重要提示:PCB作品文件展下载说明
RTS3902 这个资料网上很少。 这个方案主要是做 IPCAM 。也有用来做行车记录仪的。
4层PCB设计。
| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | | BT1 | BAT-DV560-3_8X9_5H4_5B | BATT_con | BAT-DV560-3_8X9_5H4_5B | | CON8 | FPC6-PT05-3_8X6_4H1_55B | con | FPC6-PT05-3_8X6_4H1_55B | | CON9 | FPC22-PT0_5-5X15_1H1_5B | 2. LCD 22 | FPC22-PT0_5-5X15_1H1_5B | | CON10 | FPC26-PT0_5-3_8X16_1H1_2B | GC2023 | FPC26-PT0_5-3_8X16_1H1_2B | | CS | PAD-O1_5X2 | TEST | PAD-O1_5X2 | | D11 | LED0603 | BLUE | LED0603 | | D12 | LED0603 | RED | LED0603 | | DATA | PAD-O1_5X2 | TEST | PAD-O1_5X2 | | FB4 | L0603 | 60R/100M | L0603 | | GND1 | PAD-O1_5X2 | TEST | PAD-O1_5X2 | | HDMI1 | HDMI_MIC_HXQK-539H2_9A | HDMI TYPE D | HDMI_MIC_HXQK-539H2_9A | | J2 | CON7-PT2_1A | CN7 | CON7-PT2_1A | | L4 | L3X3H1_7A | 4.7uH-DCR<0.1R-1.1A | L3X3H1_7A | | MIC1 | MIC4-4015PT1_4H1_7A | Micphone | MIC4-4015PT1_4H1_7A | | OQ3 | SOT-23 | WPM2015 | SOT-23 | | OQ4 | SOT-23 | WPM2015 | SOT-23 | | P1 | USB-MIC-A01SB141BH2_4A | USB-MICRO-SOCKET | USB-MIC-A01SB141BH2_4A | | PIFA1 | CON2-WIFI-PT4 | ANT | CON2-WIFI-PT4 | | Q7 | SOT-23 | NC/3904 | SOT-23 | | Q10 | SOT-23 | WNM6001 | SOT-23 | | Q11 | SOT-23 | WNM6001 | SOT-23 | | Q12 | SOT-23 | 3904 | SOT-23 | | RX1 | TP30_SMD | TEST | TP30_SMD | | SPK+ | TP80_SMD | NC | TP80_SMD | | SPK- | TP80_SMD | NC | TP80_SMD | | SW3 | SW4-TS-0024_8X2_3-H1_8A | WIFI-KEY | SW4-TS-0024_8X2_3-H1_8A | | SW4 | SW4-TS-0024_8X2_3-H1_8A | CAM-KEY | SW4-TS-0024_8X2_3-H1_8A | | TF | TF_CARDH1_7A | MICROSD/TF_SLOT | TF_CARDH1_7A | | U1 | BGA234-11_1X11_1PT0_65H1A | S3 | BGA234-11_1X11_1PT0_65H1A | | U2 | QFN49_0_4H0_8A | AXP203 | QFN49_0_4H0_8A | | U3 | SOT23-5 | LP3220 | SOT23-5 | | U5 | SOT23-6 | LP3110 | SOT23-6 | | U6 | SOT-23 | LP3991TL-1.8V/WL2805N18 | SOT-23 | | U7 | SOP8-PT1_27-4_45X5H1_75A | MX25L12835F | SOP8-PT1_27-4_45X5H1_75A | | U9 | SOT-23 | NC/ WL2805N18 | SOT-23 | | U14 | MSOP-8 | LPA4990 | MSOP-8 | | U15 | SOP10-PT05-MMA7660FC-H1A | NC/DA380/MMA7660 | SOP10-PT05-MMA7660FC-H1A | | U16 | LQFP64_PT0_4-7X7H1_6A | EP952 | LQFP64_PT0_4-7X7H1_6A | | U17 | SOT23-5 | WL2805E18 | SOT23-5 | | U21 | SOT23-5 | WL2805E18 | SOT23-5 | | U25 | SOT23-6 | SC1688 | SOT23-6 | | U102 | QFN40-PT0_4-5X5H0_8A | XR819 | QFN40-PT0_4-5X5H0_8A | | VCC-3V3 | PAD-O1_5X2 | TEST | PAD-O1_5X2 | | WR/RX | PAD-O1_5X2 | TEST | PAD-O1_5X2 | | X1 | CRYSTAL-4P-3225-H1A | 24M-20pF-10PPM | CRYSTAL-4P-3225-H1A | | X2 | IN-CRYSTAL_0206H1_4A | 32768 | IN-CRYSTAL_0206H1_4A | | X3 | CRYSTAL-4P-3225-H1A | NC/24M-20pF-10PPM | CRYSTAL-4P-3225-H1A |
重要提示:PCB作品文件展下载说明
