重要提示:PCB作品文件展下载说明
| Name | PCB Decal | Value | Part Type | | COM35 | USB | | USB | | CON1 | JACK-12P-RJ45 | RJ45_1X1-90D | JACK-12P-RJ45 | | CON4 | SCART-PB-RCAB | SCART | SCART-PB-RCAB | | CON21 | SIP3_2D54AAA | WAFER/2.0MM/1*4P/180D | SIP3_2D54AAA | | CON32 | CON-HDMI | HDMI/90D | CON-HDMI | | D1 | R0402 | NC/CDS2C16GTH_3PF | R0402 | | D2 | R0402 | NC/CDS2C16GTH_3PF | R0402 | | D3 | NL-DO-214AC | SMBJ15CA | NL-DO-214AC | | D4 | NL-DO-214AC | IN5189 | NL-DO-214AC | | D25 | R0402 | NC/CDS2C16GTH_3PF | R0402 | | DT1 | SOT_23 | BAV99 | SOT_23 | | DT2 | SOT_23 | BAV99 | SOT_23 | | EC1 | RB2D5_6D3 | 470UF/25V/LOWESR | RB2D5_6D3 | | EC2 | EC-5/2.5_GX | 100UF/16V | EC-5/2.5_GX | | EC5 | C0603 | 10UF/6.3V | C0603 | | EC7 | C0805 | 10UF/6.3V | C0805 | | EC8 | RB2D5_6D3 | 220UF/16V | RB2D5_6D3 | | EC10 | C0603 | 1UF/10V | C0603 | | EC15 | RB2D5_6D3 | 220UF/16V | RB2D5_6D3 | | FB3 | L0402 | BEAD/20R/300MA | L0402 | | FB8 | L0603 | BEAD/6R/500MA | L0603 | | FB12 | L0603 | BEAD/30R/3000MA | L0603 | | FB14 | L0402 | BEAD/20R/300MA | L0402 | | FB16 | R0603 | FB0603/2A | FB0603 | | FB26 | L0603 | BEAD/6R/500MA | L0603 | | FT1 | L0603 | FB100R | L0603 | | H1 | THO | | THO | | H2 | THO | | THO | | H3 | THO | | THO | | J2 | IR | IR/RX | IR | | J3 | TUNER_5007 | ATB2012_75011 | TUNER_JACK | | J4 | JACK\DC | | JACK\DC | | J6 | RCAAV-8.4-5A | | RCAAV-8.4-5A | | J8 | RCA3X2 | AV-RGB | RCA3X2 | | JC1 | 6PIN | SIP-6P_2.0 | 6PIN | | K2 | SW-4P-1102V | | SW-4P-1102V | | K3 | SW-4P-1102V | | SW-4P-1102V | | K4 | SW-4P-1102V | | SW-4P-1102V | | L1 | CD53 | 10UH/2A-CD54 | CD53 | | L2 | L5.0 | 0.3*2.2*14.5 L | L5.0 | | L3 | COIL-DLW21SN | NC/DLW21SN900HQ2 | COIL-DLW21SN | | L4 | L0603 | 0R | L0603 | | L5 | L0603 | 0R | L0603 | | L6 | L0603 | 0R | L0603 | | L7 | L0603 | 1.8UH | L0603 | | L12 | COIL-DLW21SN | NC/DLW21SN900HQ2 | COIL-DLW21SN | | L13 | COIL-DLW21SN | 0R/DLW21SN900HQ2 | COIL-DLW21SN | | L18 | CD43 | 1UH/2.7A-2520 | CD43 | | L19 | CD43 | 1UH/2.7A-2520 | CD43 | | LED1 | LED-3P_ | | LED-3P_ | | LED2 | LED_KHE30281BG1W25 | | LED3641 | | LT1 | R0402 | 6.8nH | R0402 | | LT2 | R0402 | 270nH | R0402 | | LT3 | R0402 | 270nH | R0402 | | LT4 | R0402 | 270nH | R0402 | | M1 | HOLE-M | OPTICAL | HOLE-M | | M2 | HOLE-M | OPTICAL | HOLE-M | | M3 | HOLE-M | OPTICAL | HOLE-M | | M4 | HOLE-M | OPTICAL | HOLE-M | | M7 | HOLE-MA | OPTICAL | HOLE-M | | Q1 | SOT23 | BAV99 | SOT23 | | Q2 | SOT23 | MMBT3906 | SOT23 | | Q3 | SOT23-GDS | AO3401 | SOT23-GDS | | Q4 | SOT23 | MMBT3904 | SOT23 | | Q5 | SOT23-GDS | AO3401 | SOT23-GDS | | Q6 | SOT23 | MMBT3906 | SOT23 | | Q7 | SOT23 | BAV99 | SOT23 | | Q8 | SOT23 | BAV99 | SOT23 | | Q9 | SOT23 | MMBT3904 | SOT23 | | Q10 | SOT23 | MMBT3904 | SOT23 | | Q13 | SOT23 | MMBT3904 | SOT23 | | Q14 | SOT23 | MMBT3904 | SOT23 | | Q15 | SOT23 | MMBT3904 | SOT23 | | Q16 | SOT23 | 2N7002 | SOT23 | | Q17 | SOT23 | BAV99 | SOT23 | | Q18 | SOT23 | MMBT3904 | SOT23 | | Q19 | SOT23 | MMBT3904 | SOT23 | | Q23 | SOT23 | 2N7002 | SOT23 | | Q27 | SOT_23B | SGM810/DIO6810SST3 | SOT_23 | | T1 | IC-16P-10_100BASE | F1602SMG | IC-16P-10_100BASE | | TT1 | ATB2012_75011 | ATB2012_75011 | ATB2012_75011 | | U1 | SOT23-6 | SY8113/3A_TSOT23-6 | SOT23-6 | | U3 | SOT-23-5 | SY8088/1A_SOT23-5 | SOT-23-5 | | U5 | SOT-23-5 | SY8089A/2A_SOT23-5 | SOT-23-5 | | U7 | IC-8P-SOPL-200 | IC-8P-WSON-8X6MM | IC-8P-SOPL-200 | | U8 | IC-128P-LQFP-14X14-G | MSD7S0X/LQFP128 | IC-128P-LQFP-14X14-G | | U9 | SOP16_LN1650 | FD650K/S | SOP16_LN1650 | | U11 | IC-10P-RCLAMP0524P | NC/RCLAMP0524P | IC-10P-RCLAMP0524P | | U12 | IC-10P-RCLAMP0524P | NC/RCLAMP0524P | IC-10P-RCLAMP0524P | | U16 | ESD-AOZ8802A | NC/AOZ8802ADI_0.3PF | ESD-AOZ8802A | | U19 | SOT_223_5 | REG1117-1.8V | SOT_223_5 | | UT1 | QFN24 | MXL608 | QFN24 | | X1 | XTAL | 24M | XTAL | | Y1 | XTALS-GND | 24MHZ/30PPM/DIP | XTALS-GND |
重要提示:PCB作品文件展下载说明
