| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT6100 | ANT_1P1G_ANTPCB_44R00X11R00_DSR | ANT4411DR | ANTPCB_44R00X11R00_DSR |
| ANT6101 | ANT_1P2G_ANT_JACK_ANT_JACK | ANT_JACK | ANT_JACK |
| BT2001 | BATT3_BAT3_2R54_BAT3_2R54 | BAT3_2R54 | BAT3_2R54 |
| CM7100 | CM_C_MTM-C_100UF/25V | 100uF/25V | MTM-C |
| CM7101 | CM_C_MTM-C_100UF/25V | 100uF/25V | MTM-C |
| D2001 | DIODE_DO_214AC_SS32 | SS32 | DO_214AC |
| D2003 | DIODE_SOD_323_B5819WS | B5819WS | SOD_323 |
| D4100 | DIODE BI_DIRTRIG_ESD0402_ESD54 | ESD5451N | ESD0402 |
| D4101 | DIODE_SOD_323_1N4148WS | 1N4148WS | SOD_323 |
| D9100 | DIODE BI_DIRTRIG_ESD0402_ESD54 | ESD5451N | ESD0402 |
| ED9105 | DIODE BI_DIRTRIG_ESD0402_ESD_1 | ESD5471X | ESD0402 |
| ED9106 | DIODE BI_DIRTRIG_ESD0402_ESD_1 | ESD5471X | ESD0402 |
| F2000 | FUSE_F8050_JK-SMD200L | JK-SMD200L | F8050 |
| FB2500 | INDUCTORCOM_L0603D_90R-100M | 90R-100M | L0603D |
| FB4600 | BEAD_L0603_180R-100M | 180R-100M | L0603 |
| FB4700 | BEAD_L0603_180R-100M | 180R-100M | L0603 |
| H9900 | HOLE_HOLE_C3R20_C6R00_HOLE_3R20 | HOLE_3R20 | HOLE_C3R20_C6R00 |
| H9901 | HOLE_HOLE_C3R20_C6R00_HOLE_3R20 | HOLE_3R20 | HOLE_C3R20_C6R00 |
| H9902 | HOLE_HOLE_C3R20_C6R00_HOLE_3R20 | HOLE_3R20 | HOLE_C3R20_C6R00 |
| H9903 | HOLE_HOLE_C3R20_C6R00_HOLE_3R20 | HOLE_3R20 | HOLE_C3R20_C6R00 |
| IR9200 | IR_RECEIVE_1_IR-SIR8B39_OQSS-R1 | OQSS-R12 | IR-SIR8B39 |
| J2000 | DCJACK_3P_DC3_DC_0007_5P_DC-000 | DC-0007-5P | DC3_DC_0007_5P |
| J2100 | JACK_1500_0_CNN2_2R00_6R30X4R90 | JACK_1500_2P | CNN2_2R00_6R30X4R90X6R30_V |
| J2500 | USB20_MICRO_USB20MICRO5_MU05_10 | USB20_micro | USB20MICRO5_MU05_10MGF_T |
| J4600 | CMK-CB0077-FV1_2_CON30M_2X15_0R | AXT530124 | CON30M_2X15_0R40_V_SMT |
| J4601 | OK-14GM030-04_CON30F_2X15_0R40_ | OK-14GM030-04 | CON30F_2X15_0R40_OK_14F030_04 |
| J4700 | OV2659_FPC24L_1X24_0R50_DOWN_OV | OV2659 | FPC24L_1X24_0R50_DOWN |
| J5100 | FPC_MIPI/LVDS_FPC30R_0R50_UP_30 | 30PIN FPC CON | FPC30R_0R50_UP |
| J7000 | PHONEJACK_6P_PJ6_D3R50_PJ35106S | PJ35106SY-P10 | PJ6_D3R50_PJ35106SY-P10 |
| J7100 | JACK_1500_0_CNN2_2R00_6R30X4R90 | JACK_1500_2P | CNN2_2R00_6R30X4R90X6R30_V |
| J7101 | JACK_1500_0_CNN2_2R00_6R30X4R90 | JACK_1500_2P | CNN2_2R00_6R30X4R90X6R30_V |
| J7201 | LCD_HITACHI_TX05D99VM1AAA_1_CNN | 30PIN FPC CON | CNN30_1R00_FP05SL_V |
| J7202 | LCD_HITACHI_TX05D99VM1AAA_1_CNN | 30PIN FPC CON | CNN30_1R00_FP05SL_V |
| J9100 | TFCARD_SOCKET_TF9_CKT01_009D_TF | TF-CKT01-009D | TF9_CKT01_009D |
| J9600 | USB20_MICRO_USB20MICRO5_MU05_10 | USB20_micro | USB20MICRO5_MU05_10MGF_T |
| J9901 | GND_GATE_CON2_1X2_5R08_DIP_GND_ | GND_GATE | CON2_1X2_5R08_DIP |
| J9902 | GND_GATE_CON2_1X2_5R08_DIP_GND_ | GND_GATE | CON2_1X2_5R08_DIP |
| L2000 | INDUCTORS OFFERRITE_IND_404030 | 3.3uH | IND_404030 |
| L2001 | INDUCTORS OFFERRITE_IND_606028 | 3.3uH | IND_606028 |
| L2100 | INDUCTORS OFFERRITE_IND_252010 | 470nH | IND_252010 |
| L2101 | INDUCTORS OFFERRITE_IND_252010 | 470nH | IND_252010 |
| L2102 | INDUCTORS OFFERRITE_IND_252010 | 470nH | IND_252010 |
| L2103 | INDUCTORS OFFERRITE_IND_252010 | 470nH | IND_252010 |
| L2104 | INDUCTORS OFFERRITE_IND_252010 | 470nH | IND_252010 |
| L6004 | RESISTOR_R0805_330NH | 330nH | R0805 |
| L6100 | INDUCTOR_L0402_DNP | DNP | L0402 |
| L6101 | INDUCTOR_L0402_DNP | DNP | L0402 |
| L6102 | INDUCTORS OFFERRITE_IND_303012 | 4.7uH | IND_303012 |
| L7100 | INDUCTORS OFFERRITE_IND_808040 | 15uH | IND_808040 |
| L7101 | INDUCTORS OFFERRITE_IND_808040 | 15uH | IND_808040 |
| L7102 | INDUCTORS OFFERRITE_IND_808040 | 15uH | IND_808040 |
| L7103 | INDUCTORS OFFERRITE_IND_808040 | 15uH | IND_808040 |
| L7104 | INDUCTORS OFFERRITE_IND_111114 | 15uH | IND_111114_DIP |
| L7105 | INDUCTORS OFFERRITE_IND_111114 | 15uH | IND_111114_DIP |
| L7106 | INDUCTORS OFFERRITE_IND_111114 | 15uH | IND_111114_DIP |
| L7107 | INDUCTORS OFFERRITE_IND_111114 | 15uH | IND_111114_DIP |
| LED2001 | LED_LED0603_LED_BLUE | LED_Blue | LED0603 |
| LED2003 | LED_LED0603_LED_RED | LED_RED | LED0603 |
| LED9600 | LED_LED0603_LED_RED | LED_RED | LED0603 |
| M9900 | MARK_MARK_MARK | MARK | MARK |
| M9901 | MARK_MARK_MARK | MARK | MARK |
| M9902 | MARK_MARK_MARK | MARK | MARK |
| M9903 | MARK_MARK_MARK | MARK | MARK |
| M9904 | MARK_MARK_MARK | MARK | MARK |
| M9905 | MARK_MARK_MARK | MARK | MARK |
| Q2000 | MOSFETN_SOT_23_WNM3003-3/TR | WNM3003-3/TR | SOT_23 |
| Q2001 | MOSFETN_SOT_23_WNM3003-3/TR | WNM3003-3/TR | SOT_23 |
| Q2002 | MOSFETP_SOT_23_WPM3407-3/TR | WPM3407-3/TR | SOT_23 |
| Q2500 | MOSFETN_SOT_23_WNM2016-3/TR | WNM2016-3/TR | SOT_23 |
| Q6100 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
| Q6101 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
| Q6102 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
| Q7100 | MOSFETN_SOT_323_WNM6002-3/TR | WNM6002-3/TR | SOT_323 |
| Q7201 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
| SMTSO9900 | SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_ | SMTSO30100CTJ | SMTSO_M3_C4R1_C6R0_L10R0 |
| SMTSO9901 | SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_ | SMTSO30100CTJ | SMTSO_M3_C4R1_C6R0_L10R0 |
| SMTSO9906 | SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_ | SMTSO30100CTJ | SMTSO_M3_C4R1_C6R0_L10R0 |
| SMTSO9907 | SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_ | SMTSO30100CTJ | SMTSO_M3_C4R1_C6R0_L10R0 |
| SW2000 | KEY_5PIN_SW5_6R20X6R20X2R50_PWR | PWRON | SW5_6R20X6R20X2R50 |
| SW2005 | KEY_5PIN_SW5_6R20X6R20X2R50_REC | Recovery | SW5_6R20X6R20X2R50 |
| SW2100 | KEY_5PIN_SW5_6R20X6R20X2R50_RES | RESET | SW5_6R20X6R20X2R50 |
| SW4100 | SWPUSHBUTTON_SMT2_6R00X3R50X4R | Maskrom | SMT2_6R00X3R50X4R20 |
| U1000 | MCU_RK3326_BGA418_14R00X14R00X1 | RK3326 | BGA418_14R00X14R00X1R24 |
| U2000 | DCDC_SY8113_SOT_23_6_SY8113B | SY8113B | SOT_23_6 |
| U2001 | CHARGER_BQ24133_QFN24_5R65X3R65 | BQ24133 | QFN24_5R65X3R65X1R00_T |
| U2002 | LDO_PT5108_1_SOT_89_3_SGM2203-5 | SGM2203-5.0 | SOT_89_3 |
| U2100 | RK809_QFN68_7R00X7R00X0R80_T_RK | RK809 | QFN68_7R00X7R00X0R80_T |
| U2500 | ESD_ESDA6V8UL_SOT_23_ESD5302F | ESD5302F | SOT_23 |
| U2507 | SWITCH_SY6280_SOT_23_5_SY6280AA | SY6280AAC | SOT_23_5 |
| U3000 | DDR3_16BIT_FBGA96_14R00X11R00X1 | K4B4G1646Q | FBGA96_14R00X11R00X1R20 |
| U3001 | DDR3_16BIT_FBGA96_14R00X11R00X1 | K4B4G1646Q | FBGA96_14R00X11R00X1R20 |
| U4000 | NANDFLASH_TSOP48_TSOP48_18R40X1 | H27UBG8T2DTR-BC | TSOP48_18R40X12R10X1R20 |
| U4100 | INAND_EMMC_169_2L_BGA169_18R00X | KLMAG2GEAC-B031 | BGA169_18R00X14R00X1R20_2L |
| U6100 | MODULE_AP6XXX_MD44_AP6XXX_AP621 | AP6212 | MD44_AP6XXX |
| U7100 | TPA3110_TSSOP28_9R70X4R40X1R20_ | TPA3110 | TSSOP28_9R70X4R40X1R20_T |
| U7200 | SECURE_ATSHA204A_SOP8_5R00X4R00 | ATSHA204A-SSHDA-T | SOP8_5R00X4R00X1R75 |
| U9010 | AL3006_0_MODULE-8_TMD27723 | TMD27723 | MODULE-8 |
| U9600 | INTERFACE_FT232RL_SSOP28_10R20X | FT232RL | SSOP28_10R20X5R30X2R00 |
| U9601 | ESD_ESDA6V8UL_SOT_23_ESD5302F | ESD5302F | SOT_23 |
| U9602 | SWITCH_FSUSB30MUX_MSOP10_3R00X3 | FSUSB30MUX | MSOP10_3R00X3R00X1R10 |
| Y1100 | CRYSTAL_4P_CRY4_3R20X2R50X0R80_ | 24MHz | CRY4_3R20X2R50X0R80 |
| Y2100 | CRYSTAL_2P_1G_CRY2_6R90X1R40X1R | 32.768KHz | CRY2_6R90X1R40X1R30 |
| Y6100 | CRYSTAL_4P_CRY4_3R20X2R50X0R8_1 | 26MHz | CRY4_3R20X2R50X0R80 |
