重要提示:PCB作品文件展下载说明
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESC060311_C_0_C0603__33PF33pF ICC3C060311_C_0_C0603__100NF100nF ICC8C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC9C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC10C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC11C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC12C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC13C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC14C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC15C060311_C_0_C0603__100NF100nF ICC16C060311_C_0_C0603__100NF100nF ICC17C060311_C_0_C0603__100NF100nF ICC18C060311_C_0_C0603__100NF100nF ICC19C060311_C_0_C0603__100NF100nF ICC20C060311_C_0_C0603__10NF10nF ICC21C060311_C_0_C0603__100NF100nF ICC22C060311_C_0_C0603__4.7UF4.7uF ICC23C060311_C_0_C0603__10NF10nF ICC24C060311_C_0_C0603__100NF100nF ICC25C060311_C_0_C0603__4.7UF4.7uF ICC26C060311_C_0_C0603__10NF10nF ICC27C060311_C_0_C0603__100NF100nF ICC28C060311_C_0_C0603__4.7UF4.7uF ICC29C060311_C_0_C0603__10NF10nF ICC30C060311_C_0_C0603__100NF100nF ICC31C060311_C_0_C0603__10NF10nF ICC32C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC33C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC34C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC35C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC36C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC37C060311_C_0_C0603__100NF100nF ICC38C060311_C_0_C0603__100NF100nF ICC39C060311_C_0_C0603__10NF10nF ICC40C060311_C_0_C0603__10NF10nF ICC41C060311_C_0_C0603__100NF100nF ICC45C060311_C_0_C0603__33PF33pF ICC46C060311_C_0_C0603__100NF100nF ICC47C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC53C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC54C0603CAP NP_C0603_100NF100nF ICC55C1210CAP POL_C1210_22UF_25V22uF_25V ICC56C1210CAP POL_C1210_22UF_25V22uF_25V ICC57C0805CAP NP_C0805_10UF/16V10uF/16V ICC58C0805CAP NP_C0805_10UF/16V10uF/16V ICC59C0603CAP NP_C0603_47NF47nF ICC60C0603CAP NP_C0603_47NF47nF ICC61C0805CAP NP_C0805_10UF/16V10uF/16V ICC62CAP_CASE_CCAP POL_CAP_CASE_C_47UF_16V_TAN47uF_16V_TAN ICC63C0603CAP NP_C0603_470PF470pF ICC64C0603CAP NP_C0603_470PF470pF ICC65CAP_CASE_CCAP POL_CAP_CASE_C_47UF_16V_TAN47uF_16V_TAN ICC66C0805CAP NP_C0805_10UF/16V10uF/16V ICC67C0805CAP NP_C0805_10UF/16V10uF/16V ICC68C0603CAPACITOR NON-POL_C0603_100NF100nF ICC69C0603CAPACITOR NON-POL_C0603_100NF100nF ICC70C0603CAPACITOR NON-POL_C0603_100NF100nF ICC71C0603CAPACITOR NON-POL_C0603_100NF100nF ICC72C0603CAPACITOR NON-POL_C0603_100NF100nF ICC73C0603CAP NP_C0603_100NF100nF ICC74C0805CAP POL_C0805_10UF/16V10uF/16V ICC75C0603CAP NP_C0603_100NF100nF ICC76C0603CAP NP_C0603_10NF10nF ICC77C0603CAP NP_C0603_100NF100nF ICC78C0603CAP NP_C0603_22PF22pF ICC79C0603CAP NP_C0603_22PF22pF ICC80C0805CAPACITOR NON-POL_C0805_10UF/1610uF/16V ICC81C0603CAP NP_C0603_100NF100nF ICC82C0603CAP NP_C0603_100NF100nF ICC83C0603CAP NP_C0603_100NF100nF ICC84C0603CAP NP_C0603_100NF100nF ICC85C0603CAP NP_C0603_10NF10nF ICC86C0603CAP NP_C0603_10NF10nF ICC87C0603CAP NP_C0603_DNP_1UFDNP_1uF ICC89C060311_C_0_C0603__100PF100pF ICC94C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC95C0603CAP 0.1UF 25VDC 0402_C0603_100N100nF ICC96C0603CAP NP_C0603_100NF100nF ICC97C0603CAP NP_C0603_100NF100nF ICC98C0603CAPACITOR NON-POL_C0603_100NF100nF ICC99C0603CAPACITOR NON-POL_C0603_1UF1uF ICC100C0603CAP NP_C0603_1UF1uF ICC103C0603CAPACITOR NON-POL_C0603_100NF100nF ICC104C0805CAPACITOR NON-POL_C0805_10UF/1610uF/16V ICC105C0603CAPACITOR NON-POL_C0603_100NF100nF ICC106C0805CAPACITOR NON-POL_C0805_10UF/1610uF/16V ICC107C0603CAPACITOR NON-POL_C0603_100NF100nF ICC108C0805CAPACITOR NON-POL_C0805_10UF/1610uF/16V ICC109C0603CAPACITOR NON-POL_C0603_100NF100nF ICC110C0805CAPACITOR NON-POL_C0805_10UF/1610uF/16V ICC111CON_2D00_2X7_TH_BOXHEADER 2X7 2.0MM_CON_2D00_2X7_TDNP_IDC3 2x7PIN 2.00mm ICCCON2CON_DB9DB9_CON_DB9_DB9DB9 ICCON1DC_417DC-005_0_DC_417_DC417DC417 ICCON2USB-MC-03AMINI USB-AB SMD5_1_USB-MC-03A_MMICRO_USB_AB_SMD ICCON3CON_2D54_2X7_TH_BOXJTAG_CON_2D54_2X7_TH_BOX_IDC3 2IDC3 2x7PIN 2.54mm ICCON4KRJ-320DNL_14PKRJ-320DNL_KRJ-320DNL_14P_KRJ-3KRJ-320DNL ICCON5SMADIODE SCHOTTKY_SMA_MBRA340T3GMBRA340T3G ICD1SMADIODE SCHOTTKY_SMA_MBRA340T3GMBRA340T3G ICD2LED_0603LED_0_LED_0603_GREEN 0603GREEN 0603 ICD3LED_0603LED_0_LED_0603_RED 0603RED 0603 ICD4LED_0603LED_0_LED_0603_GREEN 0603GREEN 0603 ICD5SOD882DIODE BREAKDOWN_SOD882_PESD3V3SPESD3V3S1UL ICD6LED_0603LED_0_LED_0603_GREEN 0603GREEN 0603 ICD7B340ADIODE BREAKDOWN_0_B340A_B340AB340A ICD8B340ADIODE BREAKDOWN_0_B340A_B340AB340A ICD9SOD882DIODE BREAKDOWN_SOD882_PESD3V3SPESD3V3S1UL ICD10ACH32CNFM18CC222R1C3_ACH32C_ACH32C-10ACH32C-104-T ICF1F1808FUSE_F1808_FUSE 3.5AFUSE 3.5A ICF2L0603FERRITE BEAD_L0603_220R/100MHZ220R/100MHz 2A ICFB1L0603FB_0_L0603_220R/100MHZ 2A220R/100MHz 2A ICFB4L0603FB_0_L0603_DNP_220R/100MHZ 2ADNP_220R/100MHz 2A ICFB5L0603FB_0_L0603_DNP_220R/100MHZ 2ADNP_220R/100MHz 2A ICFB6L0603FB_0_L0603_220R/100MHZ 2A220R/100MHz 2A ICFB9CON_2MM_2X15PCONN RCPT 15X2_CON_2MM_2X15P_2.2.0mm_2X15P_TH ICJ1CON_2D54_2X25_TH_BOXCONN PCB 25X2-P_CON_2D54_2X25_TIDC3 2x25PIN 2.54mm ICJ3CON_2D54_2X25_TH_BOXCONN PCB 25X2-P_CON_2D54_2X25_TIDC3 2x25PIN 2.54mm ICJ4PCIX-4PORTPCIE_BRACKET_X4_0_PCIX-4PORT_PCPCIE_Slot ICJ5SMD_HDMIA_RA2C_CONN_HDMI_TYPEA_SMD_HDMIA_RAHDMIConnA ICJ7SMD_HDMIA_RA2C_CONN_HDMI_TYPEA_SMD_HDMIA_RAHDMIConnA ICJ82D54MM_2X5P_THCON10A_2D54MM_2X5P_TH_2.54MM_2X2.54mm_2X5P_TH ICJ9MOL22-23-2031CON3_MOL22-23-2031_MOL22-23-203mol22-23-2031 ICJ10CON_1X6_2D54_TJC3CON6_CON_1X6_2D54_TJC3_CON_2.54CON_2.54mm_6P_BOX ICJ11CON_1X4_2D54_TJC3CON4_CON_1X4_2D54_TJC3_CON_2.54CON_2.54mm_4P_BOX ICJ12L1260-183MLDINDUCTOR IRON_L1260-183MLD_MSS1MSS1260-183MLD ICL1L1260-183MLDINDUCTOR IRON_L1260-183MLD_MSS1MSS1260-183MLD ICL2L06031212_BEAD_0_L0603__220R/100MHZ220R/100MHz 2A ICL4L06031212_BEAD_0_L0603__220R/100MHZ220R/100MHz 2A ICL5L06031212_BEAD_0_L0603__220R/100MHZ220R/100MHz 2A ICL6LPS3010-H30D30INDUCTOR_LPS3010-H30D30_LPS3015LPS3015-222MLB ICL7LPS3010-H30D30INDUCTOR_LPS3010-H30D30_LPS3015LPS3015-222MLB ICL8TO252AA_094SUD45P03-15_TO252AA_094_SUD45P0SUD45P03-15 ICQ1SOT23-3_DBZ3MMBT3904/SOT_SOT23-3_DBZ3_MMBT3MMBT3904 ICQ2SOT23-3_DBZ3MMBT3904/SOT_SOT23-3_DBZ3_MMBT3MMBT3904 ICQ3SOT23-3_DBZ3MMBT3904/SOT_SOT23-3_DBZ3_MMBT3MMBT3904 ICQ4SOT23-3_DBZ3MMBT3904/SOT_SOT23-3_DBZ3_MMBT3MMBT3904 ICQ5R060310_R_0_R0603__49R949R9 ICR1R060310_R_0_R0603__49R949R9 ICR2R060310_R_0_R0603__49R949R9 ICR3R060310_R_0_R0603__49R949R9 ICR4R060310_R_0_R0603__49R949R9 ICR5R060310_R_0_R0603__DNP_330RDNP_330R ICR7R060310_R_0_R0603__10K10K ICR8R060310_R_0_R0603__4K994K99 ICR9R060310_R_0_R0603__4K74K7 ICR10R060310_R_0_R0603__DNP_4K7DNP_4K7 ICR11R060310_R_0_R0603__4K74K7 ICR12R060310_R_0_R0603__4K994K99 ICR14R060310_R_0_R0603__4K994K99 ICR15R060310_R_0_R0603__10R_1%10R_1% ICR16R060310_R_0_R0603__DNP_1MDNP_1M ICR17R060310_R_0_R0603__10K10K ICR18R060310_R_0_R0603__10K10K ICR19R060310_R_0_R0603__0R_1%0R_1% ICR20R060310_R_0_R0603__0R_1%0R_1% ICR21R060310_R_0_R0603__0R_1%0R_1% ICR22R060310_R_0_R0603__0R_1%0R_1% ICR23R060310_R_0_R0603__0R_1%0R_1% ICR24R060310_R_0_R0603__0R_1%0R_1% ICR25R060310_R_0_R0603__4K74K7 ICR26R060310_R_0_R0603__4K74K7 ICR27R060310_R_0_R0603__330R330R ICR28R060310_R_0_R0603__4K74K7 ICR29R060310_R_0_R0603__4K74K7 ICR30R060310_R_0_R0603__49R949R9 ICR31R060310_R_0_R0603__49R949R9 ICR32R060310_R_0_R0603__10K10K ICR33R060310_R_0_R0603__4K74K7 ICR34R060310_R_0_R0603__4K74K7 ICR35R060310_R_0_R0603__DNP_10KDNP_10K ICR36R060310_R_0_R0603__10K10K ICR37R060310_R_0_R0603__49R949R9 ICR38R060310_R_0_R0603__DNP_4K7DNP_4K7 ICR39R060310_R_0_R0603__2K2K ICR40R060310_R_0_R0603__1K_1%1K_1% ICR41R060310_R_0_R0603__1K_1%1K_1% ICR42R060310_R_0_R0603__1K_1%1K_1% ICR43R060310_R_0_R0603__1K_1%1K_1% ICR44R060310_R_0_R0603__1K_1%1K_1% ICR45R060310_R_0_R0603__1K_1%1K_1% ICR46R060310_R_0_R0603__1K_1%1K_1% ICR47R060310_R_0_R0603__1K_1%1K_1% ICR48R060310_R_0_R0603__1K_1%1K_1% ICR49R060310_R_0_R0603__1K_1%1K_1% ICR50R060310_R_0_R0603__1K_1%1K_1% ICR51R060310_R_0_R0603__1K_1%1K_1% ICR52R060310_R_0_R0603__1K_1%1K_1% ICR53R060310_R_0_R0603__1K_1%1K_1% ICR54R060310_R_0_R0603__1K_1%1K_1% ICR55R060310_R_0_R0603__22R_1%22R_1% ICR75R060310_R_0_R0603__DNP_22R_1%DNP_22R_1% ICR77R060310_R_0_R0603__DNP_22R_1%DNP_22R_1% ICR78R060310_R_0_R0603__DNP_0RDNP_0R ICR79R060310_R_0_R0603__4K74K7 ICR85R060310_R_0_R0603__1K_1%1K_1% ICR86R060310_R_0_R0603__1K_1%1K_1% ICR87R060310_R_0_R0603__1K_1%1K_1% ICR88R060310_R_0_R0603__2K2_1%2K2_1% ICR89R060310_R_0_R0603__2K2_1%2K2_1% ICR90R060310_R_0_R0603__2K2_1%2K2_1% ICR91R060310_R_0_R0603__2K2_1%2K2_1% ICR92R060310_R_0_R0603__2K2_1%2K2_1% ICR93R060310_R_0_R0603__4K74K7 ICR94R060310_R_0_R0603__4K74K7 ICR95R060310_R_0_R0603__0R_1%0R_1% ICR96R060310_R_0_R0603__0R_1%0R_1% ICR97R060310_R_0_R0603__0R_1%0R_1% ICR98R060310_R_0_R0603__0R_1%0R_1% ICR99R060310_R_0_R0603__DNP_10KDNP_10K ICR100R060310_R_0_R0603__22R_1%22R_1% ICR101R060310_R_0_R0603__22R_1%22R_1% ICR102R060310_R_0_R0603__DNP_10KDNP_10K ICR103R060310_R_0_R0603__DNP_10KDNP_10K ICR104R060310_R_0_R0603__22R_1%22R_1% ICR105R060310_R_0_R0603__22R_1%22R_1% ICR106R060310_R_0_R0603__10K10K ICR107R060310_R_0_R0603__10K10K ICR108R060310_R_0_R0603__22R_1%22R_1% ICR109R060310_R_0_R0603__22R_1%22R_1% ICR110R060310_R_0_R0603__1K_1%1K_1% ICR111R060310_R_0_R0603__1K_1%1K_1% ICR112R060310_R_0_R0603__1K_1%1K_1% ICR113R060310_R_0_R0603__4K74K7 ICR114R060310_R_0_R0603__4K74K7 ICR115R060310_R_0_R0603__4K74K7 ICR117R060310_R_0_R0603__10R_1%10R_1% ICR118R060310_R_0_R0603__8K06_1%8K06_1% ICR119R060310_R_0_R0603__24K9_1%24K9_1% ICR120R060310_R_0_R0603__8K06_1%8K06_1% ICR121R060310_R_0_R0603__10R_1%10R_1% ICR122R060310_R_0_R0603__82K5_1%82K5_1% ICR123R060310_R_0_R0603__DNP_10KDNP_10K ICR124R060310_R_0_R0603__0R_1%0R_1% ICR126R060310_R_0_R0603__0R_1%0R_1% ICR127R060310_R_0_R0603__0R_1%0R_1% ICR128R060310_R_0_R0603__0R_1%0R_1% ICR129R060310_R_0_R0603__0R_1%0R_1% ICR130R060310_R_0_R0603__0R_1%0R_1% ICR131R060310_R_0_R0603__0R_1%0R_1% ICR132R060310_R_0_R0603__22R_1%22R_1% ICR133R060310_R_0_R0603__22R_1%22R_1% ICR134R060310_R_0_R0603__22R_1%22R_1% ICR135R060310_R_0_R0603__22R_1%22R_1% ICR136R060310_R_0_R0603__22R_1%22R_1% ICR137R060310_R_0_R0603__22R_1%22R_1% ICR138R060310_R_0_R0603__22R_1%22R_1% ICR139R060310_R_0_R0603__22R_1%22R_1% ICR140R060310_R_0_R0603__22R_1%22R_1% ICR141R060310_R_0_R0603__22R_1%22R_1% ICR142R060310_R_0_R0603__22R_1%22R_1% ICR143R060310_R_0_R0603__22R_1%22R_1% ICR144R060310_R_0_R0603__4K74K7 ICR145R060310_R_0_R0603__4K74K7 ICR146R060310_R_0_R0603__10R_1%10R_1% ICR147R060310_R_0_R0603__10K10K ICR151R060310_R_0_R0603__10K10K ICR152R060310_R_0_R0603__1K_1%1K_1% ICR153R060310_R_0_R0603__1K_1%1K_1% ICR155R060310_R_0_R0603__1K_1%1K_1% ICR157R060310_R_0_R0603__1K_1%1K_1% ICR158R060310_R_0_R0603__1K_1%1K_1% ICR159R060310_R_0_R0603__1K_1%1K_1% ICR160R060310_R_0_R0603__4K74K7 ICR161R060310_R_0_R0603__330R330R ICR162R060310_R_0_R0603__22R_1%22R_1% ICR163R060310_R_0_R0603__10K10K ICR165R060310_R_0_R0603__10K10K ICR166R060310_R_0_R0603__22R_1%22R_1% ICR167R060310_R_0_R0603__DNP_22R_1%DNP_22R_1% ICR168R060310_R_0_R0603__0R_1%0R_1% ICR169R060310_R_0_R0603__DNP_0R_1%DNP_0R_1% ICR170R060310_R_0_R0603__120K_1%120K_1% ICR171R060310_R_0_R0603__120K_1%120K_1% ICR172R060310_R_0_R0603__49K9_1%49K9_1% ICR173R060310_R_0_R0603__158K_1%158K_1% ICR174R060310_R_0_R0603__10R10R ICR175R060310_R_0_R0603__10R10R ICR176R060310_R_0_R0603__10R10R ICR177R060310_R_0_R0603__10R10R ICR178BUTTON_SW_5PSW TACK SPDT_0_BUTTON_SW_5P_SWSW TACK SPDT ICSW1CON_5PIN_DIP_2D545BIT DIP SOP SWITCH_CON_5PIN_DI5BIT 2.54MM DIP Switch ICSW2BUTTON_SW_SMD_4P_BIGSW PUSHBUTTON-SPST SHIELD_0_BUTSW_PUSHBUTTON_GREEN_SMD ICSW3BUTTON_SW_SMD_4P_BIGSW PUSHBUTTON-SPST SHIELD_0_B_1SW_PUSHBUTTON_BLACK_SMD ICSW4BUTTON_SW_SMD_4P_BIGSW PUSHBUTTON-SPST SHIELD_0_B_2SW_PUSHBUTTON_RED_SMD ICSW5SW_EVQ-PF003M160_SW-HDK632_SW_EVQ-PF003M_EVQEVQ-PF003M ICSW7TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP1TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP2TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP3TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP4TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP5TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP6TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP7TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP8TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP9TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP10TP-S4000_TP-S40_0_TP-S40_TEST POINTTest Point ICTP11HTSSOP14TPS54286PWP_HTSSOP14_TPS54286PWTPS54286PWP ICU2TSSOP16_PW16MAX232A_0_TSSOP16_PW16_MAX3232EMAX3232EUE ICU3SSOP20CH340T_SSOP20_CH340TCH340T ICU5SOT143BPRTR5V0U2X_SOT143B_PRTR5V0U2XPRTR5V0U2X ICU6SSOP8_DCTTXS0102DCUR_SSOP8_DCT_TXS0102DCTXS0102DCTTG4 ICU7SSOP8_DCTTXS0102DCUR_SSOP8_DCT_TXS0102DCTXS0102DCTTG4 ICU8SSOP8_DCTTXS0102DCUR_SSOP8_DCT_TXS0102DCTXS0102DCTTG4 ICU9SOIC_20P_26_256X252TXS0108EPWR_SOIC_20P_26_256X252TXS0108EPWR ICU10SOT-23_5P14S_TI_SN74LVC1G07_SOT-23-5_SOTSN74LVC1G00DBVT ICU11SOP127P790_8141_NUMONYX_N25Q128A21BSF40F_SON25Q032A11ESE40F ICU12TSSOP65P640_8AT24C02A_TSSOP65P640_8_24LC02B-24LC02B-I/ST ICU13SSOP8_DCTTXS0102DCUR_SSOP8_DCT_TXS0102DCTXS0102DCTTG4 ICU15SOM_TL665X_B1SOM-TL665X_B1_0_SOM_TL665X_B1_SSOM-TL665x ICU16LM1117AMS1117_1_LM1117_NX1117-1.8VNX1117-1.8V ICU17QFN50P900X900_64_PWP_A_EINF88E1112_QFN50P900X900_64_PWP_A_88E1112-C2-NNC1I000 ICU18SOT23-5TLV62565DBVT_SOT23-5_TLV62565DBTLV62565DBVT ICU19SOT23-5TLV62565DBVT_SOT23-5_TLV62565DBTLV62565DBVT ICU20SMD_3225CRYSTAL_SMD_3225_ 7V-12.000MAHE7V-12.000MAHE-T ICY1SMD_3225CRYSTAL-4 PIN_SMD_3225_7V-25.007V-25.000MAHE-T ICY2 |
重要提示:PCB作品文件展下载说明
