| Part Value Device Package Description |
| C1 10uF C-0402 C0402 Ceramic Capacitors |
| C2 10uF C-0402 C0402 Ceramic Capacitors |
| C3 100nF C-0402 C0402 Ceramic Capacitors |
| C4 100nF C-0402 C0402 Ceramic Capacitors |
| C5 100nF C-0402 C0402 Ceramic Capacitors |
| C6 1uF C-0402 C0402 Ceramic Capacitors |
| C8 10uF C-0402 C0402 Ceramic Capacitors |
| C9 10pF C-0402 C0402 Ceramic Capacitors |
| C10 10pF C-0402 C0402 Ceramic Capacitors |
| C19 10uF C-0402 C0402 Ceramic Capacitors |
| C21 10uF C-0402 C0402 Ceramic Capacitors |
| C26 10uF C-0402 C0402 Ceramic Capacitors |
| C27 10uF C-0402 C0402 Ceramic Capacitors |
| D1 DF2S6.8FS D-ESD-2P'DF2S6.8FS' SOD-923 SOD-923:304060009;SOD-123:304060001 |
| D2 DF2S6.8FS D-ESD-2P'DF2S6.8FS' SOD-923 SOD-923:304060009;SOD-123:304060001 |
| D3 DF2S6.8FS D-ESD-2P'DF2S6.8FS' SOD-923 SOD-923:304060009;SOD-123:304060001 |
| D4 DF2S6.8FS D-ESD-2P'DF2S6.8FS' SOD-923 SOD-923:304060009;SOD-123:304060001 |
| F1 1A FUSE'1206' F1206 |
| FR1 SEEEDSTUDIO-OPEN-SCH-FRAME SEEEDSTUDIO-PCB-FRAME |
| FR2 SEEEDSTUDIO-OPEN-SCH-FRAME SEEEDSTUDIO-PCB-FRAME |
| J1 HEADER-14P-2.54 H14-2.54 Header 14 |
| J2 HEADER-14P-2.54 H14-2.54 Header 14 |
| J3 MICRO-USB5+4P MICRO-USB5+5P-SMD-0.65-7.2X5.06MM5+4P-SMD-0.65-B:320010000;5+2P-SMD-0.65-AB:340032001;5+5P-SMD-0.65-7.2X5.06MM:320010050; |
| J4 DNP HEADER-2P-2.0 H2-2.0-C55D32MIL |
| K3 button 311020045 BUTTON-4P-4.5X3.2 SW4P-SMD-4.5X3.2X2.5MM SW4-6.0X6.0X5.0MM:311020024;SW4-8.0X8.0X9.0MM:311020028;SW4-SMD-6.0X6.0X5.0MM:311020004;SW4-SMD-3.35X3.35X1.5MM:311020030;SW4-SMD-5.2X5.2X2.5MM:311020046 |
| L1 WLB1608-300T15 L-0603 L0603 |
| L4 0.33uH L-MPM201610SR33_T L201610 |
| ORANGE Orange LED'0603' LED-0603 |
| PWR GREEN LED'0603' LED-0603 |
| Q1 2N7002 MOSFET-N'SI1304BDL' SOT-323 |
| Q2 S9013W TRANSISTOR-NPN-SOT323 SOT-323 NPN audion |
| Q3 S9013W TRANSISTOR-NPN-SOT323 SOT-323 NPN audion |
| Q4 TRANSISTOR-PNP SOT-323 PNP audion |
| R1 1k R-0402 R0402 |
| R2 0R R-0603 R0603 |
| R3 10k R-0402 R0402 |
| R4 10k R-0402 R0402 |
| R6 4.7k R-0402 R0402 |
| R7 1k R-0402 R0402 |
| R8 100k R-0402 R0402 |
| R9 10k R-0402 R0402 |
| R10 0R R-0402 R0402 |
| R12 1k R-0402 R0402 |
| R13 1k R-0402 R0402 |
| R14 22R R-0402 R0402 |
| R15 22R R-0402 R0402 |
| R17 100R R-0402 R0402 |
| R18 100R R-0402 R0402 |
| R23 47k R-0402 R0402 |
| R24 4.7k R-0402 R0402 |
| R25 4.7k R-0402 R0402 |
| R26 10k R-0402 R0402 |
| R28 100K_1% R-0402 R0402 |
| R29 22K_1% R-0402 R0402 |
| RX RED LED'0603' LED-0603 |
| SYS_RSTbutton 311020045 BUTTON-4P-4.5X3.2 SW4P-SMD-4.5X3.2X2.5MM SW4-6.0X6.0X5.0MM:311020024;SW4-8.0X8.0X9.0MM:311020028;SW4-SMD-6.0X6.0X5.0MM:311020004;SW4-SMD-3.35X3.35X1.5MM:311020030;SW4-SMD-5.2X5.2X2.5MM:311020046 |
| TX GREEN LED'0603' LED-0603 |
| U1 CP2102N CONVERTER-CP2102N(QFN24) QFN24G-0.5-4X4MM |
| U2 MOUDLE-MT7697F MOUDLE40P-1.27-22X18MM |
| U6 ETA3410 CONVERTER-ETA3410 DFN8G-0.5-2X2MM 3MHZ 2A High Step-DownConverter in DFN2x2-8L Package |
