| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CE0501 | CAP_C7343D_H75_DISCRETE_100UF/2 | 100UF/2.5V | C7343D_H75 |
| CE0502 | CAP_C7343D_H75_DISCRETE_100UF/2 | 100UF/2.5V | C7343D_H75 |
| CE6701 | CAP_C3528_H47_RD9_DISCRETE_47UF | 47UF/6.3V | C3528_H47_RD9 |
| CE8001 | CAP_NB_C7343D_H79_DISCRETE_330U | 330UF/2V | NB_C7343D_H79 |
| CE8002 | CAP_NB_C7343D_H79_DISCRETE_330U | 330UF/2V | NB_C7343D_H79 |
| CE8101 | CAP_C3528_DISCRETE_100UF/6.3V | 100UF/6.3V | C3528 |
| CE8102 | CAP_C3528_DISCRETE_100UF/6.3V | 100UF/6.3V | C3528 |
| CE8201 | CAP_NB_C7343D_H83_DISCRETE_220U | 220UF/2V | NB_C7343D_H83 |
| CE8202 | CAP_NB_C7343D_H83_DISCRETE_220U | 220UF/2V | NB_C7343D_H83 |
| CE8301 | CAP_NB_C7343D_H83_DISCRETE_220U | 220UF/2V | NB_C7343D_H83 |
| CE8302 | CAP_NB_C7343D_H83_DISCRETE_220U | 220UF/2V | NB_C7343D_H83 |
| CN3101 | C_ARRAYS_C_ARRAY_8P_79X49_H28_D | 33PF/50V | C_ARRAY_8P_79X49_H28 |
| CN3102 | C_ARRAYS_C_ARRAY_8P_79X49_H28_D | 33PF/50V | C_ARRAY_8P_79X49_H28 |
| CN3103 | C_ARRAYS_C_ARRAY_8P_79X49_H28_D | 33PF/50V | C_ARRAY_8P_79X49_H28 |
| CN3104 | C_ARRAYS_C_ARRAY_8P_79X49_H28_D | 33PF/50V | C_ARRAY_8P_79X49_H28 |
| CN3105 | C_ARRAYS_C_ARRAY_8P_79X49_H28_D | 33PF/50V | C_ARRAY_8P_79X49_H28 |
| CN3106 | C_ARRAYS_C_ARRAY_8P_79X49_H28_D | 33PF/50V | C_ARRAY_8P_79X49_H28 |
| D0301 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D1501 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D2001 | BAT54C_SOT23_H43_DISCRETE_BAT54 | BAT54C | SOT23_H43 |
| D2201 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D2301 | BAT54AW_SOT323_DISCRETE_BAT54AW | BAT54AW | SOT323 |
| D2302 | BAT54AW_SOT323_DISCRETE_BAT54AW | BAT54AW | SOT323 |
| D3001 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D3101 | BAT54AW_SOT323_DISCRETE_BAT54AW | BAT54AW | SOT323 |
| D4601 | BAT54AW_SOT323_DISCRETE_BAT54AW | BAT54AW | SOT323 |
| D4602 | BAT54AW_SOT323_DISCRETE_BAT54AW | BAT54AW | SOT323 |
| D5001 | BAT54C_SOT23_H43_DISCRETE_BAT54 | BAT54C | SOT23_H43 |
| D6001 | DIODE_SOD123_DISCRETE_SS0540 | SS0540 | SOD123 |
| D6005 | DF5A_SOT23_S5_SC70_RD4_H43_DISC | DF5A6.8FU | SOT23_S5_SC70_RD4_H43 |
| D6101 | SCHOTTKY_DIODE_CHENMKO_SOD323_O | CH751H-40PT | SOD323_ON_H35 |
| D6701 | VPORT_0603_D0603_DISCRETE_EGA10 | EGA10603V05A1 | D0603 |
| D6702 | VPORT_0603_D0603_DISCRETE_EGA10 | EGA10603V05A1 | D0603 |
| D8101 | DUAL_DIODE_CONVERT_1ANODE_SOT32 | BAT54SW | SOT323 |
| D8102 | DUAL_DIODE_CONVERT_1ANODE_SOT32 | BAT54SW | SOT323 |
| D8103 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D8201 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D8301 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D8302 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D8801 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D8803 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D8804 | DIODE_PHILIPS_SOD323_ON_H35_DIS | 1SS355PT | SOD323_ON_H35 |
| D9201 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| D9202 | DUAL_DIODE_3CATHODE_SOT323_DISC | BAT54CW | SOT323 |
| EC6819 | C_C0402_DISCRETE_33PF/50V | 33PF/50V | C0402 |
| EPAD01 | ANT_PAD_RD9_SMDPAD_264X79_SMD26 | SMD267X79 | SMDPAD_264X79 |
| F6701 | POLY_FUSE_POLYSWITCH_2P_1812_H2 | 1.1A/6V | POLYSWITCH_2P_1812_H24 |
| H1 | HOLE_PTH_NB_H_C315D110_153_P2_C | C315D110 | NB_H_C315D110_153_P2 |
| H2 | HOLE_PTH_NB_H_C315D110_153_P2_C | C315D110 | NB_H_C315D110_153_P2 |
| H3 | HOLE_PTH_NB_H_C315D110_153_P2_C | C315D110 | NB_H_C315D110_153_P2 |
| H4 | HOLE_PTH_NB_H_C315D110_153_P2_C | C315D110 | NB_H_C315D110_153_P2 |
| H5 | HOLE_PTH_NB_H_C315D110_153_P2_C | C315D110 | NB_H_C315D110_153_P2 |
| H6 | HOLE_PTH_NB_H_C315D110_153_P2_C | C315D110 | NB_H_C315D110_153_P2 |
| H7 | HOLE_PTH_NB_H_CRT335X315B315D11 | CRT335X315B315D110 | NB_H_CRT335X315B315D110_P2 |
| H8 | HOLE_PTH_NB_H_C197D110_134_P2_C | C197D110 | NB_H_C197D110_134_P2 |
| H9 | HOLE_PTH_NB_H_C197D110_134_P2_C | C197D110 | NB_H_C197D110_134_P2 |
| H10 | HOLE_PTH_NB_H_C197D110_134_P2_C | C197D110 | NB_H_C197D110_134_P2 |
| H11 | HOLE_PTH_NB_H_C197D110_134_P2_C | C197D110 | NB_H_C197D110_134_P2 |
| H12 | HOLE_PTH_NB_H_ST394B315D110_P2_ | ST394B315D110 | NB_H_ST394B315D110_P2 |
| H13 | SCREWHOLE_SMT_NB_SMT_NUT_CT217B | T12J | NB_SMT_NUT_CT217BI67D47_LF2 |
| H14 | SCREWHOLE_SMT_NB_SMT_NUT_CT217B | T12J | NB_SMT_NUT_CT217BI67D47_LF2 |
| H15 | HOLE_PTH_NB_H_C177D130_P2_C177I | C177I150D130 | NB_H_C177D130_P2 |
| H16 | HOLE_PTH_NB_H_C177D130_P2_C177I | C177I150D130 | NB_H_C177D130_P2 |
| H17 | HOLE_PTH_NB_H_C177D130_P2_C177I | C177I150D130 | NB_H_C177D130_P2 |
| H18 | HOLE_PTH_NB_H_C177D130_P2_C177I | C177I150D130 | NB_H_C177D130_P2 |
| H19 | SCREWHOLE_SMT_NB_SMT_NUT_CT217B | T12J | NB_SMT_NUT_CT217BI67D47_LF2 |
| H20 | SCREWHOLE_SMT_NB_SMT_NUT_CT217B | T12J | NB_SMT_NUT_CT217BI67D47_LF2 |
| H21 | HOLE_NPTH_HOLE_O110X91DO110X91N | O110X91DO110X91N | HOLE_O110X91DO110X91N |
| J0301 | BTOB_CON_31P_F_BTOB_CON_31P_39_ | BTOB_CON_31P | BTOB_CON_31P_39_F |
| J3101 | FPC_CON_24P_2HOLD_ENTERY_NB_FPC | FPC_CON_24P | NB_FPC_24P_39_2HD_RA_ENT_B |
| J3102 | ZIF_CON_6P_2HOLD_WTOB_6P_49_2HO | WtoB_CON_6P | WTOB_6P_49_2HOLD_RA_ACES1 |
| J3801 | FPC_4P_2HOLD_WTOB_4P_49_2HOLD_R | WtoB_CON_4P | WTOB_4P_49_2HOLD_RA_AC |
| J4401 | FPC_CON_12P_2HOLD_SONY_FPC_12P_ | FPC_CON_12P | FPC_12P_20_2HOLD_RA_ET_Z96J |
| J4601 | WTOB_CON_40P_13HOLD_WTOB_40P_20 | WTOB_CON_40P | WTOB_40P_20_13HOLD |
| J5001 | WTOB_CON_4P_WTOB_4P_49_RA_IO_WT | WtoB_CON_4P | WTOB_4P_49_RA |
| J5101 | SATA_CON_22P_4HOLD_TC_NB_SATA_2 | SATA_CON_22P | NB_SATA_22P_50_4H_SUYN_LF2 |
| J5102 | SATA_CON_13P_4HOLD_OCTEK_NB_SAT | SATA_CON_13P | NB_SATA_13P_4H_SUYIN_LF2 |
| J6001 | HEADER_1X4P_NB_WTOB_D_1X4P_98_S | WAFER_HD_4P | NB_WTOB_D_1X4P_98_SIN_LF2 |
| J6002 | BATT_CON_9P_2HOLD_M_RA_NB_BATT_ | BATT_CON_9P | NB_BATT_9P_2HLD_M_AL_LF2 |
| J6101 | ZIF_CON_6P_2HOLD_WTOB_6P_49_2HO | WtoB_CON_6P | WTOB_6P_49_2HOLD_RA_ACES1 |
| J6701 | FPC_CON_18P_2HOLD_ACES_FPC_18P_ | FPC_CON_18P | FPC_18P_20_2HOLD_RA_ACE_B |
| J6702 | FPC_CON_8P_2HOLD_MOLEX_FPC_CON_ | FPC_CON_8P | FPC_CON_8P_20_2HOLD_ACES |
| J6703 | ZIF_CON_6P_2HOLD_WTOB_6P_49_2HO | WtoB_CON_6P | WTOB_6P_49_2HOLD_RA_ACES1 |
| J6704 | FPC_4P_2HOLD_WTOB_4P_49_2HOLD_R | WtoB_CON_4P | WTOB_4P_49_2HOLD_RA_AC |
| J6801 | BTOB_CON_60P_8HOLD_M_NB_BTOB_60 | BTOB_CON_60P | NB_BTOB_60P_31_8HOLD_M_H87 |
| J6802 | BTOB_CON_60P_8HOLD_M_NB_BTOB_60 | BTOB_CON_60P | NB_BTOB_60P_31_8HOLD_M_H87 |
| J8112 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| J9204 | SHORT_PIN_SC_SHORTPIN_SHORTPIN | SHORTPIN | SHORTPIN |
| JP1201 | SHORT_PIN_RECTANGLE_TV_RTC_SHOR | SHORT_PIN | TV_RTC_SHORT |
| JP1202 | SHORT_PIN_RECTANGLE_TV_RTC_SHOR | SHORT_PIN | TV_RTC_SHORT |
| JP1203 | SHORT_PIN_RECTANGLE_TV_RTC_SHOR | SHORT_PIN | TV_RTC_SHORT |
| JP1401 | 3MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_ | 2MM_OPEN_5MIL | NB_2MM_OPEN_5MIL_LF |
| JP1402 | 3MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_ | 2MM_OPEN_5MIL | NB_2MM_OPEN_5MIL_LF |
| JP1403 | 3MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_ | 2MM_OPEN_5MIL | NB_2MM_OPEN_5MIL_LF |
| JP1404 | 3MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_ | 2MM_OPEN_5MIL | NB_2MM_OPEN_5MIL_LF |
| JP1502 | 3MMO_S_NB_1D8MM_OPEN_5MIL_1.8MM | 1.8MM_OPEN_5MIL | NB_1D8MM_OPEN_5MIL |
| JP2301 | 3MMO_S_NB_1D8MM_OPEN_5MIL_1.8MM | 1.8MM_OPEN_5MIL | NB_1D8MM_OPEN_5MIL |
| JP8001 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP8002 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| JP8101 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| JP8102 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP8103 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| JP8104 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| JP8105 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| JP8106 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| JP8107 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| JP8108 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| JP8109 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| JP8201 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| JP8204 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP8301 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| JP8302 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP8309 | 3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L | 1MM_OPEN_5MIL | NB_1MM_OPEN_5MIL_FLASH_LF |
| JP8401 | 3MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE | 3MM_OPEN_5MIL | 3MM_OPEN_5MIL_SP |
| JP8801 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| JP8802 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| JP8803 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| JP8804 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| JP8807 | SHORT_PIN_RECTANGLE_NB_PWR_FB_S | SHORT_PIN | NB_PWR_FB_SHORT_PT |
| JRST1 | 3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUM | SGL_JUMP | NB_OPEN2_5MIL_PT |
| L6701 | BEAD_L0805_H43_DISCRETE_80OHM/1 | 80Ohm/100Mhz | L0805_H43 |
| L6801 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L6802 | BEAD_L0603_DISCRETE_120OHM/100M | 120Ohm/100Mhz | L0603 |
| L8001 | INDUCTOR_INDUCTOR_2P_287X260_DI | 0.68UH | INDUCTOR_2P_287X260 |
| L8101 | INDUCTOR_INDUCTOR_2P_287X260__1 | 4.7UH | INDUCTOR_2P_287X260 |
| L8102 | INDUCTOR_INDUCTOR_2P_291X264_TO | 4.7UH | INDUCTOR_2P_291X264_TOKO |
| L8201 | INDUCTOR_INDUCTOR_2P_291X264__1 | 1.0UH | INDUCTOR_2P_291X264_TOKO |
| L8301 | INDUCTOR_INDUCTOR_2P_291X264__1 | 1.0UH | INDUCTOR_2P_291X264_TOKO |
| L8801 | INDUCTOR_NB_INDUCTOR_2P_244X228 | 4.7UH | NB_INDUCTOR_2P_244X228 |
| Q0301 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q0501 | NB_NPN_SOT23_NB_BJT_SOT23_H43_D | PMBS3904 | NB_BJT_SOT23_H43 |
| Q0502 | N_MOS_SOT23_SOT23_H43_DISCRETE_ | 2N7002 | SOT23_H43 |
| Q2201 | N_MOS_SOT23_SOT23_H43_DISCRETE_ | 2N7002 | SOT23_H43 |
| Q2202 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q2401 | N_MOS_SOT23_SOT23_H43_DISCRETE_ | 2N7002 | SOT23_H43 |
| Q3001 | N_MOS_SOT23_SOT23_H43_DISCRETE_ | 2N7002 | SOT23_H43 |
| Q4601 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q4602 | N_MOS_SO6_SO6_H43_DISCRETE_SI34 | SI3456BDV | SO6_H43 |
| Q4603 | N_MOS_SOT23_SOT23_H43_DISCRETE_ | 2N7002 | SOT23_H43 |
| Q5001 | NB_2N7002K_NB_MOS_SOT23_H44_DIS | 2N7002K_T1_E3 | NB_MOS_SOT23_H44 |
| Q5101 | N_MOS_SO6_SO6_H43_DISCRETE_SI34 | SI3456BDV | SO6_H43 |
| Q5102 | N_MOS_SOT23_SOT23_H43_DISCRETE_ | 2N7002 | SOT23_H43 |
| Q5701 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5702 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5703 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5704 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5705 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q5706 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q8001 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8002 | FDMC8884_NB_POW56_5P_50_197X236 | FDMS7660 | NB_POW56_5P_50_197X236_H43 |
| Q8101 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8102 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8103 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8104 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8201 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8202 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8203 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8204 | NB_2N7002K_NB_MOS_SOT23_H44_DIS | 2N7002K_T1_E3 | NB_MOS_SOT23_H44 |
| Q8301 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8302 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8303 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8801 | P_MOS_SO8_SOIC_8P_50_197X236_HO | P2003EVG | SOIC_8P_50_197X236_HOLTEK |
| Q8802 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8803 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q8804 | P_MOS_SO8_SOIC_8P_50_197X236_HO | P2003EVG | SOIC_8P_50_197X236_HOLTEK |
| Q8808 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q8809 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q8812 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| Q9101 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q9102 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q9103 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q9104 | NPN_PNP_SOT353_SOT353_DISCRETE_ | UMC4N | SOT353 |
| Q9105 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q9106 | SI7840DP_POWER33_5P_26_130X130_ | FDMC8884 | POWER33_5P_26_130X130_PAD |
| Q9107 | NPN_PNP_SOT353_SOT353_DISCRETE_ | UMC4N | SOT353 |
| Q9201 | UM6K1N_NB_SOT363_NB_DISCRETE_UM | UM6K1N | SOT363_NB |
| RN2913 | 2R4PS_2R4P0402_H18_DISCRETE_10K | 10KOHM | 2R4P0402_H18 |
| RN2914 | 2R4PS_2R4P0402_H18_DISCRETE_10K | 10KOHM | 2R4P0402_H18 |
| RN2916 | 2R4PS_2R4P0402_DISCRETE_33OHM | 33Ohm | 2R4P0402 |
| RN9201 | 2R4PS_2R4P0402_H18_DISCRETE_100 | 100KOHM | 2R4P0402_H18 |
| RNX1202 | 4R8PS_4R8P_DISCRETE_75OHM | 75Ohm | 4R8P |
| RP2101 | 8R10PS_8R10P_H24_DISCRETE_10KOH | 10kOhm | 8R10P_H24 |
| RP2102 | 8R10PS_8R10P_H24_DISCRETE_10KOH | 10kOhm | 8R10P_H24 |
| SLN4601 | SHORT_LAND_2R4P_NBP_SHORTPIN_2R | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402_NORM |
| SLN4602 | SHORT_LAND_2R4P_NBP_SHORTPIN_2R | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402_NORM |
| SLN4603 | SHORT_LAND_2R4P_NBP_SHORTPIN_2R | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402_NORM |
| SLN4604 | SHORT_LAND_2R4P_NBP_SHORTPIN_2R | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402_NORM |
| SLN6101 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6701 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6702 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6801 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6802 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6803 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6804 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6805 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6806 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| SLN6807 | SHORT_LAND_2R4P_NBP_SHORTPIN__1 | SHORT_LAND_2R4P | NBP_SHORTPIN_2R4P0402 |
| U0301 | SU9400_956P_NB_BGA_956P_19_866X | SU9400/SU9300 | NB_BGA_956P_19_866X866_SPE |
| U0701 | DDR3_DIMM_204P_4HOLD_DDR3_DIMM_ | DDR3_DIMM_204P | DDR3_DIMM_204P_24_4H_MO_REV |
| U0801 | DDR3_DIMM_204P_4HOLD_DDR3_DIM_1 | DDR3_DIMM_204P | DDR3_DIMM_204P_24_4H_MO |
| U1001 | 897605_NB_BGA_1362P_1063X984_IC | 897605 | NB_BGA_1362P_1063X984 |
| U2001 | ICH9M_SFF_NB_BGA_569P_630X630_I | ICH9M_SFF | NB_BGA_569P_630X630 |
| U2101 | NC7SZ08M5_NB_SOT23_S5_SC70_FAIR | NC7SZ08P5X | NB_SOT23_S5_SC70_FAIRCHILD |
| U2402 | ATM_SO_8P_SOIC_8P_50_197X236_IC | AT24C08AN | SOIC_8P_50_197X236 |
| U2901 | RTM875T_336_GRT_SOIC_64P_20_673 | RTM875T-336-GRT | SOIC_64P_20_673X319 |
| U3001 | IT8512E_L_ITE_QFP_128P_16_630X6 | IT8512E-L | QFP_128P_16_630X630 |
| U3101 | AT25HP512_SOIC_8P_50_212X315_IC | MX25L8005M2C_15G | SOIC_8P_50_212X315 |
| U5001 | G781_1_SOIC_8P_50_197X236_IC_G7 | G780P11U | SOIC_8P_50_197X236 |
| U8001 | MAX8796_5VIA_QFN_32P_20_S197_PA | MAX8796GTJ+ | QFN_32P_20_S197_PAD_MAX_5V |
| U8101 | RT8206AGQW_4VIA_NB_QFN_32P_S197 | RT8206AGQW | NB_QFN_32P_S197_PA_S_H31_4V |
| U8102 | RT9043_GB_SOT23_S5_H51_IC_RT904 | RT9043-GB | SOT23_S5_H51 |
| U8201 | TPS51117RGYR_QFN_14P_20_138X138 | TPS51117RGYR | QFN_14P_20_138X138_PAD |
| U8301 | TPS51116RGER_5VIA_QFN_24P_20_15 | TPS51116RGER | QFN_24P_20_157X157_PAD_5VIA |
| U8302 | NC7SZ08M5_NB_SOT23_S5_SC70_FAIR | NC7SZ08P5X | NB_SOT23_S5_SC70_FAIRCHILD |
| U8401 | APL5912KACTUL_NB_SOIC_8P_50_196 | APL5930-KAI-TRG | NB_SOIC_8P_50_196X236_PAD_A |
| U8801 | MB39A132_QFN_32P_20_197X197_PAD | MB39A132 | QFN_32P_20_197X197_PAD_AMI |
| U8802 | LMV321M5X_NB_SOT23_S5_T_IC_LMV3 | LMV321IDBVR | NB_SOT23_S5_T |
| U9201 | NC7SZ08M5_NB_SOT23_S5_SC70_FAIR | NC7SZ08P5X | NB_SOT23_S5_SC70_FAIRCHILD |
| X2001 | CRYSTAL_SMD_23GND_XTAL_4P_272X5 | 32.768Khz | XTAL_4P_272X55 |
| X2901 | CRYSTAL_XTAL_2P_197X126_TXC_H51 | 14.318Mhz | XTAL_2P_197X126_TXC_H51 |
| X3001 | CRYSTAL_SMD_23GND_XTAL_4P_272X5 | 32.768Khz | XTAL_4P_272X55 |
