查看: 14253|回复: 67
[Allegro16.6以下] 采用MC9S12HY设计的带LCD接口的S12HY汽车HVAC控制板原理图与PCB
  • 打卡总天数:5
  • 打卡总奖励:15
  • 最近打卡:2025-11-17 11:54:25
541
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-12-17 21:46 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
游客,如果您要查看本帖隐藏内容请回复
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESMH140P108MOUNT_HOLE_MH140P108_0.1MM_280-MOUNTING HOLE ICBH1MH140P108MOUNT_HOLE_MH140P108_0.1MM_280-MOUNTING HOLE ICBH2MH140P108MOUNT_HOLE_MH140P108_0.1MM_280-MOUNTING HOLE ICBH3MH140P108MOUNT_HOLE_MH140P108_0.1MM_280-MOUNTING HOLE ICBH4MH180-135PMOUNT_HOLE_MH180-135P_0.1 MM_28MH_180 ICBH5MH180-135PMOUNT_HOLE_MH180-135P_0.1 MM_28MH_180 ICBH6MH180-135PMOUNT_HOLE_MH180-135P_0.1 MM_28MH_180 ICBH7MH180-135PMOUNT_HOLE_MH180-135P_0.1 MM_28MH_180 ICBH8CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC1CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC2CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_21000PF5%DISCRETEC3CC7343-43CAP_POL_CC7343-43_DISCRETE_4.3M68UF10%DISCRETEC4C200_RAD_POLCAP_POL_C200_RAD_POL_DISCRETE_21000UF20%DISCRETEC5CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC6CC7343-31CAP_POL_CC7343-31_DISCRETE_3.1M10UF10%DISCRETEC7CC7343-43CAP_POL_CC7343-43_DISCRETE_4._168UF10%DISCRETEC8CC7343ACAP_POL_CC7343A_DISCRETE_3.1MM_47UF10%DISCRETEC9CC7343ACAP_POL_CC7343A_DISCRETE_3.1MM_47UF10%DISCRETEC10CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC11CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC12CC2012-12CAP_POL_CC2012-12_DISCRETE_1.2M10uF10%DISCRETEC13CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC14CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC15CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC16CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC17CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC18CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM18PF5%DISCRETEC19CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM18PF5%DISCRETEC20CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC27CC1210CAP_NP_CC1210_DISCRETE_2.79MM_110UF10%DISCRETEC28CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.1 M3.3 UF DISCRETEC29CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC30CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.7 M0.1uF DISCRETEC31CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_10.047UF DISCRETEC32CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC34CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC35CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC36CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC37CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_31UF10%DISCRETEC41CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.35M1uF10%DISCRETEC42CCE63X55CAP_POL_CCE63X55_DISCRETE_5.5MM47UF20%DISCRETEC43CCE63X55CAP_POL_CCE63X55_DISCRETE_5.5MM47UF20%DISCRETEC44CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_40.033UF10%DISCRETEC45CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_40.033UF10%DISCRETEC46CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC47CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC48CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC49CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC50CCE63X55CAP_POL_CCE63X55_DISCRETE_5.5MM47UF20%DISCRETEC51CCE63X55CAP_POL_CCE63X55_DISCRETE_5.5MM47UF20%DISCRETEC52CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_40.033UF10%DISCRETEC53CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_40.033UF10%DISCRETEC54CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC55CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC56CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC57CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC58SMB_4P57X3P94MMDIODE_SCHTKY_SMB_4P57X3P94MM_ICB130LB-13 ICD2SMB_4P57X3P94MMDIODE_SCHTKY_SMB_4P57X3P94MM_ICB130LB-13 ICD31206LDLED_1206LD_IC_0.75MM_370-75142_LED GREEN ICD4SMB_4P57X3P94MMDIODE_SMB_4P57X3P94MM_IC_2.40 MS1MB-13-F ICD5SMB_4P57X3P94MMDIODE_SCHTKY_SMB_4P57X3P94MM_ICB130LB-13 ICD17DIOMELF_5025ZDIODE_DIOMELF_5025_IC_2.6MM_48ZM4728A ICD18D_SMCZDIODE_D_SMC_IC_2.56 MM_480-3001SMC12AT3 ICD19LCD41_2P54_70X51MMLCD_41P_LCD41_2P54_70X51MM_IC_3GDC8799 ICDS1LCD4_5P02_79X45MMLCD_LX88461594WS6_LCD4_5P02_79XLX88461594WS6 ICDS2FUSE_26X9FUSE_FUSE_26X9_IC_13.5MM_510-00Fuse Holder ICF1CON_2X1_5P08CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2 IOJ1HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ2HDR203_M20CONN_HDR_3X2_HDR203_M20_IO_8.64HDR 2X3 IOJ3JUMP1X4-6040HDR-1X4_JUMP1X4-6040_IO_8.4MM_2HDR_1X4 IOJ4HDR2X8_4P2_SHRD_THPLUG_8X2_HDR2X8_4P2_SHRD_TH_IO_CON_2X8 IOJ7HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 TH IOJ8HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ9JUMP2X2-6040HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR 2X2 IOJ10JUMP1X4-6040HDR-1X4_JUMP1X4-6040_IO_8.4MM_2HDR_1X4 IOJ11HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ12HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 TH IOJ13HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ17HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ18HDR205CONN_HDR_5X2_HDR205_IO_330MIL_2HDR_2X5 IOJ20HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP1HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP2HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP3HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP4HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP5HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP6HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP7IND_SRU1038_SMINDUCTOR_FERRITE_A_IND_SRU1038_47UH DISCRETEL1DR127INDUCTOR_FERRITE_DR127_DISCRETE68UH20%DISCRETEL2IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL3IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL4IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL5IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL10IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL11SOT23NPN_SOT23_IC_1.26 MM_480-75156_BC847AL ICQ1SOT23MOSFET_N_SOT23_IC_1.11MM_480-75MGSF1N02LT1G ICQ2SOT23NPN_SOT23_IC_1.26 MM_480-75156_BC847AL ICQ3RC0805_OVRES_RC0805_OV_DISCRETE_0.6MM_475601%DISCRETER1RC2010RES_RC2010_DISCRETE_0.889MM_4700.01 OHM1%DISCRETER2RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER3RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER4RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER5RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER6RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER7RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_13.9K5%DISCRETER8RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER9RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER10RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER11RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER12RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_11005%DISCRETER13RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER14RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER15RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER16RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER17RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER18RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER19RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER20RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER24RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_32.2K5%DISCRETER25RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER26RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_41.0K5%DISCRETER27RC1206_OVRES_RC1206_OV_DISCRETE_470-782460.4 DISCRETER29RC0805_OVRES_RC0805_OV_DISCRETE_470-759010K DISCRETER30RC1206_OVRES_RC1206_OV_DISCRETE_470-782460.4 DISCRETER31RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER32RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_52205%DISCRETER34RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER36RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER37RC0805_OVRES_RC0805_OV_DISCRETE_0.55MM_41M5%DISCRETER38RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER39RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER40RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER42RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER43RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER44RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER45POT3_3310YPOT_POT3_3310Y_DISCRETE_18.9MM_10k20%DISCRETER46RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER47RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER48RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER49RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER50RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER51RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER52RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER53RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER54RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER55RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER56RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER57RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER58RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER59RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER60RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER61RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER62RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER63RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER64RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER65RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER66RC0805_OVRES_RC0805_OV_DISCRETE_0.70 MM_1.5K1%DISCRETER67TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP1TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP2TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP3TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP4TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP5TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP6TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP7TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP8TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOP IOTP9TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOP IOTP10TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOP IOTP11TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOP IOTP12TO263_8LM2676_8P_TO263_8_IC_4.64MM_312LM2676S-5.0 ICU1LQFP100_0P5_14X14P9S12HY64J0MLL_LQFP100_0P5_14X1MC9S12HY/HA ICU2TSOP3_2P54_6X5P6TSOP34838_3P_TSOP3_2P54_6X5P6_ITSOP34838 ICU3SC70-5_ACI_LM94022_SC70-5_A_IC_1.1 MM_3LM94022 ICU4PQFN_16_12X12_AMC33988_16P_PQFN_16_12X12_A_IC_MC33984CPNA ICU7SO8_1P27_4X5TJA1040T_SO_8P_SO8_1P27_4X5_IC_TJA1040T ICU8TSSOP16MPR083EJR2_TSSOP16_IC_1.2MM_312MPR084EJ ICU9HSOP44_11X16MMMC33932_HSOP44_11X16MM_IC_3.4 MMC33932 ICU10HSOP44_11X16MMMC33932_HSOP44_11X16MM_IC_3.4 MMC33932 ICU11XTAL-XT49MXTAL_XTAL-XT49M_IC_5.8MM_230-778MHz ICY1
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
  • 打卡总天数:691
  • 打卡月天数:11
  • 打卡总奖励:2860
  • 最近打卡:2026-11-13 12:03:10
81
发表于 2018-12-18 20:18 | 显示全部楼层
  • 打卡总天数:590
  • 打卡总奖励:2313
  • 最近打卡:2026-09-17 09:05:11
228
5万
终身成就奖特殊贡献奖社区居民忠实会员社区劳模最爱沙发社区明星优秀斑竹奖宣传大使奖
发表于 2018-12-19 08:18 | 显示全部楼层
  • 打卡总天数:540
  • 打卡月天数:10
  • 打卡总奖励:2556
  • 最近打卡:2026-11-13 09:00:04
49
1元学习Allegro(1期)
发表于 2018-12-19 08:21 | 显示全部楼层
发表于 2018-12-19 08:47 | 显示全部楼层
  • 打卡总天数:2
  • 打卡月天数:1
  • 打卡总奖励:3
  • 最近打卡:2026-11-07 12:12:56
发表于 2018-12-19 08:49 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:70
  • 打卡总奖励:221
  • 最近打卡:2026-10-20 10:03:40
发表于 2018-12-19 08:59 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:88
  • 打卡总奖励:324
  • 最近打卡:2025-10-09 09:09:44
18
1元学习Allegro(1期)
发表于 2018-12-19 09:01 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:22
  • 打卡总奖励:89
  • 最近打卡:2025-11-02 19:30:44
84
PADS高级班留级2期
发表于 2018-12-19 09:11 | 显示全部楼层
发表于 2018-12-21 09:23 | 显示全部楼层
