| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CE0604 | CAP_NB_C7343D_H79_DISCRETE_330U | 330UF/2V | NB_C7343D_H79 |
| CE2703 | CAP_C7343D_H75_DISCRETE_220UF/4 | 220UF/4V | C7343D_H75 |
| CE2704 | CAP_C7343D_H75_DISCRETE_220UF/4 | 220UF/4V | C7343D_H75 |
| CE5001 | CAP_C3528_DISCRETE_47UF/6.3V | 47UF/6.3V | C3528 |
| CE5202 | CAP_C3528_DISCRETE_100UF/6.3V | 100UF/6.3V | C3528 |
| CX5104 | C_C0402_DISCRETE_0.01UF/16V | 0.01UF/16V | C0402 |
| D0301 | DIODE_SOD323_H35_DISCRETE_RB751 | RB751V-40 | SOD323_H35 |
| D2001 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D2202 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D2203 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D2205 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D2206 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D2207 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D2605 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D2701 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D2702 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D3101 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D3102 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D3103 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D3104 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D3105 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D3106 | IP4223_CZ6_SOT457_DISCRETE_IP42 | IP4223-CZ6 | SOT457 |
| D3107 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D3108 | VPORT0603_VARISTOR_0402_PANASON | 331K | VARISTOR_0402_PANASONIC |
| D3109 | VPORT0603_VARISTOR_0402_PANASON | 331K | VARISTOR_0402_PANASONIC |
| D3110 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D3111 | VPORT0603_VARISTOR_0402_PANASON | 331K | VARISTOR_0402_PANASONIC |
| D3112 | VPORT0603_VARISTOR_0402_PANASON | 331K | VARISTOR_0402_PANASONIC |
| D3204 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D3501 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D4508 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D4509 | BAT54AW_SOT323_DISCRETE_BAT54AW | BAT54AW | SOT323 |
| D4510 | BAT54AW_SOT323_DISCRETE_BAT54AW | BAT54AW | SOT323 |
| D4604 | DUAL_DIODE_CONVERT_1ANODE_SOT23 | BAV99 | SOT23 |
| D4605 | IP4223_CZ6_SOT457_DISCRETE_IP42 | IP4223-CZ6 | SOT457 |
| D4606 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D4609 | VPORT_0603_D0603_DISCRETE_EGA10 | EGA10603V05A1 | D0603 |
| D4610 | VPORT_0603_D0603_DISCRETE_EGA10 | EGA10603V05A1 | D0603 |
| D4801 | DIODE_SOD123_DISCRETE_SS0520 | SS0520 | SOD123 |
| D4802 | DUAL_DIODE_CONVERT_1ANODE_SOT_1 | BAV99 | SOT23_H43 |
| D5201 | IP4223_CZ6_SOT457_DISCRETE_IP42 | IP4223-CZ6 | SOT457 |
| D5800 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D5801 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D6101 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D6102 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D6201 | IP4223_CZ6_SOT457_DISCRETE_IP42 | IP4223-CZ6 | SOT457 |
| D6204 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D6205 | PACDN045_SC70_DISCRETE_PACDN045 | PACDN045YB6 | SC70 |
| D7601 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D7602 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D7603 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D7604 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| F4801 | POLY_FUSE_POLYSWITCH_2P_1812_H3 | 0.2A/30V | POLYSWITCH_2P_1812_H39 |
| F5201 | POLY_FUSE_POLYSWITCH_2P_1206_H7 | 1.5A/6V | POLYSWITCH_2P_1206_H71 |
| H6501 | SCREWHOLE_SMT_NB_SMT_NUT_C236B1 | U5F-M-EXPREE | NB_SMT_NUT_C236B189D150_LF2 |
| H6502 | SCREWHOLE_SMT_NB_SMT_NUT_C236B1 | U5F-M-EXPREE | NB_SMT_NUT_C236B189D150_LF2 |
| H6504 | SCREWHOLE_4VIA_NB_H_CT354B276D9 | CT354B276D94N | NB_H_CT354B276D94N_P2_V4 |
| H6505 | SCREWHOLE_4VIA_NB_H_C354D94N_M2 | C354D94 | NB_H_C354D94N_M2_P2_V4 |
| H6506 | SCREWHOLE_4VIA_NB_H_C354D94N_M2 | C354D94 | NB_H_C354D94N_M2_P2_V4 |
| H6508 | SCREWHOLE_4VIA_NB_H_C354D94N_M2 | C354D94 | NB_H_C354D94N_M2_P2_V4 |
| H6509 | SCREWHOLE_4VIA_NB_H_CT354B276D9 | CT354B276D94N | NB_H_CT354B276D94N_P2_V4 |
| H6510 | HOLE_PTH_NB_H_C177D130_P2_C177I | C177I150D130 | NB_H_C177D130_P2 |
| H6511 | HOLE_PTH_NB_H_C177D130_P2_C177I | C177I150D130 | NB_H_C177D130_P2 |
| H6512 | HOLE_PTH_NB_H_C177D130_P2_C177I | C177I150D130 | NB_H_C177D130_P2 |
| H6513 | HOLE_PTH_NB_H_C177D130_P2_C177I | C177I150D130 | NB_H_C177D130_P2 |
| H6514 | HOLE_NPTH_HOLE_C98D98N_C98D98N | C98D98N | HOLE_C98D98N |
| H6515 | SCREWHOLE_4VIA_NB_H_C354D94N_M2 | C354D94 | NB_H_C354D94N_M2_P2_V4 |
| H6516 | SCREWHOLE_4VIA_NB_H_CT354B276D9 | CT354B276D94N | NB_H_CT354B276D94N_P2_V4 |
| H6517 | SCREWHOLE_4VIA_NB_H_C354D94N_M2 | C354D94 | NB_H_C354D94N_M2_P2_V4 |
| H6518 | SCREWHOLE_4VIA_NB_H_CT354B276D9 | CT354B276D94N | NB_H_CT354B276D94N_P2_V4 |
| H6519 | SCREWHOLE_SMT_NB_SMT_NUT_C236B1 | U5F-M-EXPREE | NB_SMT_NUT_C236B189D150_LF2 |
| H6520 | SCREWHOLE_SMT_NB_SMT_NUT_C236B1 | U5F-M-EXPREE | NB_SMT_NUT_C236B189D150_LF2 |
| H6521 | SCREWHOLE_4VIA_NB_H_C354D94N_M2 | C354D94 | NB_H_C354D94N_M2_P2_V4 |
| H6522 | SCREWHOLE_4VIA_NB_H_R335X335D94 | R335X335D94N | NB_H_R335X335D94N_P2_V4 |
| H6523 | SCREWHOLE_4VIA_NB_H_CT276B276D9 | C276D94N | NB_H_CT276B276D94N_P2_V4 |
| J0701 | ZIF_CON_30P_2HOLD_ACES_FPC_30P_ | FPC_CON_30P | FPC_30P_20_2HOLD_RA_ACE |
| J1601 | DDR3_DIMM_204P_4HOLD_DDR3_DIMM_ | DDR3_DIMM_204P | DDR3_DIMM_204P_24_4H_MO |
| J1701 | DDR3_DIMM_204P_4HOLD_DDR3_DIM_1 | DDR3_DIMM_204P | DDR3_DIMM_204P_24_4H_MO_REV |
| J3101 | FPC_CON_24P_2HOLD_ENTERY_NB_FPC | FPC_CON_24P | NB_FPC_24P_39_2HD_RA_ENT_B |
| J3102 | FPC_CON_12P_2HOLD_SONY_FPC_12P_ | FPC_CON_12P | FPC_12P_20_2HOLD_RA_ACES |
| J3103 | FPC_CON_12P_2HOLD_SONY_FPC_12P_ | FPC_CON_12P | FPC_12P_20_2HOLD_RA_ACES |
| J4401 | FPC_CON_12P_2HOLD_SONY_FPC_12P_ | FPC_CON_12P | FPC_12P_20_2HOLD_RA_ACES |
| J4511 | WTOB_CON_30P_4HOLD_IP_WTOB_30P_ | WTOB_CON_30P | WTOB_30P_4HOLD_RA |
| J4601 | D_SUB_15P_2HOLD_SUYI_NB_D_SUB_1 | D_SUB_15P3R | NB_D_SUB_15P_2H_SI_LF2 |
| J4801 | HDMI_CON_19P_4HOLD_CRE_NB_HDMI_ | HDMI_CON_19P | NB_HDMI_19P_4H_H210_LF2 |
| J5001 | FPC_4P_2HOLD_WTOB_4P_49_2HOLD_R | WtoB_CON_4P | WTOB_4P_49_2HOLD_RA |
| J5103 | SATA_CON_22P_4HOLD_TC_NB_SATA_2 | SATA_CON_22P | NB_SATA_22P_50_4H_SUYN_LF2 |
| J5202 | USB_CON_1X4P_4HOLD_SUY_USB_1X4P | USB_CON_1X4P | USB_1X4P_4HOLD_SUN_LF3 |
| J6002 | BATT_CON_9P_2HOLD_M_RA_NB_BATT_ | BATT_CON_9P | NB_BATT_9P_2HLD_M_AL_LF2 |
| J6003 | BATT_CON_9P_2HD_ALLTOP_NB_BATT_ | BATT_CON_9P | NB_BATT_9P_2HD_M_LF2 |
| J6101 | ZIF_CON_6P_2HOLD_WTOB_6P_39_2HO | WTOB_CON_6P | WTOB_6P_39_2HOLD |
| J6201 | ZIF_CON_6P_2HOLD_WTOB_CON_6P_31 | WTOB_CON_6P | WTOB_CON_6P_31_2HOLD_RA |
| J6202 | BATT_CON_6P_2HOLD_FPC_6P_20_2HO | FPC_CON_6P | FPC_6P_20_2HOLD_ACES |
| J6203 | BATT_CON_6P_2HOLD_FPC_6P_20_2HO | FPC_CON_6P | FPC_6P_20_2HOLD_ACES |
| J6301 | HEADER_2X20P_NB_HD_2X20P_50_RA_ | HEADER_2X20P | NB_HD_2X20P_50_RA_SUYN |
| J6302 | HEADER_2X20P_NB_HD_2X20P_50_RA_ | HEADER_2X20P | NB_HD_2X20P_50_RA_SUYN |
| J6303 | HEADER_2X5P_NB_HD_2X5P_50_RA_SU | HEADER_2X5P | NB_HD_2X5P_50_RA_SUY |
| J6501 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6502 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6503 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6504 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6505 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6506 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6507 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6508 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6509 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6510 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| J6511 | ANT_PAD_RD9_EMI_SPRING_106X87_E | EMI_SPRING_PAD | EMI_SPRING_106X87 |
| JP2001 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP2601 | 3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_ | 3MM_OPEN_5MIL | NB_3MM_OPEN_5MIL_LF |
| JP2602 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP2603 | 3MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_ | 2MM_OPEN_5MIL | NB_2MM_OPEN_5MIL_LF |
| JP2701 | 3MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_ | 2MM_OPEN_5MIL | NB_2MM_OPEN_5MIL_LF |
| JP2702 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP2703 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP2704 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP2705 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP3001 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP4511 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP4601 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| JP4602 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| JP4603 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| JP4801 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP7201 | SHORT_PIN_RECTANGLE_TV_RTC_SHOR | SHORT_PIN | TV_RTC_SHORT |
| JP7202 | SHORT_PIN_RECTANGLE_TV_RTC_SHOR | SHORT_PIN | TV_RTC_SHORT |
| JP7203 | SHORT_PIN_RECTANGLE_TV_RTC_SHOR | SHORT_PIN | TV_RTC_SHORT |
| JRST2001 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| JRST2002 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| L2601 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L2605 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L2608 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L2609 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L2704 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L2705 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L2706 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L2707 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L2902 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L2903 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L2904 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L2905 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L2906 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L4501 | BEAD_L0805_H43_DISCRETE_80OHM/1 | 80Ohm/100Mhz | L0805_H43 |
| L4509 | BEAD_L0603_DISCRETE_1KOHM/100MH | 1KOhm/100Mhz | L0603 |
| L4510 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L4601 | INDUCTOR_L0603_DISCRETE_0.082UH | 0.082uH | L0603 |
| L4602 | INDUCTOR_L0603_DISCRETE_0.082UH | 0.082uH | L0603 |
| L4603 | INDUCTOR_L0603_DISCRETE_0.082UH | 0.082uH | L0603 |
| L4801 | COMMON_CHOKE_12_43_CHOKE_4P_79X | 90Ohm/100Mhz | CHOKE_4P_79X47_FUKUI |
| L4802 | COMMON_CHOKE_12_43_CHOKE_4P_79X | 90Ohm/100Mhz | CHOKE_4P_79X47_FUKUI |
| L4803 | COMMON_CHOKE_12_43_CHOKE_4P_79X | 90Ohm/100Mhz | CHOKE_4P_79X47_FUKUI |
| L4804 | COMMON_CHOKE_12_43_CHOKE_4P_79X | 90Ohm/100Mhz | CHOKE_4P_79X47_FUKUI |
| L5201 | BEAD_L0805_H43_DISCRETE_80OHM/1 | 80Ohm/100Mhz | L0805_H43 |
| L6101 | COMMON_CHOKE_12_43_CHOKE_4P_7_1 | 90Ohm/100Mhz | CHOKE_4P_79X47 |
| L6202 | COMMON_CHOKE_12_43_CHOKE_4P_79X | 90Ohm/100Mhz | CHOKE_4P_79X47_FUKUI |
| L6302 | COMMON_CHOKE_12_43_CHOKE_4P_79X | 90Ohm/100Mhz | CHOKE_4P_79X47_FUKUI |
| L7001 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L7101 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L7201 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L7202 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L7203 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L7204 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L7205 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L7302 | BEAD_L0603_DISCRETE_30OHM/100MH | 30Ohm/100Mhz | L0603 |
| L7304 | BEAD_L0603_DISCRETE_30OHM/100MH | 30Ohm/100Mhz | L0603 |
| LX5202 | COMMON_CHOKE_12_43_CHOKE_4P_79X | 90Ohm/100Mhz | CHOKE_4P_79X47_FUKUI |
| PC6004 | C_C0603_DISCRETE_0.1UF/25V | 0.1UF/25V | C0603 |
| PC6005 | C_C0603_DISCRETE_33PF/50V | 33PF/50V | C0603 |
| PC6006 | C_C0603_DISCRETE_33PF/50V | 33PF/50V | C0603 |
| PC6007 | C_C0603_DISCRETE_33PF/50V | 33PF/50V | C0603 |
| PC8001 | C_C0402_DISCRETE_3300PF/25V | 3300PF/25V | C0402 |
| PC8002 | C_C0402_DISCRETE_0.1UF/16V | 0.1UF/16V | C0402 |
| PC8003 | C_C0402_DISCRETE_0.1UF/16V | 0.1UF/16V | C0402 |
| PC8004 | C_C0603_DISCRETE_0.1UF/25V | 0.1UF/25V | C0603 |
| PC8005 | C_C0603_DISCRETE_0.1UF/25V | 0.1UF/25V | C0603 |
| PC8006 | C_C0603_DISCRETE_0.1UF/25V | 0.1UF/25V | C0603 |
| PC8007 | C_C0603_DISCRETE_1UF/16V | 1UF/16V | C0603 |
| PC8008 | C_C0603_DISCRETE_1UF/16V | 1UF/16V | C0603 |
| PC8009 | C_C0603_DISCRETE_1UF/16V | 1UF/16V | C0603 |
| PC8010 | C_C1206_H75_DISCRETE_10UF/25V | 10UF/25V | C1206_H75 |
| PC8011 | C_C1206_H75_DISCRETE_10UF/25V | 10UF/25V | C1206_H75 |
| PC8012 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8013 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8014 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8015 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8016 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8017 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8018 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8019 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8020 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8021 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8022 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8023 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8024 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8025 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8027 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8028 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8029 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8030 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8031 | C_C0805_H57_DISCRETE_10UF/6.3V | 10UF/6.3V | C0805_H57 |
| PC8032 | C_C0402_DISCRETE_47PF/50V | 47PF/50V | C0402 |
| PC8033 | C_C0402_DISCRETE_100PF/50V | 100PF/50V | C0402 |
| PCE8001 | CAP_NB_C7343D_H83_DISCRETE_220U | 220UF/2V | NB_C7343D_H83 |
| PCE8002 | CAP_NB_C7343D_H83_DISCRETE_220U | 220UF/2V | NB_C7343D_H83 |
| PCE8100 | CAP_C7343D_H87_DISCRETE_100UF/6 | 100UF/6.3V | C7343D_H87 |
| PCE8101 | CAP_C7343D_H87_DISCRETE_100UF/6 | 100UF/6.3V | C7343D_H87 |
| PCE8200 | CAP_C7343D_H75_DISCRETE_100UF/2 | 100UF/2.5V | C7343D_H75 |
| PCE8201 | CAP_C7343D_H75_DISCRETE_100UF/2 | 100UF/2.5V | C7343D_H75 |
| PCE8300 | CAP_NB_C7343D_H83_DISCRETE_220U | 220UF/2V | NB_C7343D_H83 |
| PCE8500 | CAP_C7343D_H75_DISCRETE_100UF/2 | 100UF/2.5V | C7343D_H75 |
| PCE8501 | CAP_C7343D_H75_DISCRETE_100UF/2 | 100UF/2.5V | C7343D_H75 |
| PCE8600 | CAP_NB_C7343D_H83_DISCRETE_220U | 220UF/2V | NB_C7343D_H83 |
| PD6001 | IP4223_CZ6_SOT457_DISCRETE_IP42 | IP4223-CZ6 | SOT457 |
| PD8100 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8101 | DUAL_DIODE_CONVERT_1ANODE_SOT32 | BAT54SW | SOT323 |
| PD8102 | DUAL_DIODE_CONVERT_1ANODE_SOT32 | BAT54SW | SOT323 |
| PD8200 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8201 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8300 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8301 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8400 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8500 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8501 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8800 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PD8801 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| PJ8004 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJ8005 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJ8006 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJ8007 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJ8100 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJ8101 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJ8102 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJ8103 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJ8104 | SHORT_PIN_SC_SHORTPIN_SHORTPIN | SHORTPIN | SHORTPIN |
| PJ8807 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| PJP8001 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8002 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8003 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8100 | 3MMO_S_1MM_OPEN_5MIL_FLASHING_1 | 1MM_OPEN_5MIL | 1MM_OPEN_5MIL_FLASHING |
| PJP8101 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8102 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8103 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| PJP8104 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| PJP8105 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| PJP8200 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8201 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8202 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8203 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8204 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8300 | 3MMO_S_1MM_OPEN_5MIL_FLASHING_1 | 1MM_OPEN_5MIL | 1MM_OPEN_5MIL_FLASHING |
| PJP8301 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8302 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| PJP8303 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| PJP8304 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8401 | 3MMO_S_1MM_OPEN_5MIL_FLASHING_1 | 1MM_OPEN_5MIL | 1MM_OPEN_5MIL_FLASHING |
| PJP8402 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8501 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8502 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8503 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8600 | 3MMO_S_1MM_OPEN_5MIL_FLASHING_1 | 1MM_OPEN_5MIL | 1MM_OPEN_5MIL_FLASHING |
| PJP8601 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8602 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PJP8800 | 3MMO_S_1MM_OPEN_5MIL_FLASHING_1 | 1MM_OPEN_5MIL | 1MM_OPEN_5MIL_FLASHING |
| PJP8801 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| PL8001 | INDUCTOR_INDUCTOR_2P_287X260_DI | 1UH | INDUCTOR_2P_287X260 |
| PL8002 | INDUCTOR_INDUCTOR_2P_287X260_DI | 1UH | INDUCTOR_2P_287X260 |
| PL8100 | INDUCTOR_INDUCTOR_2P_287X260__1 | 4.7UH | INDUCTOR_2P_287X260 |
| PL8101 | INDUCTOR_INDUCTOR_2P_287X260__2 | 2.2UH | INDUCTOR_2P_287X260 |
| PL8200 | INDUCTOR_CHOKE_2P_453X394_CYN_D | 0.56UH | CHOKE_2P_453X394_CYN |
| PL8300 | INDUCTOR_INDUCTOR_2P_287X260_DI | 1UH | INDUCTOR_2P_287X260 |
| PL8400 | INDUCTOR_NB_INDUCTOR_2P_205X185 | 2.2UH | NB_INDUCTOR_2P_205X185 |
| PL8500 | INDUCTOR_CHOKE_2P_453X394_CYN_D | 0.56UH | CHOKE_2P_453X394_CYN |
| PL8600 | INDUCTOR_INDUCTOR_2P_287X260_DI | 1UH | INDUCTOR_2P_287X260 |
| PL8800 | INDUCTOR_INDUCTOR_2P_287X260__3 | 6.8UH | INDUCTOR_2P_287X260 |
| PL8801 | BEAD_L0805_H43_DISCRETE_80OHM/1 | 80Ohm/100Mhz | L0805_H43 |
| PL8802 | BEAD_L0805_H43_DISCRETE_80OHM/1 | 80Ohm/100Mhz | L0805_H43 |
| PL8803 | BEAD_L0805_H43_DISCRETE_80OHM/1 | 80Ohm/100Mhz | L0805_H43 |
| PQ8001 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8002 | PH8230E_MB_SOT669_COLAY_DISCR_1 | RJK0353DPA-00-J0 | MB_SOT669_COLAY |
| PQ8003 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8004 | PH8230E_MB_SOT669_COLAY_DISCR_1 | RJK0353DPA-00-J0 | MB_SOT669_COLAY |
| PQ8051 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| PQ8052 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| PQ8100 | SI7840DP_EMB20N03V_DISCRETE_EMB | EMB20N03V | EMB20N03V |
| PQ8101 | SI7840DP_EMB20N03V_DISCRETE_EMB | EMB20N03V | EMB20N03V |
| PQ8102 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8103 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8200 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8201 | PH8230E_MB_SOT669_COLAY_DISCR_1 | RJK0353DPA-00-J0 | MB_SOT669_COLAY |
| PQ8202 | UM6K1N_NB_SC70_S6_DISCRETE_UM6K | UM6K31N | SC70_S6 |
| PQ8203 | PH8230E_MB_SOT669_COLAY_DISCR_1 | RJK0353DPA-00-J0 | MB_SOT669_COLAY |
| PQ8300 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8301 | PH8230E_MB_SOT669_COLAY_DISCR_1 | RJK0353DPA-00-J0 | MB_SOT669_COLAY |
| PQ8302 | UM6K1N_NB_SC70_S6_DISCRETE_UM6K | UM6K31N | SC70_S6 |
| PQ8400 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| PQ8500 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8501 | PH8230E_MB_SOT669_COLAY_DISCR_1 | RJK0353DPA-00-J0 | MB_SOT669_COLAY |
| PQ8502 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| PQ8503 | PH8230E_MB_SOT669_COLAY_DISCR_1 | RJK0353DPA-00-J0 | MB_SOT669_COLAY |
| PQ8600 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8601 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ8602 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| PQ8603 | NPN_SOT23_SOT23_H43_DISCRETE_PM | PMBS3904 | SOT23_H43 |
| PQ8800 | SI7840DP_EMB20N03V_DISCRETE_EMB | EMB20N03V | EMB20N03V |
| PQ8801 | SI7840DP_EMB20N03V_DISCRETE_EMB | EMB20N03V | EMB20N03V |
| PQ8802 | P_MOS_SO8_SOIC_8P_50_197X236_DI | PMK35EP | SOIC_8P_50_197X236 |
| PQ8803 | P_MOS_SO8_SOIC_8P_50_197X236_DI | PMK35EP | SOIC_8P_50_197X236 |
| PQ8804 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| PQ8805 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| PQ8808 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| PQ9100 | PH8230E_MB_SOT669_COLAY_DISCRET | RJK0355DPA-00-J0 | MB_SOT669_COLAY |
| PQ9101 | SI7840DP_EMB20N03V_DISCRETE_EMB | EMB20N03V | EMB20N03V |
| PQ9102 | SI7840DP_EMB20N03V_DISCRETE_EMB | EMB20N03V | EMB20N03V |
| PQ9103 | SI7840DP_EMB20N03V_DISCRETE_EMB | EMB20N03V | EMB20N03V |
| PQ9104 | SI7840DP_EMB20N03V_DISCRETE_EMB | EMB20N03V | EMB20N03V |
| PQ9105 | PUMD12_SOT363_PHILIPS_DISCRETE_ | PUMD12 | SOT363_PHILIPS |
| PQ9106 | PUMD12_SOT363_PHILIPS_DISCRETE_ | PUMD12 | SOT363_PHILIPS |
| PRN8600 | 4R8PS_4R8P0402_H20_DISCRETE_100 | 100KOHM | 4R8P0402_H20 |
| PRN8601 | 4R8PS_4R8P0402_H20_DISCRETE_100 | 100KOHM | 4R8P0402_H20 |
| PRN8602 | 4R8PS_4R8P0402_H20_DISCRETE_10K | 10KOHM | 4R8P0402_H20 |
| PRN8801 | 4R8PS_4R8P0402_H20_DISCRETE_100 | 100KOHM | 4R8P0402_H20 |
| PT6008 | TEST_POINT_NB_TPC28T_68_TPC28T | TPC28T | NB_TPC28T_68 |
| PU8000 | RT8152GQW_MB_QFN_32P_20_S197_RI | RT8152DGQW | MB_QFN_32P_20_S197_RIC_4VIA |
| PU8101 | RT8206AGQW_4VIA_NB_QFN_32P_S197 | RT8206AGQW | NB_QFN_32P_S197_PA_S_H31_4V |
| PU8102 | UP7714HMA5_MB_SOT23_S5_MAX_IC_U | UP7714BMA5-00 | MB_SOT23_S5_MAX |
| PU8200 | RT8202APQW_4VIA_MB_QFN_16P_20_S | RT8202APQW | MB_QFN_16P_20_S118_PAD_4V |
| PU8300 | RT8202APQW_4VIA_MB_QFN_16P_20_S | RT8202APQW | MB_QFN_16P_20_S118_PAD_4V |
| PU8301 | UP7711U8_4VIA_MB_SOIC_8P_50_197 | UP7711U8 | MB_SOIC_8P_50_197X236_PD_4V |
| PU8400 | RT8015BGQW_MB_DFN_10P_20_S118_P | RT8015BGQW | MB_DFN_10P_20_S118_PAD_RI |
| PU8500 | RT8202APQW_4VIA_MB_QFN_16P_20_S | RT8202APQW | MB_QFN_16P_20_S118_PAD_4V |
| PU8600 | RT8152GQW_MB_QFN_32P_20_S197_RI | RT8152DGQW | MB_QFN_32P_20_S197_RIC_4VIA |
| PU8800 | MB39A132_4VIA_MB_QFN_32P_20_S19 | MB39A132 | MB_QFN_32P_20_S197_PAD_A_4V |
| PU8801 | LMV321M5X_NB_SOT23_S5_T_IC_LMV3 | LMV321IDBVR | NB_SOT23_S5_T |
| Q0301 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q2001 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q2101 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q2104 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q2404 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q2620 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q2621 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q2801 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q2802 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q2803 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q2901 | N_MOS_SOT23_SOT23_H43_DISCRETE_ | 2N7002ET1G | SOT23_H43 |
| Q2902 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q2903 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q3002 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q3101 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q3102 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q3204 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q3512 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q3552 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q4501 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q4502 | N_MOS_SO6_SO6_H43_DISCRETE_SI34 | SI3456BDV | SO6_H43 |
| Q4503 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q4504 | P_MOS_SOT23_SOT23_PROLIFIC_DISC | PA203EMG | SOT23_PROLIFIC |
| Q4602 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q4801 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q5001 | NB_NPN_SOT23_NB_BJT_SOT23_H43_D | PMBS3904 | NB_BJT_SOT23_H43 |
| Q5701 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5702 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5703 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5704 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5705 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5706 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5707 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5712 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5713 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5715 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5800 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q6201 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q7201 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q7202 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q7401 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q7403 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q7404 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q7407 | N_MOS_SOT23_NBS_SOT23_H43_DISCR | 2N7002 | NBS_SOT23_H43 |
| Q7601 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q7602 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q7603 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q7604 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q7605 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q7606 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q7607 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| R0301 | R_R0402_H16_DISCRETE_49.9OHM | 49.9Ohm | R0402_H16 |
| SLR1804 | SL_0603_SHORTPIN_R0603_SHORTLA | SHORT LAND | SHORTPIN_R0603 |
| U0301 | CN80617004128AA_NB_BGA_1288P_13 | CN80617004128AA | NB_BGA_1288P_1339X1102 |
| U1801 | LMV321M5X_SOT23_S5_RD1_IC_LMV32 | LMV321IDBVR | SOT23_S5_RD1 |
| U2001 | IBEXPEAK_M_NB_BGA_1071P_20_1063 | IBEXPEAK-M | NB_BGA_1071P_20_1063X984 |
| U2401 | NC7SZ08M5_SC70_S5_IC_NC7SZ08P5X | NC7SZ08P5X_NL | SC70_S5 |
| U2801 | SST25LF040A_SOIC_8P_50_213X311_ | SST25VF032B | SOIC_8P_50_213X311 |
| U2901 | ICS9LVS3162AKLFT_VIA_NB_QFN_32P | ICS9LVS3162AKLFT | NB_QFN_32P_S197_PAD_ICS_V |
| U3001 | IT8541E_L_QFP_128P_16_630X630_I | IT8570E | QFP_128P_16_630X630 |
| U3501 | ASM1452_VIA_NB_QFN_42P_20_354X1 | ASM1452 | NB_QFN_42P_20_354X138_PAD_V |
| U3502 | PI5V330_SOIC_16P_25_197X236_IC_ | TS5V330CDBQR | SOIC_16P_25_197X236 |
| U3504 | PI3L100_SOIC_16P_25_193X236_IC_ | PI5C3257QE | SOIC_16P_25_193X236 |
| U3505 | PI3L100_SOIC_16P_25_193X236_IC_ | PI5C3257QE | SOIC_16P_25_193X236 |
| U3507 | PI3L100_SOIC_16P_25_193X236_IC_ | PI5C3257QE | SOIC_16P_25_193X236 |
| U4601 | SN74LVC1G125DCKR_SOT753_IC_74LV | 74LVC1G125GV | SOT753 |
| U4602 | SN74LVC1G125DCKR_SOT753_IC_74LV | 74LVC1G125GV | SOT753 |
| U4801 | PI3HDMI201ZFE_PERICOM_QFN_56P_2 | PI3HDMI201ZFE | QFN_56P_20_433X197_PAD |
| U4803 | NC7SZ08M5_SOT23_S5_SC70_RD4_H43 | NC7SZ08P5X | SOT23_S5_SC70_RD4_H43 |
| U5002 | G781_1_SO8_H69_IC_G781 | G781 | SO8_H69 |
| U5801 | NC7SZ08M5_SOT23_S5_SC70_RD4_H43 | NC7SZ08P5X | SOT23_S5_SC70_RD4_H43 |
| U5802 | NC7SZ08M5_NB_SOT23_S5_SC70_FAIR | NC7SZ08P5X | NB_SOT23_S5_SC70_FAIRCHILD |
| U5803 | NC7SZ08M5_SOT23_S5_SC70_RD4_H43 | NC7SZ08P5X | SOT23_S5_SC70_RD4_H43 |
| U7001 | N10M_GS_S_NB_BGA_533P_31_906X90 | N11M-GE1 | NB_BGA_533P_31_906X906_H83 |
| U7002 | NC7SZ08M5_SC70_S5_IC_NC7SZ08P5X | NC7SZ08P5X_NL | SC70_S5 |
| U7501 | EDJ1108BDBG_NB_BGA_78P_31_417X2 | EDJ1108BDBG-DJ-F | NB_BGA_78P_31_417X295 |
| U7502 | EDJ1108BDBG_NB_BGA_78P_31_417X2 | EDJ1108BDBG-DJ-F | NB_BGA_78P_31_417X295 |
| U7503 | EDJ1108BDBG_NB_BGA_78P_31_417X2 | EDJ1108BDBG-DJ-F | NB_BGA_78P_31_417X295 |
| U7504 | EDJ1108BDBG_NB_BGA_78P_31_417X2 | EDJ1108BDBG-DJ-F | NB_BGA_78P_31_417X295 |
| U7505 | EDJ1108BDBG_NB_BGA_78P_31_417X2 | EDJ1108BDBG-DJ-F | NB_BGA_78P_31_417X295 |
| U7506 | EDJ1108BDBG_NB_BGA_78P_31_417X2 | EDJ1108BDBG-DJ-F | NB_BGA_78P_31_417X295 |
| U7507 | EDJ1108BDBG_NB_BGA_78P_31_417X2 | EDJ1108BDBG-DJ-F | NB_BGA_78P_31_417X295 |
| U7508 | EDJ1108BDBG_NB_BGA_78P_31_417X2 | EDJ1108BDBG-DJ-F | NB_BGA_78P_31_417X295 |
| U7601 | NC7SZ08M5_NB_SOT23_S5_SC70_FAIR | NC7SZ08P5X | NB_SOT23_S5_SC70_FAIRCHILD |
| X2001 | CRYSTAL_SMD_23GND_XTAL_4P_315X1 | 32.768Khz | XTAL_4P_315X150 |
| X2101 | CRYSTAL_XTAL_2P_236X138_DISCRET | 25Mhz | XTAL_2P_236X138 |
| X2902 | CRYSTAL_SMD_24GND_XTAL_4P_126X9 | 14.31818Mhz | XTAL_4P_126X98_EPS |
| X3001 | CRYSTAL_SMD_23GND_XTAL_4P_272X5 | 32.768Khz | XTAL_4P_272X55 |
| X7401 | CRYSTAL_SMD_24GND_XTAL_4P_236X1 | 27Mhz | XTAL_4P_236X138 |
