| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT1201 | ZN.01.10.07_0.0225_ANT1-0302-02 | 818000387 | ANT1-0302-025 |
| ANT1202 | ZN.01.10.07_0.0225_ANT1-0302-02 | 818000387 | ANT1-0302-025 |
| D802 | RB520S-30FJ_0_SOD170X130X100-2N | WSB5503W-2/TR | SOD170X130X100-2N |
| FB601 | ZN.01.02.01_0.0302_LB0402-005_D | 1K@100MHz | LB0402-005 |
| FB602 | ZN.01.02.01_0.0302_LB0402-005_D | 1K@100MHz | LB0402-005 |
| FB603 | ZN.01.02.01_0.0301_LB0402-005_D | 1.8K@100MHz | LB0402-005 |
| FB604 | ZN.01.02.01_0.0302_LB0402-005_D | 1K@100MHz | LB0402-005 |
| FB605 | ZN.01.02.01_0.0302_LB0402-005_D | 1K@100MHz | LB0402-005 |
| FB701 | ZN.01.04.01_0.0139_LB0402-005_D | 120@100MHz | LB0402-005 |
| FB702 | ZN.01.04.01_0.0139_LB0402-005_D | 120@100MHz | LB0402-005 |
| FB801 | FB_INDC1005_IS0402Q_DISCRETE_0. | 600@100MHz | INDC1005_IS0402Q |
| FB802 | FB_INDC1005_IS0402Q_DISCRETE__1 | 120@100MHz | INDC1005_IS0402Q |
| FB808 | FB_LB0402-005_DISCRETE_0.5590M | 120@100MHz | LB0402-005 |
| FB901 | FB_INDC1005_IS0402Q_DISCRETE__2 | 120@100MHz | INDC1005_IS0402Q |
| FB902 | FB_INDC1005_IS0402Q_DISCRETE__3 | 120@100MHz (DNI) | INDC1005_IS0402Q |
| FB1101 | FB_L0402-005_DISCRETE_0.3300MM | 75@100MHz | L0402-005 |
| FB1102 | FB_L0402-005_DISCRETE_0.3300_1 | 600@100MHz | L0402-005 |
| FB1103 | FB_L0402-005_DISCRETE_0.3300_2 | 120@100MHz | L0402-005 |
| FB1104 | FB_L0402-005_DISCRETE_0.3300_2 | 120@100MHz | L0402-005 |
| FB1105 | FB_L0402-005_DISCRETE_0.3300_2 | 120@100MHz | L0402-005 |
| FB1106 | FB_L0402-005_DISCRETE_0.3300_1 | 600@100MHz | L0402-005 |
| FB1201 | FB_L0402-005_DISCRETE_0.3300_1 | 600@100MHz | L0402-005 |
| FL1001 | FILTER-I1O34G25_FILS5_MUR_1M05X | 925/960MHz | FILS5_MUR_1M05X1M35Q |
| FL1002 | SAWEN1G84CV0F00_SFLT10-0201-005 | SAWEN1G84CV0F00 | SFLT10-0201-005A |
| FL1003 | FILT-SAYRF_FILS9_MUR_2M5X2M0N_D | 869/894MHz,826.4/846.6MHz | FILS9_MUR_2M5X2M0N |
| FL1004 | FILT-SAYRF_FILS9_MUR_2M5X2M0N_1 | 2110/2170MHz,1920/1980MHz | FILS9_MUR_2M5X2M0N |
| J201 | ZN.01.10.06_0.0140_PWC3-0804-01 | R175AA06-03265RR | PWC3-0804-019 |
| J601 | ZN.01.10.04_1.0062_JACK_1300X85 | AJ011-20352A02 | JACK_1300X850X420-6N |
| J701 | ZN.01.10.09_1.0069_USB_65P750X5 | WKUBI011-011 | USB_65P750X500X300-5N |
| J702 | A12 CON ZIF 8PIN0_0.3MM_SMD100 | 12 pin | SMD100P1150X200-12N |
| J703 | J_4_T-CARD_CN_1115X605X170-9N_T | TF006-17112A91 | T-CARD_CN_1115X605X170-9N |
| J704 | CON-SIM6-MTG2-J_2_SIM_CN_254P16 | WKSM019-1511 | SIM_CN_254P1640X1630X150-6N |
| J705 | CON-SIM6-MTG2-J_3_SIM_CN_127P15 | 78646-3001 | SIM_CN_127P1545X1305X145-8N |
| J801 | BL125-25RL-TAGF_0_ZIF_CON_60P90 | BL125-25RL-TAGF | ZIF_CON_60P900X325X110-25N |
| J802 | ZN.01.10.05_0.0148_SED24-16-S-0 | AXT524124 | SED24-16-S-010 |
| J803 | ZN.01.10.05_0.0150_SED30-16-S-0 | C-BBR43-04-01 | SED30-16-S-010A |
| J804 | A10 CON BTB 10PINLSMTRON_0_TP_ | GB042-10S-H10 | TP_CON_40P450X390X100-10N |
| J807 | HDR1X2-J_2_TP118_24_LED_FPC | led_fpc | TP118_24 |
| J1001 | ZN.01.11.01_0.0004_RF_CON_260X2 | ECT818000163 | RF_CON_260X250X165-6N |
| J1002 | A12 RFCABLE_0_RF_CN_170X170X95 | 818000157 | RF_CN_170X170X95-4N |
| L201 | IND-SHIELDED-NO-DOT_INDC2016_IS | 0.47uH | INDC2016_IS0806_TYN |
| L202 | IND-SHIELDED-NO-DOT_INDC2016_IS | 0.47uH | INDC2016_IS0806_TYN |
| L203 | IND-SHIELDED-NO-DOT_INDS2_SAMSU | 0.47uH | INDS2_SAMSUNG_2520Q |
| L204 | IND_INDS2_CYN_PIFE32251BQ_DISCR | 2.2uH | INDS2_CYN_PIFE32251BQ |
| L205 | IND-SHIELDED-NO-DOT_INDC2016_IS | 0.47uH | INDC2016_IS0806_TYN |
| L206 | IND-SHIELDED-NO-DOT_INDC2016_IS | 0.47uH | INDC2016_IS0806_TYN |
| L207 | IND-SHIELDED-NO-DOT_INDC2016_IS | 0.47uH | INDC2016_IS0806_TYN |
| L601 | IND_INDC1608_IS0603Q_DISCRETE_0 | 120nH | INDC1608_IS0603Q |
| L805 | IND_L2520-012_DISCRETE_4.7UH | 4.7uH | L2520-012 |
| L1001 | IND-DOT-1_L0201-003_DISCRETE_0. | 18nH(DNI) | L0201-003 |
| L1002 | IND-DOT-1_L0201-003_DISCRETE_0. | 18nH(DNI) | L0201-003 |
| L1003 | IND-DOT-1_L0201-003_DISCRETE__1 | 6.8nH (DNI) | L0201-003 |
| L1004 | IND-DOT-1_INDS2_MUR_LQP03TQ_D_3 | 5.6nH | INDS2_MUR_LQP03TQ |
| L1005 | IND-DOT-1_INDS2_MUR_LQP03TQ_D_4 | 7.5nH | INDS2_MUR_LQP03TQ |
| L1006 | IND-DOT-1_INDS2_MUR_LQP03TQ_DIS | 18nH | INDS2_MUR_LQP03TQ |
| L1008 | IND-DOT-1_L0201-003_DISCRETE__2 | 12nH | L0201-003 |
| L1009 | CAP_C0201-003_DISCRETE_0.3300_2 | 0.5pF (DNI) | C0201-003 |
| L1010 | IND-DOT-1_L0201-003_DISCRETE__3 | 18nH | L0201-003 |
| L1011 | IND-DOT-1_INDS2_MUR_LQP03TQ_D_4 | 7.5nH | INDS2_MUR_LQP03TQ |
| L1012 | CAP_CAPC0603_IS0201Q_DISCRETE_3 | 1.2pF | CAPC0603_IS0201Q |
| L1014 | IND-DOT-1_L0201-003_DISCRETE__2 | 12nH | L0201-003 |
| L1015 | IND-DOT-1_INDS2_MUR_LQP03TQ_DIS | 18nH | INDS2_MUR_LQP03TQ |
| L1016 | CAP_CAPC0603_IS0201Q_DISCRETE_3 | 1.2pF | CAPC0603_IS0201Q |
| L1017 | IND-DOT-1_INDS2_MUR_LQP03TQ_DIS | 18nH | INDS2_MUR_LQP03TQ |
| L1018 | IND-DOT-1_INDS2_MUR_LQG15HQ_DIS | 27nH (DNI) | INDS2_MUR_LQG15HQ |
| L1019 | IND-DOT-1_INDS2_MUR_LQP03TQ_D_5 | 18nH (DNI) | INDS2_MUR_LQP03TQ |
| L1020 | IND-DOT-1_INDS2_MUR_LQP03TQ_DIS | 18nH | INDS2_MUR_LQP03TQ |
| L1021 | IND-DOT-1_INDS2_MUR_LQG15HQ_D_1 | 4.3nH | INDS2_MUR_LQG15HQ |
| L1022 | IND-DOT-1_INDC1005_IS0402Q_DISC | 3.3nH (DNI) | INDC1005_IS0402Q |
| L1023 | IND-DOT-1_INDS2_MUR_LQG15HQ_D_2 | 5.6nH | INDS2_MUR_LQG15HQ |
| L1024 | IND-DOT-1_INDS2_MUR_LQP03TQ_D_6 | 1.8nH | INDS2_MUR_LQP03TQ |
| L1025 | IND-DOT-1_INDS2_MUR_LQP03TQ_D_7 | 3.3nH | INDS2_MUR_LQP03TQ |
| L1026 | IND-DOT-1_INDS2_MUR_LQG15HQ_D_3 | 22nH(DNI) | INDS2_MUR_LQG15HQ |
| L1027 | IND-DOT-1_INDS2_MUR_LQP03TQ_D_6 | 1.8nH | INDS2_MUR_LQP03TQ |
| L1028 | IND-DOT-1_INDS2_MUR_LQG15HQ_D_4 | 2.0nH(DNI) | INDS2_MUR_LQG15HQ |
| L1029 | IND-DOT-1_INDC1005_IS0402Q_DISC | 3.3nH (DNI) | INDC1005_IS0402Q |
| L1030 | CAP_CAPC1005_IS0402Q_DISCRET_12 | 1pF | CAPC1005_IS0402Q |
| L1031 | CAP_CAPC1005_IS0402Q_DISCRET_13 | 0.5pF | CAPC1005_IS0402Q |
| L1101 | IND-DOT-1_L0402-005_DISCRETE_0. | 3.9nH (DNI) | L0402-005 |
| L1102 | IND-DOT-1_L0402-005_DISCRETE_0. | 3.9nH (DNI) | L0402-005 |
| L1105 | IND-DOT-1_L0402-005_DISCRETE__1 | 4.7nH | L0402-005 |
| L1106 | IND-DOT-1_INDS2_MUR_LQG15HQ_D_5 | 1nH | INDS2_MUR_LQG15HQ |
| L1107 | ZN.01.04.02_0.0134_INDC2016_IS0 | 2.2uH | INDC2016_IS0806_TYN |
| L1201 | IND-DOT-1_L0402-005_DISCRETE__2 | 6.8nH | L0402-005 |
| L1202 | IND-DOT-1_L0402-005_DISCRETE__3 | 3.9nH | L0402-005 |
| L1203 | IND-DOT-1_L0402-005_DISCRETE__3 | 3.9nH | L0402-005 |
| L1204 | IND-DOT-1_L0402-005_DISCRETE__4 | 2.2nH | L0402-005 |
| Q701 | ZN.01.08.02_0.0088_SOT416_B_E_C | PDTC143ZE | SOT416_B_E_C |
| Q801 | NPN-4.7K-47K_SOT416_B_E_C_DISCR | DTC143ZET1 | SOT416_B_E_C |
| REC1 | SPEAKER_REC1200X600X265-2N_IO_J | JHDR1005S24-3LT | REC1200X600X265-2N |
| S701 | 16PIN_FPC_0_SMD80P440X200-6N_6P | 6PIN_FPC | SMD80P440X200-6N |
| S702 | 4PIN_KEY_0_SMD100P450X200-5N_5P | 5PIN_KEY | SMD100P450X200-5N |
| S703 | HDR1X2-J_2_SMD100P200X150-2N_LE | led_fpc | SMD100P200X150-2N |
| TH201 | THERMISTOR_RESC1005_IS0402Q_DIS | 47K | RESC1005_IS0402Q |
| TH901 | THERMISTOR_R0402-004_DISCRETE_0 | 47K | R0402-004 |
| TIE201 | NET-TIE_NET_TIE_CAPC0603_IS0201 | 201 | NET_TIE_CAPC0603_IS0201Q |
| U201 | BCM59054A0IUB1G-W1000-24357_WLB | BCM59054A1IUB0G | WLBGA40P12X12_140_489X504N |
| U301 | 21664A0IFDBG-W1000-24774_BGA50P | BCM21664IFDBG | BGA50P23X23_458_1200X1200N |
| U401 | KMNJS000ZM-BGA162_BGA50P10X20_1 | KMN5U000ZM-B203 | BGA50P10X20_162_1150X1300N |
| U701 | ZN.01.05.08_0.0343_BCC12-20-020 | BMA250 | BCC12-20-0202-010 |
| U801 | EMIX21A390FNPE_3_FIL_88X65X52-4 | TCF03025H90002A | FIL_88X65X52-4N |
| U804 | EMIX21A390FNPE_3_FIL_88X65X52-4 | TCF03025H90002A | FIL_88X65X52-4N |
| U805 | EMIX21A390FNPE_3_FIL_88X65X52-4 | TCF03025H90002A | FIL_88X65X52-4N |
| U806 | SGM3727_0_DFN8-20-0202-008_SGM3 | SGM3727 | DFN8-20-0202-008 |
| U807 | EMIX21A390FNPE_3_FIL_88X65X52-4 | TCF03025H90002A | FIL_88X65X52-4N |
| U808 | EMIX21A390FNPE_3_FIL_88X65X52-4 | TCF03025H90002A | FIL_88X65X52-4N |
| U809 | EMIX21A390FNPE_3_FIL_88X65X52-4 | TCF03025H90002A | FIL_88X65X52-4N |
| U901 | BCM2093IFBG-W1000-23946-ALT_BGA | BCM2093IFBG | BGA40P10X10_77_440X440N |
| U1001 | RF3237-MOD30H_MODS30_RFMD_RF323 | RF3237 | MODS30_RFMD_RF3236Q |
| U1002 | SKY7776X-DFN10H_SON60P300X300_1 | SKY77765 | SON60P300X300_10_SKY_RFMD-10PQ |
| U1003 | SKY7776X-DFN10H_SON60P300X300_2 | SKY77761 | SON60P300X300_10_SKY_RFMD-10PQ |
| U1101 | BCM4330XKUBG-W1000-20922_WLBGA4 | BCM4330XKUBG | WLBGA40P12X12_133_489X533N |
| U1102 | SKY-13309-DFN8_SON40P150X150_8_ | SKY13317 | SON40P150X150_8_SKY-373Q |
| U1201 | DGLT36M07_0_QFN95P250X200X87-9N | B9106_EPCOS | QFN95P250X200X87-9N |
| U1202 | OSC-O4G13V6NC25_OSCS6_KYO_KT252 | 26.000MHz | OSCS6_KYO_KT2520FQ |
| U1203 | BCM4752IUB2G-W1000-23942_WLBGA4 | BCM4752IUB2G | WLBGA40P6X5_30_247X207N |
| VRB607 | DIO-TVS-BIPOLAR_DIOC1005_IS0402 | 18V,3pF | DIOC1005_IS0402_BIQ |
| Y201 | ZN.01.06.01_0.0051G_X4-0701-014 | 32.768KHz | X4-0701-014 |
| Y901 | XTAL-1G3G_XTALS4_2M5X2M_DISCRET | 26.000MHz | XTALS4_2M5X2M |
