LTST-C190 | LTST-C190KGKT | LED0603 |
| LED4 | LTST-C190KGKT_LED0603_LTST-C190 | LTST-C190KGKT | LED0603 |
| LED5 | LTST-C190KGKT_LED0603_LTST-C190 | LTST-C190KGKT | LED0603 |
| M1 | HOLE_8R00D3R50_HOLE_8R00D35R0_H | HOLE_8R00D3R50 | HOLE_8R00D35R0 |
| M2 | HOLE_8R00D3R50_HOLE_8R00D35R0_H | HOLE_8R00D3R50 | HOLE_8R00D35R0 |
| M4 | HOLE_8R00D3R50_HOLE_8R00D35R0_H | HOLE_8R00D3R50 | HOLE_8R00D35R0 |
| M5 | HOLE_8R00D3R50_HOLE_8R00D35R0_H | HOLE_8R00D3R50 | HOLE_8R00D35R0 |
| M6 | HOLE_8R00D3R50_HOLE_8R00D35R0_H | HOLE_8R00D3R50 | HOLE_8R00D35R0 |
| M7 | HOLE_8R00D3R50_HOLE_8R00D35R0_H | HOLE_8R00D3R50 | HOLE_8R00D35R0 |
| M8 | HOLE_8R00D3R50_HOLE_8R00D35R0_H | HOLE_8R00D3R50 | HOLE_8R00D35R0 |
| Q2 | MMBT3906LT1G_SOT23-3_MMBT3906LT | MMBT3906LT1G | SOT23-3 |
| Q4 | MMBT3906LT1G_SOT23-3_MMBT3906LT | MMBT3906LT1G | SOT23-3 |
| Q7 | MMBTA56_SOT23-3_MMBTA56 | MMBTA56 | SOT23-3 |
| Q8 | MMBTA56_SOT23-3_MMBTA56 | MMBTA56 | SOT23-3 |
| Q9 | IRLML6401TRPBF_SOT23-3_IRLML640 | IRLML6401TRPBF | SOT23-3 |
| Q10 | IRLML6401TRPBF_SOT23-3_IRLML640 | IRLML6401TRPBF | SOT23-3 |
| Q11 | BFP740_SOT343_BFP740 | BFP740 | SOT343 |
| Q12 | BFP740_SOT343_BFP740 | BFP740 | SOT343 |
| Q17 | MMBT3906LT1G_SOT23-3_MMBT3906LT | MMBT3906LT1G | SOT23-3 |
| Q18 | FDMS7672_SO8-5R15X6R15_FDMS7672 | FDMS7672 | SO8-5R15X6R15 |
| Q19 | FDD120AN15A0_DPAK_FDD120AN15A0 | FDD120AN15A0 | DPAK |
| RV1 | RV-100V-4500A-VSR2-300_CAPTM-15 | RV-100V-4500A-VSR2-300 | CAPTM-15R5X4 |
| RV2 | RV-100V-4500A-VSR2-300_CAPTM-15 | RV-100V-4500A-VSR2-300 | CAPTM-15R5X4 |
| RV3 | RV-100V-4500A-VSR2-300_CAPTM-15 | RV-100V-4500A-VSR2-300 | CAPTM-15R5X4 |
| RV4 | RV-100V-4500A-VSR2-300_CAPTM-15 | RV-100V-4500A-VSR2-300 | CAPTM-15R5X4 |
| RV5 | RV-100V-4500A-VSR2-300_CAPTM-15 | RV-100V-4500A-VSR2-300 | CAPTM-15R5X4 |
| S1 | TSW4-RG_SWTM4-7R4X6R55_TSW4-RG | TSW4-RG | SWTM4-7R4X6R55 |
| T1 | 0905A00K_XFMRSM24-17R5X12R2_HX6 | HX6072NLT | XFMRSM24-17R5X12R2 |
| T4 | T-10MH_INDSM4-18X17R8_10MH | 10MH | INDSM4-18X17R8 |
| T5 | SUMIDAT224_XFMRSM10-13R5X14R2- | SUMIDA T224 | XFMRSM10-13R5X14R2-A |
| T6 | T-3.5MH_CM8-001R_3.5MH | 3.5MH | CM8-001R |
| U1 | AR9344_BGA409-0R65-18X18_(S1+S2 | AR9344 | BGA409-0R65-18X18 |
| U2 | DDRII-32M*16BIT_BGA84-0R80-8X12 | DDRII-32M*16bit | BGA84-0R80-8X12R5 |
| U3 | AR9382_QFN108-040-12X12-H6R2X3R | AR9382 | QFN108-040-12X12-H6R2X3R9 |
| U7 | S25FL128S_SOIC16-50-300_SPIFLA | SPI FLASH 128Mbit | SOIC16-50-300 |
| U10 | B50610KMLG_QFN48-050-7X7-H4R1_B | B50610KMLG | QFN48-050-7X7-H4R1 |
| U28 | SE5004L_QFN20-050-4X4-H2R5_SE50 | SE5004L | QFN20-050-4X4-H2R5 |
| U31 | SE5004L_QFN20-050-4X4-H2R5_SE50 | SE5004L | QFN20-050-4X4-H2R5 |
| U43 | DDRII-32M*16BIT_BGA84-0R80-8X12 | DDRII-32M*16bit | BGA84-0R80-8X12R5 |
| U67 | ADM706SAR_REEL_SO8-50-154_ADM70 | ADM706SAR_REEL | SO8-50-154 |
| U68 | LM75BIMX_3NOPB_SO8-50-154_LM75B | LM75BIMX_3NOPB | SO8-50-154 |
| U70 | DB0603N2400ANTR_DB0603N_DB0603N | DB0603N2400ANTR | DB0603N |
| U71 | SKY65174-21_MCM10-050-4X4_SKY65 | SKY65174-21 | MCM10-050-4X4 |
| U72 | DB0603N2400ANTR_DB0603N_DB0603N | DB0603N2400ANTR | DB0603N |
| U73 | SN74LVC1G125DCK_SC70-5_SN74LVC1 | SN74LVC1G125DCK | SC70-5 |
| U74 | SKY65174-21_MCM10-050-4X4_SKY65 | SKY65174-21 | MCM10-050-4X4 |
| U75 | SN74LVC1G125DCK_SC70-5_SN74LVC1 | SN74LVC1G125DCK | SC70-5 |
| U76 | SKY13370-374LF_DFN6-050-1R5X1R5 | SKY13370-374LF | DFN6-050-1R5X1R5 |
| U77 | SN74LVC1G125DCK_SC70-5_SN74LVC1 | SN74LVC1G125DCK | SC70-5 |
| U78 | DB0603N2400ANTR_DB0603N_DB0603N | DB0603N2400ANTR | DB0603N |
| U79 | SKY65174-21_MCM10-050-4X4_SKY65 | SKY65174-21 | MCM10-050-4X4 |
| U80 | DB0603N2400ANTR_DB0603N_DB0603N | DB0603N2400ANTR | DB0603N |
| U81 | SN74LVC1G125DCK_SC70-5_SN74LVC1 | SN74LVC1G125DCK | SC70-5 |
| U82 | SKY65174-21_MCM10-050-4X4_SKY65 | SKY65174-21 | MCM10-050-4X4 |
| U83 | SN74LVC1G125DCK_SC70-5_SN74LVC1 | SN74LVC1G125DCK | SC70-5 |
| U84 | SKY13370-374LF_DFN6-050-1R5X1R5 | SKY13370-374LF | DFN6-050-1R5X1R5 |
| U85 | SN74LVC1G125DCK_SC70-5_SN74LVC1 | SN74LVC1G125DCK | SC70-5 |
| U96 | MAX15053_BGA9-0R50-1R5X1R5_MAX1 | MAX15053 | BGA9-0R50-1R5X1R5 |
| U97 | MIC5209YML_MLF8-065-3X3_MIC5209 | MIC5209YML | MLF8-065-3X3 |
| U99 | MAX3232E_SSOP16-26-209_MAX3232E | MAX3232E | SSOP16-26-209 |
| U100 | MAX5969A_TDFN10-050-3X3_MAX5969 | MAX5969A | TDFN10-050-3X3 |
| U101 | DB0603N5800ANTR_DB0603N_DB0603N | DB0603N5800ANTR | DB0603N |
| U102 | DB0603N5800ANTR_DB0603N_DB0603N | DB0603N5800ANTR | DB0603N |
| U103 | SE5004L_QFN20-050-4X4-H2R5_SE50 | SE5004L | QFN20-050-4X4-H2R5 |
| U104 | SN74LVC1G125DCK_SC70-5_SN74LVC1 | SN74LVC1G125DCK | SC70-5 |
| U105 | DB0603N5800ANTR_DB0603N_DB0603N | DB0603N5800ANTR | DB0603N |
| U106 | DB0603N5800ANTR_DB0603N_DB0603N | DB0603N5800ANTR | DB0603N |
| U107 | SE5004L_QFN20-050-4X4-H2R5_SE50 | SE5004L | QFN20-050-4X4-H2R5 |
| U108 | SN74LVC1G125DCK_SC70-5_SN74LVC1 | SN74LVC1G125DCK | SC70-5 |
| U109 | MAX15050_BGA16-0R50-2R0X2R0_MAX | MAX15050 | BGA16-0R50-2R0X2R0 |
| U110 | MAX5974_TQFN16-050-3X3-H1R1_MAX | MAX5974 | TQFN16-050-3X3-H1R1 |
| U111 | FOD817CSD_SOIC4-100-256_FOD817C | FOD817CSD | SOIC4-100-256 |
| U112 | TLV431AIDBVR_SOT23-5_TLV431AIDB | TLV431AIDBVR | SOT23-5 |
| U113 | SKY85601-11_QFN16-050-2R5X2R5-H | SKY85601-11 | QFN16-050-2R5X2R5-H1R35 |
| U114 | SKY85601-11_QFN16-050-2R5X2R5-H | SKY85601-11 | QFN16-050-2R5X2R5-H1R35 |
| X1 | CRYSTAL-25M-0532_X4-5R0X3R2_25M | 25MHz | X4-5R0X3R2 |
| X2 | CRYSTAL-40M-3225_X4-3R2X2R5_40M | 40MHz | X4-3R2X2R5 |
| X3 | CRYSTAL-40M-3225_X4-3R2X2R5_40M | 40MHz | X4-3R2X2R5 |
