● 兼容紫外光阻挡及光学自动检查功能,可提高 PCB 生产效率与准确性
UVB and AOI (automatic optical inspection) compatible, so as to increase productivity and accuracy.
● 优良的耐热性能和机械性能
Excellent heat resistance and mechanical properties
● 符合 IPC-4101B/21 的规范要求
IPC-4101B/21 specification is applicable.
Test Item
测试项目
Unit
单位
Test Method
(IPC-TM-650)
测试方法
Test Condition
处理条件
Specification
(IPC-4101B)
规格值
Typical
Value
典型值
Peel Strength (1 oz.)
铜箔剥离强度 N/mm 2.4.8
125℃ ≥0.70 1.70
Float 288℃ / 10 Sec ≥1.05 1.75
Thermal Stress
热应力 Sec 2.4.13.1 Float288℃/unetched ≥10 180
Bow / Twist
弯弓度/翘曲度 % 2.4.22.1 A ≤ 1.0 0.17 / 0.35
Flexural Strength
抗弯强度 N/mm2
2.4.4
Warp ≥415 565
Fill ≥345 416
Flammability
燃烧性 Rating UL94 UL94 UL94 V-0 V-0
Glass Transition (Tg)
玻璃化转变温度 ℃ 2.4.25 E-2/105 DSC ≥130 135
Surface Resistivity
表面电阻 MΩ 2.5.17.1 C-96/35/90 ≥1.0×104
1.0×106
Volume Resistivity
体积电阻 MΩ-cm 2.5.17.1 C-96/35/90 ≥1.0×106
1.0×108
Dielectric Constant
介电常数 — 2.5.5.2 Etched/@1 MHZ ≤5.4 4.58
Loss Tangent
介质损耗 — 2.5.5.2 Etched/@1 MHZ ≤0.035 0.022
Arc Resistance
耐电弧性 Sec 2.5.1 D-48/50+D-0.5/23 ≥60 125
Moisture Absorption
吸水率 % 2.6.2.1 D-24/23
≤0.35(min0.51mm) 0.21
≤0.80(max0.51mm) 0.19
Z-Axis Expansion
Z-轴热膨胀系数 ppm/℃ 2.4.24 E-2/105 TMA — 58/286
TD ℃ 2.4.24.6 TGA —— 305
T-260 min 2.4.24.1 TMA —— 20
T-288 min 2.4.24.1 TMA —— 3
Remarks: Specimen Thickness: 1.6 mm 1/1 样品厚度:1.6 mm 1/1
A = Keep the specimen originally without any process 保持原样,不作处理
C = Temperature and humidity conditioning 在恒温恒湿的空气中处理;
D = Temperature conditioning immersion in distilled water. 浸在恒温的水中处理
E = Immersing in distilled water with temperature control 在恒温的空气中处理;
KB 产 品 技 术 资 料
TECHNICAL INFORMATION
KB-6160/6160A/6160C(ANSI:FR-4)
覆铜箔环氧玻纤布层压板
Features 特 点
KINGBOARD LAMINATES HOLDINGS LIMITED Website : http://www.kblaminates.com
建建建 建 滔滔滔滔 积积积积 层层层层 板板板板 控控控控 股股股股 有有有有 限限限限 公公公公 司司司司 Version: 1.0
General Properties 一般特性
45
UV blocking (thickness) UV 阻挡 UV blocking (wave / UV-3100)
Thermal expansion of Z-direction (test by TMA) Dielectric constant 介电常数
Applications 应用领域
● Computer, communication equipment, instrument, OA equipment, etc.
计算机及外围设备、通讯设备、仪器仪表、办公自动设备等
Base Color
基板颜色
Thickness
厚度
Copper Cladding
铜箔厚度
Regular Size(mm)
常规尺寸
CTI Value
CTI 值
黄色
(yellow)
0.05mm ~
3.5mm
12µm , 18µm
35µm, 70µm
105µm
940*1245mm (37" * 49")
1042*1245mm (41" * 49")
1093*1245mm (43" * 49")
KB-6160:150V
KB-6160A:175V
KB-6160C: 300V/600V
Note: Other sheet size and thickness could be available upon request.
可根据客户要求提供其它尺寸和厚度.
Speciality Chart 板材特性图
Purchasing Information 采购信息
KB 产 品 技 术 资 料
覆铜箔环氧玻纤布层压板
建建建 建 滔滔滔滔 积积积积 层层层层 板板板板 控控控控 股股股股 有有有有 限限限限 公公公公 司司司司 Version: 1.0 |
